Zainstalowałem IspConfig3. Działa jakoś przyjemnie. Niestety FTP nie działa. Zainstalowałem proftpd według tego poradnika: http://www.howtoforge.com/ispconfig-3-p ... for-debian
Niestety, nie mogę się połączyć. Klient ftp pokazuje mi:
Odpowiedź    220 ProFTPD 1.3.3a Server (Debian) [91.239.XX.xXX]
Polecenie:    USER XXX_user
Odpowiedź    331 Password required for itbeta_user
Polecenie:    PASS *********
Odpowiedź    230 User XX_user logged in
Polecenie:    SYST
Błąd:    Nie można połączyć się z serwerem
Logi proftpd:
Sep 09 23:52:18 vz12085 proftpd[3888] 91.239.XX (62.69.243.XX[62.69.243.XX]): FTP session opened.
Sep 09 19:52:20 vz12085 proftpd[3888] 91.239.XX (62.69.243.XX[62.69.243.XX]): Preparing to chroot to directory '/var/www/clients/client1/web1'
Sep 09 19:52:20 vz12085 proftpd[3888] 91.239.XX(62.69.243.XX[62.69.243.XX]): FTP session closed.
Sep 09 23:52:25 vz12085 proftpd[3889] 91.239.XX (62.69.243.XX[62.69.243.XX]): FTP session opened.
Sep 09 19:52:27 vz12085 proftpd[3889] 91.239.xX (62.69.243.XX[62.69.243.XX]): Preparing to chroot to directory '/var/www/clients/client1/web1'
Sep 09 19:52:29 vz12085 proftpd[3889] 91.239.XX (62.69.243.X[62.69.243.XX]): FTP session closed.
Konfig proftpd:
# /etc/proftpd/proftpd.conf -- This is a basic ProFTPD configuration file.
# To really apply changes reload proftpd after modifications.
# Includes DSO modules
Include /etc/proftpd/modules.conf
# Set off to disable IPv6 support which is annoying on IPv4 only boxes.
UseIPv6                         off
# If set on you can experience a longer connection delay in many cases.
IdentLookups                    off
UseReverseDNS off
ServerName                      "Debian"
ServerType                      standalone
DeferWelcome                    off
MultilineRFC2228                on
DefaultServer                   on
ShowSymlinks                    on
TimeoutNoTransfer               600
TimeoutStalled                  600
TimeoutIdle                     1200
DisplayLogin                    welcome.msg
DisplayChdir                    .message true
ListOptions                     "-l"
DenyFilter                      \*.*/
# Use this to jail all users in their homes
DefaultRoot                     ~
# Users require a valid shell listed in /etc/shells to login.
# Use this directive to release that constrain.
# RequireValidShell             off
# Port 21 is the standard FTP port.
# In some cases you have to specify passive ports range to by-pass
# firewall limitations. Ephemeral ports can be used for that, but
# feel free to use a more narrow range.
# PassivePorts                  49152 65534
# If your host was NATted, this option is useful in order to
# allow passive tranfers to work. You have to use your public
# address and opening the passive ports used on your firewall as well.
# MasqueradeAddress             1.2.3.4
# This is useful for masquerading address with dynamic IPs:
# refresh any configured MasqueradeAddress directives every 8 hours
<IfModule mod_dynmasq.c>
# DynMasqRefresh 28800
</IfModule>
# To prevent DoS attacks, set the maximum number of child processes
# to 30.  If you need to allow more than 30 concurrent connections
# at once, simply increase this value.  Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances                    30
# Set the user and group that the server normally runs at.
User                            proftpd
Group                           nogroup
# Umask 022 is a good standard umask to prevent new files and dirs
# (second parm) from being group and world writable.
Umask                           022  022
# Normally, we want files to be overwriteable.
AllowOverwrite                  on
# Uncomment this if you are using NIS or LDAP via NSS to retrieve passwords:
# PersistentPasswd              off
# This is required to use both PAM-based authentication and local passwords
# (such as xinetd)
MaxInstances                    30
User                            proftpd
Group                           nogroup
Umask                           022  022
AllowOverwrite                  on
# AuthOrder                     mod_auth_pam.c* mod_auth_unix.c
# Be warned: use of this directive impacts CPU average load!
# Uncomment this if you like to see progress and transfer rate with ftpwho
# in downloads. That is not needed for uploads rates.
# UseSendFile                   off
TransferLog /var/log/proftpd/xferlog
SystemLog   /var/log/proftpd/proftpd.log
<IfModule mod_quotatab.c>
QuotaEngine off
</IfModule>
<IfModule mod_ratio.c>
Ratios off
</IfModule>
# UseSendFile                   off
QuotaEngine off
</IfModule>
Ratios off
</IfModule>
# Delay engine reduces impact of the so-called Timing Attack described in
# http://security.lss.hr/index.php?page=details&ID=LSS-2004-10-02
# It is on by default.
<IfModule mod_delay.c>
DelayEngine on
</IfModule>
<IfModule mod_ctrls.c>
ControlsEngine        off
ControlsMaxClients    2
ControlsLog           /var/log/proftpd/controls.log
ControlsInterval      5
ControlsSocket        /var/run/proftpd/proftpd.sock
</IfModule>
<IfModule mod_ctrls_admin.c>
AdminControlsEngine off
</IfModule>
## http://security.lss.hr/index.php?page=details&ID=LSS-2004-10-02
DelayEngine on
</IfModule>
ControlsEngine        off
ControlsInterval      5
</IfModule>
</IfModule>
# Alternative authentication frameworks
#Include /etc/proftpd/ldap.conf
Include /etc/proftpd/sql.conf
# This is used for FTPS connections
#Include /etc/proftpd/tls.conf
# Useful to keep VirtualHost/VirtualRoot directives separated
#Include /etc/proftpd/virtuals.con
# A basic anonymous configuration, no upload directories.
# <Anonymous ~ftp>
#   User                                ftp
#   Group               #   UserAlias                   anonymous ftp
#   # Cosmetic changes, all files belongs to ftp user
#   DirFakeUser on ftp
#   DirFakeGroup on ftp
#   # Limit the maximum number of anonymous logins
#   MaxClients                  10
#   # We want 'welcome.msg' displayed at login, and '.message' displayed
#   # in each newly chdired directory.
#   DisplayLogin                        welcome.msg
#   DisplayChdir                .message
#   # Limit WRITE everywhere in the anonymous chroot
#   <Directory *>
#     <Limit WRITE>
#       DenyAll
#     </Limit>
#   </Directory>
#   # Uncomment this if you're brave.
#   # <Directory incoming>
#   #   # Umask 022 is a good standard umask to prevent new files and dirs
#   #   # (second parm) from being group and world writable.
#   #   Umask                           022  022
#   #            <Limit READ WRITE>
#   #            DenyAll
#   #            </Limit>
#   #            <Limit STOR>
#   #            AllowAll
#   #            </Limit>
#   # </Directory>
# </Anonymous>
Chyba dobrze przekopiowałem.
Dziękuję za pomoc.
