B
dulaman
Błąd przy generowaniu pliku xorg.conf
Post autor: dulaman »
Mam problem z wygenerowaniem pliku xorg.conf. Plik generowałem standardowo, wyłączając przedtem xdm. Polecenia, jakich użyłem:
service xdg stop
Xorg -configure
Co prawda, nie mam jak pokazać wyniku, użycia tego polecenia, ale posiadam plik log:
[    19.733]
X.Org X Server 1.11.3.901 (1.11.4 RC 1)
Release Date: 2012-01-06
[    19.733] X Protocol Version 11, Revision 0
[    19.733] Build Operating System: Linux 2.6.32-5-amd64 i686 Debian
[    19.733] Current Operating System: Linux adam-netbook 3.2.0-1-686-pae #1 SMP Fri Feb 17 06:27:21 UTC 2012 i686
[    19.733] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-1-686-pae root=UUID=91af656c-0fd5-4387-a8e3-8de044deb3ba ro quiet
[    19.733] Build Date: 19 January 2012  10:32:06AM
[    19.733] xorg-server 2:1.11.3.901-2 (Cyril Brulebois <kibi@debian.org>)
[    19.733] Current version of pixman: 0.24.4
[    19.733] 	Before reporting problems, check http://wiki.x.org
[    19.733] Markers: (--) probed, (**) from config file, (==) default setting,
[    19.734] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Mar 13 19:29:31 2012
[    19.742] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    19.819] (==) No Layout section.  Using the first Screen section.
[    19.819] (==) No screen section available. Using defaults.
[    19.819] (**) |-->Screen "Default Screen Section" (0)
[    19.819] (**) |   |-->Monitor "<default monitor>"
[    19.834] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[    19.834] (==) Automatically adding devices
[    19.834] (==) Automatically enabling devices
[    19.885] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    19.885] 	Entry deleted from font path.
[    20.032] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
	built-ins
[    20.032] (==) ModulePath set to "/usr/lib/xorg/modules"
[    20.032] (II) The server relies on udev to provide the list of input devices.
[    20.069] (II) Loader magic: 0xb7744580
[    20.069] (II) Module ABI versions:
[    20.069] 	X.Org ANSI C Emulation: 0.4
[    20.069] 	X.Org Video Driver: 11.0
[    20.069] 	X.Org XInput driver : 13.0
[    20.069] 	X.Org Server Extension : 6.0
[    20.071] (--) PCI:*(0:0:2:0) 8086:a011:1025:034a rev 0, Mem @ 0x58180000/524288, 0x40000000/268435456, 0x58000000/1048576, I/O @ 0x000060c0/8
[    20.071] (--) PCI: (0:0:2:1) 8086:a012:1025:034a rev 0, Mem @ 0x58100000/524288
[    20.071] (II) Open ACPI successful (/var/run/acpid.socket)
[    20.071] (II) LoadModule: "extmod"
[    20.108] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[    20.127] (II) Module extmod: vendor="X.Org Foundation"
[    20.128] 	compiled for 1.11.3.901, module version = 1.0.0
[    20.128] 	Module class: X.Org Server Extension
[    20.128] 	ABI class: X.Org Server Extension, version 6.0
[    20.128] (II) Loading extension SELinux
[    20.128] (II) Loading extension MIT-SCREEN-SAVER
[    20.128] (II) Loading extension XFree86-VidModeExtension
[    20.128] (II) Loading extension XFree86-DGA
[    20.128] (II) Loading extension DPMS
[    20.128] (II) Loading extension XVideo
[    20.128] (II) Loading extension XVideo-MotionCompensation
[    20.128] (II) Loading extension X-Resource
[    20.128] (II) LoadModule: "dbe"
[    20.128] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[    20.146] (II) Module dbe: vendor="X.Org Foundation"
[    20.146] 	compiled for 1.11.3.901, module version = 1.0.0
[    20.146] 	Module class: X.Org Server Extension
[    20.146] 	ABI class: X.Org Server Extension, version 6.0
[    20.146] (II) Loading extension DOUBLE-BUFFER
[    20.146] (II) LoadModule: "glx"
[    20.146] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    20.172] (II) Module glx: vendor="X.Org Foundation"
[    20.172] 	compiled for 1.11.3.901, module version = 1.0.0
[    20.172] 	ABI class: X.Org Server Extension, version 6.0
[    20.172] (==) AIGLX enabled
[    20.172] (II) Loading extension GLX
[    20.172] (II) LoadModule: "record"
