Konfiguracja dźwi
MateuszS
Konfiguracja dźwięku, karta intel
Post autor: MateuszS »
Nie mam dźwięku na Debianie z jądrem w wersji 3.2.0. Mimo, że wykrywa kartę
http://www.alsa-project.org/db/?f=3998a ... 7d28da1aa5
!!ALSA Information Script v 0.4.60
!!Script ran on: Mon May 28 17:05:17 UTC 2012
!!Linux Distribution
Debian GNU/Linux wheezy/sid \n \l
!!DMI Information
Manufacturer:
Product Name:
Product Version:
!!Kernel Information
Kernel release:    3.2.0-2-686-pae
Operating System:  GNU/Linux
Architecture:      i686
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     1.0.24
Library version:    1.0.25
Utilities version:  1.0.25
!!Loaded ALSA modules
snd_hda_intel
snd_virtuoso
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
ESound Daemon:
      Installed - Yes (/usr/bin/esd)
      Running - No
!!Soundcards recognised by ALSA
 0 [NVidia         ]: HDA-Intel - HDA NVidia
                      HDA NVidia at 0xf4100000 irq 22
 1 [DS             ]: AV200 - Xonar DS
                      Asus Virtuoso 66 at 0x9400, irq 17
 2 [HDMI           ]: HDA-Intel - HDA ATI HDMI
                      HDA ATI HDMI at 0xf3010000 irq 41
!!PCI Soundcards installed in the system
00:05.0 Audio device: NVIDIA Corporation MCP61 High Definition Audio (rev a2)
01:07.0 Multimedia audio controller: C-Media Electronics Inc CMI8788 [Oxygen HD Audio]
02:00.1 Audio device: Advanced Micro Devices [AMD] nee ATI RV770 HDMI Audio [Radeon HD 4850/4870]
!!Advanced information - PCI Vendor/Device/Subsystem ID's
00:05.0 0403: 10de:03f0 (rev a2)
	Subsystem: 1458:a002
01:07.0 0401: 13f6:8788
	Subsystem: 1043:838e
02:00.1 0403: 1002:aa30
	Subsystem: 174b:aa30
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : Y
	bdl_pos_adj : 32,32,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : 1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	position_fix : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	power_save : 0
	power_save_controller : Y
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : N
	snoop : Y
!!Module: snd_virtuoso
	enable_msi : -1
	power_save : 0
	single_cmd : N
	snoop : Y
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC883
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x10ec0883
Subsystem Id: 0x1458e601
Revision Id: 0x100002
No Modem Function Group found
Default PCM:
    rates [0x560]: 44100 48000 96000 192000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x11: Stereo
  Device: name="ALC883 Analog", type="Audio", device=0
  Converter: stream=8, channel=0
  PCM:
    formats [0x1]: PCM
Node 0x03 [Audio Output] wcaps 0x11: Stereo
  PCM:
    formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x11: Stereo
  PCM:
    formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x11: Stereo
  PCM:
    formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x211: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=0, device=0
  Control: name="IEC958 Playback Pro Mask", index=0, device=0
  Control: name="IEC958 Playback Default", index=0, device=0
  Control: name="IEC958 Playback Switch", index=0, device=0
  Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
  Device: name="ALC883 Digital", type="SPDIF", device=1
  Digital: Enabled
  Digital category: 0x0
  PCM:
    bits [0x1e]: 16 20 24 32
    formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10011b: Stereo Amp-In
  Control: name="Capture Switch", index=0, device=0
  Control: name="Capture Volume", index=0, device=0
  Amp-In caps: ofs=0x08, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80]
  Converter: stream=4, channel=0
  SDI-Select: 0
  PCM:
    rates [0x160]: 44100 48000 96000
    bits [0x6]: 16 20
    formats [0x1]: PCM
  Connection: 1
     0x23
Node 0x09 [Audio Input] wcaps 0x10011b: Stereo Amp-In
  Control: name="Capture Switch", index=1, device=0
