Brak dźwi
Darek554
Brak dźwięku w Debianie Squeeze
Post autor: Darek554 »
Brak dźwięku w Debianie Squeeze:
0 [Intel          ]: HDA-Intel - HDA Intel
                     HDA Intel at 0xfdff8000 irq 16
1 [HDMI           ]: HDA-Intel - HDA ATI HDMI
                     HDA ATI HDMI at 0xfdcfc000 irq 17
 0 snd_hda_intel
 1 snd_hda_intel
Advanced Linux Sound Architecture Driver Version 1.0.21.
Albo jak kto woli z alsy:
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.60
!!Script ran on: Fri Jan 20 15:12:14 UTC 2012
!!Linux Distribution
Debian GNU/Linux 6.0 \n \l
!!DMI Information
Manufacturer:      Gigabyte Technology Co., Ltd.
Product Name:      G31M-ES2L
Product Version:
!!Kernel Information
Kernel release:    2.6.32-5-amd64
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     1.0.21
Library version:    1.0.23
Utilities version:  1.0.23
!!Loaded ALSA modules
snd_hda_intel
snd_hda_intel
!!Sound Servers on this system
No sound servers found.
!!Soundcards recognised by ALSA
!!PCI Soundcards installed in the system
00:1b.0 Audio device: Intel Corporation N10/ICH 7 Family High Definition Audio Controller (rev 01)
01:00.1 Audio device: ATI Technologies Inc HD48x0 audio
!!Advanced information - PCI Vendor/Device/Subsystem ID's
00:1b.0 0403: 8086:27d8 (rev 01)
    Subsystem: 1458:a002
01:00.1 0403: 1002:aa30
    Subsystem: 1787:aa30
!!Modprobe options (Sound related)
snd-atiixp-modem: index=-2
snd-intel8x0m: index=-2
snd-via82xx-modem: index=-2
snd-pcsp: index=-2
snd-usb-audio: index=-2
!!Loaded sound module options
!!Module: snd_hda_intel
    bdl_pos_adj : 1,32,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
    enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
    enable_msi : 0
    id : <NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>
    index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
    model : <NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>
    patch : <NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>
    position_fix : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
    power_save : 0
    power_save_controller : Y
    probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
    probe_only : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
    single_cmd : N
    enable_msi : 0
    power_save : 0
    single_cmd : N
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC887
Address: 2
Function Id: 0x1
Vendor Id: 0x10ec0887
Subsystem Id: 0x1458a002
Revision Id: 0x100302
No Modem Function Group found
Default PCM:
    rates [0x5f0]: 32000 44100 48000 88200 96000 192000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Amp-Out caps: ofs=0x40, nsteps=0x40, stepsize=0x03, mute=0
  Amp-Out vals:  [0x40 0x40]
  Converter: stream=0, channel=0
  PCM:
    rates [0x560]: 44100 48000 96000 192000
    formats [0x1]: PCM
  Power: setting=D0, actual=D0
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  PCM:
    formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  PCM:
    formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  PCM:
    formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
  Digital:
  Digital category: 0x0
  PCM:
    formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Amp-In caps: ofs=0x10, nsteps=0x2e, stepsize=0x03, mute=1
  Amp-In vals:  [0x80 0x80]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x22
Node 0x0a [Audio Input] wcaps 0x100711: Stereo Digital
  SDI-Select: 0
  Digital:
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 10
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Connection: 2
     0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x05 0x0b
Node 0x10 [Audio Output] wcaps 0x611: Stereo Digital
  Digital:
  PCM:
    formats [0x1]: PCM
Node 0x11 [Pin Complex] wcaps 0x400781: Stereo Digital
  Pincap 0x00000014: OUT Detect
  Pin Default 0x411110f0: [N/A] Speaker at Ext Rear
    Conn = 1/8, Color = Black
    DefAssociation = 0xf, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=00, enabled=0
  Connection: 1
     0x10
Node 0x12 [Pin Complex] wcaps 0x400401: Stereo
