Informacje o moim systemie:
root@SERWER:/home/michal# dpkg -l | grep postfix
ii  postfix                              2.9.3-2                            i386         High-performance mail transport agent
ii  postfix-doc                          2.9.3-2                            all          Documentation for Postfix
root@SERWER:/home/michal# dpkg -l | grep dovecot
ii  dovecot-common                       1:2.1.7-2                          all          Transitional package for dovecot
ii  dovecot-core                         1:2.1.7-2                          i386         secure mail server that supports mbox, maildir, dbox and mdbox mailboxes
ii  dovecot-gssapi                       1:2.1.7-2                          i386         GSSAPI authentication support for Dovecot
ii  dovecot-imapd                        1:2.1.7-2                          i386         secure IMAP server that supports mbox, maildir, dbox and mdbox mailboxes
ii  dovecot-ldap                         1:2.1.7-2                          i386         LDAP support for Dovecot
ii  dovecot-mysql                        1:2.1.7-2                          i386         MySQL support for Dovecot
ii  dovecot-pgsql                        1:2.1.7-2                          i386         PostgreSQL support for Dovecot
ii  dovecot-pop3d                        1:2.1.7-2                          i386         secure POP3 server that supports mbox, maildir, dbox and mdbox mailboxes
ii  dovecot-sieve                        1:2.1.7-2                          i386         sieve filters support for Dovecot
ii  dovecot-sqlite                       1:2.1.7-2                          i386         SQLite support for Dovecot
root@SERWER:/home/michal# uname --all
Linux SERWER 3.2.0-3-686-pae #1 SMP Thu Jun 28 08:56:46 UTC 2012 i686 GNU/Linux
Pliki konfiguracyjne:
/etc/postfix/main.cf:
command_directory = /usr/sbin
mail_owner = postfix
mydomain = poczta.3-a.net
myhostname = poczta.3-a.net
myorigin = /etc/mailname
mydestination = $mydomain, $myhostname, localhost, localhost.localdomain,
mynetworks = 127.0.0.0/8
inet_interfaces = all
inet_protocols = ipv4
home_mailbox = Maildir/
mail_spool_directory = /home/
smtpd_banner = ESMTP on $myhostname !
mailbox_size_limit = 0
recipient_delimiter = +
biff = no
append_dot_mydomain = no
relayhost =
#AUTH SMTP
smtpd_sasl_type = dovecot
smtpd_sasl_auth_enable = yes
smtpd_sasl2_auth_enable = yes
smtpd_sasl_security_options = noanonymous
smtpd_sasl_local_domain = $myhostname
smtpd_recipient_restrictions =
	permit_mynetworks,
	permit_sasl_authenticated,
	reject_unauth_destination,
	reject_unknown_recipient_domain,
	reject_non_fqdn_recipient
smtpd_client_restrictions =
	#reject_unknown_client,
	reject_rbl_client dul.dnsbl.sorbs.net,
	reject_rbl_client list.dsbl.org,
	reject_rbl_client sbl.spamhaus.org,
	reject_rbl_client cbl.abuseat.org
smtpd_sender_restrictions =
	reject_unknown_sender_domain,
	reject_non_fqdn_sender,
	reject_unknown_address
#TLS
smtpd_tls_auth_only = yes
smtp_use_tls = yes
smtpd_use_tls = yes
smtp_tls_note_starttls_offer = yes
smtpd_tls_key_file = /etc/postfix/ssl/mail.pem
smtpd_tls_cert_file = /etc/postfix/ssl/mail.pem
smtpd_tls_CAfile = /etc/postfix/ssl/mail.pem
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
smtpd_tls_session_cache_database = btree:${queue_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${queue_directory}/smtp_scache
tls_random_source = dev:/dev/urandom
base_dir = /var/run/dovecot/
protocols = imap imaps pop3 pop3s
listen = *
disable_plaintext_auth = no
shutdown_clients = yes
#logi
log_path=/var/log/dovecot.log
info_log_path = /var/log/mail.log
log_timestamp = "%Y-%m-%d %H:%M:%S "
syslog_facility = mail
login_process_size = 64
login_greeting = Welcome. I’m ready ...
login_log_format_elements = user=<%u> method=%m rip=%r lip=%l %c
login_log_format = %$: %s
login_chroot = no
login_user = dovecot
login_process_per_connection = yes
login_processes_count = 3
login_max_processes_count = 128
mail_location = maildir:~/Maildir
#SSL
ssl_disable = no
ssl_cert_file = /etc/postfix/ssl/mail.pem
ssl_key_file = /etc/postfix/ssl/mail.pem
verbose_ssl = yes
mail_access_groups = postfix
protocol imap {
protocol pop3 {
pop3_uidl_format = %08Xu%08Xv
protocol lda {
postmaster_address = postmaster@test.com
auth_verbose = yes
auth_debug = yes
auth default {
mechanisms = plain login
passdb pam {
userdb passwd {
user = root
socket listen {
client {
path = /var/spool/postfix/private/auth
mode = 0660
user = postfix
group = postfix
doveconf: Warning: NOTE: You can get a new clean config file with: doveconf -n > dovecot-new.conf
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:2: 'imaps' protocol is no longer necessary, remove it
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:2: 'pop3s' protocol is no longer necessary, remove it
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:11: login_process_size has been replaced by service { vsz_limit }
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:15: login_chroot has been replaced by service { chroot }
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:16: login_user has been replaced by service { user }
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:17: login_process_per_connection has been replaced by service { service_count }
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:18: login_processes_count has been replaced by service { process_min_avail }
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:19: login_max_processes_count has been replaced by service { process_limit }
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:22: ssl_disable has been renamed to ssl
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:23: ssl_cert_file has been replaced by ssl_cert = <file
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:24: ssl_key_file has been replaced by ssl_key = <file
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:37: add auth_ prefix to all settings inside auth {} and remove the auth {} section completely
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:39: passdb pam {} has been replaced by passdb { driver=pam }
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:41: userdb passwd {} has been replaced by userdb { driver=passwd }
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:43: auth_user has been replaced by service auth { user }
[....] Starting IMAP/POP3 mail server: dovecotdoveconf: Warning: NOTE: You can get a new clean config file with: doveconf -n > dovecot-new.conf
. ok
root@SERWER:/home/michal# /etc/init.d/postfix start
[....] Starting Postfix Mail Transport Agent: postfixpostconf: warning: /etc/postfix/main.cf: unused parameter: smtpd_sasl2_auth_enable=yes
/usr/sbin/postconf: warning: /etc/postfix/main.cf: unused parameter: smtpd_sasl2_auth_enable=yes
. ok
Jak widac, twierdzi ze jest blad autoryzacji - oczywiscie uzytkownik istnieje i haslo podawane jest dobre. Podpowiecie mi w czym problem?
