MySql -kompilacja
Elber
MySql -kompilacja
Post autor: Elber »
Witam, mam problem z kompilacją mysql 5.0.41, rozpakowałem, wchodze do folderu i daje:
./configure --prefix=/usr/local/mysql --with-charset=latin2
I wywala mi:
Debian-40-etch-32-minimal:~/mysql-5.0.41# ./configure --prefix=/usr/local/mysql --with-charset=latin2
checking build system type... i686-pc-linux-gnulibc1
checking host system type... i686-pc-linux-gnulibc1
checking target system type... i686-pc-linux-gnulibc1
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... no
checking "character sets"... default: latin2, collation: latin2_general_ci; compiled in: latin2 latin1 utf8
checking whether to compile national Unicode collations... yes
checking whether make sets $(MAKE)... (cached) no
checking for gawk... (cached) mawk
checking for gcc... gcc
checking for C compiler default output file name... configure: error: C compiler cannot create executables
See `config.log' for more details.
Zainstalowałem GCC ale to nie pomogło :(
miszmaniac
Post autor: miszmaniac »
Spróbuj zainstalować tą paczkę:
build-essential
Nie tylko same gcc.
Rad
Post autor: Rad »
aptitude install libc6-dev spróbuj.
Elber
Post autor: Elber »
Dzięki, zainstalowałem oby dwie rzecz i ruszyło dalej, lecz teraz mam:
checking for sched.h... yes
checking crypt.h usability... yes
checking crypt.h presence... yes
checking for crypt.h... yes
checking alloca.h usability... yes
checking alloca.h presence... yes
checking for alloca.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking sys/malloc.h usability... no
checking sys/malloc.h presence... no
checking for sys/malloc.h... no
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking linux/config.h usability... yes
checking linux/config.h presence... yes
checking for linux/config.h... yes
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for floor in -lm... yes
checking for gethostbyname_r in -lnsl_r... no
checking for gethostbyname_r in -lnsl... yes
checking for gethostbyname_r... yes
checking for setsockopt... yes
checking for yp_get_default_domain... yes
checking for p2open... no
checking for p2open in -lgen... no
checking for bind... yes
checking for library containing crypt... -lcrypt
checking for library containing inet_aton... none required
checking for sched_yield... yes
checking for zlib compression library... system-wide zlib not found, using one bundled with MySQL
checking whether SHM_HUGETLB is declared... yes
checking for atomic operations... no
checking if we should use pstack... no
checking for int8... no
checking "Linux threads"... "starting"
checking "getconf GNU_LIBPTHREAD_VERSION"... "NPTL"
"no need to check headers"
checking "for pthread_create in -lpthread"... "yes"
checking "named thread libs:"... "-lpthread"
checking for strtok_r in -lpthread... yes
checking for strtok_r... yes
checking for dlopen in -ldl... yes
checking for dlopen... yes
checking for dlerror... yes
checking for unistd.h... (cached) yes
checking for restartable system calls... yes
checking "need of special linking flags"... "-rdynamic"
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for off_t... yes
checking for struct stat.st_rdev... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking needs mysys_new helpers... no
checking for char... yes
checking size of char... 1
checking for char*... yes
checking size of char*... 4
checking for short... yes
checking size of short... 2
checking for int... yes
checking size of int... 4
checking for long... yes
checking size of long... 4
checking for long long... yes
checking size of long long... 8
checking size of off_t... 8
checking if time_t is unsigned... no
checking the need for #pragma interface/implementation... no
checking whether byte ordering is bigendian... no
checking base type of last arg to accept... socklen_t
checking struct type to use with setrlimit... struct rlimit
checking stack direction for C alloca... -1
checking for working alloca.h... (cached) yes
checking for alloca... yes
checking if struct timespec has a ts_sec member... no
checking if we have tzname variable... yes
checking for type ulong... yes
checking for type uchar... no
checking for type uint... yes
checking for type fp_except... no
checking for type in_addr_t... yes