[    20.173] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[    20.192] (II) Module record: vendor="X.Org Foundation"
[    20.192] 	compiled for 1.11.3.901, module version = 1.13.0
[    20.192] 	Module class: X.Org Server Extension
[    20.192] 	ABI class: X.Org Server Extension, version 6.0
[    20.193] (II) Loading extension RECORD
[    20.193] (II) LoadModule: "dri"
[    20.193] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[    20.203] (II) Module dri: vendor="X.Org Foundation"
[    20.204] 	compiled for 1.11.3.901, module version = 1.0.0
[    20.204] 	ABI class: X.Org Server Extension, version 6.0
[    20.204] (II) Loading extension XFree86-DRI
[    20.204] (II) LoadModule: "dri2"
[    20.204] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[    20.205] (II) Module dri2: vendor="X.Org Foundation"
[    20.205] 	compiled for 1.11.3.901, module version = 1.2.0
[    20.205] 	ABI class: X.Org Server Extension, version 6.0
[    20.205] (II) Loading extension DRI2
[    20.205] (==) Matched intel as autoconfigured driver 0
[    20.205] (==) Matched vesa as autoconfigured driver 1
[    20.205] (==) Matched fbdev as autoconfigured driver 2
[    20.205] (==) Assigned the driver to the xf86ConfigLayout
[    20.206] (II) LoadModule: "intel"
[    20.271] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[    20.307] (II) Module intel: vendor="X.Org Foundation"
[    20.307] 	compiled for 1.11.3.901, module version = 2.18.0
[    20.307] 	Module class: X.Org Video Driver
[    20.307] 	ABI class: X.Org Video Driver, version 11.0
[    20.307] (II) LoadModule: "vesa"
[    20.308] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    20.325] (II) Module vesa: vendor="X.Org Foundation"
[    20.325] 	compiled for 1.11.0, module version = 2.3.0
[    20.325] 	Module class: X.Org Video Driver
[    20.325] 	ABI class: X.Org Video Driver, version 11.0
[    20.325] (II) LoadModule: "fbdev"
[    20.326] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    20.327] (II) Module fbdev: vendor="X.Org Foundation"
[    20.327] 	compiled for 1.11.0, module version = 0.4.2
[    20.327] 	ABI class: X.Org Video Driver, version 11.0
[    20.327] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
	i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
	E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
	965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
	4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
	Sandybridge Desktop (GT1), Sandybridge Desktop (GT2),
	Sandybridge Desktop (GT2+), Sandybridge Mobile (GT1),
	Sandybridge Mobile (GT2), Sandybridge Mobile (GT2+),
	Sandybridge Server, Ivybridge Mobile (GT1), Ivybridge Mobile (GT2),
	Ivybridge Desktop (GT1), Ivybridge Desktop (GT2), Ivybridge Server
[    20.329] (II) VESA: driver for VESA chipsets: vesa
[    20.329] (II) FBDEV: driver for framebuffer: fbdev
[    20.329] (++) using VT number 7
[    20.329] (WW) xf86OpenConsole: setpgid failed: Operation not permitted
[    20.329] (WW) xf86OpenConsole: setsid failed: Operation not permitted
[    20.342] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[    20.342] (WW) Falling back to old probe method for vesa
[    20.342] (WW) Falling back to old probe method for fbdev
[    20.394] (II) Loading sub module "fbdevhw"
[    20.394] (II) LoadModule: "fbdevhw"
[    20.394] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    20.416] (II) Module fbdevhw: vendor="X.Org Foundation"
[    20.416] 	compiled for 1.11.3.901, module version = 0.0.2
[    20.417] 	ABI class: X.Org Video Driver, version 11.0
[    20.417] drmOpenDevice: node name is /dev/dri/card0
[    20.417] drmOpenDevice: open result is 9, (OK)
[    20.417] drmOpenByBusid: Searching for BusID pci:0000:00:02.0
[    20.417] drmOpenByBusid: drmOpenMinor returns 9
[    20.418] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[    20.418] (II) intel(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    20.418] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[    20.418] (==) intel(0): RGB weight 888
[    20.418] (==) intel(0): Default visual is TrueColor
