Posiadam nagrywarkE dvd LG sata i system Debian 6 z jądrem 2.6.38-bpo.2-amd64 z Backportów, niestety go nie wykrywa. Nie widać go w dmesg, ani w /dev/dvd, /dev/cdrom, /dev/sr*, /dev/sd*. Na poprzedniej wersji jądra wszystko działało (2.6.32-5-amd64).
lspci -k
00:00.0 Host bridge: Intel Corporation Sandy Bridge DRAM Controller (rev 09)
Kernel driver in use: agpgart-intel
00:02.0 VGA compatible controller: Intel Corporation Sandy Bridge Integrated Graphics Controller (rev 09)
Subsystem: Giga-byte Technology Device d000
Kernel driver in use: i915
00:16.0 Communication controller: Intel Corporation Cougar Point HECI Controller #1 (rev 04)
Subsystem: Giga-byte Technology Device 1c3a
00:1a.0 USB Controller: Intel Corporation Cougar Point USB Enhanced Host Controller #2 (rev 05)
Subsystem: Giga-byte Technology Device 5006
00:1b.0 Audio device: Intel Corporation Cougar Point High Definition Audio Controller (rev 05)
Subsystem: Giga-byte Technology Device a002
Kernel driver in use: HDA Intel
00:1c.0 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 1 (rev b5)
00:1c.4 PCI bridge: Intel Corporation Cougar Point PCI Express Root Port 5 (rev b5)
00:1d.0 USB Controller: Intel Corporation Cougar Point USB Enhanced Host Controller #1 (rev 05)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5)
00:1f.0 ISA bridge: Intel Corporation Cougar Point LPC Controller (rev 05)
Subsystem: Giga-byte Technology Device 5001
00:1f.2 IDE interface: Intel Corporation Cougar Point 4 port SATA IDE Controller (rev 05)
Subsystem: Giga-byte Technology Device b002
Kernel driver in use: ata_piix
00:1f.3 SMBus: Intel Corporation Cougar Point SMBus Controller (rev 05)
Kernel driver in use: i801_smbus
00:1f.5 IDE interface: Intel Corporation Cougar Point 2 port SATA IDE Controller (rev 05)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
Subsystem: Giga-byte Technology GA-EP45-DS5 Motherboard
Kernel driver in use: r8169Kod: Zaznacz cały
uname -a
Linux debian 2.6.38-bpo.2-amd64 #1 SMP Mon Jun 6 15:24:02 UTC 2011 x86_64 GNU/LinuxKod: Zaznacz cały
lsmod
Module Size Used by
acpi_cpufreq 12849 0
mperf 12411 1 acpi_cpufreq
cpufreq_conservative 13878 0
cpufreq_userspace 12576 0
cpufreq_powersave 12454 0
cpufreq_stats 12713 0
ppdev 12725 0
lp 17190 0
sco 17555 2
bridge 61403 0
stp 12392 1 bridge
bnep 17424 2
rfcomm 32744 0
l2cap 40163 6 bnep,rfcomm
bluetooth 55503 6 sco,bnep,rfcomm,l2cap
rfkill 19014 3 bluetooth
kvm_intel 49947 0
binfmt_misc 12914 1
kvm 263288 1 kvm_intel
fuse 61520 1
ext2 62796 1
loop 22515 0
i915 315266 2
drm_kms_helper 26893 1 i915
snd_hda_codec_realtek 283898 1
drm 165567 3 i915,drm_kms_helper
i2c_algo_bit 12834 1 i915
snd_hda_intel 25946 0
snd_hda_codec 67647 2 snd_hda_codec_realtek,snd_hda_intel
snd_hwdep 13148 1 snd_hda_codec
snd_pcm 67327 2 snd_hda_intel,snd_hda_codec
video 17553 1 i915
snd_seq 44678 0
snd_timer 22658 2 snd_pcm,snd_seq
snd_seq_device 13155 1 snd_seq
snd 52280 8 snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_seq,snd_timer,snd_seq_device
processor 27431 5 acpi_cpufreq
parport_pc 22191 1
soundcore 13014 1 snd
thermal_sys 17939 2 video,processor
serio_raw 12878 0
tpm_tis 13125 0
tpm 17756 1 tpm_tis
tpm_bios 12903 1 tpm
snd_page_alloc 12969 2 snd_hda_intel,snd_pcm
button 12994 1 i915
parport 31650 3 ppdev,lp,parport_pc
i2c_i801 16870 0
joydev 17138 0
evdev 17475 11
i2c_core 23725 5 i915,drm_kms_helper,drm,i2c_algo_bit,i2c_i801
pcspkr 12579 0
ext4 285166 6
mbcache 12930 2 ext2,ext4
jbd2 65157 1 ext4
crc16 12343 2 l2cap,ext4
sha256_generic 16797 2
cryptd 14463 0
aes_x86_64 16796 16
aes_generic 37122 1 aes_x86_64
cbc 12747 8
dm_crypt 22256 1
dm_mod 62467 21 dm_crypt
raid10 26243 0
raid456 52187 0
async_raid6_recov 12507 1 raid456
async_pq 12559 2 raid456,async_raid6_recov
raid6_pq 82523 2 async_raid6_recov,async_pq
async_xor 12385 3 raid456,async_raid6_recov,async_pq
xor 12556 1 async_xor
async_memcpy 12350 2 raid456,async_raid6_recov
async_tx 12566 5 raid456,async_raid6_recov,async_pq,async_xor,async_memcpy
raid1 26147 0
raid0 16985 0
multipath 13009 0
linear 12807 0
md_mod 82494 6 raid10,raid456,raid1,raid0,multipath,linear
usbhid 39900 0
hid 72616 1 usbhid
sd_mod 35501 3
crc_t10dif 12348 1 sd_mod
ata_generic 12479 0
ehci_hcd 39529 0
ata_piix 25319 2
libata 147240 2 ata_generic,ata_piix
scsi_mod 161457 2 sd_mod,libata
usbcore 118812 3 usbhid,ehci_hcd
r8169 37209 0
mii 12634 1 r8169
nls_base 12753 1 usbcoreKod: Zaznacz cały
dmesg | grep -i ata
[ 0.000000] BIOS-e820: 00000000dafd3000 - 00000000daff0000 (ACPI data)
[ 0.000000] NODE_DATA [000000021fdfb000 - 000000021fdfffff]
[ 0.000000] Memory: 8100248k/8910848k available (3260k kernel code, 606852k absent, 203748k reserved, 3425k data, 676k init)
[ 0.900474] Write protecting the kernel read-only data: 6144k
[ 0.995028] libata version 3.00 loaded.
