Jul 4 09:02:07 atrium-gw postfix/pickup[25559]: EAA7515C001: uid=106 from=<logcheck>
Jul 4 09:02:07 atrium-gw postfix/cleanup[26681]: EAA7515C001: message-id=<20070704070207.EAA7515C001@atrium-gw>
Jul 4 09:02:07 atrium-gw postfix/qmgr[2986]: EAA7515C001: from=<logcheck@atrium-gw>, size=12535, nrcpt=1 (queue active)
Jul 4 09:02:08 atrium-gw postfix/local[26685]: EAA7515C001: to=<admin@atrium-gw>, orig_to=<root>, relay=local, delay=1, statu
s=sent (delivered to command: procmail -a "$EXTENSION")
Jul 4 09:02:08 atrium-gw postfix/qmgr[2986]: EAA7515C001: removed
Jul 4 10:02:09 atrium-gw postfix/pickup[25559]: 536C64F6A45: uid=106 from=<logcheck>
Jul 4 10:02:09 atrium-gw postfix/cleanup[613]: 536C64F6A45: message-id=<20070704080209.536C64F6A45@atrium-gw>
Jul 4 10:02:09 atrium-gw postfix/qmgr[2986]: 536C64F6A45: from=<logcheck@atrium-gw>, size=15271, nrcpt=1 (queue active)
Jul 4 10:02:09 atrium-gw postfix/local[617]: 536C64F6A45: to=<admin@atrium-gw>, orig_to=<root>, relay=local, delay=0, status=
Jul 4 10:02:09 atrium-gw postfix/qmgr[2986]: 536C64F6A45: removed
Jul 4 10:17:11 atrium-gw postfix/smtpd[2084]: connect from r_caffe[192.168.100.50]
Jul 4 10:17:11 atrium-gw postfix/smtpd[2084]: NOQUEUE: reject: RCPT from r_caffe[192.168.100.50]: 554 <
raczkowski1@op.pl>: Re
lay access denied; from=<
admin@atrium-pc.pl> to=<
raczkowski1@op.pl> proto=ESMTP helo=<[127.0.0.1]>
Jul 4 10:17:19 atrium-gw postfix/smtpd[2084]: disconnect from r_caffe[192.168.100.50]
Jul 4 10:23:29 atrium-gw postfix/smtpd[2586]: connect from r_caffe[192.168.100.50]
Jul 4 10:23:29 atrium-gw postfix/smtpd[2586]: lost connection after CONNECT from r_caffe[192.168.100.50]
Jul 4 10:23:29 atrium-gw postfix/smtpd[2586]: disconnect from r_caffe[192.168.100.50]
Jul 4 10:23:30 atrium-gw postfix/smtpd[2586]: connect from r_caffe[192.168.100.50]
Jul 4 10:23:30 atrium-gw postfix/smtpd[2586]: lost connection after CONNECT from r_caffe[192.168.100.50]
Jul 4 10:23:30 atrium-gw postfix/smtpd[2586]: disconnect from r_caffe[192.168.100.50]
Jul 4 11:02:11 atrium-gw postfix/pickup[3621]: 66E074F5896: uid=106 from=<logcheck>
Jul 4 11:02:11 atrium-gw postfix/cleanup[7294]: 66E074F5896: message-id=<20070704090211.66E074F5896@atrium-gw>
Jul 4 11:02:11 atrium-gw postfix/qmgr[2986]: 66E074F5896: from=<logcheck@atrium-gw>, size=17607, nrcpt=1 (queue active)
Jul 4 11:02:11 atrium-gw postfix/local[7298]: 66E074F5896: to=<admin@atrium-gw>, orig_to=<root>, relay=local, delay=0, status
Jul 4 11:02:11 atrium-gw postfix/qmgr[2986]: 66E074F5896: removed
Jul 4 12:02:10 atrium-gw postfix/pickup[3621]: 274104F587E: uid=106 from=<logcheck>
Jul 4 12:02:10 atrium-gw postfix/cleanup[13924]: 274104F587E: message-id=<20070704100209.274104F587E@atrium-gw>
Jul 4 12:02:10 atrium-gw postfix/qmgr[2986]: 274104F587E: from=<logcheck@atrium-gw>, size=27078, nrcpt=1 (queue active)
Jul 4 12:02:10 atrium-gw postfix/local[13928]: 274104F587E: to=<admin@atrium-gw>, orig_to=<root>, relay=local, delay=1, statu
Jul 4 12:02:10 atrium-gw postfix/qmgr[2986]: 274104F587E: removed
Jul 4 13:02:09 atrium-gw postfix/pickup[14937]: C8D3215C001: uid=106 from=<logcheck>
Jul 4 13:02:09 atrium-gw postfix/cleanup[20468]: C8D3215C001: message-id=<20070704110209.C8D3215C001@atrium-gw>
Jul 4 13:02:09 atrium-gw postfix/qmgr[2986]: C8D3215C001: from=<logcheck@atrium-gw>, size=44284, nrcpt=1 (queue active)
Jul 4 13:02:10 atrium-gw postfix/local[20472]: C8D3215C001: to=<admin@atrium-gw>, orig_to=<root>, relay=local, delay=1, statu
Jul 4 13:02:10 atrium-gw postfix/qmgr[2986]: C8D3215C001: removed
Jul 4 13:02:48 atrium-gw postfix/pickup[14937]: E14E615C001: uid=33 from=<www-data>
Jul 4 13:02:48 atrium-gw postfix/cleanup[20468]: E14E615C001: message-id=<20070704110248.E14E615C001@atrium-gw>
Jul 4 13:02:48 atrium-gw postfix/qmgr[2986]: E14E615C001: from=<www-data@atrium-gw>, size=656, nrcpt=2 (queue active)
Jul 4 13:02:51 atrium-gw postfix/smtp[20486]: E14E615C001: to=<
admin@atrium-pc.pl>, relay=atrium-pc.home.pl[212.85.124.158],