  Control: name="Capture Volume", index=1, device=0
  Device: name="ALC883 Analog", type="Audio", device=2
  Converter: stream=0, channel=0
  SDI-Select: 0
  PCM:
    bits [0x6]: 16 20
    formats [0x1]: PCM
  Connection: 1
     0x22
Node 0x0a [Audio Input] wcaps 0x100391: Stereo Digital
  Control: name="IEC958 Capture Switch", index=0, device=0
  Control: name="IEC958 Capture Default", index=0, device=0
  SDI-Select: 0
  Digital:
  PCM:
    formats [0x1]: PCM
  Unsolicited: tag=00, enabled=0
  Connection: 1
     0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Control: name="CD Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=4, ofs=0
  Control: name="CD Playback Switch", index=0, device=0
  Control: name="Line Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=2, ofs=0
  Control: name="Line Playback Switch", index=0, device=0
  Control: name="Mic Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Control: name="Mic Playback Switch", index=0, device=0
  Control: name="Front Mic Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=1, ofs=0
  Control: name="Front Mic Playback Switch", index=0, device=0
  Control: name="Beep Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=5, ofs=0
  Control: name="Beep Playback Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x19 0x19] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 10
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
  Control: name="Front Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-In vals:  [0x00 0x00] [0x00 0x00]
  Amp-Out caps: ofs=0x1f, nsteps=0x1f, stepsize=0x05, mute=0
  Amp-Out vals:  [0x1f 0x1f]
  Connection: 2
     0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
  Control: name="Surround Playback Volume", index=0, device=0
  Connection: 2
     0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
  Control: name="Center Playback Volume", index=0, device=0
    ControlAmp: chs=1, dir=Out, idx=0, ofs=0
  Control: name="LFE Playback Volume", index=0, device=0
    ControlAmp: chs=2, dir=Out, idx=0, ofs=0
  Connection: 2
     0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
  Control: name="Side Playback Volume", index=0, device=0
  Connection: 2
     0x05 0x0b
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x00 0x00]
  Pincap 0x0000003e: IN OUT HP Detect Trigger
  Pin Default 0x01014410: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Green
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Connection: 5
     0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x15 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Pin Default 0x01011412: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Black
    DefAssociation = 0x1, Sequence = 0x2
  Pin-ctls: 0x40: OUT
  Connection: 5
     0x0c 0x0d* 0x0e 0x0f 0x26
Node 0x16 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Pin Default 0x01016411: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Orange
    DefAssociation = 0x1, Sequence = 0x1
  Pin-ctls: 0x40: OUT
  Connection: 5
     0x0c 0x0d 0x0e* 0x0f 0x26
Node 0x17 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Pin Default 0x01012414: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Grey
    DefAssociation = 0x1, Sequence = 0x4
  Pin-ctls: 0x40: OUT
  Connection: 5
     0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x18 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Control: name="Mic Boost Volume", index=0, device=0
  Amp-Out vals:  [0x80 0x80]
  Pincap 0x0000173e: IN OUT HP Detect Trigger
    Vref caps: HIZ 50 GRD 80
  Pin Default 0x01a19c40: [Jack] Mic at Ext Rear
    Conn = 1/8, Color = Pink
    DefAssociation = 0x4, Sequence = 0x0
  Pin-ctls: 0x24: IN VREF_80
  Connection: 5
Node 0x19 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Control: name="Front Mic Boost Volume", index=0, device=0
