Podczas rozmów (nagrywania) szumi mi mikrofon. Na Windowsie się tak nie dzieje.
Próbowałem już wszystkiego, ale nic nie zdziałałem.
Otóż i informacje:
http://www.alsa-project.org/db/?f=a69e8 ... 37daa14e89
!!ALSA Information Script v 0.4.61
!!Script ran on: Mon Jul 30 09:56:25 UTC 2012
!!Linux Distribution
Debian GNU/Linux wheezy/sid \n \l PRETTY_NAME="Debian GNU/Linux wheezy/sid" NAME="Debian GNU/Linux" ID=debian
!!DMI Information
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: H55M-S2H
Product Version:
Firmware Version: F5
!!Kernel Information
Kernel release: 3.2.0-3-amd64
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: 1.0.24
Library version: 1.0.25
Utilities version:
!!Loaded ALSA modules
snd_hda_intel
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
!!Soundcards recognised by ALSA
0 [Intel ]: HDA-Intel - HDA Intel
HDA Intel at 0xfbff8000 irq 42
1 [Generic ]: HDA-Intel - HD-Audio Generic
HD-Audio Generic at 0xfbcfc000 irq 43
!!PCI Soundcards installed in the system
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 06)
01:00.1 Audio device: Advanced Micro Devices [AMD] nee ATI Juniper HDMI Audio [Radeon HD 5700 Series]
!!Advanced information - PCI Vendor/Device/Subsystem ID's
00:1b.0 0403: 8086:3b56 (rev 06)
Subsystem: 1458:a002
01:00.1 0403: 1002:aa58
Subsystem: 1787:aa58
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : Y
bdl_pos_adj : 1,32,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : 1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
position_fix : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
power_save : 0
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : N
snoop : Y
enable_msi : -1
power_save : 0
single_cmd : N
snoop : Y
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC887
Address: 2
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0887
Subsystem Id: 0x1458a102
Revision Id: 0x100202
No Modem Function Group found
Default PCM:
rates [0x560]: 44100 48000 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
GPIO: io=2, o=0, i=0, unsolicited=1, wake=1
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x411: Stereo
Device: name="ALC887 Analog", type="Audio", device=0
Converter: stream=8, channel=0
PCM:
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Power: setting=D0, actual=D0
Node 0x03 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=0, device=0
Control: name="IEC958 Playback Pro Mask", index=0, device=0
Control: name="IEC958 Playback Default", index=0, device=0
Control: name="IEC958 Playback Switch", index=0, device=0
Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
Device: name="ALC887 Digital", type="SPDIF", device=1
Digital:
Digital category: 0x0
PCM:
rates [0x5e0]: 44100 48000 88200 96000 192000
formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Switch", index=0, device=0
Control: name="Capture Volume", index=0, device=0
Amp-In caps: ofs=0x0b, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x1e 0x1e]
Converter: stream=4, channel=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Switch", index=1, device=0
Control: name="Capture Volume", index=1, device=0
Device: name="ALC887 Analog", type="Audio", device=2
Amp-In vals: [0x80 0x80]
Converter: stream=0, channel=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Audio Input] wcaps 0x100711: Stereo Digital
Control: name="IEC958 Capture Switch", index=0, device=0
Control: name="IEC958 Capture Default", index=0, device=0
SDI-Select: 0
Digital:
PCM:
formats [0x1]: PCM
Connection: 1
0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="CD Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=4, ofs=0
Control: name="CD Playback Switch", index=0, device=0
Control: name="Line Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name="Line Playback Switch", index=0, device=0
Control: name="Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Mic Playback Switch", index=0, device=0
Control: name="Front Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name="Front Mic Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x00 0x00] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name="Front Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out caps: ofs=0x1f, nsteps=0x1f, stepsize=0x05, mute=0
Amp-Out vals: [0x10 0x10]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name="Surround Playback Volume", index=0, device=0
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name="Center Playback Volume", index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name="LFE Playback Volume", index=0, device=0
ControlAmp: chs=2, dir=Out, idx=0, ofs=0
Connection: 2
0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name="Side Playback Volume", index=0, device=0
Connection: 2
0x05 0x0b
