[+] MySQL zmniejszenie zapotrzebowania na pami
sylver
[+] MySQL zmniejszenie zapotrzebowania na pamięć RAM
Post autor: sylver »
M
am problem z mysql zabiera mi dość dużo pamięci ram (około 350MB).
Moje pytanie brzmi następująco, czy da się ograniczyć mysql aby np. brało tylko 100MB ramu?
mysql    24140  0.1  2.7 354020 58324 pts/2    Sl   12:15   0:01 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --p
Oto wynik z MySQLTuner:
-------- General Statistics --------------------------------------------------
[--] Skipped version check for MySQLTuner script
[OK] Currently running supported MySQL version 5.5.19-1~dotdeb.1
[OK] Operating on 64-bit architecture
-------- Storage Engine Statistics -------------------------------------------
[--] Status: +Archive -BDB -Federated +InnoDB -ISAM -NDBCluster
[--] Data in MyISAM tables: 67M (Tables: 807)
[--] Data in InnoDB tables: 96K (Tables: 6)
[--] Data in PERFORMANCE_SCHEMA tables: 0B (Tables: 17)
[!!] Total fragmented tables: 10
-------- Security Recommendations  -------------------------------------------
[OK] All database users have passwords assigned
-------- Performance Metrics -------------------------------------------------
[--] Up for: 9m 59s (2K q [4.746 qps], 913 conn, TX: 9M, RX: 235K)
[--] Reads / Writes: 97% / 3%
[--] Total buffers: 164.0M global + 2.7M per thread (151 max threads)
[OK] Maximum possible memory usage: 569.8M (27% of installed RAM)
[OK] Slow queries: 0% (0/2K)
[OK] Highest usage of available connections: 1% (2/151)
[!!] Key buffer size / total MyISAM indexes: 2.0M/14.1M
[!!] Key buffer hit rate: 94.8% (801 cached / 42 reads)
[!!] Query cache efficiency: 5.3% (100 cached / 1K selects)
[OK] Query cache prunes per day: 0
[OK] Sorts requiring temporary tables: 0% (0 temp sorts / 9 sorts)
[OK] Temporary tables created on disk: 20% (54 on disk / 261 total)
[OK] Thread cache hit rate: 99% (2 created / 913 connections)
[!!] Table cache hit rate: 6% (400 open / 6K opened)
[OK] Open file limit used: 78% (800/1K)
[OK] Table locks acquired immediately: 100% (1K immediate / 1K locks)
[OK] InnoDB data size / buffer pool: 96.0K/128.0M
-------- Recommendations -----------------------------------------------------
General recommendations:
    Run OPTIMIZE TABLE to defragment tables for better performance
    MySQL started within last 24 hours - recommendations may be inaccurate
    Enable the slow query log to troubleshoot bad queries
    Increase table_cache gradually to avoid file descriptor limits
Variables to adjust:
    key_buffer_size (> 14.1M)
    query_cache_limit (> 1M, or use smaller result sets)
    table_cache (> 400)
To mój konfig:
# The MySQL database server configuration file.
# You can copy this to one of:
# - "/etc/mysql/my.cnf" to set global options,
# - "~/.my.cnf" to set user-specific options.
# One can use all long options that the program supports.
# Run program with --help to get a list of available options and with
# --print-defaults to see which it would actually understand and use.
# For explanations see
# http://dev.mysql.com/doc/mysql/en/server-system-variables.html
# This will be passed to all mysql clients
# It has been reported that passwords should be enclosed with ticks/quotes
# escpecially if they contain "#" chars...
# Remember to edit /etc/mysql/debian.cnf when changing the socket location.
[client]
port        = 3306
socket        = /var/run/mysqld/mysqld.sock
# Here is entries for some specific programs
# The following values assume you have at least 32M ram
# This was formally known as [safe_mysqld]. Both versions are currently parsed.
[mysqld_safe]
nice        = 0
[mysqld]
# * Basic Settings
user        = mysql
pid-file    = /var/run/mysqld/mysqld.pid
port        = 3306
basedir        = /usr
datadir        = /var/lib/mysql
tmpdir        = /tmp
lc-messages-dir    = /usr/share/mysql
skip-external-locking
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
bind-address        = 127.0.0.1
# * Fine Tuning
key_buffer        = 2M
max_allowed_packet    = 2M
thread_stack        = 192K
thread_cache_size       = 8
# This replaces the startup script and checks MyISAM tables if needed
# the first time they are touched
myisam-recover         = BACKUP
#max_connections        = 100
#table_cache            = 64
#thread_concurrency     = 10
# * Query Cache Configuration
query_cache_limit    = 1M
query_cache_size        = 2M
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
# As of 5.1 you can enable the log at runtime!
#general_log_file        = /var/log/mysql/mysql.log
#general_log             = 1
# Error logging goes to syslog due to /etc/mysql/conf.d/mysqld_safe_syslog.cnf.
# Here you can see queries with especially long duration
#log_slow_queries    = /var/log/mysql/mysql-slow.log
#long_query_time = 2
#log-queries-not-using-indexes
# The following can be used as easy to replay backup logs or for replication.
# note: if you are setting up a replication slave, see README.Debian about
#       other settings you may need to change.
#server-id        = 1
#log_bin            = /var/log/mysql/mysql-bin.log
expire_logs_days    = 10
max_binlog_size         = 2M
#binlog_do_db        = include_database_name
#binlog_ignore_db    = include_database_name
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
# * Security Features
# Read the manual, too, if you want chroot!
# chroot = /var/lib/mysql/
# For generating SSL certificates I recommend the OpenSSL GUI "tinyca".
# ssl-ca=/etc/mysql/cacert.pem
# ssl-cert=/etc/mysql/server-cert.pem
# ssl-key=/etc/mysql/server-key.pem
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash    # faster start of mysql but no tab completition
[isamchk]
key_buffer        = 2M
# * IMPORTANT: Additional settings that can override those from this file!
#   The files must end with '.cnf', otherwise they'll be ignored.
!includedir /etc/mysql/conf.d/
lessmian2
Post autor: lessmian2 »
W pakiecie mysql-common masz przykładowy plik konfiguracyjny dla słabszego/mniejszego sprzętu - /usr/share/doc/mysql-server-5.5/examples/my-small.cnf
Spróbuj na nim odpalić MySQLa i sprawdź ile wtedy zajmuje pamięci. Pamiętaj też, że może się to odbić na wydajności.
sylver
Zmieniłem konfigi i niestety mam dalej tak samo.
Problem rozwiązany. Zainstalowałem mysql 5.1, wyłączyłem innoDB i teraz bierze tylko 75MB ramu.