  Pincap 0x00000020: IN
  Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x00 0x00]
  Pincap 0x0001003e: IN OUT HP EAPD Detect Trigger
  EAPD 0x0:
  Pin Default 0x01014410: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Green
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0c
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Pincap 0x00000036: IN OUT Detect Trigger
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0d
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0e
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Amp-In vals:  [0x00 0x00]
  Amp-Out vals:  [0x80 0x80]
  Pincap 0x00003736: IN OUT Detect Trigger
    Vref caps: HIZ 50 GRD 80 100
  Pin Default 0x01a19c40: [Jack] Mic at Ext Rear
    Conn = 1/8, Color = Pink
    DefAssociation = 0x4, Sequence = 0x0
  Pin-ctls: 0x24: IN VREF_80
  Connection: 5
     0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Pincap 0x0000373e: IN OUT HP Detect Trigger
  Pin Default 0x02a19c50: [Jack] Mic at Ext Front
    DefAssociation = 0x5, Sequence = 0x0
  Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Pin Default 0x0181344f: [Jack] Line In at Ext Rear
    Conn = 1/8, Color = Blue
    DefAssociation = 0x4, Sequence = 0xf
  Pin-ctls: 0x20: IN VREF_HIZ
  Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Pincap 0x0001373e: IN OUT HP EAPD Detect Trigger
  EAPD 0x0:
  Pin Default 0x02214c20: [Jack] HP Out at Ext Front
    DefAssociation = 0x2, Sequence = 0x0
  Pin-ctls: 0xc0: OUT HP VREF_HIZ
  Connection: 5
Node 0x1c [Pin Complex] wcaps 0x400481: Stereo
  Pincap 0x00000024: IN Detect
  Pin Default 0x593301f0: [N/A] CD at Int ATAPI
    Conn = ATAPI, Color = Unknown
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
  Pin Default 0x4005c603: [N/A] Line Out at Ext N/A
    Conn = Optical, Color = UNKNOWN
    DefAssociation = 0x0, Sequence = 0x3
  Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
  Pin Default 0x014b6130: [Jack] SPDIF Out at Ext Rear
    Conn = Comb, Color = Orange
    DefAssociation = 0x3, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x06
Node 0x1f [Pin Complex] wcaps 0x400681: Stereo Digital
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
  Processing caps: benign=0, ncoeff=24
  Processing Coefficient: 0xc00
  Coefficient Index: 0x0c
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In vals:  [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 12
     0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b 0x12
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 11
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  PCM:
    formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x25 0x0b
Codec: ATI R6xx HDMI
Address: 0
Function Id: 0x1
Vendor Id: 0x1002aa01
Subsystem Id: 0x00aa0100
Revision Id: 0x100100
Default PCM:
    rates [0x70]: 32000 44100 48000
    bits [0x2]: 16
    formats [0x1]: PCM
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x201: Stereo Digital
  Digital:
Node 0x03 [Pin Complex] wcaps 0x400381: Stereo Digital
  Pincap 0x00000094: OUT Detect HDMI
  Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x02
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 10 Jan 20 16:02 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 13 Jan 20 16:02 /dev/snd/controlC1
crw-rw----+ 1 root audio 116,  9 Jan 20 16:02 /dev/snd/hwC0D2
crw-rw----+ 1 root audio 116, 12 Jan 20 16:02 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116,  8 Jan 20 16:02 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116,  7 Jan 20 16:10 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116,  6 Jan 20 16:02 /dev/snd/pcmC0D1c
crw-rw----+ 1 root audio 116,  5 Jan 20 16:02 /dev/snd/pcmC0D1p
crw-rw----+ 1 root audio 116,  4 Jan 20 16:02 /dev/snd/pcmC0D2c
crw-rw----+ 1 root audio 116, 11 Jan 20 16:02 /dev/snd/pcmC1D3p
crw-rw----+ 1 root audio 116,  3 Jan 20 16:02 /dev/snd/seq
crw-rw----+ 1 root audio 116,  2 Jan 20 16:02 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  80 Jan 20 16:02 .
drwxr-xr-x 3 root root 300 Jan 20 16:02 ..