[    20.418] (II) intel(0): Integrated Graphics Chipset: Intel(R) Pineview GM
[    20.418] (--) intel(0): Chipset: "Pineview GM"
[    20.418] (**) intel(0): Relaxed fencing enabled
[    20.418] (**) intel(0): Wait on SwapBuffers? enabled
[    20.418] (**) intel(0): Triple buffering? enabled
[    20.418] (**) intel(0): Framebuffer tiled
[    20.418] (**) intel(0): Pixmaps tiled
[    20.419] (**) intel(0): 3D buffers tiled
[    20.419] (**) intel(0): SwapBuffers wait enabled
[    20.419] (==) intel(0): video overlay key set to 0x101fe
[    20.419] (II) intel(0): Output LVDS1 has no monitor section
[    20.520] (II) intel(0): found backlight control interface /sys/class/backlight/acpi_video0
[    20.552] (II) intel(0): Output VGA1 has no monitor section
[    20.552] (II) intel(0): EDID for output LVDS1
[    20.552] (II) intel(0): Manufacturer: AUO  Model: 61d2  Serial#: 0
[    20.552] (II) intel(0): Year: 2009  Week: 0
[    20.552] (II) intel(0): EDID Version: 1.3
[    20.552] (II) intel(0): Digital Display Input
[    20.552] (II) intel(0): Max Image Size [cm]: horiz.: 22  vert.: 13
[    20.552] (II) intel(0): Gamma: 2.20
[    20.552] (II) intel(0): No DPMS capabilities specified
[    20.552] (II) intel(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    20.552] (II) intel(0): First detailed timing is preferred mode
[    20.553] (II) intel(0): redX: 0.590 redY: 0.345   greenX: 0.325 greenY: 0.540
[    20.553] (II) intel(0): blueX: 0.150 blueY: 0.145   whiteX: 0.313 whiteY: 0.329
[    20.553] (II) intel(0): Manufacturer's mask: 0
[    20.553] (II) intel(0): Supported detailed timing:
[    20.553] (II) intel(0): clock: 49.8 MHz   Image Size:  222 x 125 mm
[    20.553] (II) intel(0): h_active: 1024  h_sync: 1072  h_sync_end 1104 h_blank_end 1338 h_border: 0
[    20.553] (II) intel(0): v_active: 600  v_sync: 602  v_sync_end 608 v_blanking: 620 v_border: 0
[    20.553] (II) intel(0): Unknown vendor-specific block f
[    20.553] (II) intel(0):  AUO
[    20.553] (II) intel(0):  B101AW06 V1
[    20.553] (II) intel(0): EDID (in hex):
[    20.553] (II) intel(0): 	00ffffffffffff0006afd26100000000
[    20.553] (II) intel(0): 	0013010380160d780a15859758538a26
[    20.553] (II) intel(0): 	25505400000001010101010101010101
[    20.553] (II) intel(0): 	0101010101017413003a415814203020
[    20.553] (II) intel(0): 	2600de7d000000180000000f00000000
[    20.553] (II) intel(0): 	00000000000000000020000000fe0041
[    20.554] (II) intel(0): 	554f0a202020202020202020000000fe
[    20.554] (II) intel(0): 	004231303141573036205631200a0029
[    20.554] (II) intel(0): EDID vendor "AUO", prod id 25042
[    20.554] (II) intel(0): Printing DDC gathered Modelines:
[    20.554] (II) intel(0): Modeline "1024x600"x0.0   49.80  1024 1072 1104 1338  600 602 608 620 -hsync -vsync (37.2 kHz)
[    20.554] (II) intel(0): Not using default mode "320x240" (doublescan mode not supported)
[    20.554] (II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
[    20.554] (II) intel(0): Not using default mode "512x384" (doublescan mode not supported)
[    20.554] (II) intel(0): Not using default mode "640x480" (doublescan mode not supported)
[    20.554] (II) intel(0): Not using default mode "640x512" (doublescan mode not supported)
[    20.554] (II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
[    20.554] (II) intel(0): Not using default mode "576x432" (doublescan mode not supported)
[    20.555] (II) intel(0): Not using default mode "680x384" (doublescan mode not supported)
[    20.555] (II) intel(0): Not using default mode "700x525" (doublescan mode not supported)
[    20.555] (II) intel(0): Not using default mode "720x450" (doublescan mode not supported)
[    20.555] (II) intel(0): Not using default mode "800x512" (doublescan mode not supported)
[    20.555] (II) intel(0): Not using default mode "840x525" (doublescan mode not supported)
[    20.555] (II) intel(0): Not using default mode "960x540" (doublescan mode not supported)
[    20.555] (II) intel(0): Not using default mode "960x600" (doublescan mode not supported)
