Postanowiłem zmienić oprogramowanie, z apache na nginksa i już na samym początku coś nie działa.
Otóż, żadna strona w php (skrypty np. mybb czy WP) oprócz phpinfo nie działa - wyświetla wewnętrzny błąd serwera. No i działa jeszcze ispconfig.
Mój system to Debian 6, 64 bit. Po uruchomieniu tego wszystkiego zostaje jeszcze ponad 1,5 B wolnej pamięci ram. Na cały katalog z plikami www ustawiłem tymczasowo prawa dostępu 755.
Oto moje pliki konfiguracyjne.
nginx.conf
user www-data;
worker_processes 4;
pid /var/run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# server_names_hash_bucket_size 64;
# server_name_in_redirect off;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# Logging Settings
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# Gzip Settings
gzip on;
gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/x-javascript text/xml application/xml application/xml+rss text/javascript;
# nginx-naxsi config
# Uncomment it if you installed nginx-naxsi
#include /etc/nginx/naxsi_core.rules;
# nginx-passenger config
# Uncomment it if you installed nginx-passenger
#passenger_root /usr;
#passenger_ruby /usr/bin/ruby;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
## Detect when HTTPS is used
map $scheme $fastcgi_https {
default off;
https on;
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
php5-fpm.conf
; FPM Configuration ;
; All relative paths in this configuration file are relative to PHP's install
; prefix (/usr). This prefix can be dynamicaly changed by using the
; '-p' argument from the command line.
; Include one or more files. If glob(3) exists, it is used to include a bunch of
; files from a glob(3) pattern. This directive can be used everywhere in the
; file.
; Relative path can also be used. They will be prefixed by:
; - the global prefix if it's been set (-p arguement)
; - /usr otherwise
;include=/etc/php5/fpm/*.conf
; Global Options ;
[global]
; Pid file
; Note: the default prefix is /var
; Default Value: none
pid = /var/run/php5-fpm.pid
; Error log file
; If it's set to "syslog", log is sent to syslogd instead of being written
; in a local file.
; Default Value: log/php-fpm.log
error_log = /var/log/php5-fpm.log
; syslog_facility is used to specify what type of program is logging the
; message. This lets syslogd specify that messages from different facilities
; will be handled differently.
; See syslog(3) for possible values (ex daemon equiv LOG_DAEMON)
; Default Value: daemon
;syslog.facility = daemon
; syslog_ident is prepended to every message. If you have multiple FPM
; instances running on the same server, you can change the default value
; which must suit common needs.
; Default Value: php-fpm
;syslog.ident = php-fpm
; Log level
; Possible Values: alert, error, warning, notice, debug
; Default Value: notice
log_level = debug
; If this number of child processes exit with SIGSEGV or SIGBUS within the time
; interval set by emergency_restart_interval then FPM will restart. A value
; of '0' means 'Off'.
; Default Value: 0
;emergency_restart_threshold = 0
; Interval of time used by emergency_restart_interval to determine when
; a graceful restart will be initiated. This can be useful to work around
; accidental corruptions in an accelerator's shared memory.
; Available Units: s(econds), m(inutes), h(ours), or d(ays)
; Default Unit: seconds
; Default Value: 0
;emergency_restart_interval = 0
; Time limit for child processes to wait for a reaction on signals from master.
; Available units: s(econds), m(inutes), h(ours), or d(ays)
; Default Value: 0
;process_control_timeout = 0
; The maximum number of processes FPM will fork. This has been design to control
; the global number of processes when using dynamic PM within a lot of pools.
; Use it with caution.
; Note: A value of 0 indicates no limit
; Default Value: 0
; process.max = 128
; Send FPM to background. Set to 'no' to keep FPM in foreground for debugging.
; Default Value: yes
;daemonize = yes
; Set open file descriptor rlimit for the master process.
; Default Value: system defined value
;rlimit_files = 1024
; Set max core size rlimit for the master process.