  Pin Default 0x02a19c50: [Jack] Mic at Ext Front
    DefAssociation = 0x5, Sequence = 0x0
  Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Pin Default 0x01813441: [Jack] Line In at Ext Rear
    Conn = 1/8, Color = Blue
    DefAssociation = 0x4, Sequence = 0x1
  Pin-ctls: 0x20: IN VREF_HIZ
  Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
  Control: name="Headphone Playback Switch", index=0, device=0
  Pin Default 0x02214c20: [Jack] HP Out at Ext Front
    DefAssociation = 0x2, Sequence = 0x0
  Pin-ctls: 0xc0: OUT HP VREF_HIZ
  Connection: 5
Node 0x1c [Pin Complex] wcaps 0x400001: Stereo
  Pincap 0x00000020: IN
  Pin Default 0x9933014f: [Fixed] CD at Int ATAPI
    Conn = ATAPI, Color = Unknown
    DefAssociation = 0x4, Sequence = 0xf
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x1d [Pin Complex] wcaps 0x400000: Mono
  Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
    DefAssociation = 0xf, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x1e [Pin Complex] wcaps 0x400300: Mono Digital
  Pincap 0x00000010: OUT
  Pin Default 0x99430130: [Fixed] SPDIF Out at Int ATAPI
    DefAssociation = 0x3, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
  Connection: 1
     0x06
Node 0x1f [Pin Complex] wcaps 0x400200: Mono Digital
  Pin Default 0x99c30160: [Fixed] SPDIF In at Int ATAPI
    DefAssociation = 0x6, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
  Processing caps: benign=0, ncoeff=17
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
  Control: name="Input Source", index=1, device=0
  Amp-In vals:  [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Amp-Out caps: N/A
  Connection: 11
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
  Control: name="Input Source", index=0, device=0
  Amp-Out caps: N/A
  Connection: 11
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x11: Stereo
  PCM:
    formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
  Connection: 2
     0x25 0x0b
Codec: ATI R6xx HDMI
Address: 0
Vendor Id: 0x1002aa01
Subsystem Id: 0x00aa0100
Revision Id: 0x100100
Default PCM:
    rates [0x70]: 32000 44100 48000
    bits [0x2]: 16
    formats [0x1]: PCM
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x201: Stereo Digital
  Converter: stream=1, channel=0
  Digital: Enabled GenLevel
  Digital category: 0x2
Node 0x03 [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="ELD", index=0, device=3
  Pincap 0x00000094: OUT Detect HDMI
  Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
  Pin-ctls: 0x00:
  Unsolicited: tag=03, enabled=1
  Connection: 1
     0x02
--endcollapse--
!!ALSA Device nodes
crw-rw---T  1 root audio 116, 12 May 28 18:50 /dev/snd/controlC0
crw-rw---T  1 root audio 116,  5 May 28 18:50 /dev/snd/controlC1
crw-rw---T  1 root audio 116, 15 May 28 18:50 /dev/snd/controlC2
crw-rw---T  1 root audio 116, 11 May 28 18:50 /dev/snd/hwC0D0
crw-rw---T  1 root audio 116, 14 May 28 18:50 /dev/snd/hwC2D0
crw-rw---T  1 root audio 116, 10 May 28 18:53 /dev/snd/pcmC0D0c
crw-rw---T  1 root audio 116,  9 May 28 19:02 /dev/snd/pcmC0D0p
crw-rw---T  1 root audio 116,  8 May 28 18:53 /dev/snd/pcmC0D1c
crw-rw---T  1 root audio 116,  7 May 28 18:53 /dev/snd/pcmC0D1p
crw-rw---T  1 root audio 116,  6 May 28 18:50 /dev/snd/pcmC0D2c
crw-rw---T  1 root audio 116,  4 May 28 18:53 /dev/snd/pcmC1D0c
crw-rw---T  1 root audio 116,  3 May 28 18:53 /dev/snd/pcmC1D0p
crw-rw---T  1 root audio 116,  2 May 28 18:53 /dev/snd/pcmC1D1p
crw-rw---T  1 root audio 116, 13 May 28 18:53 /dev/snd/pcmC2D3p
crw-rw---T  1 root audio 116,  1 May 28 18:50 /dev/snd/seq
crw-rw---T  1 root audio 116, 33 May 28 18:50 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 100 May 28 18:50 .
drwxr-xr-x 3 root root 380 May 28 18:50 ..
