Brak dźwi
czacha777
Brak dźwięku po instalacji Debiana
Post autor: czacha777 »
Mam podobny problem jak w tym temacie: http://debian.linux.pl/threads/25846-Br ... ie-Squeeze na świeżej instalacji Debiana, może komuś udało się to rozwiązać? Mam jądro w wersji 3.2.0-1-amd64. Pojawia się też komunikat o braku "Gstreamer". Próbowałem, instalować pakiety Gstreamer alsa-source, base, utils. ale niestety bez skutku. Co mogę jeszcze zrobić?
root@debian:/home/czacha777# cat /proc/asound/cards
 0 [SB             ]: HDA-Intel - HDA ATI SB
                      HDA ATI SB at 0xfe024000 irq 16
 1 [Generic        ]: HDA-Intel - HD-Audio Generic
                      HD-Audio Generic at 0xfdffc000 irq 43
root@debian:/home/czacha777# dpkg -l | grep alsa
ii  alsa-base                            1.0.23+dfsg-2                      ALSA driver configuration files
ii  alsa-source                          1.0.23+dfsg-2                      ALSA driver sources
ii  alsa-utils                           1.0.23-3                           Utilities for configuring and using ALSA
rc  alsamixergui                         0.9.0rc2-1-9                       graphical soundcard mixer for ALSA soundcard driver
ii  alsaplayer-alsa                      0.99.80-5+b1                       PCM player designed for ALSA (ALSA output module)
ii  alsaplayer-common                    0.99.80-5+b1                       PCM player designed for ALSA (common files)
ii  alsaplayer-gtk                       0.99.80-5+b1                       PCM player designed for ALSA (GTK+ version)
ii  alsaplayer-jack                      0.99.80-5+b1                       PCM player designed for ALSA (JACK output module)
rc  cairo-dock-alsamixer-plugin          2.1.3.10-3                         Cairo-dock - Alsamixer plug-in
ii  gnome-alsamixer                      0.9.7~cvs.20060916.ds.1-2          ALSA sound mixer for GNOME
ii  libsdl1.2debian-alsa                 1.2.14-6.1                         Simple DirectMedia Layer (with X11 and ALSA options)
ii  libsox-fmt-alsa                      14.3.1-1+b1                        SoX alsa format I/O library
root@debian:/home/czacha777# cat /proc/asound/modules
 0 snd_hda_intel
 1 snd_hda_intel
root@debian:/home/czacha777# cat /proc/asound/version
Advanced Linux Sound Architecture Driver Version 1.0.24.
root@debian:/home/czacha777#  lspci | grep -i audio
00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA)
01:00.1 Audio device: ATI Technologies Inc Redwood HDMI Audio [Radeon HD 5600 Series]
czacha777@debian:~$ cat /proc/asound/modules
 0 snd_hda_intel
 1 snd_hda_intel
czacha777@debian:~$ cat /proc/asound/version
Advanced Linux Sound Architecture Driver Version 1.0.21.
czacha777@debian:~$
Wynik skryptu alsy:
http://www.alsa-project.org/db/?f=5138f ... 05f856b00a
!!ALSA Information Script v 0.4.60
!!Script ran on: Sat Feb 18 12:28:46 UTC 2012
!!Linux Distribution
Debian GNU/Linux 6.0 \n \l
!!DMI Information
Manufacturer:      Gigabyte Technology Co., Ltd.
Product Name:      GA-MA74GMT-S2
Product Version:
!!Kernel Information
Kernel release:    2.6.32-5-amd64
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     1.0.21
Library version:    1.0.23
Utilities version:  1.0.23
!!Loaded ALSA modules
snd_hda_intel
snd_hda_intel
!!Sound Servers on this system
No sound servers found.
