[+] Instalacja build-essential w Debianie Squeeze
sethiel
Post autor: sethiel »
Mam całkiem świeżą instalację Debiana 6, chciałem zainstalować build-essential i w sumie to nie wiem co system ode mnie chce:
# apt-get install  build-essential
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
 build-essential : Depends: libc6-dev but it is not going to be installed or
                            libc-dev
                   Depends: gcc (>= 4:4.4.3) but it is not going to be installed
                   Depends: g++ (>= 4:4.4.3) but it is not going to be installed
E: Broken packages
# apt-get install libc6-dev
 libc6-dev : Depends: libc6 (= 2.11.3-4) but 2.13-35 is to be installed
             Depends: libc-dev-bin (= 2.11.3-4) but it is not going to be installed
             Recommends: gcc but it is not going to be installed or
                         c-compiler
E: Broken packages
A build-essential chciałem aby zainstalować squid3 ze wsparciem dla SSL i zobaczyć jak działa:
# apt-get build-dep squid3
Note, selecting 'libcap-dev' instead of 'libcap2-dev'
                            libc-dev
 libexpat1-dev : Depends: libc6-dev but it is not going to be installed or
                          libc-dev
 libkrb5-dev : Depends: krb5-multidev (= 1.8.3+dfsg-4squeeze6) but it is not going to be installed
 libpam0g-dev : Depends: libc6-dev but it is not going to be installed or
                         libc-dev
 libsasl2-dev : Depends: libc6-dev but it is not going to be installed
E: Build-dependencies for squid3 could not be satisfied.
ArnVaker
Post autor: ArnVaker »
W sources.list masz repozytorium wersji testowej/niestabilnej.
sethiel
I tak i nie.
deb http://ftp.pl.debian.org/debian/ squeeze main non-free contrib
deb-src http://ftp.pl.debian.org/debian/ squeeze main non-free contrib
deb http://security.debian.org/ squeeze/updates main contrib non-free
deb-src http://security.debian.org/ squeeze/updates main contrib non-free
# squeeze-updates, previously known as 'volatile'
deb http://ftp.pl.debian.org/debian/ squeeze-updates main contrib non-free
deb-src http://ftp.pl.debian.org/debian/ squeeze-updates main contrib non-free
#backports
deb http://backports.debian.org/debian-backports squeeze-backports main
#deb http://ftp.pl.debian.org/debian/ wheezy main contrib non-free
#deb-src http://ftp.pl.debian.org/debian/ wheezy main contrib non-free
#deb http://security.debian.org/ wheezy/updates main contrib non-free
#deb-src http://security.debian.org/ wheezy/updates main contrib non-free
Faktycznie korzystałem z repozytorium wheeze tylko dla jednego pakietu którego nie ma w squeeze - tcptrack - i nic więcej zeń nie brałem. Ale pewnie wymagał jakiś zależności które mi namieszały.
I faktycznie namieszały - bowiem na innej maszynce na której nie robiłem takich rzeczy build-essential zainstalowało się bez problemu.
Tematu więc nie ciągnę - bo odkręcić to to będzie zapewne jakiś koszmar - więc skompiluje sobie gdzieś indziej a potem przeniosę.
ArnVaker
Zależy jak bardzo masz pomieszane, może nie taki koszmar wcale.
Znalezienie pakietów zainstalowanych spoza repozytorium wersji stabilnej:
aptitude search '?any-version(~i !?and(~ODebian ~Astable))'
Zrównanie do wersji stabilnej:
  • Wpis do /etc/apt/preferences:
    Package: *
    Pin: release a=stable
    Pin-Priority: 1100
  • Zrównanie:
    apt-get dist-upgrade
sethiel
i A gcc-4.7-base        - GCC, the GNU Compiler Collection (base package)
i   libc-bin        - Embedded GNU C Library: Binaries
i   libc6        - Embedded GNU C Library: Shared libraries
i   libc6-i686        - Embedded GNU C Library: Shared libraries [i686 optimized]
i   libstdc++6        - GNU Standard C++ Library v3
i   locales        - Embedded GNU C Library: National Language (locale) data [support]
i A multiarch-support        - Transitional package to ensure multiarch compatibility
i   sarg        - squid analysis report generator
i   squid3        - A full featured Web Proxy cache (HTTP proxy)
i A squid3-common        - A full featured Web Proxy cache (HTTP proxy) - common files
i   squid3-dbg        - A full featured Web Proxy cache (HTTP proxy) - Debug symbols
i   tcptrack        - TCP connection tracker, with states and speeds
squid3 to akrutat moje zabawy z kompilacją, a pozostałe to wymagania tcptrack - który to jest bardzo fajny ale występuje w etch/lenny/wheezy natomiast w squeeze były jakieś problemy i zrezygnowali.
Dzięki za pomoc i zwrócenie uwagi, kompilację zrobiłem sobie na maszynce bez żadnych machlojek.