Node 0x10 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
PCM:
formats [0x1]: PCM
Node 0x11 [Pin Complex] wcaps 0x400780: Mono Digital
Pincap 0x00000014: OUT Detect
Pin Default 0x411110f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=00, enabled=0
Connection: 1
0x10
Node 0x12 [Pin Complex] wcaps 0x400401: Stereo
Pincap 0x00000020: IN
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0000003e: IN OUT HP Detect Trigger
Pin Default 0x01014410: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x40: OUT
Connection: 5
0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x15 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pin Default 0x01011412: [Jack] Line Out at Ext Rear
DefAssociation = 0x1, Sequence = 0x2
Pin-ctls: 0x40: OUT
Connection: 5
0x0c 0x0d* 0x0e 0x0f 0x26
Node 0x16 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pincap 0x00000036: IN OUT Detect Trigger
Pin Default 0x01016411: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Orange
DefAssociation = 0x1, Sequence = 0x1
Pin-ctls: 0x40: OUT
Connection: 5
0x0c 0x0d 0x0e* 0x0f 0x26
Node 0x17 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pin Default 0x01012414: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Grey
DefAssociation = 0x1, Sequence = 0x4
Pin-ctls: 0x40: OUT
Connection: 5
0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Mic Boost Volume", index=0, device=0
Amp-In vals: [0x03 0x03]
Amp-Out vals: [0x80 0x80]
Pincap 0x0000373e: IN OUT HP Detect Trigger
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x01a19c40: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Connection: 5
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Front Mic Boost Volume", index=0, device=0
Pin Default 0x02a19c50: [Jack] Mic at Ext Front
DefAssociation = 0x5, Sequence = 0x0
Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pin Default 0x0181344f: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x4, Sequence = 0xf
Pin-ctls: 0x20: IN VREF_HIZ
Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pin Default 0x02214c20: [Jack] HP Out at Ext Front
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP VREF_HIZ
Connection: 5
Node 0x1c [Pin Complex] wcaps 0x400481: Stereo
Pincap 0x00000024: IN Detect
Pin Default 0x593301f0: [N/A] CD at Int ATAPI
Conn = ATAPI, Color = Unknown
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x4005e601: [N/A] Line Out at Ext N/A
Conn = Optical, Color = White
DefAssociation = 0x0, Sequence = 0x1
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400780: Mono Digital
Pin Default 0x014b6130: [Jack] SPDIF Out at Ext Rear
Conn = Comb, Color = Orange
DefAssociation = 0x3, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Pin Complex] wcaps 0x400680: Mono Digital
Pin Default 0x01cb7160: [Jack] SPDIF In at Ext Rear
Conn = Comb, Color = Yellow
DefAssociation = 0x6, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=25
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Input Source", index=1, device=0
Amp-In vals: [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 12
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b 0x12
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Input Source", index=0, device=0
Connection: 11
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Connection: 2
0x25 0x0b
Codec: ATI R6xx HDMI
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x1002aa01
Subsystem Id: 0x00aa0100
Revision Id: 0x100200
Default PCM:
rates [0x70]: 32000 44100 48000
bits [0x2]: 16
formats [0x1]: PCM
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x201: Stereo Digital
Converter: stream=1, channel=0
Digital: Enabled GenLevel
Digital category: 0x2
Node 0x03 [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="ELD", index=0, device=3
Pincap 0x00000094: OUT Detect HDMI
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
Pin-ctls: 0x00:
Unsolicited: tag=03, enabled=1
Connection: 1
0x02
--endcollapse--
!!ALSA Device nodes
crw-rw---T 1 root audio 116, 8 Jul 30 10:34 /dev/snd/controlC0
crw-rw---T 1 root audio 116, 11 Jul 30 10:34 /dev/snd/controlC1
crw-rw---T 1 root audio 116, 7 Jul 30 10:34 /dev/snd/hwC0D2
crw-rw---T 1 root audio 116, 10 Jul 30 10:34 /dev/snd/hwC1D0
crw-rw---T 1 root audio 116, 6 Jul 30 11:15 /dev/snd/pcmC0D0c
crw-rw---T 1 root audio 116, 5 Jul 30 11:39 /dev/snd/pcmC0D0p
crw-rw---T 1 root audio 116, 4 Jul 30 10:34 /dev/snd/pcmC0D1c
crw-rw---T 1 root audio 116, 3 Jul 30 10:34 /dev/snd/pcmC0D1p
crw-rw---T 1 root audio 116, 2 Jul 30 10:34 /dev/snd/pcmC0D2c
crw-rw---T 1 root audio 116, 9 Jul 30 10:34 /dev/snd/pcmC1D3p
crw------T 1 root root 116, 1 Jul 30 10:34 /dev/snd/seq
crw-rw---T 1 root audio 116, 33 Jul 30 10:34 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Jul 30 10:34 .
