Linux debian 3.3-6.slh.1-aptosid-amd64 #1 SMP PREEMPT Sun May 13 00:23:59 UTC 2012 x86_64 GNU/LinuxKod: Zaznacz cały
# dmesg | grep input
[ 1.011959] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.130038] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0A08:00/device:0c/PNP0C0C:00/input/input1
[ 1.130481] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0A08:00/device:0c/PNP0C0D:00/input/input2
[ 1.156166] input: Sleep Button as /devices/LNXSYSTM:00/device:00/PNP0A08:00/device:0c/PNP0C0E:00/input/input3
[ 1.156668] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 2.319340] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:01/input/input5
[ 9.636963] input: PC Speaker as /devices/platform/pcspkr/input/input6
[ 11.046165] input: PS/2 Mouse as /devices/platform/i8042/serio1/input/input7
[ 11.078639] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input8
[ 11.909154] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/rc/rc0/input9
[ 12.491408] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 12.491556] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 12.491653] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 26.766246] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input13Kod: Zaznacz cały
Testing ... (interrupt to exit)
Event: time 1336920144.696359, type 4 (EV_MSC), code 4 (MSC_SCAN), value 866b13
Event: time 1336920144.696362, -------------- SYN_REPORT ------------
Event: time 1336920147.446361, type 4 (EV_MSC), code 4 (MSC_SCAN), value 866b11
Event: time 1336920147.446364, -------------- SYN_REPORT ------------
Event: time 1336920148.446367, type 4 (EV_MSC), code 4 (MSC_SCAN), value 866b1c
Event: time 1336920148.446370, -------------- SYN_REPORT ------------
Event: time 1336920149.196486, type 4 (EV_MSC), code 4 (MSC_SCAN), value 866b12
Event: time 1336920149.196490, -------------- SYN_REPORT ------------Kod: Zaznacz cały
irrecord -H devinput --device=/dev/input/event9 test.confKod: Zaznacz cały
# Please make this file available to others
# by sending it to <lirc@bartelmus.de>
# this config file was automatically generated
# using lirc-0.9.0-pre1(devinput) on Sun May 13 15:11:31 2012
# contributed by
# brand: test.conf
# model no. of remote control:
# devices being controlled by this remote:
begin remote
name test.conf
bits 56
eps 30
aeps 100
one 0 0
zero 0 0
pre_data_bits 8
pre_data 0x0
gap 749986
toggle_bit_mask 0x0
begin codes
KEY_MUTE 0x04000400866B13 0x00000000000000
KEY_EPG 0x04000400866B11 0x00000000000000
KEY_TV 0x04000400866B1C 0x00000000000000
KEY_POWER 0x04000400866B12 0x00000000000000
KEY_1 0x04000400866B01 0x00000000000000
KEY_2 0x04000400866B02 0x00000000000000
KEY_3 0x04000400866B03 0x00000000000000
KEY_AUDIO 0x04000400866B0D 0x00000000000000
KEY_4 0x04000400866B04 0x00000000000000
KEY_5 0x04000400866B05 0x00000000000000
KEY_6 0x04000400866B06 0x00000000000000
KEY_PRINT 0x04000400866B19 0x00000000000000
KEY_7 0x04000400866B07 0x00000000000000
KEY_8 0x04000400866B08 0x00000000000000
KEY_9 0x04000400866B09 0x00000000000000
KEY_ZOOM 0x04000400866B10 0x00000000000000
KEY_BACK 0x04000400866B0A 0x00000000000000
KEY_0 0x04000400866B00 0x00000000000000
KEY_CHANNELUP 0x04000400866B0B 0x00000000000000
KEY_VOLUMEUP 0x04000400866B0C 0x00000000000000
KEY_TEXT 0x04000400866B1B 0x00000000000000
KEY_RECORD 0x04000400866B1D 0x00000000000000
KEY_CHANNELDOWN 0x04000400866B15 0x00000000000000
KEY_VOLUMEDOWN 0x04000400866B18 0x00000000000000
KEY_STOP 0x04000400866B0E 0x00000000000000
KEY_PAUSE 0x04000400866B1E 0x00000000000000
KEY_REWIND 0x04000400866B0F 0x00000000000000
KEY_FORWARD 0x04000400866B1A 0x00000000000000
end codes
end remote
# /etc/lirc/hardware.conf
# Arguments which will be used when launching lircd
LIRCD_ARGS=""
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD=false
#Don't start irexec, even if a good config file seems to exist.
#START_IREXEC=false
#Try to load appropriate kernel modules
LOAD_MODULES=true
# Run "lircd --driver=help" for a list of supported drivers.
DRIVER="dev/input"
# usually /dev/lirc0 is the correct setting for systems using udev
DEVICE="/dev/input/event9"
MODULES=""
# Default configuration files for your hardware if any
LIRCD_CONF=""
LIRCMD_CONF=""Kod: Zaznacz cały
l# /etc/init.d/lirc start
[ ok ] Loading LIRC modules:.
[ ok ] Starting remote control daemon(s) : LIRC :.Macie jakiś pomysł co tutaj może być nie tak?