lrwxrwxrwx 1 root root  12 May 28 18:50 pci-0000:00:05.0 -> ../controlC0
lrwxrwxrwx 1 root root  12 May 28 18:50 pci-0000:01:07.0 -> ../controlC1
lrwxrwxrwx 1 root root  12 May 28 18:50 pci-0000:02:00.1 -> ../controlC2
!!Aplay/Arecord output
APLAY
ALSA lib conf.c:122:( parse_def) show is not a compound
ALSA lib conf.c:1686 :( snd_config_load1) _toplevel_:24:26:Unexpected char
ALSA lib conf.c:3406 :( config_file_open) /usr/share/alsa/pulse-alsa.conf may be old or corrupted: consider to remove or fix it
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 0: ALC883 Analog [ALC883 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 1: ALC883 Digital [ALC883 Digital]
  Subdevices: 1/1
card 1: DS [Xonar DS], device 0: Multichannel [Multichannel]
  Subdevices: 1/1
card 1: DS [Xonar DS], device 1: Digital [Digital]
  Subdevices: 1/1
card 2: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
  Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 2: ALC883 Analog [ALC883 Analog]
  Subdevices: 1/1
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card 0 [NVidia]
Card hw:0 'NVidia'/'HDA NVidia at 0xf4100000 irq 22'
  Mixer name	: 'Realtek ALC883'
  Components	: 'HDA:10ec0883,1458e601,00100002'
  Controls      : 40
  Simple ctrls  : 22
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined penum
  Playback channels: Mono
  Limits: Playback 0 - 31
  Mono: Playback 31 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pswitch penum
  Playback channels: Front Left - Front Right
  Mono:
  Front Left: Playback [on]
  Front Right: Playback [on]
Simple mixer control 'PCM',0
  Capabilities: pvolume penum
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
  Capabilities: pvolume pswitch penum
  Mono:
  Front Left: Playback 31 [100%] [0.00dB] [on]
  Front Right: Playback 31 [100%] [0.00dB] [on]
Simple mixer control 'Front Mic',0
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
  Capabilities: volume penum
  Capture channels: Front Left - Front Right
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
  Mono:
Simple mixer control 'Center',0
Simple mixer control 'LFE',0
Simple mixer control 'Side',0
  Mono:
Simple mixer control 'Line',0
  Mono:
Simple mixer control 'CD',0
  Mono:
  Front Left: Playback 25 [81%] [3.00dB] [on]
  Front Right: Playback 25 [81%] [3.00dB] [on]
Simple mixer control 'Mic',0
  Mono:
Simple mixer control 'Mic Boost',0
  Limits: 0 - 3
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined cswitch cswitch-joined penum
  Capture channels: Mono
  Mono: Playback [on] Capture [off]
Simple mixer control 'IEC958 Default PCM',0
  Capabilities: pswitch pswitch-joined penum
  Mono: Playback [on]
Simple mixer control 'Beep',0
  Mono:
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch penum
  Limits: Capture 0 - 31
  Front Left: Capture 0 [0%] [-12.00dB] [off]
  Front Right: Capture 0 [0%] [-12.00dB] [off]
Simple mixer control 'Capture',1
Simple mixer control 'Channel Mode',0
  Capabilities: enum
  Items: '6ch' '8ch'
  Item0: '6ch'
Simple mixer control 'Input Source',0
  Capabilities: cenum
  Items: 'Mic' 'Front Mic' 'Line' 'CD'
  Item0: 'Mic'
Simple mixer control 'Input Source',1
  Capabilities: cenum
  Item0: 'Mic'
!!-------Mixer controls for card 1 [DS]
Card hw:1 'DS'/'Asus Virtuoso 66 at 0x9400, irq 17'
  Mixer name	: 'AV200'
  Components	: 'WM8776 WM8766 AV200'
  Controls      : 31
  Simple ctrls  : 25
  Capabilities: pvolume pswitch pswitch-joined penum
  Playback channels: Front Left - Front Right - Rear Left - Rear Right - Front Center - Woofer - Side Left - Side Right
  Limits: Playback 135 - 255
  Mono:
  Front Left: Playback 231 [80%] [-12.00dB] [on]
  Front Right: Playback 231 [80%] [-12.00dB] [on]
  Rear Left: Playback 231 [80%] [-12.00dB] [on]
  Rear Right: Playback 231 [80%] [-12.00dB] [on]
  Front Center: Playback 231 [80%] [-12.00dB] [on]
  Woofer: Playback 231 [80%] [-12.00dB] [on]
  Side Left: Playback 231 [80%] [-12.00dB] [on]
  Side Right: Playback 231 [80%] [-12.00dB] [on]
  Limits: Playback 61 - 127
