Mam problem z konfiguracja xorga dla sterowników nvidii nie mogę w ogóle uruchomić x-ów, mam zainstalowanie sterowniki nvidii i moim celem jest skłonienie sprzętu żeby współpracował ze mną w natywnej rozdzielczości monitora 1366x768, a nie w takiej jak obecnie 1024x768.
Jądro:
uname -r
2.6.32-5-amd64
lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation Sandy Bridge Integrated Graphics Controller (rev 09)
01:00.0 VGA compatible controller: nVidia Corporation Device 1051 (rev a1)
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 295.40 (buildmeister@swio-display-x86-rhel47-06.nvidia.com) Thu Apr 5 22:40:54 PDT 2012
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
X.Org X Server 1.7.7
Release Date: 2010-05-04
Build Operating System: Linux 3.0.0-1-amd64 x86_64 Debian
Current Operating System: Linux camrip-deb 2.6.32-5-amd64 #1 SMP Mon Jan 16 16:22:28 UTC 2012 x86_64
Kernel command line: BOOT_IMAGE=/vmlinuz-2.6.32-5-amd64 root=UUID=2d9037af-6764-469c-9f43-e4448fcb150f ro quiet
Build Date: 29 October 2011 06:58:14PM
xorg-server 2:1.7.7-14 (Julien Cristau <jcristau@debian.org>)
Current version of pixman: 0.16.4
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Apr 14 20:17:20 2012
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(==) ServerLayout "Layout0"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Device0"
(**) |-->Input Device "Keyboard0"
(**) |-->Input Device "Mouse0"
Entry deleted from font path.
(WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
(WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
(WW) `fonts.dir' not found (or not valid) in "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType".
(Run 'mkfontdir' on "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType").
(==) FontPath set to:
/usr/share/fonts/X11/misc,
built-ins
(WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
(WW) Disabling Keyboard0
(WW) Disabling Mouse0
(II) Loader magic: 0x7c8a40
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(--) using VT number 7
(--) PCI:*(0:0:2:0) 8086:0116:1043:1682 Intel Corporation Sandy Bridge Integrated Graphics Controller rev 9, Mem @ 0xdc400000/4194304, 0xb0000000/268435456, I/O @ 0x0000e000/64
(--) PCI: (0:1:0:0) 10de:1051:1043:1762 nVidia Corporation rev 161, Mem @ 0xdb000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/524288
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
compiled for 1.7.7, module version = 1.0.0
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA GLX Module 295.40 Thu Apr 5 21:57:38 PDT 2012
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
(II) NVIDIA dlloader X Driver 295.40 Thu Apr 5 21:38:35 PDT 2012
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 00@00:02:0
(EE) No devices detected.
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
Jeszcze mogę dodać, że jestem w stanie uruchomić x-y lecz wcześniej muszę usunąć xorga z /etc/X11 i wtedy wygląda to tak:
ls /etc/X11/
app-defaults fonts X xkb Xreset.d Xsession Xsession.options Xwrapper.config
fluxbox rgb.txt xinit Xreset Xresources Xsession.d XvMCConfig
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Apr 14 20:18:33 2012
(==) No Layout section. Using the first Screen section.
(==) No screen section available. Using defaults.
(**) |-->Screen "Default Screen Section" (0)
(**) | |-->Monitor "<default monitor>"
(==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
built-ins
(II) The server relies on udev to provide the list of input devices.
(==) Matched intel as autoconfigured driver 0
(==) Matched vesa as autoconfigured driver 1
(==) Matched fbdev as autoconfigured driver 2
(==) Assigned the driver to the xf86ConfigLayout
(II) LoadModule: "intel"
(II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
(II) Module intel: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 2.13.0
ABI class: X.Org Video Driver, version 6.0
(II) LoadModule: "vesa"
(II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
(II) Module vesa: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 2.3.0
(II) LoadModule: "fbdev"
(II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) Module fbdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 0.4.2
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
Sandybridge, Sandybridge, Sandybridge, Sandybridge, Sandybridge,
(II) VESA: driver for VESA chipsets: vesa
(II) FBDEV: driver for framebuffer: fbdev
(WW) Falling back to old probe method for fbdev
(II) Loading sub module "fbdevhw"
(II) LoadModule: "fbdevhw"
(II) Loading /usr/lib/xorg/modules/linux/libfbdevhw.so
(II) Module fbdevhw: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 0.0.2
(EE) open /dev/fb0: No such file or directory
(II) Loading sub module "vbe"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) VESA(0): initializing int10
(II) VESA(0): Primary V_BIOS segment is: 0xc000
(II) VESA(0): VESA BIOS detected
(II) VESA(0): VESA VBE Version 3.0
(II) VESA(0): VESA VBE Total Mem: 65472 kB
(II) VESA(0): VESA VBE OEM: Intel(R)Sandybridge Mobile Graphics Chipset Accelerated VGA BIOS
(II) VESA(0): VESA VBE OEM Software Rev: 1.0
(II) VESA(0): VESA VBE OEM Vendor: Intel Corporation
(II) VESA(0): VESA VBE OEM Product: Intel(R)Sandybridge Mobile Graphics Controller
(II) VESA(0): VESA VBE OEM Product Rev: Hardware Version 0.0
(II) VESA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
(==) VESA(0): Depth 24, (--) framebuffer bpp 32
(==) VESA(0): RGB weight 888
(==) VESA(0): Default visual is TrueColor
(==) VESA(0): Using gamma correction (1.0, 1.0, 1.0)
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Module "ddc" already built-in
(II) VESA(0): VESA VBE DDC supported
(II) VESA(0): VESA VBE DDC Level 2
(II) VESA(0): VESA VBE DDC transfer in appr. 1 sec.