lrwxrwxrwx 1 root root  12 Jan 20 16:02 pci-0000:00:1b.0 -> ../controlC0
lrwxrwxrwx 1 root root  12 Jan 20 16:02 pci-0000:01:00.1 -> ../controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: ALC887 Analog [ALC887 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 1: ALC887 Digital [ALC887 Digital]
  Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 3: ATI HDMI [ATI HDMI]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
  Subdevices: 1/1
card 0: Intel [HDA Intel], device 2: ALC887 Analog [ALC887 Analog]
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card 0 [Intel]
amixer: Mixer load hw:0 error: Invalid argument
Card hw:0 'Intel'/'HDA Intel at 0xfdff8000 irq 16'
  Mixer name    : 'Realtek ALC887'
  Components    : 'HDA:10ec0887,1458a002,00100302'
  Controls      : 40
amixer: Mixer hw:0 load error: Invalid argument
!!-------Mixer controls for card 1 [HDMI]
Card hw:1 'HDMI'/'HDA ATI HDMI at 0xfdcfc000 irq 17'
  Mixer name    : 'ATI R6xx HDMI'
  Components    : 'HDA:1002aa01,00aa0100,00100100'
  Controls      : 4
  Simple ctrls  : 1
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined penum
  Playback channels: Mono
  Mono: Playback [off]
!!Alsactl output
--startcollapse--
--endcollapse--
!!All Loaded Modules
Module
ppdev
lp
sco
acpi_cpufreq
bridge
stp
bnep
rfcomm
l2cap
crc16
cpufreq_conservative
bluetooth
cpufreq_powersave
rfkill
cpufreq_userspace
cpufreq_stats
binfmt_misc
fuse
loop
snd_hda_codec_atihdmi
snd_hda_codec_realtek
snd_hda_intel
snd_hda_codec
snd_hwdep
snd_pcm
snd_seq
snd_timer
radeon
snd_seq_device
ttm
drm_kms_helper
i2c_i801
snd
drm
i2c_algo_bit
soundcore
i2c_core
rng_core
parport_pc
snd_page_alloc
parport
psmouse
serio_raw
evdev
pcspkr
button
processor
ext3
jbd
mbcache
sg
sr_mod
sd_mod
crc_t10dif
cdrom
ata_generic
uhci_hcd
ata_piix
thermal
libata
floppy
thermal_sys
atl1c
scsi_mod
ehci_hcd
usbcore
nls_base
!!Sysfs Files
/sys/class/sound/hwC0D2/init_pin_configs:
0x11 0x411110f0
0x12 0x411111f0
0x14 0x01014410
0x15 0x411111f0
0x16 0x411111f0
0x17 0x411111f0
0x18 0x01a19c40
0x19 0x02a19c50
0x1a 0x0181344f
0x1b 0x02214c20
0x1c 0x593301f0
0x1d 0x4005c603
0x1e 0x014b6130
0x1f 0x411111f0
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC1D0/init_pin_configs:
0x03 0x18560010
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
!!ALSA/HDA dmesg
[    4.285178] [drm] Connector 0:
[    4.285179] [drm]   HDMI-A
[    4.285181] [drm]   HPD1
[    4.428226] [drm] Initialized radeon 2.0.0 20080528 for 0000:01:00.0 on minor 0
[    4.712052] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    4.712078] HDA Intel 0000:00:1b.0: setting latency timer to 64
[    4.812090] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input6
[    4.814724] HDA Intel 0000:01:00.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[    4.814760] HDA Intel 0000:01:00.1: setting latency timer to 64
[    5.185682] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.190745] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.193768] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.197703] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.200974] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.205164] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.209037] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.213421] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.217141] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.221357] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.225414] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.231359] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.234999] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.239956] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.244352] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.249047] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.252332] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.256853] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.263900] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.267396] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.273050] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.277673] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.281001] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.285917] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.289586] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.295003] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.298236] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.303651] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.306669] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.310546] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.314377] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.318990] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.325608] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.330197] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.334004] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.337904] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.462689] Adding 507896k swap on /dev/sda7.  Priority:-1 extents:1 across:507896k
[    6.788657] EXT3-fs: mounted filesystem with ordered data mode.
[    7.497512] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.499879] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.502345] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.504960] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.507347] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.509753] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.512108] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.514630] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.517071] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.519463] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.521922] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.524295] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.526722] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.529108] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.531494] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.533943] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.536902] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.539281] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.541963] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.544404] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.546845] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.549467] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.551845] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.554320] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.556949] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.559341] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.561786] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.564174] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.566657] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.569263] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.571634] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.574058] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.576466] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.578997] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.582759] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.585239] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.781947] fuse init (API version 7.13)
[   22.484012] eth0: no IPv6 routers present
[   34.741913] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[  565.939450] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[  565.943341] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[  565.964171] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
Z góry dziękuję za pomoc.
  1. Czy pakiet linux-sound-base jest zainstalowany?
  2. Dodałeś użytkownika do grupy audio?
Darek554
  1. Po wpisaniu w terminalu wyświetla mi to:
    aptitude install linux-sound-base
    Nie zostaną zainstalowane, zaktualizowane ani usunięte żadne pakiety.
    0 pakietów aktualizowanych, 0 instalowanych, 0 do usunięcia i 0 nie aktualizowanych.