[    20.555] (II) intel(0): Printing probed modes for output LVDS1
[    20.555] (II) intel(0): Modeline "1024x600"x60.0   49.80  1024 1072 1104 1338  600 602 608 620 -hsync -vsync (37.2 kHz)
[    20.555] (II) intel(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz)
[    20.555] (II) intel(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz)
[    20.555] (II) intel(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz)
[    20.592] (II) intel(0): EDID for output VGA1
[    20.592] (II) intel(0): Output LVDS1 connected
[    20.592] (II) intel(0): Output VGA1 disconnected
[    20.592] (II) intel(0): Using exact sizes for initial modes
[    20.592] (II) intel(0): Output LVDS1 using initial mode 1024x600
[    20.592] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[    20.592] (II) intel(0): Kernel page flipping support detected, enabling
[    20.592] (**) intel(0): Display dimensions: (220, 130) mm
[    20.592] (**) intel(0): DPI set to (118, 117)
[    20.592] (II) Loading sub module "fb"
[    20.592] (II) LoadModule: "fb"
[    20.592] (II) Loading /usr/lib/xorg/modules/libfb.so
[    20.743] (II) Module fb: vendor="X.Org Foundation"
[    20.743] 	compiled for 1.11.3.901, module version = 1.0.0
[    20.743] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    20.743] (II) Loading sub module "dri2"
[    20.743] (II) LoadModule: "dri2"
[    20.743] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[    20.743] (II) Module dri2: vendor="X.Org Foundation"
[    20.743] 	compiled for 1.11.3.901, module version = 1.2.0
[    20.743] 	ABI class: X.Org Server Extension, version 6.0
[    20.743] (II) UnloadModule: "vesa"
[    20.744] (II) Unloading vesa
[    20.744] (II) UnloadModule: "fbdev"
[    20.744] (II) Unloading fbdev
[    20.744] (II) UnloadModule: "fbdevhw"
[    20.744] (II) Unloading fbdevhw
[    20.744] (==) Depth 24 pixmap format is 32 bpp
[    20.744] (II) intel(0): [DRI2] Setup complete
[    20.744] (II) intel(0): [DRI2]   DRI driver: i915
[    20.744] (II) intel(0): Allocated new frame buffer 1024x600 stride 4096, tiled
[    20.821] (II) UXA(0): Driver registered support for the following operations:
[    20.821] (II)         solid
[    20.821] (II)         copy
[    20.821] (II)         composite (RENDER acceleration)
[    20.821] (II)         put_image
[    20.821] (II)         get_image
[    20.821] (==) intel(0): Backing store disabled
[    20.821] (==) intel(0): Silken mouse enabled
[    20.821] (II) intel(0): Initializing HW Cursor
[    20.840] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    20.842] (==) intel(0): DPMS enabled
[    20.842] (==) intel(0): Intel XvMC decoder disabled
[    20.842] (II) intel(0): Set up textured video
[    20.842] (II) intel(0): Set up overlay video
[    20.843] (II) intel(0): direct rendering: DRI2 Enabled
[    20.843] (==) intel(0): hotplug detection: "enabled"
[    20.843] (--) RandR disabled
[    20.843] (II) Initializing built-in extension Generic Event Extension
[    20.843] (II) Initializing built-in extension SHAPE
[    20.843] (II) Initializing built-in extension MIT-SHM
[    20.843] (II) Initializing built-in extension XInputExtension
[    20.843] (II) Initializing built-in extension XTEST
[    20.843] (II) Initializing built-in extension BIG-REQUESTS
[    20.843] (II) Initializing built-in extension SYNC
[    20.843] (II) Initializing built-in extension XKEYBOARD
[    20.843] (II) Initializing built-in extension XC-MISC
[    20.843] (II) Initializing built-in extension SECURITY
[    20.843] (II) Initializing built-in extension XINERAMA
[    20.843] (II) Initializing built-in extension XFIXES
[    20.843] (II) Initializing built-in extension RENDER
[    20.843] (II) Initializing built-in extension RANDR
[    20.844] (II) Initializing built-in extension COMPOSITE
[    20.844] (II) Initializing built-in extension DAMAGE
[    20.844] (II) SELinux: Disabled on system
[    21.337] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[    21.337] (II) AIGLX: enabled GLX_INTEL_swap_event
