Wszystko pięknie zainstalowane moduły działają ale nie potrafie uruchomić samej karty sieciowej
uname -a
Linux mirror 2.6.18-4-686 #1 SMP Wed May 9 23:03:12 UTC 2007 i686 GNU/LinuxKod: Zaznacz cały
iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
sit0 no wireless extensions.
eth2 radio off ESSID:"feniu.part"
Mode:Managed Channel:0 Access Point: Not-Associated
Bit Rate:0 kb/s Tx-Power=off Sensitivity=8/0
Retry limit:7 RTS thr :o ff Fragment thr :o ff
Encryption key :o ff
Power Management :o ff
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
ipw2200: Detected Intel PRO/Wireless 2200BG Network Connection
ipw2200: Radio Frequency Kill Switch is On:
Kill switch must be turned off for wireless networking to work.
ipw2200: Detected geography ZZM (11 802.11bg channels, 0 802.11a channels)
lsmod |grep 2200
ipw2200 125252 0
ieee80211 43372 1 ipw2200
firmware_class 9600 2 ipw2200,pcmcia
Po włączeniu przycisku uruchamiającego sieciówke dmesg wysyła:
atkbd.c: Unknown key pressed (translated set 2, code 0x6d on isa0060/serio0).
atkbd.c: Use 'setkeycodes 6d <keycode>' to make it known.
atkbd.c: Unknown key released (translated set 2, code 0x6d on isa0060/serio0).
atkbd.c: Use 'setkeycodes 6d <keycode>' to make it known.Kod: Zaznacz cały
cat /sys/bus/pci/drivers/ipw2200/*/rf_kill
21 = SW based RF kill active (radio off)
2 = HW based RF kill active (radio off)
3 = Both HW and SW RF kill active (radio off)
Próba:
echo 1 > /sys/bus/pci/drivers/ipw2200/*/rf_kill Kod: Zaznacz cały
modprobe ipw2200 led=1Może ktoś pomóc?
