markossx
Posty: 489 Rejestracja: 26 maja 2007, 16:01
Post
autor: markossx » 01 listopada 2012, 17:01
Potrzebuję pomocy w skrypcie znalezionym w sieci.
Wynik działania widoczny jest po zakończeniu, czyli ctrl+c, potrzebuję zapisu do pliku - da się to ogarnąć?
http://aspersa.googlecode.com/svn/trunk/iodump
#!/usr/bin/env perl
# This program is part of Aspersa (http://code.google.com/p/aspersa/)
=pod
=head1 NAME
iodump - Compute per-PID I/O stats for Linux when iotop/pidstat/iopp are not available.
=head1 SYNOPSIS
Prepare the system:
dmesg -c
/etc/init.d/klogd stop
echo 1 > /proc/sys/vm/block_dump
Start the reporting:
while true; do sleep 1; dmesg -c; done | perl iodump
CTRL-C
Stop the system from dumping these messages:
echo 0 > /proc/sys/vm/block_dump
/etc/init.d/klogd start
=head1 AUTHOR
Baron Schwartz
=cut
use strict;
use warnings FATAL => 'all';
use English qw(-no_match_vars);
use sigtrap qw(handler finish untrapped normal-signals);
my %tasks;
my $oktorun = 1;
my $line;
while ( $oktorun && (defined ($line = <>)) ) {
my ( $task, $pid, $activity, $where, $device );
= $line =~ m/(\S+)\((\d+)\): (READ|WRITE) block (\d+) on (\S+)/;
if ( !$task ) {
= $line =~ m/(\S+)\((\d+)\): (dirtied) inode \(.*?\) (\d+) on (\S+)/;
if ( $task ) {
my $s = $tasks{$pid} ||= { pid => $pid, task => $task };
++$s->{lc $activity};
++$s->{activity};
++$s->{devices}->{$device};
printf("%-15s %10s %10s %10s %10s %10s %s\n",
qw(TASK PID TOTAL READ WRITE DIRTY DEVICES));
foreach my $task (
reverse sort { $a->{activity} <=> $b->{activity} } values %tasks
printf("%-15s %10d %10d %10d %10d %10d %s\n",
$task->{task}, $task->{pid},
($task->{'activity'} || 0),
($task->{'read'} || 0),
($task->{'write'} || 0),
($task->{'dirty'} || 0),
join(', ', keys %{$task->{devices}}));
sub finish {
my ( $signal ) = @_;
if ( $oktorun ) {
print STDERR "# Caught SIG$signal.\n";
$oktorun = 0;
else {
print STDERR "# Exiting on SIG$signal.\n";
exit(1);
maxdawid
Posty: 52 Rejestracja: 17 września 2008, 11:30
Post
autor: maxdawid » 01 listopada 2012, 18:46
Może być?
PS nie znam perla
#!/usr/bin/env perl
=pod
=head1 NAME
=head1 SYNOPSIS
Prepare the system:
dmesg -c
CTRL-C
=head1 AUTHOR
Baron Schwartz
=cut
use strict;
my %tasks;
my $oktorun = 1;
my $line;
if ( !$task ) {
if ( $task ) {
++$s->{activity};
open(LOG, ">>", "log.txt") or die "Nie można otworzyć pliku: $!";
printf LOG ("%-15s %10s %10s %10s %10s %10s %s\n",
foreach my $task (
printf LOG ("%-15s %10d %10d %10d %10d %10d %s\n",
sub finish {
if ( $oktorun ) {
$oktorun = 0;
else {
exit(1);
markossx
Post
autor: markossx » 01 listopada 2012, 19:10
Sprawdze już jutro, dzięki za zainteresowanie.
