mam problem z x-ami po odpaleniu startx mam takie cosik czy ktos wie co to moze byc?? i jak to naprawic?? z gory dzieki za pomoc....
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Jul 4 23:59:28 2007
(EE) AIGLX: Screen 0 is not DRI capable
xkb_keycodes { include "xfree86+aliases(qwertz)" };
xkb_types { include "complete" };
xkb_compatibility { include "complete" };
xkb_symbols { include "pc(pc105)+de(nodeadkeys)+level3(ralt_switch_multikey)" };
xkb_geometry { include "pc(pc105)" };
xkb_types { include "%" };
xkb_compatibility { include "%" };
xkb_symbols { include "%" };
xkb_geometry { include "%" };
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Error: Missing KeyNames section in a Keymap file
> Description of Keymap not compiled
Errors from xkbcomp are not fatal to the X server
(EE) Error loading keymap /var/lib/xkb/server-0.xkm
waiting for X server to shut down FreeFontPath: FPE "/usr/share/fonts/X11/misc" refcount is 2, should be 1; fixing.