!!Soundcards recognised by ALSA
                      HD-Audio Generic at 0xfdffc000 irq 19
!!PCI Soundcards installed in the system
!!Advanced information - PCI Vendor/Device/Subsystem ID's
00:14.2 0403: 1002:4383
	Subsystem: 1458:a002
01:00.1 0403: 1002:aa60
	Subsystem: 1787:aa60
!!Modprobe options (Sound related)
snd-atiixp-modem: index=-2
snd-intel8x0m: index=-2
snd-via82xx-modem: index=-2
snd-pcsp: index=-2
snd-usb-audio: index=-2
!!Loaded sound module options
!!Module: snd_hda_intel
	bdl_pos_adj : 32,32,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : 0
	id : <NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	model : <NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>
	patch : <NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>
	position_fix : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	power_save : 0
	power_save_controller : Y
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
	single_cmd : N
	enable_msi : 0
	power_save : 0
	single_cmd : N
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC887
Address: 0
Function Id: 0x1
Vendor Id: 0x10ec0887
Subsystem Id: 0x1458a002
Revision Id: 0x100302
No Modem Function Group found
Default PCM:
    rates [0x5f0]: 32000 44100 48000 88200 96000 192000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Amp-Out caps: ofs=0x40, nsteps=0x40, stepsize=0x03, mute=0
  Amp-Out vals:  [0x40 0x40]
  Converter: stream=0, channel=0
  PCM:
    rates [0x560]: 44100 48000 96000 192000
    formats [0x1]: PCM
  Power: setting=D0, actual=D0
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  PCM:
    formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  PCM:
    formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  PCM:
    formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
  Digital:
  Digital category: 0x0
  PCM:
    formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Amp-In caps: ofs=0x10, nsteps=0x2e, stepsize=0x03, mute=1
  Amp-In vals:  [0x80 0x80]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x22
Node 0x0a [Audio Input] wcaps 0x100711: Stereo Digital
  SDI-Select: 0
  Digital:
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 10
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Connection: 2
     0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x05 0x0b
Node 0x10 [Audio Output] wcaps 0x611: Stereo Digital
  Digital:
  PCM:
    formats [0x1]: PCM
Node 0x11 [Pin Complex] wcaps 0x400781: Stereo Digital
  Pincap 0x00000014: OUT Detect
  Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
    Conn = 1/8, Color = Black
    DefAssociation = 0xf, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=00, enabled=0
  Connection: 1
     0x10
Node 0x12 [Pin Complex] wcaps 0x400401: Stereo
  Pincap 0x00000020: IN
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x00 0x00]
  Pincap 0x0000003e: IN OUT HP Detect Trigger
  Pin Default 0x01014410: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Green
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0c
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Pincap 0x00000036: IN OUT Detect Trigger
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0d
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0e
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Amp-In vals:  [0x00 0x00]
  Amp-Out vals:  [0x80 0x80]
  Pincap 0x00003736: IN OUT Detect Trigger