; Possible Values: 'unlimited' or an integer greater or equal to 0
;rlimit_core = 0
; Specify the event mechanism FPM will use. The following is available:
; - select (any POSIX os)
; - poll (any POSIX os)
; - epoll (linux >= 2.5.44)
; - kqueue (FreeBSD >= 4.1, OpenBSD >= 2.9, NetBSD >= 2.0)
; - /dev/poll (Solaris >= 7)
; - port (Solaris >= 10)
; Default Value: not set (auto detection)
; events.mechanism = epoll
; Pool Definitions ;
; Multiple pools of child processes may be started with different listening
; ports and different management options. The name of the pool will be
; used in logs and stats. There is no limitation on the number of pools which
; FPM can handle. Your system will tell you anyway :)
; To configure the pools it is recommended to have one .conf file per
; pool in the following directory:
include=/etc/php5/fpm/pool.d/*.conf
Wirtualny host z sites-enabled:
server {
listen *:80;
server_name ghst.pl www.ghst.pl;
root /var/www/ghst.pl/web;
index index.html index.htm index.php index.cgi index.pl index.xhtml;
error_page 400 /error/400.html;
error_page 401 /error/401.html;
error_page 403 /error/403.html;
error_page 404 /error/404.html;
error_page 405 /error/405.html;
error_page 500 /error/500.html;
error_page 502 /error/502.html;
error_page 503 /error/503.html;
recursive_error_pages on;
location = /error/400.html {
internal;
location = /error/401.html {
internal;
location = /error/403.html {
internal;
location = /error/404.html {
internal;
location = /error/405.html {
internal;
location = /error/500.html {
internal;
location = /error/502.html {
internal;
location = /error/503.html {
internal;
error_log /var/log/ispconfig/httpd/ghst.pl/error.log;
access_log /var/log/ispconfig/httpd/ghst.pl/access.log combined;
## Disable .htaccess and other hidden files
location ~ /\. {
deny all;
access_log off;
log_not_found off;
location = /favicon.ico {
log_not_found off;
access_log off;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location /stats {
index index.html index.php;
auth_basic "Members Only";
auth_basic_user_file /var/www/clients/client1/web2/.htpasswd_stats;
location ^~ /awstats-icon {
alias /usr/share/awstats/icon;
location ~ \.php$ {
try_files $uri =404;
include /etc/nginx/fastcgi_params;
fastcgi_pass 127.0.0.1:9011;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_param PATH_INFO $fastcgi_script_name;
fastcgi_intercept_errors on;
}Log php5-fpm przy włączonym debugowaniu (restart php5-fpm i wejście na adres, pod którym znajduje się mybb):
[23-Apr-2012 16:58:26.596604] DEBUG: pid 2029, fpm_scoreboard_init_main(), line 40: got clock tick '100'
[23-Apr-2012 16:58:26.597308] DEBUG: pid 2029, fpm_event_init_main(), line 331: event module is epoll and 1 fds have been reserved
[23-Apr-2012 16:58:26.597340] NOTICE: pid 2029, fpm_init(), line 80: fpm is running, pid 2029
[23-Apr-2012 16:58:26.597940] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2030 started
[23-Apr-2012 16:58:26.598383] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2031 started
[23-Apr-2012 16:58:26.607241] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2033 started
[23-Apr-2012 16:58:26.607921] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2034 started
[23-Apr-2012 16:58:26.608378] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2035 started
[23-Apr-2012 16:58:26.609210] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2036 started
[23-Apr-2012 16:58:26.609744] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2037 started
[23-Apr-2012 16:58:26.610204] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2038 started
[23-Apr-2012 16:58:26.615348] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2040 started
[23-Apr-2012 16:58:26.615935] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2041 started
[23-Apr-2012 16:58:26.616408] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2043 started
[23-Apr-2012 16:58:26.616873] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2044 started
[23-Apr-2012 16:58:26.617306] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2045 started
[23-Apr-2012 16:58:26.617732] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2046 started
[23-Apr-2012 16:58:26.623620] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2048 started
[23-Apr-2012 16:58:26.624232] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2049 started
[23-Apr-2012 16:58:26.624772] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2050 started
[23-Apr-2012 16:58:26.625300] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2051 started
[23-Apr-2012 16:58:26.626621] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2052 started
[23-Apr-2012 16:58:26.627276] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web2] child 2054 started
[23-Apr-2012 16:58:26.627740] DEBUG: pid 2029, fpm_children_make(), line 421: [pool apps] child 2055 started
[23-Apr-2012 16:58:26.628192] DEBUG: pid 2029, fpm_children_make(), line 421: [pool apps] child 2056 started
[23-Apr-2012 16:58:26.628643] DEBUG: pid 2029, fpm_children_make(), line 421: [pool ispconfig] child 2057 started
[23-Apr-2012 16:58:26.629076] DEBUG: pid 2029, fpm_children_make(), line 421: [pool ispconfig] child 2058 started
[23-Apr-2012 16:58:26.629506] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2059 started
[23-Apr-2012 16:58:26.639026] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2060 started
[23-Apr-2012 16:58:26.639641] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2061 started
[23-Apr-2012 16:58:26.640079] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2062 started
[23-Apr-2012 16:58:26.640539] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2063 started
[23-Apr-2012 16:58:26.641018] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2064 started
[23-Apr-2012 16:58:26.641495] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2065 started
[23-Apr-2012 16:58:26.644167] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2066 started
[23-Apr-2012 16:58:26.644759] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2067 started
[23-Apr-2012 16:58:26.645198] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2068 started
[23-Apr-2012 16:58:26.645635] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2069 started
[23-Apr-2012 16:58:26.651470] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2070 started
[23-Apr-2012 16:58:26.652032] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2071 started
[23-Apr-2012 16:58:26.652470] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2072 started
[23-Apr-2012 16:58:26.653881] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2073 started
[23-Apr-2012 16:58:26.654485] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2074 started
[23-Apr-2012 16:58:26.654936] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2075 started
[23-Apr-2012 16:58:26.664921] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2076 started
[23-Apr-2012 16:58:26.665531] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2077 started
[23-Apr-2012 16:58:26.665982] DEBUG: pid 2029, fpm_children_make(), line 421: [pool web3] child 2078 started
[23-Apr-2012 16:58:26.666424] DEBUG: pid 2029, fpm_children_make(), line 421: [pool www] child 2079 started
[23-Apr-2012 16:58:26.675565] DEBUG: pid 2029, fpm_children_make(), line 421: [pool www] child 2080 started
[23-Apr-2012 16:58:26.675599] DEBUG: pid 2029, fpm_event_loop(), line 360: 147520 bytes have been reserved in SHM
[23-Apr-2012 16:58:26.675604] NOTICE: pid 2029, fpm_event_loop(), line 361: ready to handle connections