  Mono:
  Front Left: Playback 108 [71%] [on]
  Front Right: Playback 108 [71%] [on]
  Capabilities: cswitch cswitch-joined penum
  Mono: Capture [off]
  Mono: Capture [off]
  Mono: Capture [off]
  Mono: Playback [off]
Simple mixer control 'Aux',0
  Mono: Capture [off]
Simple mixer control 'ADC Filter',0
  Capabilities: cenum
  Items: 'None' 'High-pass Filter'
  Item0: 'High-pass Filter'
Simple mixer control 'ALC Attack Time',0
  Capabilities: cenum
  Items: '8.40 ms' '16.8 ms' '33.6 ms' '67.2 ms' '134 ms' '269 ms' '538 ms' '1.08 s' '2.15 s' '4.3 s' '8.6 s'
  Item0: '33.6 ms'
Simple mixer control 'ALC Decay Time',0
  Capabilities: cenum
  Items: '33.5 ms' '67.0 ms' '134 ms' '268 ms' '536 ms' '1.07 s' '2.14 s' '4.29 s' '8.58 s' '17.2 s' '34.3 s'
  Item0: '268 ms'
Simple mixer control 'ALC Hold Time',0
  Capabilities: cenum
  Items: '0 ms' '2.67 ms' '5.33 ms' '10.6 ms' '21.3 ms' '42.7 ms' '85.3 ms' '171 ms' '341 ms' '683 ms' '1.37 s' '2.73 s' '5.46 s' '10.9 s' '21.8 s' '43.7 s'
  Item0: '0 ms'
Simple mixer control 'ALC Maximum Attenuation',0
  Capabilities: cvolume cvolume-joined penum
  Limits: Capture 10 - 15
  Mono: Capture 10 [0%] [-21.00dB]
Simple mixer control 'ALC Maximum Gain',0
  Limits: Capture 1 - 7
  Mono: Capture 7 [100%] [24.00dB]
Simple mixer control 'ALC Target Level',0
  Limits: Capture 0 - 15
  Mono: Capture 11 [73%] [-5.00dB]
Simple mixer control 'Analog Input Monitor',0
  Limits: Playback 0 - 1
  Mono: Playback 1 [100%] [0.00dB] [off]
Simple mixer control 'Input',0
  Capabilities: cvolume penum
  Limits: Capture 165 - 255
  Front Left: Capture 165 [0%]
  Front Right: Capture 165 [0%]
Simple mixer control 'Level Control',0
  Capabilities: cenum
  Items: 'None' 'Peak Limiter' 'Automatic Level Control'
  Item0: 'Automatic Level Control'
Simple mixer control 'Noise Gate',0
  Mono: Capture [off]
Simple mixer control 'Noise Gate Threshold',0
  Limits: Capture 0 - 7
  Mono: Capture 0 [0%] [-78.00dB]
Simple mixer control 'Stereo Upmixing',0
  Capabilities: enum
  Items: 'Front' 'Front Surround' 'Front Surround Back' 'Front Surround Center/LFE' 'Front Surround Center/LFE Back'
  Item0: 'Front Surround Center/LFE Back'
!!-------Mixer controls for card 2 [HDMI]
Card hw:2 'HDMI'/'HDA ATI HDMI at 0xf3010000 irq 41'
  Mixer name	: 'ATI R6xx HDMI'
  Components	: 'HDA:1002aa01,00aa0100,00100100'
  Controls      : 5
  Simple ctrls  : 1
  Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.NVidia {
	control.1 {
		iface MIXER
		name 'Front Playback Volume'
		value.0 31
		value.1 31
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -4650
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.2 {
		iface MIXER
		name 'Front Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.3 {
		iface MIXER
		name 'Surround Playback Volume'
		value.0 31
		value.1 31
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -4650
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.4 {
		iface MIXER
		name 'Surround Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.5 {
		iface MIXER
		name 'Center Playback Volume'
		value 31
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 31'
			dbmin -4650
			dbmax 0
			dbvalue.0 0
	control.6 {
		iface MIXER
		name 'LFE Playback Volume'
		value 31
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 31'
			dbmin -4650
			dbmax 0
			dbvalue.0 0
	control.7 {
		iface MIXER
		name 'Center Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.8 {
		iface MIXER
		name 'LFE Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.9 {
		iface MIXER
		name 'Side Playback Volume'
		value.0 31
		value.1 31
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -4650
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.10 {
		iface MIXER
		name 'Side Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.11 {
		iface MIXER
		name 'Headphone Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.12 {
		iface MIXER
		name 'CD Playback Volume'
		value.0 25
		value.1 25
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 300