[    21.337] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[    21.337] (II) AIGLX: enabled GLX_SGI_make_current_read
[    21.337] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[    21.338] (II) AIGLX: Loaded and initialized i915
[    21.338] (II) GLX: Initialized DRI2 GL provider for screen 0
[    21.339] (II) intel(0): Setting screen physical size to 270 x 158
[    23.434] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[    23.486] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    23.486] (II) LoadModule: "evdev"
[    23.487] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    23.545] (II) Module evdev: vendor="X.Org Foundation"
[    23.545] 	compiled for 1.11.0, module version = 2.6.0
[    23.545] 	Module class: X.Org XInput Driver
[    23.545] 	ABI class: X.Org XInput driver, version 13.0
[    23.545] (II) Using input driver 'evdev' for 'Power Button'
[    23.545] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    23.545] (**) Power Button: always reports core events
[    23.545] (**) Power Button: Device: "/dev/input/event4"
[    23.545] (--) Power Button: Found keys
[    23.545] (II) Power Button: Configuring as keyboard
[    23.545] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input4/event4"
[    23.545] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    23.545] (**) Option "xkb_rules" "evdev"
[    23.546] (**) Option "xkb_model" "pc105"
[    23.546] (**) Option "xkb_layout" "pl"
[    23.871] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[    23.871] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    23.871] (II) Using input driver 'evdev' for 'Video Bus'
[    23.871] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    23.872] (**) Video Bus: always reports core events
[    23.872] (**) Video Bus: Device: "/dev/input/event9"
[    23.872] (--) Video Bus: Found keys
[    23.872] (II) Video Bus: Configuring as keyboard
[    23.872] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:00/input/input9/event9"
[    23.872] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    23.872] (**) Option "xkb_rules" "evdev"
[    23.872] (**) Option "xkb_model" "pc105"
[    23.872] (**) Option "xkb_layout" "pl"
[    23.874] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    23.874] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    23.874] (II) Using input driver 'evdev' for 'Power Button'
[    23.874] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    23.875] (**) Power Button: always reports core events
[    23.875] (**) Power Button: Device: "/dev/input/event1"
[    23.875] (--) Power Button: Found keys
[    23.875] (II) Power Button: Configuring as keyboard
[    23.876] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input1/event1"
[    23.876] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[    23.876] (**) Option "xkb_rules" "evdev"
[    23.876] (**) Option "xkb_model" "pc105"
[    23.876] (**) Option "xkb_layout" "pl"
[    23.878] (II) config/udev: Adding input device Lid Switch (/dev/input/event3)
[    23.878] (II) No input driver/identifier specified (ignoring)
[    23.879] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[    23.879] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    23.879] (II) Using input driver 'evdev' for 'Sleep Button'
[    23.880] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    23.880] (**) Sleep Button: always reports core events
[    23.880] (**) Sleep Button: Device: "/dev/input/event2"
[    23.880] (--) Sleep Button: Found keys
[    23.880] (II) Sleep Button: Configuring as keyboard
[    23.880] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input2/event2"
[    23.880] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[    23.880] (**) Option "xkb_rules" "evdev"
[    23.880] (**) Option "xkb_model" "pc105"
[    23.880] (**) Option "xkb_layout" "pl"
[    23.882] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event10)
[    23.882] (II) No input driver/identifier specified (ignoring)
[    23.884] (II) config/udev: Adding input device HDA Intel Mic (/dev/input/event11)
