Wersja 1 - aktualna stabilna wersja (Squeeze), GNOME 2.32, aktualne stabilne, standardowe jajko (nie chce mi się sprawdzać jaka to wersja konkretnie bo jak zrestartuję to znowu mnie rozłączy i nie będę mógł się połączyć z Internetem), architektura i386
Wersja 2 - testowa (Wheezy):
Linux 178235066008 3.2.0-1-686-pae #1 SMP Sun Feb 5 23:52:49 UTC 2012 i686 GNU/LinuxKod: Zaznacz cały
hagonbc@178235066008:~$ lsusb
Bus 002 Device 002: ID 09da:000a A4 Tech Co., Ltd Optical Mouse Opto 510D
Bus 002 Device 003: ID 0e5e:6622 Conwise Technology Co., Ltd. CW6622
Bus 002 Device 004: ID 058f:9360 Alcor Micro Corp. 8-in-1 Media Card Reader
Bus 001 Device 005: ID 04e8:684a Samsung Electronics Co., Ltd Kod: Zaznacz cały
hagonbc@178235066008:~$ lspci -k
00:00.0 RAM memory: nVidia Corporation MCP61 Memory Controller (rev a1)
Subsystem: Elitegroup Computer Systems Device 2601
00:01.0 ISA bridge: nVidia Corporation MCP61 LPC Bridge (rev a2)
00:01.1 SMBus: nVidia Corporation MCP61 SMBus (rev a2)
Kernel driver in use: nForce2_smbus
00:01.2 RAM memory: nVidia Corporation MCP61 Memory Controller (rev a2)
00:02.0 USB controller: nVidia Corporation MCP61 USB Controller (rev a2)
Kernel driver in use: ohci_hcd
00:02.1 USB controller: nVidia Corporation MCP61 USB Controller (rev a2)
00:04.0 PCI bridge: nVidia Corporation MCP61 PCI bridge (rev a1)
00:05.0 Audio device: nVidia Corporation MCP61 High Definition Audio (rev a2)
Subsystem: Elitegroup Computer Systems Device a88d
00:06.0 IDE interface: nVidia Corporation MCP61 IDE (rev a2)
Kernel driver in use: pata_amd
00:08.0 IDE interface: nVidia Corporation MCP61 SATA Controller (rev a2)
Kernel driver in use: sata_nv
00:09.0 PCI bridge: nVidia Corporation MCP61 PCI Express bridge (rev a2)
00:0b.0 PCI bridge: nVidia Corporation MCP61 PCI Express bridge (rev a2)
00:0c.0 PCI bridge: nVidia Corporation MCP61 PCI Express bridge (rev a2)
00:0d.0 VGA compatible controller: nVidia Corporation C61 [GeForce 6100 nForce 405] (rev a2)
Kernel driver in use: nouveau
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
Kernel driver in use: k8temp
01:05.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8185 IEEE 802.11a/b/g Wireless LAN Controller (rev 20)
Subsystem: Realtek Semiconductor Co., Ltd. Device 8225
Kernel driver in use: rtl8180
01:06.0 Modem: Motorola SM56 Data Fax Modem (rev 04)
Subsystem: Motorola Device 3020
01:09.0 FireWire (IEEE 1394): Texas Instruments TSB43AB23 IEEE-1394a-2000 Controller (PHY/Link)
Subsystem: Elitegroup Computer Systems Device 8056
Kernel driver in use: firewire_ohci
03:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8056 PCI-E Gigabit Ethernet Controller (rev 12)
Kernel driver in use: sky2
root@178235066008:/home/hagonbc# cat /etc/resolv.conf
# Generated by NetworkManager
nameserver 212.2.96.53
nameserver 212.2.96.54
root@178235066008:/home/hagonbc# cat /etc/network/interfaces
auto lo
iface lo inet loopback
allow-hotplug eth0
#NetworkManager#iface eth0 inet dhcp