    Do pobrania 0 B archiwów. Zajęte po rozpakowaniu: 0 B.
    Instaluje jako root
  2. Już jestem dodany.
yossarian
Post autor: yossarian »
Masz starą wersję Alsy:
m-a update
m-a prepare
m-a a-i alsa-source
Podaj wcześniejsze wyniki po aktualizacji Alsy.
Darek554
Wpisuje w konsoli jak root:
 m-a update
I mi wyskakuje:
 m-a update bash: m-a: nie znaleziono polecenia
yossarian
apt-get install module-assistant
Darek554
Wykonałem wszystkie polecenia, zainstalowało i zaktualizowało źródła alsy.
Co teraz?
yossarian
Napisałem juz wcześniej:
yossarian pisze: Podaj wcześniejsze wyniki po aktualizacji Alsy.
Pokaż teraz wynik skryptu. Zobaczymy czy coś się poprawiło.
Darek554
Oto wyniki:
http://www.alsa-project.org/db/?f=bf934 ... d57acd6335
!!Script ran on: Tue Jan 24 14:11:10 UTC 2012
!!DMI Information
Product Version:
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
snd_hda_intel
snd_hda_intel
snd-pcsp: index=-2
	enable_msi : 0
	power_save : 0
	single_cmd : N
	enable_msi : 0
	power_save : 0
	single_cmd : N
--startcollapse--
Address: 2
Function Id: 0x1
Default PCM:
    formats [0x1]: PCM
  PCM:
    formats [0x1]: PCM
  PCM:
    formats [0x1]: PCM
  PCM:
    formats [0x1]: PCM
  PCM:
    formats [0x1]: PCM
  Digital:
  PCM:
    formats [0x1]: PCM
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x23
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x22
  SDI-Select: 0
  Digital:
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x1f
  Connection: 10
  Connection: 2
     0x02 0x0b
  Connection: 2
     0x03 0x0b
  Connection: 2
     0x04 0x0b
  Connection: 2
     0x05 0x0b
  Digital:
  PCM:
    formats [0x1]: PCM
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x10
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
  EAPD 0x0:
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0c
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0d
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0e
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0f
  Connection: 5
  Connection: 5
  Connection: 5
  EAPD 0x0:
  Connection: 5
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
  Pin-ctls: 0x20: IN
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x06
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
  Processing Coefficient: 0x3f02
  Coefficient Index: 0x0d
  Connection: 12
  Connection: 11
  PCM:
    formats [0x1]: PCM
  Connection: 2
     0x25 0x0b
Address: 0
Function Id: 0x1
Default PCM:
    bits [0x2]: 16
    formats [0x1]: PCM
  Digital:
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x02
--endcollapse--
!!ALSA Device nodes
crw-rw----  1 root audio 116, 10 Jan 24 15:04 /dev/snd/controlC0
crw-rw----  1 root audio 116, 13 Jan 24 15:04 /dev/snd/controlC1
crw-rw----  1 root audio 116,  9 Jan 24 15:04 /dev/snd/hwC0D2
crw-rw----  1 root audio 116, 12 Jan 24 15:04 /dev/snd/hwC1D0
crw-rw----  1 root audio 116,  8 Jan 24 15:04 /dev/snd/pcmC0D0c
crw-rw----  1 root audio 116,  7 Jan 24 15:06 /dev/snd/pcmC0D0p
crw-rw----  1 root audio 116,  6 Jan 24 15:04 /dev/snd/pcmC0D1c
crw-rw----  1 root audio 116,  5 Jan 24 15:04 /dev/snd/pcmC0D1p
crw-rw----  1 root audio 116,  4 Jan 24 15:04 /dev/snd/pcmC0D2c
crw-rw----  1 root audio 116, 11 Jan 24 15:04 /dev/snd/pcmC1D3p
crw-rw----  1 root audio 116,  3 Jan 24  2012 /dev/snd/seq
crw-rw----  1 root audio 116,  2 Jan 24  2012 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  80 Jan 24 15:04 .
drwxr-xr-x 3 root root 300 Jan 24 15:04 ..