			dbvalue.1 300
	control.13 {
		iface MIXER
		name 'CD Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.14 {
		iface MIXER
		name 'Line Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.15 {
		iface MIXER
		name 'Line Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.16 {
		iface MIXER
		name 'Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.17 {
		iface MIXER
		name 'Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.18 {
		iface MIXER
		name 'Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.19 {
		iface MIXER
		name 'Front Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.20 {
		iface MIXER
		name 'Front Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.21 {
		iface MIXER
		name 'Front Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.22 {
		iface MIXER
		name 'Channel Mode'
		value '6ch'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 '6ch'
			item.1 '8ch'
	control.23 {
		iface MIXER
		name 'Capture Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.24 {
		iface MIXER
		index 1
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.25 {
		iface MIXER
		name 'Capture Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -1200
			dbmax 3450
			dbvalue.0 -1200
			dbvalue.1 -1200
	control.26 {
		iface MIXER
		index 1
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -1200
			dbmax 3450
			dbvalue.0 -1200
			dbvalue.1 -1200
	control.27 {
		iface MIXER
		name 'Input Source'
		value Mic
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Mic
			item.1 'Front Mic'
			item.2 Line
			item.3 CD
	control.28 {
		iface MIXER
		name 'Input Source'
		index 1
		value Mic
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Mic
			item.1 'Front Mic'
			item.2 Line
			item.3 CD
	control.29 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.30 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.31 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.32 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.33 {
		iface MIXER
		name 'IEC958 Default PCM Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.34 {
		iface MIXER
		name 'IEC958 Capture Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.35 {
		iface MIXER
		name 'IEC958 Capture Default'
		comment {
			access read
			type IEC958
			count 1
	control.36 {
		iface MIXER
		name 'Beep Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.37 {
		iface MIXER
		name 'Beep Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.38 {
		iface MIXER
		name 'Master Playback Volume'
		value 31
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 31'
			dbmin -4650
			dbmax 0
			dbvalue.0 0
	control.39 {
		iface MIXER
		name 'Master Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.40 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
state.DS {
	control.1 {
		iface MIXER
		value.0 231
		value.1 231
		value.2 231
		value.3 231
		value.4 231
		value.5 231
		value.6 231
		value.7 231
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '135 - 255'
			dbmin -6000
			dbmax 0
			dbvalue.0 -1200
			dbvalue.1 -1200
			dbvalue.2 -1200
			dbvalue.3 -1200
			dbvalue.4 -1200
			dbvalue.5 -1200
			dbvalue.6 -1200
			dbvalue.7 -1200
	control.2 {
		iface MIXER
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.3 {
		iface MIXER
		name 'Stereo Upmixing'
		value Front Surround Center/LFE Back
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Front
			item.1 Front Surround
			item.2 Front Surround Back
			item.3 Front Surround Center/LFE
			item.4 Front Surround Center/LFE Back
	control.4 {
		iface MIXER
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.5 {
		iface PCM
		device 1
		value '0482000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.6 {
		iface PCM
		device 1
		value '3eff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.7 {
		iface PCM
		device 1
		name 'IEC958 Playback PCM Stream'
		comment {
			access 'read write inactive'
			type IEC958
			count 1
	control.8 {
		iface MIXER
		name 'Analog Input Monitor Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.9 {