[    23.884] (II) No input driver/identifier specified (ignoring)
[    23.885] (II) config/udev: Adding input device HDA Intel Headphone (/dev/input/event12)
[    23.885] (II) No input driver/identifier specified (ignoring)
[    23.886] (II) config/udev: Adding input device 1.3M WebCam (/dev/input/event8)
[    23.886] (**) 1.3M WebCam: Applying InputClass "evdev keyboard catchall"
[    23.886] (II) Using input driver 'evdev' for '1.3M WebCam'
[    23.886] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    23.886] (**) 1.3M WebCam: always reports core events
[    23.886] (**) 1.3M WebCam: Device: "/dev/input/event8"
[    23.886] (--) 1.3M WebCam: Found keys
[    23.886] (II) 1.3M WebCam: Configuring as keyboard
[    23.886] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.7/usb1/1-4/1-4:1.0/input/input8/event8"
[    23.886] (II) XINPUT: Adding extended input device "1.3M WebCam" (type: KEYBOARD, id 10)
[    23.887] (**) Option "xkb_rules" "evdev"
[    23.887] (**) Option "xkb_model" "pc105"
[    23.887] (**) Option "xkb_layout" "pl"
[    23.888] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[    23.888] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    23.888] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[    23.888] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    23.889] (**) AT Translated Set 2 keyboard: always reports core events
[    23.889] (**) AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[    23.889] (--) AT Translated Set 2 keyboard: Found keys
[    23.889] (II) AT Translated Set 2 keyboard: Configuring as keyboard
[    23.889] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[    23.889] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 11)
[    23.889] (**) Option "xkb_rules" "evdev"
[    23.889] (**) Option "xkb_model" "pc105"
[    23.889] (**) Option "xkb_layout" "pl"
[    23.891] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event7)
[    23.891] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[    23.891] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Multitouch Touchpad"
[    23.891] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[    23.891] (II) LoadModule: "synaptics"
[    23.891] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[    24.034] (II) Module synaptics: vendor="X.Org Foundation"
[    24.034] 	compiled for 1.11.2.902, module version = 1.5.0
[    24.034] 	Module class: X.Org XInput Driver
[    24.034] 	ABI class: X.Org XInput driver, version 13.0
[    24.034] (II) Using input driver 'synaptics' for 'SynPS/2 Synaptics TouchPad'
[    24.034] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[    24.034] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    24.034] (**) Option "Device" "/dev/input/event7"
[    24.088] (--) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5612
[    24.088] (--) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4618
[    24.088] (--) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[    24.088] (--) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 0
[    24.088] (--) synaptics: SynPS/2 Synaptics TouchPad: buttons: left right double triple
[    24.088] (--) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[    24.092] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[    24.092] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    24.100] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event7"
[    24.100] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 12)
[    24.100] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[    24.100] (**) synaptics: SynPS/2 Synaptics TouchPad: MaxSpeed is now 1.75
[    24.100] (**) synaptics: SynPS/2 Synaptics TouchPad: AccelFactor is now 0.038
[    24.100] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[    24.100] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[    24.100] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[    24.100] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[    24.101] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[    24.101] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[    24.101] (**) SynPS/2 Synaptics TouchPad: Ignoring device from InputClass "touchpad ignore duplicates"