lrwxrwxrwx 1 root root  12 Jan 24 15:04 pci-0000:00:1b.0 -> ../controlC0
lrwxrwxrwx 1 root root  12 Jan 24 15:04 pci-0000:01:00.1 -> ../controlC1
APLAY
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
ARECORD
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
!!Amixer output
  Controls      : 40
  Controls      : 4
  Simple ctrls  : 1
!!Alsactl output
--startcollapse--
--endcollapse--
Module
xt_limit
xt_tcpudp
acpi_cpufreq
ipt_LOG
ipt_MASQUERADE
xt_DSCP
cpufreq_powersave
ipt_REJECT
cpufreq_userspace
nf_conntrack_irc
cpufreq_stats
nf_conntrack_ftp
xt_state
ppdev
lp
sco
bridge
stp
bnep
rfcomm
l2cap
crc16
bluetooth
rfkill
binfmt_misc
fuse
iptable_nat
nf_nat
nf_conntrack_ipv4
nf_conntrack
nf_defrag_ipv4
iptable_mangle
iptable_filter
ip_tables
x_tables
loop
snd_hda_intel
radeon
snd_hda_codec
i2c_i801
parport_pc
snd_hwdep
parport
ttm
snd_seq
snd_pcm
rng_core
psmouse
evdev
snd_timer
drm_kms_helper
drm
i2c_algo_bit
i2c_core
snd_seq_device
snd
soundcore
snd_page_alloc
pcspkr
serio_raw
button
processor
ext3
jbd
mbcache
sg
sr_mod
sd_mod
cdrom
crc_t10dif
ata_generic
ata_piix
libata
uhci_hcd
floppy
atl1c
thermal
thermal_sys
ehci_hcd
scsi_mod
usbcore
nls_base
!!Sysfs Files
0x11 0x411110f0
0x12 0x411111f0
0x14 0x01014410
0x15 0x411111f0
0x16 0x411111f0
0x17 0x411111f0
0x18 0x01a19c40
0x19 0x02a19c50
0x1a 0x0181344f
0x1b 0x02214c20
0x1c 0x593301f0
0x1d 0x4005c603
0x1e 0x014b6130
0x1f 0x411111f0
0x03 0x18560010
!!ALSA/HDA dmesg
[    4.048547] [drm] radeon: Initializing kernel modesetting.
[    4.048955] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    4.048998] HDA Intel 0000:00:1b.0: setting latency timer to 64
[    4.049199] [drm] register mmio base: 0xFDCE0000
[    4.183899] [drm] Connector 0:
[    4.183901] [drm]   HDMI-A
[    4.183902] [drm]   HPD1
[    4.183928] [drm]     DFP2: INTERNAL_KLDSCP_LVTMA
[    4.211778] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input5
[    4.310999] [drm] fb mappable at 0xD0040000
[    4.328224] [drm] Initialized radeon 2.0.0 20080528 for 0000:01:00.0 on minor 0
[    4.328278] HDA Intel 0000:01:00.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[    4.328319] HDA Intel 0000:01:00.1: setting latency timer to 64
[    4.393187] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input6
[    5.151473] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.155338] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.158484] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.162903] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.167649] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.172779] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.176043] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.181298] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.185881] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.190903] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.194654] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.198396] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.203687] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.207523] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.210798] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.214917] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.219124] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.225591] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.233210] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.236749] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.243932] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.248728] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.253837] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.256901] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.260304] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.263556] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.268013] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.273121] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.277641] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.281327] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.285291] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.288439] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.292869] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.296981] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.303342] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.307242] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    5.453424] Adding 507896k swap on /dev/sda7.  Priority:-1 extents:1 across:507896k
[    7.507270] sysctl net.netfilter.nf_conntrack_acct=1 to enable it.
[    7.796090] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.798504] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.800943] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.803339] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.805826] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.808231] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.810718] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.813169] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.815590] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.818252] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.820691] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.823114] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.825542] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.827940] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.830395] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.832855] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.835271] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.837715] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.840168] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.842758] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.845436] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.847854] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.850331] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.852792] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.855206] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.857667] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.860124] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.862746] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.865393] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.867809] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.870640] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.873081] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.875866] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.878349] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.880768] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    7.883580] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[    8.063769] fuse init (API version 7.13)
[   21.176507] eth0: no IPv6 routers present
[  152.943543] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[  378.762296] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[  378.766087] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[  378.787334] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[  394.830397] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[  394.834333] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
[  394.849439] hda_codec: num_steps = 0 for NID=0xc (ctl = Front Playback Volume)
yossarian
Nie zrestartowałeś systemu/Alsy, więc te wyniki masz ze starej wersji sterownika.
Sprawdź czy masz już nowszą wersję, powinieneś otrzymać 1.0.23:
cat /proc/asound/version
i czy wyskoczą jakieś błędy:
alsamixer
amixer
