Can't fetch domain SID for name: SERVER
Sesjusz
Post autor: Sesjusz »
Nowo postawiona najnowsza wersja Debiana, aktualnie konfiguruję. Zerkam przy okazji do syslog a tam co 32 minuty komunikaty:
Jun 13 07:55:46 server winbindd[24986]: [2012/06/13 07:55:46.858738,  0] winbindd/winbindd_passdb.c:149(sid_to_name)
Jun 13 07:55:46 server winbindd[24986]:   Possible deadlock: Trying to lookup SID S-1-5-21-1002196034-96341254-2794086627-513 with passdb backend
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.859158,  0] winbindd/idmap.c:201(smb_register_idmap_alloc)
Jun 13 07:55:46 server winbindd[25016]:   idmap_alloc module tdb already registered!
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.859233,  0] winbindd/idmap.c:149(smb_register_idmap)
Jun 13 07:55:46 server winbindd[25016]:   Idmap module passdb already registered!
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.859268,  0] winbindd/idmap.c:149(smb_register_idmap)
Jun 13 07:55:46 server winbindd[25016]:   Idmap module nss already registered!
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.859354,  0] winbindd/idmap_tdb.c:287(idmap_tdb_open_db)
Jun 13 07:55:46 server winbindd[25016]:   Upgrade of IDMAP_VERSION from -1 to 2 is not possible with incomplete configuration
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.866817,  0] winbindd/idmap.c:201(smb_register_idmap_alloc)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.866866,  0] winbindd/idmap.c:149(smb_register_idmap)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.866898,  0] winbindd/idmap.c:149(smb_register_idmap)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.866976,  0] winbindd/idmap_tdb.c:287(idmap_tdb_open_db)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.867509,  0] winbindd/idmap.c:201(smb_register_idmap_alloc)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.867554,  0] winbindd/idmap.c:149(smb_register_idmap)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.867586,  0] winbindd/idmap.c:149(smb_register_idmap)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.867663,  0] winbindd/idmap_tdb.c:287(idmap_tdb_open_db)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.867722,  0] winbindd/idmap.c:201(smb_register_idmap_alloc)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.867754,  0] winbindd/idmap.c:149(smb_register_idmap)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.867784,  0] winbindd/idmap.c:149(smb_register_idmap)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.867870,  0] winbindd/idmap_tdb.c:287(idmap_tdb_open_db)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.868242,  0] winbindd/idmap.c:201(smb_register_idmap_alloc)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.868281,  0] winbindd/idmap.c:149(smb_register_idmap)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.868315,  0] winbindd/idmap.c:149(smb_register_idmap)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.868387,  0] winbindd/idmap_tdb.c:287(idmap_tdb_open_db)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.868445,  0] winbindd/idmap.c:201(smb_register_idmap_alloc)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.868477,  0] winbindd/idmap.c:149(smb_register_idmap)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.868508,  0] winbindd/idmap.c:149(smb_register_idmap)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.868613,  0] winbindd/idmap_tdb.c:287(idmap_tdb_open_db)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.868960,  0] winbindd/idmap.c:201(smb_register_idmap_alloc)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.869002,  0] winbindd/idmap.c:149(smb_register_idmap)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.869034,  0] winbindd/idmap.c:149(smb_register_idmap)
Jun 13 07:55:46 server winbindd[25016]: [2012/06/13 07:55:46.869105,  0] winbindd/idmap_tdb.c:287(idmap_tdb_open_db)
Jun 13 07:55:46 server winbindd[24986]: [2012/06/13 07:55:46.870052,  0] winbindd/winbindd_passdb.c:149(sid_to_name)
Jun 13 07:55:46 server winbindd[24986]: [2012/06/13 07:55:46.870473,  0] winbindd/winbindd_passdb.c:149(sid_to_name)
Jun 13 07:55:46 server winbindd[24986]: [2012/06/13 07:55:46.871232,  0] winbindd/winbindd_passdb.c:149(sid_to_name)
Wygooglałem, że problemem jest uzyskiwanie SID'ów domeny, po wydaniu polecania otrzymuję taki komunikat:
root@server:/# net getdomainsid
SID for local machine SERVER is: S-1-5-21-759537529-1116112613-2385187407
Could not fetch domain SID
Czy postawicie podobną diagnozę i jakieś panaceum dla problemu ?
