Mam problem z dźwiękiem, a raczej jego brakiem w Debianie Squeeze. Mój zestaw słuchawkowy to Creative HS 1200 Wireless.
Wynik skryptu alsy:
!!ALSA Information Script v 0.4.60
!!Script ran on: Sun Apr 8 09:51:09 UTC 2012
!!Linux Distribution
Debian GNU/Linux 6.0 \n \l
!!DMI Information
Manufacturer: To Be Filled By O.E.M.
Product Name: To Be Filled By O.E.M.
Product Version: To Be Filled By O.E.M.
!!Kernel Information
Kernel release: 2.6.32-5-686
Operating System: GNU/Linux
Architecture: i686
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: 1.0.21
Library version: 1.0.23
Utilities version: 1.0.23
!!Loaded ALSA modules
snd_hda_intel
snd_usb_audio
snd_usb_audio
!!Sound Servers on this system
No sound servers found.
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xfa200000 irq 22
1 [Q9000 ]: USB-Audio - QuickCam Pro 9000
Logitech, Inc. QuickCam Pro 9000 at usb-0000:00:1d.0-1.6, high speed
2 [Headset ]: USB-Audio - Creative HS-1200 Headset
Creative HS-1200 Headset Creative HS-1200 Headset at usb-0000:00:1d.0-1.8, full
!!PCI Soundcards installed in the system
00:1b.0 Audio device: Intel Corporation Cougar Point High Definition Audio Controller (rev 05)
01:00.1 Audio device: nVidia Corporation Device 0e0c (rev a1)
!!Advanced information - PCI Vendor/Device/Subsystem ID's
00:1b.0 0403: 8086:1c20 (rev 05)
Subsystem: 1849:0892
01:00.1 0403: 10de:0e0c (rev a1)
Subsystem: 1462:2600
!!Modprobe options (Sound related)
snd-atiixp-modem: index=-2
snd-intel8x0m: index=-2
snd-via82xx-modem: index=-2
snd-pcsp: index=-2
snd-usb-audio: index=-2
!!Loaded sound module options
!!Module: snd_hda_intel
bdl_pos_adj : 1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : 0
id : <NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
model : <NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>
patch : <NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>
position_fix : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
power_save : 0
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
single_cmd : N
!!Module: snd_usb_audio
async_unlink : Y
device_setup : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
ignore_ctl_error : N
index : -2,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
nrpacks : 8
pid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
vid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
async_unlink : Y
nrpacks : 8
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ID 892
Address: 0
Function Id: 0x1
Vendor Id: 0x10ec0892
Subsystem Id: 0x18490892
Revision Id: 0x100302
No Modem Function Group found
Default PCM:
rates [0x5f0]: 32000 44100 48000 88200 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Amp-Out caps: ofs=0x40, nsteps=0x40, stepsize=0x03, mute=0
Amp-Out vals: [0x2c 0x2c]
Converter: stream=0, channel=0
PCM:
rates [0x560]: 44100 48000 96000 192000
formats [0x1]: PCM
Power: setting=D0, actual=D0
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Amp-Out vals: [0x40 0x40]
PCM:
formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x41d: Stereo Amp-Out
PCM:
formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x41d: Stereo Amp-Out
PCM:
formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
Digital category: 0x0
PCM:
formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In caps: ofs=0x10, nsteps=0x2e, stepsize=0x03, mute=1
Amp-In vals: [0x1c 0x1c]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In vals: [0x90 0x90]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Audio Input] wcaps 0x100711: Stereo Digital
SDI-Select: 0
Digital:
PCM:
formats [0x1]: PCM
Connection: 1
0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x05 0x0b
Node 0x10 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
PCM:
formats [0x1]: PCM
Node 0x11 [Pin Complex] wcaps 0x400781: Stereo Digital
Pincap 0x00000010: OUT
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Unsolicited: tag=00, enabled=0
Connection: 1
0x10
Node 0x12 [Pin Complex] wcaps 0x400401: Stereo
Pincap 0x00000020: IN
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0001003e: IN OUT HP EAPD Detect Trigger
EAPD 0x0:
Pin Default 0x01014010: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Connection: 1
0x0c
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Amp-Out vals: [0x80 0x80]
Pincap 0x00000036: IN OUT Detect Trigger
Pin Default 0x01011012: [Jack] Line Out at Ext Rear
DefAssociation = 0x1, Sequence = 0x2
Pin-ctls: 0x20: IN