drwxr-xr-x 3 root root 300 Jul 30 10:34 ..
lrwxrwxrwx 1 root root 12 Jul 30 10:34 pci-0000:00:1b.0 -> ../controlC0
lrwxrwxrwx 1 root root 12 Jul 30 10:34 pci-0000:01:00.1 -> ../controlC1
!!Aplay/Arecord output
APLAY
./alsa-info.sh: line 118: aplay: command not found
ARECORD
./alsa-info.sh: line 122: arecord: command not found
!!Amixer output
!!-------Mixer controls for card 0 [Intel]
./alsa-info.sh: line 143: amixer: command not found
./alsa-info.sh: line 144: amixer: command not found
!!-------Mixer controls for card 1 [Generic]
!!Alsactl output
--startcollapse--
--endcollapse--
!!All Loaded Modules
Module
fuse
cryptd
aes_x86_64
aes_generic
rfcomm
bnep
bluetooth
binfmt_misc
loop
usblp
usb_storage
uas
arc4
rt73usb
rt2x00usb
rt2x00lib
mac80211
snd_hda_codec_hdmi
cfg80211
rfkill
crc_itu_t
joydev
hid_a4tech
snd_hda_codec_realtek
radeon
ttm
drm_kms_helper
drm
snd_hda_intel
snd_hda_codec
snd_hwdep
snd_pcm
snd_page_alloc
power_supply
i2c_algo_bit
snd_timer
snd
coretemp
i2c_i801
i2c_core
evdev
serio_raw
acpi_cpufreq
soundcore
mperf
iTCO_wdt
iTCO_vendor_support
pcspkr
processor
crc32c_intel
thermal_sys
button
ext4
crc16
jbd2
mbcache
usbhid
hid
sr_mod
sd_mod
cdrom
crc_t10dif
ata_generic
pata_jmicron
uhci_hcd
ata_piix
libata
r8169
mii
ehci_hcd
scsi_mod
usbcore
usb_common
!!Sysfs Files
/sys/class/sound/hwC0D2/init_pin_configs:
0x11 0x411110f0
0x12 0x411111f0
0x14 0x01014410
0x15 0x01011412
0x16 0x01016411
0x17 0x01012414
0x18 0x01a19c40
0x19 0x02a19c50
0x1a 0x0181344f
0x1b 0x02214c20
0x1c 0x593301f0
0x1d 0x4005e601
0x1e 0x014b6130
0x1f 0x01cb7160
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC1D0/init_pin_configs:
0x03 0x18560010
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
!!ALSA/HDA dmesg
[ 5.068897] i801_smbus 0000:00:1f.3: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 5.300953] snd_hda_intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 5.300998] snd_hda_intel 0000:00:1b.0: irq 42 for MSI/MSI-X
[ 5.301020] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[ 5.302348] Error: Driver 'pcspkr' is already registered, aborting...
[ 5.402831] [drm] Connector 1:
[ 5.402833] [drm] HDMI-A
[ 5.402834] [drm] HPD5
[ 5.728381] [drm] Initialized radeon 2.12.0 20080528 for 0000:01:00.0 on minor 0
[ 5.728449] snd_hda_intel 0000:01:00.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 5.728518] snd_hda_intel 0000:01:00.1: irq 43 for MSI/MSI-X
[ 5.728540] snd_hda_intel 0000:01:00.1: setting latency timer to 64
[ 5.781749] HDMI status: Codec=0 Pin=3 Presence_Detect=0 ELD_Valid=0
[ 5.781912] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input6
[ 5.942777] usb 2-5: reset high-speed USB device number 3 using ehci_hcd
[ 25.833293] wlan0: no IPv6 routers present
[ 28.524684] hda-intel: azx_get_response timeout, switching to polling mode: last cmd=0x20aa0000
[ 1821.259816] wlan0: deauthenticating from 00:27:19:f7:22:6a by local choice (reason=3)