[    24.102] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[    24.102] (II) No input driver/identifier specified (ignoring)
[    24.104] (II) config/udev: Adding input device Acer WMI hotkeys (/dev/input/event6)
[    24.104] (**) Acer WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    24.104] (II) Using input driver 'evdev' for 'Acer WMI hotkeys'
[    24.104] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    24.104] (**) Acer WMI hotkeys: always reports core events
[    24.104] (**) Acer WMI hotkeys: Device: "/dev/input/event6"
[    24.104] (--) Acer WMI hotkeys: Found keys
[    24.104] (II) Acer WMI hotkeys: Configuring as keyboard
[    24.104] (**) Option "config_info" "udev:/sys/devices/virtual/input/input6/event6"
[    24.104] (II) XINPUT: Adding extended input device "Acer WMI hotkeys" (type: KEYBOARD, id 13)
[    24.104] (**) Option "xkb_rules" "evdev"
[    24.104] (**) Option "xkb_model" "pc105"
[    24.104] (**) Option "xkb_layout" "pl"
[    38.289] (II) intel(0): EDID vendor "AUO", prod id 25042
[    38.289] (II) intel(0): Printing DDC gathered Modelines:
[    38.289] (II) intel(0): Modeline "1024x600"x0.0   49.80  1024 1072 1104 1338  600 602 608 620 -hsync -vsync (37.2 kHz)
[    38.320] (II) intel(0): EDID vendor "AUO", prod id 25042
[    38.320] (II) intel(0): Printing DDC gathered Modelines:
[    38.320] (II) intel(0): Modeline "1024x600"x0.0   49.80  1024 1072 1104 1338  600 602 608 620 -hsync -vsync (37.2 kHz)
[    50.239] (II) config/udev: Adding input device  USB OPTICAL MOUSE (/dev/input/event13)
[    50.239] (**)  USB OPTICAL MOUSE: Applying InputClass "evdev pointer catchall"
[    50.239] (II) Using input driver 'evdev' for ' USB OPTICAL MOUSE'
[    50.239] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    50.239] (**)  USB OPTICAL MOUSE: always reports core events
[    50.239] (**)  USB OPTICAL MOUSE: Device: "/dev/input/event13"
[    50.248] (--)  USB OPTICAL MOUSE: Found 3 mouse buttons
[    50.322] (--)  USB OPTICAL MOUSE: Found scroll wheel(s)
[    50.322] (--)  USB OPTICAL MOUSE: Found relative axes
[    50.322] (--)  USB OPTICAL MOUSE: Found x and y relative axes
[    50.323] (II)  USB OPTICAL MOUSE: Configuring as mouse
[    50.323] (II)  USB OPTICAL MOUSE: Adding scrollwheel support
[    50.323] (**)  USB OPTICAL MOUSE: YAxisMapping: buttons 4 and 5
[    50.323] (**)  USB OPTICAL MOUSE: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    50.323] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.0/input/input13/event13"
[    50.323] (II) XINPUT: Adding extended input device " USB OPTICAL MOUSE" (type: MOUSE, id 14)
[    50.323] (II)  USB OPTICAL MOUSE: initialized for relative axes.
[    50.323] (**)  USB OPTICAL MOUSE: (accel) keeping acceleration scheme 1
[    50.323] (**)  USB OPTICAL MOUSE: (accel) acceleration profile 0
[    50.324] (**)  USB OPTICAL MOUSE: (accel) acceleration factor: 2.000
[    50.324] (**)  USB OPTICAL MOUSE: (accel) acceleration threshold: 4
[    50.324] (II) config/udev: Adding input device  USB OPTICAL MOUSE (/dev/input/mouse1)
[    50.325] (II) No input driver/identifier specified (ignoring)
Moja wersja jądra to:
Linux adam-netbook 3.2.0-1-686-pae #1 SMP Fri Feb 17 06:27:21 UTC 2012 i686 GNU/Linux
Karta graficzna to Intel GMA 3150
Moduły jądra:
$ lsmod
Module                  Size  Used by
usbhid                 31523  0
hid                    60120  1 usbhid
parport_pc             22036  0
ppdev                  12651  0
lp                     12797  0
parport                31254  3 parport_pc,ppdev,lp
binfmt_misc            12813  1
nfsd                  173714  2
cryptd                 14125  0
aes_i586               16608  1
aes_generic            32970  1 aes_i586
nfs                   261507  0
lockd                  57255  2 nfsd,nfs
fscache                31978  1 nfs
auth_rpcgss            32143  2 nfsd,nfs
nfs_acl                12463  2 nfsd,nfs
