Problem z compiz
ewter
Problem z compiz
Post autor: ewter »
Witam, pół nocy meczyłem sie z zajnstalowaniem sterownika do mojej geforce2 mx 200 64MB i się udało :)
Teraz mam problem z odpaleniem compiz.
jaaa@debian:~$ compiz --replace
Fatal: Failed test: texture_from_pixmap support
Checks indicate that it's impossible to start compiz on your system.
lub
jaaa@debian:~$ compiz --replace -c emerald
Debian-Lenny 2.6.18-4-686
xorg.conf:
# xorg.conf (xorg X Window System server configuration file)
# package.
Section "Files"
EndSection
Section "InputDevice"
        Identifier      "Generic Keyboard"
        Driver          "kbd"
        Option          "CoreKeyboard"
"xorg.conf" 67L, 1685C                                       2,1           Top
        Driver          "kbd"
        Option          "XkbRules"      "xorg"
        Option          "XkbModel"      "pc105"
        Option          "XkbLayout"     "pl"
EndSection
        Identifier      "Configured Mouse"
        Driver          "mouse"
        Option          "CorePointer"
        Option          "Device"                "/dev/psaux"
        Option          "Protocol"              "ImPS/2"
        Option          "Emulate3Buttons"       "true"
EndSection
Section "Device"
        Identifier      "nVidia Corporation NV11DDR [GeForce2 MX200]"
        Driver          "nvidia"
        BusID           "PCI:1:0:0"
        VideoRam        65516
EndSection
                                                             22,2-9        47%
EndSection
Section "Monitor"
        Identifier      "COMPAQ V500"
        Option          "DPMS"
        HorizSync       30-70
        VertRefresh     50-160
EndSection
Section "Screen"
        Identifier      "Default Screen"
        Device          "nVidia Corporation NV11DDR [GeForce2 MX200]"
        Monitor         "COMPAQ V500"
        DefaultDepth    24
        SubSection "Display"
        Modes           "1280x1024" "1152x864" "1024x768" "800x600" "640x480"
        EndSubSection
EndSection
Section "ServerLayout"
        Identifier      "Default Layout"
        Screen          "Default Screen"
        InputDevice     "Generic Keyboard"
                                                             43,1          95%
        InputDevice     "Configured Mouse"
EndSection
el_carles
Post autor: el_carles »
To niekoniecznie musi być rozwiązaniem:
root@debian / pią lip 06 / 09:42:09 / /home/k / 3.1 /
# -> aptitude search pixmap
p gtk-engines-pixmap - Pixmap-based theme for GTK+ 1.2
p gtk-engines-qtpixmap - QtPixmap GTK1.x theming engine
p gtk2-engines-qtpixmap - QtPixmap GTK2.x theming engine
p pixmap - A pixmap editor
# aptitude install gtk-engines-pixmap
//edit
i nie wiem czy to w cf'ie jest konieczne ale dodaj do xorg.conf
Section "Extensions"
Option "Composite" "Enable"
EndSection
ewter
Post autor: ewter »
próbowałem, bez pozytywnego rezultatu :|
edit:
EndSection
po dodaniu tego na koncu xorg.conf nie mage wejsc do x'ów
,,Fatal server error
(EE) Problem pasing the config file
(EE) Error pasing the config file"
el_carles
A co Ci wywala:
$ glxinfo | grep direct
ewter
Post autor: ewter »
debian:/#  glxinfo | grep direct
Xlib: connection to ":0.0" refused by server
Xlib: Invalid MIT-MAGIC-COOKIE-1 key
Error: unable to open display (null)
zuczek126p
Post autor: zuczek126p »
Zrób to z poziomu zwykłego użytkownika (no i spod X'ów).
el_carles
No i jak z tym userem?
ewter
Post autor: ewter »
jaaa@debian:~$ glxinfo | grep direct
direct rendering: Yes
el_carles
a to dziwne :|
Spróbuj w takim razie dodać do xorg.conf
w sekcji Screen:
Option         "AddARGBGLXVisuals" "true"
Option         "AllowGLXWithComposite" "true"
w sekcji Device:
Option          "TripleBuffer" "true"
//edit
- W tym temacie - możesz pobrać mój xorg.conf. Może do czegoś Ci się przyda?! Bo jak te ostatnie opcje nie zadziałają to nie wiem o co chodzi...
ewter
Post autor: ewter »
No niestety dodanie tych wpisów nie pomogło... :( jakieś jeszcze pomysły?
