Już podaję.
ls -l -a /etc/apache2/mods-enabled
lrwxrwxrwx 1 root root 28 12-14 13:08 alias.conf -> ../mods-available/alias.conf
lrwxrwxrwx 1 root root 28 12-14 13:08 alias.load -> ../mods-available/alias.load
lrwxrwxrwx 1 root root 33 12-14 13:08 auth_basic.load -> ../mods-available/auth_basic.load
lrwxrwxrwx 1 root root 33 12-14 13:08 authn_file.load -> ../mods-available/authn_file.load
lrwxrwxrwx 1 root root 36 12-14 13:08 authz_default.load -> ../mods-available/authz_default.load
lrwxrwxrwx 1 root root 38 12-14 13:08 authz_groupfile.load -> ../mods-available/authz_groupfile.load
lrwxrwxrwx 1 root root 33 12-14 13:08 authz_host.load -> ../mods-available/authz_host.load
lrwxrwxrwx 1 root root 33 12-14 13:08 authz_user.load -> ../mods-available/authz_user.load
lrwxrwxrwx 1 root root 32 12-14 13:08 autoindex.conf -> ../mods-available/autoindex.conf
lrwxrwxrwx 1 root root 32 12-14 13:08 autoindex.load -> ../mods-available/autoindex.load
lrwxrwxrwx 1 root root 26 12-14 13:08 cgi.load -> ../mods-available/cgi.load
lrwxrwxrwx 1 root root 30 12-14 13:08 deflate.conf -> ../mods-available/deflate.conf
lrwxrwxrwx 1 root root 30 12-14 13:08 deflate.load -> ../mods-available/deflate.load
lrwxrwxrwx 1 root root 26 12-14 13:08 dir.conf -> ../mods-available/dir.conf
lrwxrwxrwx 1 root root 26 12-14 13:08 dir.load -> ../mods-available/dir.load
lrwxrwxrwx 1 root root 26 12-14 13:08 env.load -> ../mods-available/env.load
lrwxrwxrwx 1 root root 27 12-14 13:08 mime.conf -> ../mods-available/mime.conf
lrwxrwxrwx 1 root root 27 12-14 13:08 mime.load -> ../mods-available/mime.load
lrwxrwxrwx 1 root root 35 12-14 13:44 mod-security.load -> ../mods-available/mod-security.load
lrwxrwxrwx 1 root root 34 12-14 13:08 negotiation.conf -> ../mods-available/negotiation.conf
lrwxrwxrwx 1 root root 34 12-14 13:08 negotiation.load -> ../mods-available/negotiation.load
lrwxrwxrwx 1 root root 27 12-14 13:09 perl.load -> ../mods-available/perl.load
lrwxrwxrwx 1 root root 27 12-19 11:16 php5.conf -> ../mods-available/php5.conf
lrwxrwxrwx 1 root root 27 12-19 11:16 php5.load -> ../mods-available/php5.load
lrwxrwxrwx 1 root root 29 12-14 13:09 python.load -> ../mods-available/python.load
lrwxrwxrwx 1 root root 33 12-14 13:08 reqtimeout.conf -> ../mods-available/reqtimeout.conf
lrwxrwxrwx 1 root root 33 12-14 13:08 reqtimeout.load -> ../mods-available/reqtimeout.load
lrwxrwxrwx 1 root root 30 12-14 13:56 rewrite.load -> ../mods-available/rewrite.load
lrwxrwxrwx 1 root root 31 12-14 13:08 setenvif.conf -> ../mods-available/setenvif.conf
lrwxrwxrwx 1 root root 31 12-14 13:08 setenvif.load -> ../mods-available/setenvif.load
lrwxrwxrwx 1 root root 26 12-14 13:56 ssl.conf -> ../mods-available/ssl.conf
lrwxrwxrwx 1 root root 26 12-14 13:56 ssl.load -> ../mods-available/ssl.load
lrwxrwxrwx 1 root root 29 12-14 13:08 status.conf -> ../mods-available/status.conf
lrwxrwxrwx 1 root root 29 12-14 13:08 status.load -> ../mods-available/status.load
lrwxrwxrwx 1 root root 32 12-14 13:44 unique_id.load -> ../mods-available/unique_id.load
/etc/apache2/ports.conf
NameVirtualHost *:80
Listen 80
<IfModule mod_ssl.c>
# If you add NameVirtualHost *:443 here, you will also have to change
# the VirtualHost statement in /etc/apache2/sites-available/default-ssl
# to <VirtualHost *:443>
# Server Name Indication for SSL named virtual hosts is currently not
# supported by MSIE on Windows XP.
Listen 443
</IfModule>
<IfModule mod_gnutls.c>
Listen 443
</IfModule>
<VirtualHost *:80>
ServerAdmin webmaster@localhost
DocumentRoot /var/www
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from all
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
ErrorLog ${APACHE_LOG_DIR}/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/access.log combined
Alias /doc/ "/usr/share/doc/"
<Directory "/usr/share/doc/">
Options Indexes MultiViews FollowSymLinks
AllowOverride None
Order deny,allow
Deny from all
Allow from 127.0.0.0/255.0.0.0 ::1/128
</Directory>
</VirtualHost>
<VirtualHost _default_:443>
<Directory />
AllowOverride None
</Directory>
AllowOverride None
Order allow,deny
allow from all
</Directory>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# alert, emerg.
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/ssl_access.log combined
AllowOverride None
Order deny,allow
Deny from all
</Directory>
SSLEngine on
SSLCertificateFile /etc/apache2/ssl/apache2.crt
SSLCertificateKeyFile /etc/apache2/ssl/apache2.key
<FilesMatch "\.(cgi|shtml|phtml|php)$">
SSLOptions +StdEnvVars
</FilesMatch>
<Directory /usr/lib/cgi-bin>
</Directory>
BrowserMatch "MSIE [2-6]" \
nokeepalive ssl-unclean-shutdown \
downgrade-1.0 force-response-1.0
# MSIE 7 and newer should be able to use keepalive
BrowserMatch "MSIE [17-9]" ssl-unclean-shutdown
</VirtualHost>
</IfModule>
/etc/apache2/sites-available/domena1.pl
<VirtualHost *:80>
ServerName [url=http://www.test.domena1.pl]www.test.domena1.pl[/URL]
ServerAdmin [EMAIL="webmaster@domena1.pl"]webmaster@domena1.pl[/EMAIL]
ServerAlias test.domena1.pl
DocumentRoot /home/test/public_html
<Directory />
AllowOverride None
</Directory>
<Directory /home/test/public_html/>
AllowOverride None
Order allow,deny
allow from all
</Directory>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# alert, emerg.
LogLevel warn
AllowOverride None
Order deny,allow
Deny from all
</Directory>
Alias /javascript/ /home/test/public_html/javascript/
<Directory "/home/test/public_html/javascript/">
</Directory>
<Location />
RewriteEngine on
RewriteCond %{HTTPS} off
RewriteRule ^(.*)$ [URL]https://www.test.domena1.pl[/URL] [R]
</Location>
</VirtualHost>
/etc/apache2/site-available/domena1.pl-ssl
<VirtualHost *:443>
SSLEngine On
<Directory />
AllowOverride None
</Directory>
AllowOverride None
Order allow,deny
allow from all
</Directory>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# alert, emerg.
LogLevel warn
AllowOverride None
Order deny,allow
Deny from all
</Directory>
Options FollowSymLinks MultiViews
</Directory>
</VirtualHost>
</IfModule>
Naprawdę nikt nie wie? Dodam, że na drugim serwerze mam taką samą konfigurację i jest wszystko w porządku.