		iface MIXER
		name 'Analog Input Monitor Playback Volume'
		value 1
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 1'
			dbmin -600
			dbmax 0
			dbvalue.0 0
	control.10 {
		iface MIXER
		name 'Headphone Playback Volume'
		value.0 108
		value.1 108
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '61 - 127'
	control.11 {
		iface MIXER
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.12 {
		iface MIXER
		name 'Input Capture Volume'
		value.0 165
		value.1 165
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '165 - 255'
	control.13 {
		iface MIXER
		name 'Line Capture Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.14 {
		iface MIXER
		name 'Mic Capture Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.15 {
		iface MIXER
		name 'Front Mic Capture Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.16 {
		iface MIXER
		name 'Aux Capture Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.17 {
		iface MIXER
		name 'ADC Filter Capture Enum'
		value 'High-pass Filter'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 None
			item.1 'High-pass Filter'
	control.18 {
		iface MIXER
		name 'Level Control Capture Enum'
		value 'Automatic Level Control'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 None
			item.1 'Peak Limiter'
			item.2 'Automatic Level Control'
	control.19 {
		iface MIXER
		name 'Limiter Threshold Capture Volume'
		value 11
		comment {
			type INTEGER
			count 1
			range '0 - 15'
			dbmin -1600
			dbmax -100
			dbvalue.0 -500
	control.20 {
		iface MIXER
		name 'Limiter Attack Time Capture Enum'
		value '1 ms'
		comment {
			type ENUMERATED
			count 1
			item.0 '0.25 ms'
			item.1 '0.5 ms'
			item.2 '1 ms'
			item.3 '2 ms'
			item.4 '4 ms'
			item.5 '8 ms'
			item.6 '16 ms'
			item.7 '32 ms'
			item.8 '64 ms'
			item.9 '128 ms'
			item.10 '256 ms'
	control.21 {
		iface MIXER
		name 'Limiter Decay Time Capture Enum'
		value '9.6 ms'
		comment {
			type ENUMERATED
			count 1
			item.0 '1.2 ms'
			item.1 '2.4 ms'
			item.2 '4.8 ms'
			item.3 '9.6 ms'
			item.4 '19.2 ms'
			item.5 '38.4 ms'
			item.6 '76.8 ms'
			item.7 '154 ms'
			item.8 '307 ms'
			item.9 '614 ms'
			item.10 '1.23 s'
	control.22 {
		iface MIXER
		name 'Limiter Transient Window Capture Enum'
		value '125 us'
		comment {
			type ENUMERATED
			count 1
			item.0 '0 us'
			item.1 '62.5 us'
			item.2 '125 us'
			item.3 '250 us'
			item.4 '500 us'
			item.5 '1 ms'
			item.6 '2 ms'
			item.7 '4 ms'
	control.23 {
		iface MIXER
		name 'Limiter Maximum Attenuation Capture Volume'
		value 6
		comment {
			type INTEGER
			count 1
			range '3 - 12'
			dbmin -1200
			dbmax -300
			dbvalue.0 -900
	control.24 {
		iface MIXER
		name 'ALC Target Level Capture Volume'
		value 11
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 15'
			dbmin -1600
			dbmax -100
			dbvalue.0 -500
	control.25 {
		iface MIXER
		name 'ALC Attack Time Capture Enum'
		value '33.6 ms'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 '8.40 ms'
			item.1 '16.8 ms'
			item.2 '33.6 ms'
			item.3 '67.2 ms'
			item.4 '134 ms'
			item.5 '269 ms'
			item.6 '538 ms'
			item.7 '1.08 s'
			item.8 '2.15 s'
			item.9 '4.3 s'
			item.10 '8.6 s'
	control.26 {
		iface MIXER
		name 'ALC Decay Time Capture Enum'
		value '268 ms'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 '33.5 ms'
			item.1 '67.0 ms'
			item.2 '134 ms'
			item.3 '268 ms'
			item.4 '536 ms'
			item.5 '1.07 s'
			item.6 '2.14 s'
			item.7 '4.29 s'
			item.8 '8.58 s'
			item.9 '17.2 s'
			item.10 '34.3 s'
	control.27 {
		iface MIXER
		name 'ALC Maximum Gain Capture Volume'
		value 7
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '1 - 7'
			dbmin 0
			dbmax 2400
			dbvalue.0 2400
	control.28 {
		iface MIXER
		name 'ALC Maximum Attenuation Capture Volume'
		value 10
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '10 - 15'
			dbmin -2100
			dbmax -100
			dbvalue.0 -2100
	control.29 {
		iface MIXER
		name 'ALC Hold Time Capture Enum'