Connection: 1
0x0d
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Pin Default 0x01016011: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Orange
DefAssociation = 0x1, Sequence = 0x1
Pin-ctls: 0x20: IN
Connection: 1
0x0e
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Pin Default 0x01012014: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Grey
DefAssociation = 0x1, Sequence = 0x4
Pin-ctls: 0x20: IN
Connection: 1
0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Amp-In vals: [0x03 0x03]
Pincap 0x00003736: IN OUT Detect Trigger
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x01a19840: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Connection: 5
0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pincap 0x0000373e: IN OUT HP Detect Trigger
Pin Default 0x02a19950: [Jack] Mic at Ext Front
DefAssociation = 0x5, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN VREF_HIZ
Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pin Default 0x0181304f: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x4, Sequence = 0xf
Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pincap 0x0001373e: IN OUT HP EAPD Detect Trigger
EAPD 0x0:
Pin Default 0x02214120: [Jack] HP Out at Ext Front
DefAssociation = 0x2, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0xc0: OUT HP VREF_HIZ
Connection: 5
Node 0x1c [Pin Complex] wcaps 0x400481: Stereo
Pincap 0x00000024: IN Detect
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x4006de01: [N/A] Line Out at Ext N/A
Conn = Digital, Color = UNKNOWN
DefAssociation = 0x0, Sequence = 0x1
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
Pin Default 0x014b2130: [Jack] SPDIF Out at Ext Rear
Conn = Comb, Color = Grey
DefAssociation = 0x3, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Pin Complex] wcaps 0x400681: Stereo Digital
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=24
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 12
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b 0x12
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 11
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x41d: Stereo Amp-Out
PCM:
formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x25 0x0b
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 9 Apr 8 11:48 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 5 Apr 8 11:48 /dev/snd/controlC1
crw-rw---- 1 root audio 116, 12 Apr 8 11:48 /dev/snd/controlC2
crw-rw---- 1 root audio 116, 8 Apr 8 11:48 /dev/snd/hwC0D0
crw-rw---- 1 root audio 116, 7 Apr 8 11:48 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 6 Apr 8 11:50 /dev/snd/pcmC0D0p
crw-rw---- 1 root audio 116, 4 Apr 8 11:48 /dev/snd/pcmC1D0c
crw-rw---- 1 root audio 116, 11 Apr 8 11:48 /dev/snd/pcmC2D0c
crw-rw---- 1 root audio 116, 10 Apr 8 11:48 /dev/snd/pcmC2D0p
crw-rw---- 1 root audio 116, 3 Apr 8 11:48 /dev/snd/seq
crw-rw---- 1 root audio 116, 2 Apr 8 11:48 /dev/snd/timer
/dev/snd/by-id:
total 0
drwxr-xr-x 2 root root 80 Apr 8 11:48 .
drwxr-xr-x 4 root root 300 Apr 8 11:48 ..
lrwxrwxrwx 1 root root 12 Apr 8 11:48 usb-046d_0990_9BD3842C-02 -> ../controlC1
lrwxrwxrwx 1 root root 12 Apr 8 11:48 usb-Creative_HS-1200_Headset_Creative_HS-1200_Headset-00 -> ../controlC2
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 100 Apr 8 11:48 .
lrwxrwxrwx 1 root root 12 Apr 8 11:48 pci-0000:00:1b.0 -> ../controlC0
lrwxrwxrwx 1 root root 12 Apr 8 11:48 pci-0000:00:1d.0-usb-0:1.6:1.2 -> ../controlC1
lrwxrwxrwx 1 root root 12 Apr 8 11:48 pci-0000:00:1d.0-usb-0:1.8:1.0 -> ../controlC2
!!ALSA configuration files
!!System wide config file (/etc/asound.conf)
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: HDA Generic [HDA Generic]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 2: Headset [Creative HS-1200 Headset], device 0: USB Audio [USB Audio]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
card 1: Q9000 [QuickCam Pro 9000], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card 0 [PCH]
Card hw:0 'PCH'/'HDA Intel PCH at 0xfa200000 irq 22'
Mixer name : 'Realtek ID 892'
Components : 'HDA:10ec0892,18490892,00100302'
Controls : 4
Simple ctrls : 3
Simple mixer control 'Master',0
Capabilities: pvolume penum
Playback channels: Front Left - Front Right
Limits: Playback 0 - 64
Mono:
Front Left: Playback 44 [69%] [-20.00dB]
Front Right: Playback 44 [69%] [-20.00dB]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch penum
Capture channels: Front Left - Front Right