sunrpc                143853  6 nfsd,nfs,lockd,auth_rpcgss,nfs_acl
fuse                   52153  5
loop                   17810  0
snd_hda_codec_realtek   142101  1
snd_hda_intel          21856  1
snd_hda_codec          63448  2 snd_hda_codec_realtek,snd_hda_intel
snd_hwdep              12943  1 snd_hda_codec
arc4                   12418  2
snd_pcm_oss            36181  0
snd_mixer_oss          17668  1 snd_pcm_oss
snd_pcm                53390  3 snd_hda_intel,snd_hda_codec,snd_pcm_oss
uvcvideo               56896  0
videodev               61658  1 uvcvideo
snd_seq_midi           12744  0
media                  13692  2 uvcvideo,videodev
joydev                 17010  0
snd_rawmidi            18376  1 snd_seq_midi
snd_seq_midi_event     13124  1 snd_seq_midi
i915                  303460  2
iwlwifi               146774  0
drm_kms_helper         22699  1 i915
drm                   134178  3 i915,drm_kms_helper
snd_seq                39487  2 snd_seq_midi,snd_seq_midi_event
snd_timer              22356  2 snd_pcm,snd_seq
snd_seq_device         13016  3 snd_seq_midi,snd_rawmidi,snd_seq
snd                    42691  13 snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
mac80211              171359  1 iwlwifi
soundcore              12921  1 snd
i2c_algo_bit           12713  1 i915
acer_wmi               21601  0
sparse_keymap          12680  1 acer_wmi
i2c_i801               12670  0
iTCO_wdt               16945  0
iTCO_vendor_support    12632  1 iTCO_wdt
psmouse                54927  0
cfg80211              117454  2 iwlwifi,mac80211
rfkill                 18516  2 acer_wmi,cfg80211
snd_page_alloc         12867  2 snd_hda_intel,snd_pcm
i2c_core               19116  6 videodev,i915,drm_kms_helper,drm,i2c_algo_bit,i2c_i801
evdev                  17225  16
pcspkr                 12515  0
ac                     12552  0
serio_raw              12803  0
battery                12957  0
power_supply           13283  2 ac,battery
wmi                    13051  1 acer_wmi
processor              27483  0
button                 12817  1 i915
video                  17412  1 i915
ext4                  302787  1
mbcache                12897  1 ext4
jbd2                   52246  1 ext4
crc16                  12327  1 ext4
sd_mod                 35425  5
crc_t10dif             12332  1 sd_mod
ahci                   20821  4
libahci                18308  1 ahci
libata                124981  2 ahci,libahci
scsi_mod              135161  2 sd_mod,libata
uhci_hcd               22337  0
ehci_hcd               35509  0
usbcore               104352  5 usbhid,uvcvideo,uhci_hcd,ehci_hcd
fan                    12594  0
thermal                13103  0
thermal_sys            17752  4 processor,video,fan,thermal
atl1c                  31529  0
usb_common             12338  1 usbcore
Za wszelką pomoc z góry dziękuję.
Teraz się już nie generuje. Od wydania squeeze bodajrze.
dulaman
Wiem o tym, ale z różnych powodów i po części z przymusu wolę mieć wszystko w jednym pliku konfiguracyjnym.
Poza tym polecenie
]dpkg-reconfigure xserver-xorg
nie działa u mnie, nawet przy wyłącznych X-ach.
DaVidoSS
Post autor: DaVidoSS »
Spróbuj tak:
su
/etc/init.d/xdm stop
X -configure
mv /root/xorg.conf.new /etc/X11/xorg.conf
dulaman
DavidoSS wiem, że po konfiguracji tworzony jest plik xorg.conf.new, ale ten plik nie został utworzony, a jak już wspominałem wcześniej wyłączyłem przed generowaniem pliku konfiguracyjnego xdm.
Na wypadek jakbyś mi nie wierzył:
adam@adam-netbook:/etc/X11$ ls
app-defaults             fluxbox  plik     X    xinit  Xreset    Xresources  Xsession.d        XvMCConfig
default-display-manager  fonts    rgb.txt  xdm  xkb    Xreset.d  Xsession    Xsession.options  Xwrapper.config
Przepraszam, nie zauważyłem, że tam jest /root a nie /etc/Xorg, już znalazłem ten plik. Dziękuję DavidoSS.
DaVidoSS
Ech ludzie ludzie....
Ale polecenie:
X -configure
nie tworzyło pliku w katalogu /etc/X11 tylko w katalogu /root pod nazwą xorg.conf.new i stamtąd należało go skopiować w odpowiednie miejsce zmieniając nazwę.
