Mam problem z postfiksem. Po instalacji według poradnika dostępnego na forum nie wychodzi poczta na zewnętrzne domeny. Odbieranie działa ze wszystkich domen. Wewnątrz domeny mogę wysyłać. W logach jest zapis:
Relay access deniedKod: Zaznacz cały
2012-04-19 09:59:02 auth(default): Info: new auth connection: pid=5890Apr 19 09:59:03 uran postfix/smtpd[5890]: warning: 102.1.27.172.list.dsbl.org: RBL lookup error: Host or domain name not found. Name service error for name=102.1.27.172.list.dsbl.org type=A: Host not found, try again
Apr 19 09:59:03 uran postfix/smtpd[5890]: NOQUEUE: reject: RCPT from unknown[172.27.1.102]: 554 5.7.1 <zamowienia@autkoplus.com>: Relay access denied; from=<michal@domena.pl> to=<xxx@o2.pl> proto=ESMTP helo=<michalPC>
Apr 19 09:59:05 uran postfix/smtpd[5890]: disconnect from unknown[172.27.1.102]
command_directory = /usr/sbinmail_owner = postfix
mydomain = domena.pl
myhostname = uran.domena.pl
myorigin = wajbex.pl
mydestination = $mydomain, $myhostname, localhost, localhost.localdomain, localhost.$mydomain
mynetworks = 192.168.0.0/24 127.0.0.0/8
inet_interfaces = all
inet_protocols = ipv4
home_mailbox = Maildir/
mail_spool_directory = /home/
smtpd_banner = ESMTP on $myhostname !
mailbox_size_limit = 0
recipient_delimiter = +
biff = no
append_dot_mydomain = no
relayhost =
UTH SMTPsmtpd_sasl_type = dovecot
smtpd_sasl_auth_enable = yes
smtpd_sasl2_auth_enable = yes
smtpd_sasl_security_options = noanonymous
smtpd_sasl_local_domain = $myhostname
smtpd_recipient_restrictions =
permit_mynetworks,
permit_sasl_authenticated,
reject_unauth_destination,
reject_unknown_recipient_domain,
reject_non_fqdn_recipient
smtpd_client_restrictions =
#reject_unknown_client,
reject_rbl_client dul.dnsbl.sorbs.net,
reject_rbl_client list.dsbl.org,
reject_rbl_client sbl.spamhaus.org,
reject_rbl_client cbl.abuseat.org
smtpd_sender_restrictions =
reject_unknown_sender_domain,
reject_non_fqdn_sender,
reject_unknown_address
#TLS
smtpd_tls_auth_only = yes
smtp_use_tls = yes
smtpd_use_tls = yes
smtp_tls_note_starttls_offer = yes
smtpd_tls_key_file = /etc/postfix/ssl/mail.pem
smtpd_tls_cert_file = /etc/postfix/ssl/mail.pem
smtpd_tls_CAfile = /etc/postfix/ssl/mail.pem
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
smtpd_tls_session_cache_database = btree:${queue_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${queue_directory}/smtp_scache
tls_random_source = dev:/dev/urandom
Temat do zamknięcia,okazuje się, że błędnie był wpisany adres w pliku /etc/postfix/main.cf w linii:
mynetworks =