[23-Apr-2012 16:58:27.676450] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:27.676479] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:27.676484] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:27.676489] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:27.676493] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:28.676818] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:28.676850] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:28.676854] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:28.676859] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:28.676864] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:29.676837] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:29.676868] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:29.676872] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:29.676878] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:29.676894] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:30.677564] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:30.677595] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:30.677600] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:30.677605] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:30.677609] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:31.677807] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:31.677829] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:31.677833] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:31.677838] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:31.677843] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:32.678571] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:32.678592] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:32.678596] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:32.678602] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:32.678606] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:33.681568] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:33.681593] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:33.681598] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:33.681603] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:33.681619] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:34.681712] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:34.681745] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:34.681749] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:34.681755] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:34.681759] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:35.683013] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:35.683043] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:35.683047] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:35.683052] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:35.683057] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:36.683618] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:36.683648] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:36.683652] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:36.683657] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:36.683662] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:37.683694] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:37.683719] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:37.683723] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:37.683728] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:37.683733] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:38.683732] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:38.683759] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:38.683763] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:38.683768] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:38.683772] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:39.684695] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:39.684725] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:39.684729] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:39.684734] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:39.684739] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:40.693735] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:40.693767] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:40.693772] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:40.693777] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:40.693781] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:41.698447] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:41.698473] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:41.698477] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:41.698482] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:41.698486] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:42.698690] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:42.698723] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:42.698728] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:42.698733] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:42.698738] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:43.698891] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:43.698923] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:43.698928] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:43.698933] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:43.698937] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:44.699696] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:44.699733] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:44.699738] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:44.699743] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:44.699748] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:45.701664] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:45.701701] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:45.701705] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:45.701710] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:45.701714] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:46.704803] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:46.704833] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:46.704848] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:46.704854] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:46.704858] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:47.705710] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:47.705740] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:47.705744] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:47.705750] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:47.705754] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:48.706815] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:48.706838] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:48.706842] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:48.706847] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:48.706852] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:49.706820] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web2] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:49.706849] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool apps] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:49.706854] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool ispconfig] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
[23-Apr-2012 16:58:49.706859] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool web3] currently 0 active children, 20 spare children, 20 running children. Spawning rate 1
[23-Apr-2012 16:58:49.706863] DEBUG: pid 2029, fpm_pctl_perform_idle_server_maintenance(), line 379: [pool www] currently 0 active children, 2 spare children, 2 running children. Spawning rate 1