    Vref caps: HIZ 50 GRD 80 100
  Pin Default 0x01a19c40: [Jack] Mic at Ext Rear
    Conn = 1/8, Color = Pink
    DefAssociation = 0x4, Sequence = 0x0
  Pin-ctls: 0x24: IN VREF_80
  Connection: 5
     0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Pincap 0x0000373e: IN OUT HP Detect Trigger
  Pin Default 0x02a19c50: [Jack] Mic at Ext Front
    DefAssociation = 0x5, Sequence = 0x0
  Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Pin Default 0x0181344f: [Jack] Line In at Ext Rear
    Conn = 1/8, Color = Blue
    DefAssociation = 0x4, Sequence = 0xf
  Pin-ctls: 0x20: IN VREF_HIZ
  Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Pin Default 0x02214c20: [Jack] HP Out at Ext Front
    DefAssociation = 0x2, Sequence = 0x0
  Pin-ctls: 0xc0: OUT HP VREF_HIZ
  Connection: 5
Node 0x1c [Pin Complex] wcaps 0x400481: Stereo
  Pincap 0x00000024: IN Detect
  Pin Default 0x593301f0: [N/A] CD at Int ATAPI
    Conn = ATAPI, Color = Unknown
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
  Pin Default 0x4005c603: [N/A] Line Out at Ext N/A
    Conn = Optical, Color = UNKNOWN
    DefAssociation = 0x0, Sequence = 0x3
  Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
  Pin Default 0x014b6130: [Jack] SPDIF Out at Ext Rear
    Conn = Comb, Color = Orange
    DefAssociation = 0x3, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x06
Node 0x1f [Pin Complex] wcaps 0x400681: Stereo Digital
  Pin Default 0x01cb7160: [Jack] SPDIF In at Ext Rear
    Conn = Comb, Color = Yellow
    DefAssociation = 0x6, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
  Processing caps: benign=0, ncoeff=24
  Processing Coefficient: 0x3f02
  Coefficient Index: 0x0d
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In vals:  [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 12
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b 0x12
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 11
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  PCM:
    formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x25 0x0b
Codec: ATI R6xx HDMI
Address: 0
Function Id: 0x1
Vendor Id: 0x1002aa01
Subsystem Id: 0x00aa0100
Revision Id: 0x100200
Default PCM:
    rates [0x70]: 32000 44100 48000
    bits [0x2]: 16
    formats [0x1]: PCM
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x201: Stereo Digital
  Digital:
Node 0x03 [Pin Complex] wcaps 0x400381: Stereo Digital
  Pincap 0x00000094: OUT Detect HDMI
  Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x02
--endcollapse--
!!ALSA Device nodes
crw-rw----  1 root audio 116, 10 Feb 18 12:43 /dev/snd/controlC0
crw-rw----  1 root audio 116, 13 Feb 18 12:43 /dev/snd/controlC1
crw-rw----  1 root audio 116,  9 Feb 18 12:43 /dev/snd/hwC0D0
crw-rw----  1 root audio 116, 12 Feb 18 12:43 /dev/snd/hwC1D0
crw-rw----  1 root audio 116,  8 Feb 18 12:43 /dev/snd/pcmC0D0c
crw-rw----  1 root audio 116,  7 Feb 18 13:28 /dev/snd/pcmC0D0p
crw-rw----  1 root audio 116,  6 Feb 18 12:43 /dev/snd/pcmC0D1c
crw-rw----  1 root audio 116,  5 Feb 18 12:43 /dev/snd/pcmC0D1p
crw-rw----  1 root audio 116,  4 Feb 18 12:43 /dev/snd/pcmC0D2c
crw-rw----  1 root audio 116, 11 Feb 18 12:43 /dev/snd/pcmC1D3p
crw-rw----  1 root audio 116,  3 Feb 18 12:43 /dev/snd/seq
crw-rw----  1 root audio 116,  2 Feb 18 12:43 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  80 Feb 18 12:43 .
drwxr-xr-x 3 root root 300 Feb 18 12:43 ..