(II) VESA(0): VESA VBE DDC read successfully
(II) VESA(0): Manufacturer: LGD Model: 2dc Serial#: 0
(II) VESA(0): Year: 2010 Week: 0
(II) VESA(0): EDID Version: 1.3
(II) VESA(0): Digital Display Input
(II) VESA(0): Max Image Size [cm]: horiz.: 34 vert.: 19
(II) VESA(0): Gamma: 2.20
(II) VESA(0): No DPMS capabilities specified
(II) VESA(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
(II) VESA(0): First detailed timing is preferred mode
(II) VESA(0): redX: 0.623 redY: 0.369 greenX: 0.346 greenY: 0.610
(II) VESA(0): blueX: 0.148 blueY: 0.098 whiteX: 0.313 whiteY: 0.329
(II) VESA(0): Manufacturer's mask: 0
(II) VESA(0): Supported detailed timing:
(II) VESA(0): clock: 70.0 MHz Image Size: 344 x 194 mm
(II) VESA(0): h_active: 1366 h_sync: 1402 h_sync_end 1450 h_blank_end 1492 h_border: 0
(II) VESA(0): v_active: 768 v_sync: 771 v_sync_end 776 v_blanking: 782 v_border: 0
(II) VESA(0): LG Display
(II) VESA(0): LP156WH4-TLA1
(II) VESA(0): EDID (in hex):
(II) VESA(0): 00ffffffffffff0030e4dc0200000000
(II) VESA(0): 00140103802213780aa9059f5e589c26
(II) VESA(0): 19505400000001010101010101010101
(II) VESA(0): 010101010101581b567e50000e302430
(II) VESA(0): 350058c2100000190000000000000000
(II) VESA(0): 00000000000000000000000000fe004c
(II) VESA(0): 4720446973706c61790a2020000000fe
(II) VESA(0): 004c503135365748342d544c41310079
(II) VESA(0): EDID vendor "LGD", prod id 732
(II) VESA(0): Printing DDC gathered Modelines:
(II) VESA(0): Modeline "1366x768"x0.0 70.00 1366 1402 1450 1492 768 771 776 782 -hsync -vsync (46.9 kHz)
(II) VESA(0): Searching for matching VESA mode(s):
Mode: 160 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
GreenFieldPosition: 0
BlueMaskSize: 0
BlueFieldPosition: 0
RsvdMaskSize: 0
RsvdFieldPosition: 0
DirectColorModeInfo: 0
PhysBasePtr: 0x0
LinBytesPerScanLine: 0
BnkNumberOfImagePages: 0
LinNumberOfImagePages: 0
LinRedMaskSize: 0
LinRedFieldPosition: 0
LinGreenMaskSize: 0
LinGreenFieldPosition: 0
LinBlueMaskSize: 0
LinBlueFieldPosition: 0
LinRsvdMaskSize: 0
LinRsvdFieldPosition: 0
MaxPixelClock: 0
Mode: 161 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 162 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 163 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 164 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 165 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 166 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 167 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 168 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 169 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 16a (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 16b (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 16c (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 16d (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 16e (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 16f (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 170 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 171 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 13c (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 14d (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 15c (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 13a (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 14b (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 15a (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 107 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 11a (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 11b (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 105 (1024x768)
ModeAttributes: 0x9b
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
WinFuncPtr: 0xc000863f
BytesPerScanline: 1024
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 84
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0xb0000000
LinBytesPerScanLine: 1024
BnkNumberOfImagePages: 84