[ 0.998922] ata_piix 0000:00:1f.2: version 2.13
[ 0.998942] ata_piix 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.998947] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.151043] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.151317] scsi0 : ata_piix
[ 1.151392] scsi1 : ata_piix
[ 1.151739] ata1: SATA max UDMA/133 cmd 0xfe00 ctl 0xfd00 bmdma 0xfa00 irq 19
[ 1.151744] ata2: SATA max UDMA/133 cmd 0xfc00 ctl 0xfb00 bmdma 0xfa08 irq 19
[ 1.151762] ata_piix 0000:00:1f.5: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 1.151766] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 1.151793] ata_piix 0000:00:1f.5: setting latency timer to 64
[ 1.151982] scsi2 : ata_piix
[ 1.152029] scsi3 : ata_piix
[ 1.152278] ata3: SATA max UDMA/133 cmd 0xf700 ctl 0xf600 bmdma 0xf300 irq 19
[ 1.152281] ata4: SATA max UDMA/133 cmd 0xf500 ctl 0xf400 bmdma 0xf308 irq 19
[ 1.481675] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.492405] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.498720] ata1.01: failed to resume link (SControl 0)
[ 2.506717] ata2.01: failed to resume link (SControl 0)
[ 2.654750] ata1.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.654762] ata1.01: SATA link down (SStatus 0 SControl 0)
[ 2.654772] ata1.01: link offline, clearing class 3 to NONE
[ 2.662759] ata2.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.662775] ata2.01: SATA link down (SStatus 0 SControl 0)
[ 2.662868] ata1.00: ATAPI: HL-DT-ST DVDRAM GH22NS70, EX00, max UDMA/100
[ 2.671044] ata2.00: ATA-8: ST2000DL001-9VT156, CC43, max UDMA/133
[ 2.671047] ata2.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.678831] ata1.00: configured for UDMA/100
[ 2.779433] ata2.00: configured for UDMA/133
[ 2.779443] ata1.00: TEST_UNIT_READY failed (err_mask=0x2)
[ 9.001285] ata1.01: failed to resume link (SControl 0)
[ 9.157314] ata1.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 9.157326] ata1.01: SATA link down (SStatus 0 SControl 0)
[ 9.157336] ata1.01: link offline, clearing class 3 to NONE
[ 9.181379] ata1.00: configured for UDMA/100
[ 14.180156] ata1.00: qc timeout (cmd 0xa0)
[ 14.180158] ata1.00: TEST_UNIT_READY failed (err_mask=0x4)
[ 14.180162] ata1.00: limiting SATA link speed to 1.5 Gbps
[ 14.180165] ata1.00: limiting speed to UDMA/100:PIO3
[ 15.527848] ata1.01: failed to resume link (SControl 0)
[ 15.683878] ata1.00: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 15.683890] ata1.01: SATA link down (SStatus 0 SControl 0)
[ 15.683899] ata1.01: link offline, clearing class 3 to NONE
[ 15.707941] ata1.00: configured for UDMA/100
[ 20.706715] ata1.00: qc timeout (cmd 0xa0)
[ 20.706718] ata1.00: TEST_UNIT_READY failed (err_mask=0x4)
[ 20.706720] ata1.00: disabled
[ 20.706737] ata1.00: hard resetting link
[ 21.026637] ata1.01: hard resetting link
[ 22.054411] ata1.01: failed to resume link (SControl 0)
[ 22.210439] ata1.00: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 22.210451] ata1.01: SATA link down (SStatus 0 SControl 0)
[ 22.210461] ata1.01: link offline, clearing class 3 to NONE
[ 22.210463] ata1: EH complete
[ 22.210543] scsi 1:0:0:0: Direct-Access ATA ST2000DL001-9VT1 CC43 PQ: 0 ANSI: 5