lrwxrwxrwx 1 root root  12 Feb 18 12:43 pci-0000:00:14.2 -> ../controlC0
lrwxrwxrwx 1 root root  12 Feb 18 12:43 pci-0000:01:00.1 -> ../controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: SB [HDA ATI SB], device 0: ALC887 Analog [ALC887 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: SB [HDA ATI SB], device 1: ALC887 Digital [ALC887 Digital]
  Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 3: ATI HDMI [ATI HDMI]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
  Subdevices: 1/1
card 0: SB [HDA ATI SB], device 2: ALC887 Analog [ALC887 Analog]
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card 0 [SB]
amixer: Mixer load hw:0 error: Invalid argument
Card hw:0 'SB'/'HDA ATI SB at 0xfe024000 irq 16'
  Mixer name	: 'Realtek ALC887'
  Components	: 'HDA:10ec0887,1458a002,00100302'
  Controls      : 40
amixer: Mixer hw:0 load error: Invalid argument
!!-------Mixer controls for card 1 [Generic]
Card hw:1 'Generic'/'HD-Audio Generic at 0xfdffc000 irq 19'
  Mixer name	: 'ATI R6xx HDMI'
  Components	: 'HDA:1002aa01,00aa0100,00100200'
  Controls      : 4
  Simple ctrls  : 1
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined penum
  Playback channels: Mono
  Mono: Playback [off]
!!Alsactl output
--startcollapse--
--endcollapse--
!!All Loaded Modules
Module
powernow_k8
cpufreq_powersave
cpufreq_conservative
cpufreq_userspace
cpufreq_stats
parport_pc
ppdev
lp
parport
sco
bridge
stp
bnep
rfcomm
l2cap
bluetooth
rfkill
binfmt_misc
fuse
loop
snd_hda_codec_atihdmi
snd_hda_codec_realtek
snd_hda_intel
snd_hda_codec
snd_hwdep
snd_pcm
radeon
snd_seq
snd_timer
ttm
snd_seq_device
drm_kms_helper
snd
drm
soundcore
snd_page_alloc
i2c_algo_bit
edac_core
edac_mce_amd
i2c_piix4
k10temp
i2c_core
pcspkr
evdev
processor
button
serio_raw
ext4
mbcache
jbd2
crc16
usbhid
hid
sg
sr_mod
cdrom
sd_mod
crc_t10dif
ata_generic
usb_storage
ohci_hcd
pata_atiixp
ahci
floppy
r8169
mii
thermal
thermal_sys
ehci_hcd
libata
usbcore
nls_base
scsi_mod
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x11 0x411111f0
0x12 0x411111f0
0x14 0x01014410
0x15 0x411111f0
0x16 0x411111f0
0x17 0x411111f0
0x18 0x01a19c40
0x19 0x02a19c50
0x1a 0x0181344f
0x1b 0x02214c20
0x1c 0x593301f0
0x1d 0x4005c603
0x1e 0x014b6130
0x1f 0x01cb7160
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC1D0/init_pin_configs:
0x03 0x18560010
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
!!ALSA/HDA dmesg
[    5.465036] [drm] Connector 0:
[    5.465037] [drm]   HDMI-A
[    5.465038] [drm]   HPD4
[    5.465055] [drm]     CRT2: INTERNAL_KLDSCP_DAC2
[    5.564048] HDA Intel 0000:00:14.2: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    5.589425] [drm] fb mappable at 0xD0040000
[    5.609800] [drm] Initialized radeon 2.0.0 20080528 for 0000:01:00.0 on minor 0
[    5.700031] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:14.2/input/input8
[    5.702734] HDA Intel 0000:01:00.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[    5.702766] HDA Intel 0000:01:00.1: setting latency timer to 64
[    6.382550] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.385009] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.387671] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.389945] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.393401] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.393547] usb-storage: device scan complete
[    6.402423] sd 6:0:0:2: [sde] Attached SCSI removable disk
[    6.403940] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.406512] sd 6:0:0:3: [sdf] Attached SCSI removable disk
[    6.408308] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.417549] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.421297] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.426546] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.432328] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.439501] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.442110] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.444737] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.447086] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.451230] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.453378] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.455646] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.457899] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.461107] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.463873] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.466195] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.469023] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.471708] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.475956] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.478230] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.480627] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.484425] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.488061] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.490542] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.493917] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.496065] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.499502] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.501667] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.504018] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    6.506853] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    8.500032] hub 6-0:1.0: Cannot enable port 1.  Maybe the USB cable is bad?
[   15.218894] loop: module loaded
[   16.177396] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.179396] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.181417] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.183416] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.185437] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.187438] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.189478] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.191500] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.193737] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.195741] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.197957] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.199957] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.201999] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.204021] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.206591] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.208633] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.210611] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.212639] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.214639] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.216699] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.218693] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.220740] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.222742] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.224778] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.226784] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.228823] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.230823] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.232863] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.234869] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.236900] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.238955] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.240975] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.242975] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.245121] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.247264] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.249288] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[   16.330150] fuse init (API version 7.13)
[   30.420009] eth0: no IPv6 routers present
[   45.123749] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[  502.468768] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[  502.474514] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[  502.504298] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[ 2712.507682] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[ 2712.513717] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[ 2712.535864] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
czacha777, pogrywasz sobie w kulki na małe bramki. Nie ma innych ,,normalnych'' serwisów do wstawienia pliku tekstowego. A opcja dodaj załącznik na forum? Popraw nie każdy ma konto na użytym przez Ciebie serwisie.