checking if g++ supports bool types... yes
checking if conversion of longlong to float works... yes
checking for sigset_t... yes
checking for off_t... (cached) yes
checking for size_t... (cached) yes
checking for u_int32_t... yes
checking if pthread_yield takes zero arguments... yes
checking if pthread_yield takes 1 argument... no
checking for malloc.h... (cached) yes
checking sys/cdefs.h usability... yes
checking sys/cdefs.h presence... yes
checking for sys/cdefs.h... yes
checking for working alloca.h... yes
checking for alloca... (cached) yes
checking whether gcc needs -traditional... no
checking return type of signal handlers... void
checking for re_comp... yes
checking for regcomp... yes
checking for strdup... yes
checking vis.h usability... no
checking vis.h presence... no
checking for vis.h... no
checking for strlcat... no
checking for strlcpy... no
checking for issetugid... no
checking for fgetln... no
checking for getline... yes
checking for flockfile... yes
checking varargs.h usability... no
checking varargs.h presence... no
checking for varargs.h... no
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking ndir.h usability... no
checking ndir.h presence... no
checking for ndir.h... no
checking sys/dir.h usability... yes
checking sys/dir.h presence... yes
checking for sys/dir.h... yes
checking sys/file.h usability... yes
checking sys/file.h presence... yes
checking for sys/file.h... yes
checking sys/ndir.h usability... no
checking sys/ndir.h presence... no
checking for sys/ndir.h... no
checking sys/ptem.h usability... no
checking sys/ptem.h presence... no
checking for sys/ptem.h... no
checking sys/pte.h usability... no
checking sys/pte.h presence... no
checking for sys/pte.h... no
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking sys/stream.h usability... no
checking sys/stream.h presence... no
checking for sys/stream.h... no
checking for sys/mman.h... (cached) yes
checking curses.h usability... no
checking curses.h presence... no
checking for curses.h... no
checking termcap.h usability... no
checking termcap.h presence... no
checking for termcap.h... no
checking for termio.h... (cached) yes
checking termbits.h usability... no
checking termbits.h presence... no
checking for termbits.h... no
checking asm/termbits.h usability... yes
checking asm/termbits.h presence... yes
checking for asm/termbits.h... yes
checking grp.h usability... yes
checking grp.h presence... yes
checking for grp.h... yes
checking paths.h usability... yes
checking paths.h presence... yes
checking for paths.h... yes
checking semaphore.h usability... yes
checking semaphore.h presence... yes
checking for semaphore.h... yes
checking for lstat... yes
checking for putenv... yes
checking for select... yes
checking for setenv... yes
checking for setlocale... yes
checking for strcoll... yes
checking for tcgetattr... yes
checking whether stat file-mode macros are broken... no
checking for type of signal functions... posix
checking whether programs are able to redeclare getpw functions... yes
checking for TIOCGWINSZ in sys/ioctl.h... yes
checking for FIONREAD in sys/ioctl.h... yes
checking for TIOCSTAT in sys/ioctl.h... no
checking if struct dirent has a d_ino member... yes
checking if struct dirent has a d_namlen member... no
checking whether signal handlers are of type void... yes
checking wctype.h usability... yes
checking wctype.h presence... yes
checking for wctype.h... yes
checking wchar.h usability... yes
checking wchar.h presence... yes
checking for wchar.h... yes
checking langinfo.h usability... yes
checking langinfo.h presence... yes
checking for langinfo.h... yes
checking for mbsrtowcs... yes
checking for mbrtowc... yes
checking for mbrlen... yes
checking for wctomb... yes
checking for wcwidth... yes
checking for wcsdup... yes
checking for mbstate_t... yes
checking for nl_langinfo and CODESET... yes
checking for tgetent in -lncurses... no
checking for tgetent in -lcurses... no
checking for tgetent in -ltermcap... no
checking for tgetent in -ltinfo... no
checking for termcap functions library... configure: error: No curses/termcap library found
Rad
Post autor: Rad »
apt-get install libncurses5-dev
Było w pierwszym linku na google.
Elber
Post autor: Elber »
No wiem już znalazłem, dzięki panowie za pomoc.
Pozdr0