LinNumberOfImagePages: 84
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 230000000
Mode: 117 (1024x768)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 2048
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 41
RedMaskSize: 5
RedFieldPosition: 11
GreenMaskSize: 6
GreenFieldPosition: 5
BlueMaskSize: 5
RsvdMaskSize: 0
LinBytesPerScanLine: 2048
BnkNumberOfImagePages: 41
LinNumberOfImagePages: 41
LinRedMaskSize: 5
LinRedFieldPosition: 11
LinGreenMaskSize: 6
LinGreenFieldPosition: 5
LinBlueMaskSize: 5
LinRsvdMaskSize: 0
*Mode: 118 (1024x768)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 4096
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 20
RedMaskSize: 8
RedFieldPosition: 16
GreenMaskSize: 8
GreenFieldPosition: 8
BlueMaskSize: 8
RsvdMaskSize: 8
RsvdFieldPosition: 24
LinBytesPerScanLine: 4096
BnkNumberOfImagePages: 20
LinNumberOfImagePages: 20
LinRedMaskSize: 8
LinRedFieldPosition: 16
LinGreenMaskSize: 8
LinGreenFieldPosition: 8
LinBlueMaskSize: 8
LinRsvdMaskSize: 8
LinRsvdFieldPosition: 24
*Mode: 112 (640x480)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 2560
XResolution: 640
YResolution: 480
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 52
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 8
LinBytesPerScanLine: 2560
BnkNumberOfImagePages: 52
LinNumberOfImagePages: 52
LinRedMaskSize: 8
LinGreenMaskSize: 8
LinBlueMaskSize: 8
LinRsvdMaskSize: 8
Mode: 114 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 1600
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 67
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
LinBytesPerScanLine: 1600
BnkNumberOfImagePages: 67
LinNumberOfImagePages: 67
LinRedMaskSize: 5
LinGreenMaskSize: 6
LinBlueMaskSize: 5
LinRsvdMaskSize: 0
*Mode: 115 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 3200
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 33
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 8
LinBytesPerScanLine: 3200
BnkNumberOfImagePages: 33
LinNumberOfImagePages: 33
LinRedMaskSize: 8
LinGreenMaskSize: 8
LinBlueMaskSize: 8
LinRsvdMaskSize: 8
Mode: 101 (640x480)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 640
XResolution: 640
YResolution: 480
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 203
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
LinBytesPerScanLine: 640
BnkNumberOfImagePages: 203
LinNumberOfImagePages: 203
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
Mode: 103 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 832
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 126
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
LinBytesPerScanLine: 832
BnkNumberOfImagePages: 126
LinNumberOfImagePages: 126
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
Mode: 111 (640x480)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 1280
XResolution: 640
YResolution: 480
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 101
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
LinBytesPerScanLine: 1280
BnkNumberOfImagePages: 101
LinNumberOfImagePages: 101
LinRedMaskSize: 5
LinGreenMaskSize: 6
LinBlueMaskSize: 5
LinRsvdMaskSize: 0
(II) VESA(0): Total Memory: 1023 64KB banks (65472kB)
(II) VESA(0): <default monitor>: Using hsync value of 46.92 kHz
(II) VESA(0): <default monitor>: Using vrefresh value of 60.00 Hz
(WW) VESA(0): Unable to estimate virtual size
(II) VESA(0): Not using built-in mode "1024x768" (no mode of this name)
(II) VESA(0): Not using built-in mode "800x600" (no mode of this name)
(II) VESA(0): Not using built-in mode "640x480" (no mode of this name)
(WW) VESA(0): No valid modes left. Trying less strict filter...
(II) VESA(0): Not using built-in mode "1024x768" (hsync out of range)
(II) VESA(0): Not using built-in mode "800x600" (hsync out of range)
(II) VESA(0): Not using built-in mode "640x480" (hsync out of range)
(WW) VESA(0): No valid modes left. Trying aggressive sync range...
