Fragment kodu pliku konfiguracyjnego dansguardian.conf:
# Network Settings
# the IP that DansGuardian listens on. If left blank DansGuardian will
# listen on all IPs. That would include all NICs, loopback, modem, etc.
# Normally you would have your firewall protecting this, but if you want
# you can limit it to only 1 IP. Yes only one.
filterip = 172.23.198.1
# the port that DansGuardian listens to.
filterport = 8080
# the ip of the proxy (default is the loopback - i.e. this server)
proxyip = 172.23.198.1
# the port DansGuardian connects to proxy on
proxyport = 3128 Kod: Zaznacz cały
# Network Settings
filterport = 8080
proxyport = 3128
echo 1 > /proc/sys/net/ipv4/ip_forward
# czyszczenie starych regul
iptables -F
iptables -X
iptables -t nat -X
iptables -t nat -F
# ustawienie polityki dzialania
iptables -P INPUT DROP
iptables -P FORWARD DROP
iptables -P OUTPUT ACCEPT
# zezwolenie na laczenie sie z naszym zewnetrznym ip po ssh
iptables -A INPUT -i eth0 -s 172.23.198.0/24 -j ACCEPT
iptables -A INPUT -p icmp --icmp-type echo-request -j ACCEPT
iptables -A FORWARD -o lo -j ACCEPT
iptables -A INPUT -s 0/0 -d 172.23.198.1 -p tcp --dport 3128 -j ACCEPT
iptables -A OUTPUT -s 0/0 -d 172.23.198.1 -p tcp --dport 3128 -j ACCEPT
iptables -A INPUT -s 0/0 -d 172.23.198.1 -p udp --dport 3128 -j ACCEPT
iptables -A OUTPUT -s 0/0 -d 172.23.198.1 -p udp --dport 3128 -j ACCEPT
iptables -A INPUT -s 0/0 -d 172.23.198.1 -p tcp --dport 8080 -j ACCEPT
iptables -A OUTPUT -s 0/0 -d 172.23.198.1 -p tcp --dport 8080 -j ACCEPT
iptables -A INPUT -s 0/0 -d 172.23.198.1 -p udp --dport 8080 -j ACCEPT
iptables -A OUTPUT -s 0/0 -d 172.23.198.1 -p udp --dport 8080 -j ACCEPT
iptables -A INPUT -s 0/0 -d 172.23.198.0/24 -p tcp --dport 3128 -j ACCEPT
iptables -A OUTPUT -s 0/0 -d 172.23.198.0/24 -p tcp --dport 3128 -j ACCEPT
iptables -A INPUT -s 0/0 -d 172.23.198.0/24 -p udp --dport 3128 -j ACCEPT
iptables -A OUTPUT -s 0/0 -d 172.23.198.0/24 -p udp --dport 3128 -j ACCEPT
# polaczenia nawiazane
iptables -A INPUT -j ACCEPT -m state --state ESTABLISHED,RELATED
iptables -A FORWARD -j ACCEPT -m state --state ESTABLISHED,RELATED
iptables -A OUTPUT -j ACCEPT -m state --state ESTABLISHED,RELATED
# udostepniaie internetu w sieci lokalnej
iptables -t filter -A FORWARD -s 172.23.198.0/255.255.255.0 -d 0/0 -j ACCEPT
iptables -t filter -A FORWARD -s 0/0 -d 172.23.198.0/255.255.255.0 -j ACCEPT
iptables -t nat -A POSTROUTING -s 172.23.198.0/24 -j MASQUERADE
iptables -t nat -A PREROUTING -s 172.23.198.0/24 -p tcp --dport 80 -j REDIRECT --to-port 8080
iptables -t nat -A PREROUTING -s 172.23.198.0/255.255.255.0 -p tcp --dport 80 -j REDIRECT --to-port 3128
Już chyba wiem. Nie ustawiłem rutingu na drugą kartę po zmianie adresu. Ale i tak proszę o uwagi krytyczne i analizę. Pingi na ruter 192.168.1.1 chodzą
Czy obie karty mogą mieć tą samą maskę?
Ruter umożliwia nadanie masek:
- 255.255.255.0
255.255.255.128
255.255.255.192
255.255.255.224
255.255.255.240
255.255.255.248
255.255.255.252
[Dodano: 2007-07-02, 18:57]
Przepraszam za zamieszanie. Wpisałem zły adres rutera jako bramy, ale wpadka.
