Obserwuję forum od około trzech miesięcy, również od tego czasu jestem szczęśliwym posiadaczem Debiana. Posiadam Acera Aspire 3000 (w którym skonfigurowałem nową drukarkę, i sprzęt), oraz podpięty do niego ploter Cogi E1360, z którym właśnie mam problem.
Ploter Cogi:
[URL]http://www.cogi.de/index.php?route=product/product&path=67_85&product_id=217[/URL]Kod: Zaznacz cały
Linux debian 2.6.32-5-686 #1 SMP Thu Nov 3 04:23:54 UTC 2011 i686 GNU/LinuxKod: Zaznacz cały
i386Kod: Zaznacz cały
root@debian:/home/pzebzda# lsusb
Bus 003 Device 005: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 09da:000a A4 Tech Co., Ltd Port Mouse
root@debian:/home/pzebzda# lspci
00:00.0 Host bridge: Silicon Integrated Systems [SiS] 760/M760 Host (rev 03)
00:01.0 PCI bridge: Silicon Integrated Systems [SiS] SG86C202
00:02.0 ISA bridge: Silicon Integrated Systems [SiS] SiS963 [MuTIOL Media IO] (rev 25)
00:02.1 SMBus: Silicon Integrated Systems [SiS] SiS961/2 SMBus Controller
00:02.5 IDE interface: Silicon Integrated Systems [SiS] 5513 [IDE]
00:02.6 Modem: Silicon Integrated Systems [SiS] AC'97 Modem Controller (rev a0)
00:02.7 Multimedia audio controller: Silicon Integrated Systems [SiS] AC'97 Sound Controller (rev a0)
00:03.0 USB Controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f)
00:03.1 USB Controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f)
00:03.2 USB Controller: Silicon Integrated Systems [SiS] USB 2.0 Controller
00:04.0 Ethernet controller: Silicon Integrated Systems [SiS] SiS900 PCI Fast Ethernet (rev 91)
00:06.0 CardBus bridge: Texas Instruments PCI1410 PC card Cardbus Controller (rev 02)
00:0b.0 Network controller: Broadcom Corporation BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller (rev 02)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:00.0 VGA compatible controller: Silicon Integrated Systems [SiS] 661/741/760 PCI/AGP or 662/761Gx PCIE VGA Display Adapter
[ 7996.316073] usb 3-3: new full speed USB device using ohci_hcd and address 2
[ 7996.528987] usb 3-3: New USB device found, idVendor=067b, idProduct=2303
[ 7996.528997] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7996.529005] usb 3-3: Product: USB-Serial Controller
[ 7996.529011] usb 3-3: Manufacturer: Prolific Technology Inc.
[ 7996.529234] usb 3-3: configuration #1 chosen from 1 choice
[ 7997.298525] usbcore: registered new interface driver usbserial
[ 7997.299156] USB Serial support registered for generic
[ 7997.299772] usbcore: registered new interface driver usbserial_generic
[ 7997.299779] usbserial: USB Serial Driver core
[ 7997.341149] USB Serial support registered for pl2303
[ 7997.341786] pl2303 3-3:1.0: pl2303 converter detected
[ 7997.374366] usb 3-3: pl2303 converter now attached to ttyUSB0
[ 7997.374414] usbcore: registered new interface driver pl2303
[ 7997.374420] pl2303: Prolific PL2303 USB to serial adaptor driverUstawienia drukarki:
serial:/dev/ttyUSB0?baud=9600+bits=8+parity=none+flow=hard
Nota z README:
* Prolific PL2303 USB to serial adaptor driver
* Copyright (C) 2001 Greg Kroah-Hartman (greg@kroah.com)
* Original driver for 2.2.x by anonymous
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* See Documentation/usb/usb-serial.txt for more information on using this driver
* 2001_Oct_06 gkh
* Added RTS and DTR line control. Thanks to joe@bndlg.de for parts of it.
* 2001_Sep_19 gkh
* Added break support.
* 2001_Aug_30 gkh
* fixed oops in write_bulk_callback.
* 2001_Aug_28 gkh
* reworked buffer logic to be like other usb-serial drivers. Hopefully
* removing some reported problems.
* 2001_Jun_06 gkh
* finished porting to 2.4 format.