(II) VESA(0): <default monitor>: Using hsync range of 31.50-46.92 kHz
(II) VESA(0): <default monitor>: Using vrefresh range of 50.00-60.00 Hz
(--) VESA(0): Virtual size is 1024x768 (pitch 1024)
(**) VESA(0): *Built-in mode "1024x768"
(**) VESA(0): *Built-in mode "800x600"
(**) VESA(0): Display dimensions: (340, 190) mm
(**) VESA(0): DPI set to (76, 102)
(II) VESA(0): Attempting to use 60Hz refresh for mode "800x600" (115)
(**) VESA(0): Using "Shadow Framebuffer"
(II) Loading sub module "shadow"
(II) LoadModule: "shadow"
(II) Loading /usr/lib/xorg/modules/libshadow.so
(II) Module shadow: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) UnloadModule: "fbdev"
(II) Unloading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) UnloadModule: "fbdevhw"
(II) Unloading /usr/lib/xorg/modules/linux/libfbdevhw.so
(==) Depth 24 pixmap format is 32 bpp
(II) Reloading /usr/lib/xorg/modules/libint10.so
(II) VESA(0): virtual address = 0x7f9d4ef6d000,
physical address = 0xb0000000, size = 67043328
(II) VESA(0): Setting up VESA Mode 0x118 (1024x768)
(==) VESA(0): Backing store disabled
(==) VESA(0): DPMS enabled
(==) RandR enabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XC-MISC
SELinux: Disabled on system, not enabling in X server
(EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
(II) config/udev: Adding input device Power Button (/dev/input/event4)
(**) Power Button: Applying InputClass "evdev keyboard catchall"
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 2.3.2
ABI class: X.Org XInput driver, version 7.0
(**) Power Button: always reports core events
(**) Power Button: Device: "/dev/input/event4"
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) Option "xkb_model" "pc105"
(**) Option "xkb_layout" "pl"
(II) config/udev: Adding input device Lid Switch (/dev/input/event2)
(II) No input driver/identifier specified (ignoring)
(II) config/udev: Adding input device Sleep Button (/dev/input/event3)
(**) Sleep Button: Applying InputClass "evdev keyboard catchall"
(**) Sleep Button: always reports core events
(**) Sleep Button: Device: "/dev/input/event3"
(II) Sleep Button: Found keys
(II) Sleep Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD)
(II) config/udev: Adding input device ASUS USB2.0 WebCam (/dev/input/event6)
(**) ASUS USB2.0 WebCam: Applying InputClass "evdev keyboard catchall"
(**) ASUS USB2.0 WebCam: always reports core events
(**) ASUS USB2.0 WebCam: Device: "/dev/input/event6"
(II) ASUS USB2.0 WebCam: Found keys
(II) ASUS USB2.0 WebCam: Configuring as keyboard
(II) XINPUT: Adding extended input device "ASUS USB2.0 WebCam" (type: KEYBOARD)
(II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event8)
(II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event1)
(**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
(**) AT Translated Set 2 keyboard: always reports core events
(**) AT Translated Set 2 keyboard: Device: "/dev/input/event1"
(II) AT Translated Set 2 keyboard: Found keys
(II) AT Translated Set 2 keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
(II) config/udev: Adding input device PS/2 Synaptics TouchPad (/dev/input/event7)
(**) PS/2 Synaptics TouchPad: Applying InputClass "evdev pointer catchall"
(**) PS/2 Synaptics TouchPad: always reports core events
(**) PS/2 Synaptics TouchPad: Device: "/dev/input/event7"
(II) PS/2 Synaptics TouchPad: Found 3 mouse buttons
(II) PS/2 Synaptics TouchPad: Found relative axes
(II) PS/2 Synaptics TouchPad: Found x and y relative axes
(II) PS/2 Synaptics TouchPad: Configuring as mouse
(**) PS/2 Synaptics TouchPad: YAxisMapping: buttons 4 and 5
(**) PS/2 Synaptics TouchPad: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "PS/2 Synaptics TouchPad" (type: MOUSE)
(II) PS/2 Synaptics TouchPad: initialized for relative axes.
(II) config/udev: Adding input device PS/2 Synaptics TouchPad (/dev/input/mouse1)
(II) config/udev: Adding input device PC Speaker (/dev/input/event5)
(II) config/udev: Adding input device Macintosh mouse button emulation (/dev/input/event0)
(**) Macintosh mouse button emulation: Applying InputClass "evdev pointer catchall"
(**) Macintosh mouse button emulation: always reports core events
(**) Macintosh mouse button emulation: Device: "/dev/input/event0"
(II) Macintosh mouse button emulation: Found 3 mouse buttons
(II) Macintosh mouse button emulation: Found relative axes
(II) Macintosh mouse button emulation: Found x and y relative axes
(II) Macintosh mouse button emulation: Configuring as mouse
(**) Macintosh mouse button emulation: YAxisMapping: buttons 4 and 5
(**) Macintosh mouse button emulation: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "Macintosh mouse button emulation" (type: MOUSE)
(II) Macintosh mouse button emulation: initialized for relative axes.
(II) config/udev: Adding input device Macintosh mouse button emulation (/dev/input/mouse0)
(II) config/udev: Adding input device ACPI Virtual Keyboard Device (/dev/input/event9)
(**) ACPI Virtual Keyboard Device: Applying InputClass "evdev keyboard catchall"
(**) ACPI Virtual Keyboard Device: always reports core events
(**) ACPI Virtual Keyboard Device: Device: "/dev/input/event9"
(II) ACPI Virtual Keyboard Device: Found keys
(II) ACPI Virtual Keyboard Device: Configuring as keyboard
(II) XINPUT: Adding extended input device "ACPI Virtual Keyboard Device" (type: KEYBOARD)