Limits: Capture 0 - 46
Front Left: Capture 28 [61%] [12.00dB] [on]
Front Right: Capture 28 [61%] [12.00dB] [on]
!!-------Mixer controls for card 1 [Q9000]
Card hw:1 'Q9000'/'Logitech, Inc. QuickCam Pro 9000 at usb-0000:00:1d.0-1.6, high speed'
Mixer name : 'USB Mixer'
Components : 'USB046d:0990'
Controls : 2
Simple ctrls : 1
Simple mixer control 'Mic',0
Capabilities: cvolume cvolume-joined cswitch cswitch-joined penum
Capture channels: Mono
Limits: Capture 0 - 3072
Mono: Capture 3072 [100%] [30.00dB] [on]
!!-------Mixer controls for card 2 [Headset]
Card hw:2 'Headset'/'Creative HS-1200 Headset Creative HS-1200 Headset at usb-0000:00:1d.0-1.8, full'
Components : 'USB041e:0401'
Controls : 4
Simple ctrls : 2
Capabilities: pvolume pvolume-joined pswitch pswitch-joined penum
Playback channels: Mono
Limits: Playback 0 - 27
Mono: Playback 27 [100%] [-6.00dB] [on]
Limits: Capture 0 - 28
Mono: Capture 28 [100%] [0.00dB] [on]
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
comment.access 'read write'
comment.type BOOLEAN
comment.count 2
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
control.2 {
comment.type INTEGER
comment.count 2
comment.range '0 - 46'
comment.dbmin -1600
comment.dbmax 3000
iface MIXER
name 'Capture Volume'
value.0 28
value.1 28
control.3 {
comment.count 2
comment.range '0 - 64'
comment.dbmin -6400
comment.dbmax 0
iface MIXER
name 'Master Playback Volume'
value.0 44
value.1 44
control.4 {
comment.access 'read write user'
comment.count 2
comment.range '0 - 255'
comment.tlv '0000000100000008ffffec1400000014'
comment.dbmin -5100
comment.dbmax 0
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
state.Q9000 {
control.1 {
comment.count 1
iface MIXER
name 'Mic Capture Switch'
value true
control.2 {
comment.count 1
comment.range '0 - 3072'
comment.dbmin 1800
comment.dbmax 3000
iface MIXER
name 'Mic Capture Volume'
value 3072
state.Headset {
control.1 {
comment.count 1
iface MIXER
name 'PCM Playback Switch'
value true
control.2 {
comment.count 1
comment.range '0 - 27'
comment.dbmin -6000
comment.dbmax -600
iface MIXER
value 27
control.3 {
comment.count 1
iface MIXER
value true
control.4 {
comment.count 1
comment.range '0 - 28'
comment.dbmin 0
comment.dbmax 0
iface MIXER
value 28
--endcollapse--
!!All Loaded Modules
Module
acpi_cpufreq
cpufreq_stats
cpufreq_powersave
cpufreq_userspace
cpufreq_conservative
parport_pc
ppdev
lp
parport
sco
bridge
stp
bnep
rfcomm
l2cap
crc16
bluetooth
rfkill
binfmt_misc
fuse
loop
snd_hda_codec_realtek
snd_usb_audio
snd_usb_lib
snd_seq_midi
snd_seq_midi_event
snd_hda_intel
snd_rawmidi
snd_hda_codec
snd_hwdep
nvidia
nouveau
ttm
uvcvideo
drm_kms_helper
snd_pcm
snd_page_alloc
snd_seq
snd_timer
snd_seq_device
snd
soundcore
joydev
videodev
v4l1_compat
usbhid
hid
drm
i2c_algo_bit
evdev
pcspkr
button
processor
i2c_i801
i2c_core
psmouse
serio_raw
ext3
jbd
mbcache
sg
sr_mod
sd_mod
crc_t10dif
cdrom
ata_generic
xhci
ata_piix
libata
floppy
ehci_hcd
scsi_mod
r8169
usbcore
nls_base
mii
thermal
thermal_sys
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x11 0x411111f0
0x12 0x411111f0
0x14 0x01014010
0x15 0x01011012
0x16 0x01016011
0x17 0x01012014
0x18 0x01a19840
0x19 0x02a19950
0x1a 0x0181304f
0x1b 0x02214120
0x1c 0x411111f0
0x1d 0x4006de01
0x1e 0x014b2130
0x1f 0x411111f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
!!ALSA/HDA dmesg
[ 4.954940] NVRM: loading NVIDIA UNIX x86 Kernel Module 295.33 Sat Mar 17 14:56:23 PDT 2012
[ 5.015041] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 5.015065] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 5.394516] usbcore: registered new interface driver snd-usb-audio
Linux wodoonet 2.6.32-5-686 #1 SMP Mon Mar 26 05:20:33 UTC 2012 i686 GNU/LinuxKod: Zaznacz cały
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 006: ID 041e:0401 Creative Technology, Ltd
Bus 002 Device 005: ID 046d:c317 Logitech, Inc. Wave Corded Keyboard
Bus 002 Device 004: ID 046d:0990 Logitech, Inc. QuickCam Pro 9000
Bus 002 Device 003: ID 04b4:0033 Cypress Semiconductor Corp. Mouse
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hubLista kart dźwiękowych
Creative HS-1200 Headset Creative HS-1200 Headset at usb-0000:00:1d.0-1.8, fullKod: Zaznacz cały
root@wodoonet:/home/mrwodoo# cat /proc/asound/modules
0 snd_hda_intel
1 snd_usb_audio
2 snd_usb_audio
root@wodoonet:/home/mrwodoo# cat /proc/asound/version
Advanced Linux Sound Architecture Driver Version 1.0.21.