		value '0 ms'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 '0 ms'
			item.1 '2.67 ms'
			item.2 '5.33 ms'
			item.3 '10.6 ms'
			item.4 '21.3 ms'
			item.5 '42.7 ms'
			item.6 '85.3 ms'
			item.7 '171 ms'
			item.8 '341 ms'
			item.9 '683 ms'
			item.10 '1.37 s'
			item.11 '2.73 s'
			item.12 '5.46 s'
			item.13 '10.9 s'
			item.14 '21.8 s'
			item.15 '43.7 s'
	control.30 {
		iface MIXER
		name 'Noise Gate Capture Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.31 {
		iface MIXER
		name 'Noise Gate Threshold Capture Volume'
		value 0
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 7'
			dbmin -7800
			dbmax -3600
			dbvalue.0 -7800
state.HDMI {
	control.1 {
		iface MIXER
		comment {
			access read
			type IEC958
			count 1
	control.2 {
		iface MIXER
		comment {
			access read
			type IEC958
			count 1
	control.3 {
		iface MIXER
		value '0482000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.4 {
		iface MIXER
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.5 {
		iface PCM
		device 3
		name ELD
		value ''
		comment {
			access read
			type BYTES
			count 0
--endcollapse--
!!All Loaded Modules
Module
powernow_k8
mperf
cpufreq_stats
cpufreq_conservative
cpufreq_powersave
cpufreq_userspace
cryptd
aes_i586
aes_generic
ppdev
lp
bnep
rfcomm
bluetooth
binfmt_misc
nfsd
nfs
nfs_acl
auth_rpcgss
fscache
lockd
sunrpc
loop
firewire_sbp2
arc4
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_virtuoso
radeon
snd_hda_intel
ttm
snd_oxygen_lib
snd_hda_codec
ath9k_htc
snd_mpu401_uart
drm_kms_helper
snd_seq_midi
snd_seq_midi_event
snd_hwdep
snd_rawmidi
ath9k_common
snd_pcm
ath9k_hw
drm
snd_page_alloc
snd_seq
ath
mac80211
power_supply
i2c_algo_bit
pcspkr
i2c_nforce2
evdev
k8temp
snd_seq_device
snd_timer
cfg80211
rfkill
processor
i2c_core
parport_pc
parport
snd
soundcore
button
thermal_sys
ext4
crc16
jbd2
mbcache
usbhid
hid
sd_mod
crc_t10dif
ohci_hcd
ata_generic
floppy
8139too
sata_nv
pata_amd
libata
ehci_hcd
usbcore
8139cp
mii
scsi_mod
firewire_ohci
firewire_core
crc_itu_t
forcedeth
usb_common
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x14 0x01014410
0x15 0x01011412
0x16 0x01016411
0x17 0x01012414
0x18 0x01a19c40
0x19 0x02a19c50
0x1a 0x01813441
0x1b 0x02214c20
0x1c 0x9933014f
0x1d 0x411111f0
0x1e 0x99430130
0x1f 0x99c30160
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC2D0/init_pin_configs:
0x03 0x18560010
/sys/class/sound/hwC2D0/driver_pin_configs:
/sys/class/sound/hwC2D0/user_pin_configs:
/sys/class/sound/hwC2D0/init_verbs:
!!ALSA/HDA dmesg
[    7.871707] ACPI: PCI Interrupt Link [AAZA] enabled at IRQ 22
[    7.871716] snd_hda_intel 0000:00:05.0: PCI INT B -> Link[AAZA] -> GSI 22 (level, low) -> IRQ 22
[    7.871720] hda_intel: Disabling MSI
[    7.871745] snd_hda_intel 0000:00:05.0: setting latency timer to 64
[    7.977180] [drm] radeon kernel modesetting enabled.
[    8.069132] [drm] Connector 1:
[    8.069133] [drm]   HDMI-A
[    8.069135] [drm]   HPD3
[    8.383303] Console: switching to colour frame buffer device 210x65
[    8.385243] input: Xonar DS Headphone as /devices/pci0000:00/0000:00:04.0/0000:01:07.0/sound/card1/input5
[    8.393626] fb0: radeondrmfb frame buffer device
[    8.693777] cfg80211:     (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    8.696135] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:05.0/input/input6
[    8.742540] ath9k_htc 1-4:1.0: ath9k_htc: HTC initialized with 33 credits
[    8.827193] ACPI: PCI Interrupt Link [APC5] enabled at IRQ 16
[    8.827202] snd_hda_intel 0000:02:00.1: PCI INT B -> Link[APC5] -> GSI 16 (level, low) -> IRQ 16
[    8.827269] snd_hda_intel 0000:02:00.1: irq 41 for MSI/MSI-X
[    8.827311] snd_hda_intel 0000:02:00.1: setting latency timer to 64
[    8.878387] HDMI status: Codec=0 Pin=3 Presence_Detect=0 ELD_Valid=0
[    8.878530] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:09.0/0000:02:00.1/sound/card2/input7
[    8.933667] ath9k_htc 1-4:1.0: ath9k_htc: FW Version: 1.3
Nikt nie wie? Przecież tu chyba nawet nie trzeba sterowników instalować.