I wstaw zwykły plik tekstowy, tak jak jest oryginalnie generowany.
czacha777
fnmirk pisze: czacha777, pogrywasz sobie w kulki na małe bramki. Nie ma innych ,,normalnych'' serwisów do wstawienia pliku tekstowego. A opcja dodaj załącznik na forum? Popraw nie każdy ma konto na użytym przez Ciebie serwisie.
Na rapidzie nie trzeba mieć konta by pobrać, może w linku będzie ok ?
http:// wklej.org
Masz dwie karty dźwiękowe. Czy do odpowiedniej karty dźwiękowej podpiąłeś głośniki? Zdecyduj się której karty dźwiękowej chcesz używać:
http://debian.linux.pl/threads/19984-Dw ... post124590
czacha777
Mój plik /alsa-base.conf wygląda tak:
# autoloader aliases
install sound-slot-0 /sbin/modprobe snd-card-0
install sound-slot-1 /sbin/modprobe snd-card-1
install sound-slot-2 /sbin/modprobe snd-card-2
install sound-slot-3 /sbin/modprobe snd-card-3
install sound-slot-4 /sbin/modprobe snd-card-4
install sound-slot-5 /sbin/modprobe snd-card-5
install sound-slot-6 /sbin/modprobe snd-card-6
install sound-slot-7 /sbin/modprobe snd-card-7
# Cause optional modules to be loaded above generic modules
install snd /sbin/modprobe --ignore-install snd && { /sbin/modprobe --quiet snd-ioctl32 ; /sbin/modprobe --quiet snd-seq ; }
install snd-rawmidi /sbin/modprobe --ignore-install snd-rawmidi && { /sbin/modprobe --quiet snd-seq-midi ; : ; }
install snd-emu10k1 /sbin/modprobe --ignore-install snd-emu10k1 && { /sbin/modprobe --quiet snd-emu10k1-synth ; : ; }
# Prevent abnormal drivers from grabbing index 0
options bt87x index=-2
options cx88_alsa index=-2
options snd-atiixp-modem index=-2
options snd-intel8x0m index=-0
options snd-via82xx-modem index=-2
# Keep snd-pcsp from beeing loaded as first soundcard
options snd-pcsp index=-2
# Keep snd-usb-audio from beeing loaded as first soundcard
options snd-usb-audio index=-2
Co mam w nim zmienić? Chcę używać dźwięku wbudowanego na płycie, druga karta wykrywana to grafika z hdmi.
Masz problem bo obydwie karty korzystają z tego samego modułu. Wpisz w konsoli użytkownika:
alsamixer
następnie naciśnij klawisz F6 i wybierz odpowiednią kartę dźwiękową.
czacha777
Problem w tym że nic nie chce się uruchomić.
root@debian:/home/czacha777# alsamixer
ALSA lib conf.c:1181 :( parse_def) HD-Audio does not exists
ALSA lib conf.c:1661 :( snd_config_load1) _toplevel_:3:30:Unexpected char
ALSA lib conf.c:3441 :( snd_config_hook_load) /etc/asound.conf may be old or corrupted: consider to remove or fix it
ALSA lib conf.c:3302 :( snd_config_hooks_call) function snd_config_hook_load returned error: Zły argument
ALSA lib conf.c:3687 :( snd_config_update_r) hooks failed, removing configuration
cannot open mixer: Zły argument
Uruchom program w konsoli zwykłego użytkownika nie administratora.
