Dźwięk działa na Ubuntu lecz na najnowszym Debianie Squeeze nie chce działać. Wyniki skryptu alsy znajdują się poniżej.
http://www.alsa-project.org/db/?f=5fa70 ... e4767a8d4b
!!ALSA Information Script v 0.4.60
!!Script ran on: Mon Jan 9 19:20:11 UTC 2012
!!Linux Distribution
Debian GNU/Linux 6.0 \n \l
!!DMI Information
Manufacturer: Dell Inc.
Product Name: XPS L701X
Product Version: A05
!!Kernel Information
Kernel release: 2.6.32-5-amd64
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: 1.0.21
Library version: 1.0.23
Utilities version: 1.0.23
!!Loaded ALSA modules
snd_hda_intel
!!Sound Servers on this system
No sound servers found.
!!Soundcards recognised by ALSA
0 [Intel ]: HDA-Intel - HDA Intel
HDA Intel at 0xf0900000 irq 22
!!PCI Soundcards installed in the system
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 06)
02:00.1 Audio device: nVidia Corporation Device 0be9 (rev a1)
!!Advanced information - PCI Vendor/Device/Subsystem ID's
00:1b.0 0403: 8086:3b56 (rev 06)
Subsystem: 1028:046c
02:00.1 0403: 10de:0be9 (rev a1)
!!Modprobe options (Sound related)
snd-atiixp-modem: index=-2
snd-intel8x0m: index=-2
snd-via82xx-modem: index=-2
snd-pcsp: index=-2
snd-usb-audio: index=-2
!!Loaded sound module options
!!Module: snd_hda_intel
bdl_pos_adj : 1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : 0
id : <NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
model : <NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>
patch : <NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>
position_fix : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
power_save : 0
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
single_cmd : N
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ID 665
Address: 0
Function Id: 0x1
Vendor Id: 0x10ec0665
Subsystem Id: 0x1028046c
Revision Id: 0x100003
No Modem Function Group found
Default PCM:
rates [0x560]: 44100 48000 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Amp-Out caps: ofs=0x40, nsteps=0x40, stepsize=0x03, mute=0
Amp-Out vals: [0x37 0x37]
Converter: stream=0, channel=0
PCM:
formats [0x1]: PCM
Power: setting=D0, actual=D0
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Amp-Out vals: [0x40 0x40]
PCM:
formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x41d: Stereo Amp-Out
PCM:
formats [0x1]: PCM
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
Digital category: 0x0
PCM:
rates [0x5e0]: 44100 48000 88200 96000 192000
formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In caps: ofs=0x0b, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x14 0x14]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In vals: [0x8b 0x8b]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x97 0x97] [0x97 0x97] [0x97 0x97] [0x97 0x97] [0x97 0x97] [0x97 0x97] [0x97 0x97] [0x97 0x97]
Connection: 8
0x18 0x19 0x1a 0x1b 0x1d 0x14 0x15 0x16
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010a: Mono Amp-In
Amp-In vals: [0x00] [0x80]
Connection: 2
0x02 0x0b
Node 0x10 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
PCM:
formats [0x1]: PCM
Node 0x11 [Pin Complex] wcaps 0x400700: Mono Digital
Pincap 0x00000010: OUT
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x10
Node 0x12 [Pin Complex] wcaps 0x400401: Stereo
Pincap 0x00000020: IN
Pin Default 0x99a30950: [Fixed] Mic at Int ATAPI
Conn = ATAPI, Color = Unknown
DefAssociation = 0x5, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x13 [Pin Complex] wcaps 0x400401: Stereo
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x80 0x80]
Pincap 0x0001003c: IN OUT HP EAPD Detect
EAPD 0x0:
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Unsolicited: tag=00, enabled=0
Connection: 2
0x0c* 0x0d
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Amp-Out vals: [0x00 0x00]
EAPD 0x0:
Pin Default 0x99130110: [Fixed] Speaker at Int ATAPI
DefAssociation = 0x1, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0xc0: OUT HP
Connection: 2
0x0c* 0x0d
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Pincap 0x00000034: IN OUT Detect
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Connection: 1
0x0e
Node 0x17 [Pin Complex] wcaps 0x40050c: Mono Amp-Out
Amp-Out vals: [0x80]
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 1
0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Pincap 0x00001734: IN OUT Detect
Vref caps: HIZ 50 GRD 80
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN VREF_HIZ
Connection: 1
0x0e
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Amp-In vals: [0x03 0x03]
Pincap 0x0000173c: IN OUT HP Detect
Pin Default 0x03211020: [Jack] HP Out at Ext Left
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP VREF_HIZ
Connection: 3
0x0c* 0x0d 0x0e
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pin Default 0x03a11840: [Jack] Mic at Ext Left
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Connection: 1
0x0d
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pin Default 0x0321101f: [Jack] HP Out at Ext Left
DefAssociation = 0x1, Sequence = 0xf
Pin-ctls: 0x00: VREF_HIZ
Connection: 3
0x0c* 0x0d 0x0e
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x598301f0: [N/A] Line In at Int ATAPI
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400780: Mono Digital
Pincap 0x00000014: OUT Detect
Pin Default 0x03451130: [Jack] SPDIF Out at Ext Left
Conn = Optical, Color = Black
DefAssociation = 0x3, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=17
Node 0x21 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Pincap 0x0000001c: OUT HP Detect
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 3
0x0c* 0x0d 0x0e
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1d 0x14 0x15 0x16 0x0b 0x12
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1d 0x14 0x15 0x16 0x0b 0x13
Codec: Intel G45 DEVIBX
Address: 3
Function Id: 0x1
Vendor Id: 0x80862804
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital:
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1e]: 16 20 24 32
formats [0x5]: PCM AC3
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled
PCM:
Node 0x04 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pincap 0x09000094: OUT Detect HDMI
Pin Default 0x58560010: [N/A] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
Pin-ctls: 0x40: OUT
Unsolicited: tag=08, enabled=1
Connection: 2
0x02* 0x03
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Amp-Out vals: [0x00 0x80]
Pin Default 0x18560020: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x40: OUT
Connection: 2
0x02* 0x03
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin Default 0x58560030: [N/A] Digital Out at Int HDMI
Pin-ctls: 0x40: OUT
Connection: 2
0x02* 0x03
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 9 Jan 9 20:09 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 8 Jan 9 20:09 /dev/snd/hwC0D0
crw-rw---- 1 root audio 116, 7 Jan 9 20:09 /dev/snd/hwC0D3
crw-rw---- 1 root audio 116, 6 Jan 9 20:09 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 5 Jan 9 20:09 /dev/snd/pcmC0D0p
crw-rw---- 1 root audio 116, 4 Jan 9 20:09 /dev/snd/pcmC0D3p
crw-rw---- 1 root audio 116, 3 Jan 9 20:09 /dev/snd/seq
crw-rw---- 1 root audio 116, 2 Jan 9 20:09 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Jan 9 20:09 .
drwxr-xr-x 3 root root 220 Jan 9 20:09 ..
lrwxrwxrwx 1 root root 12 Jan 9 20:09 pci-0000:00:1b.0 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: HDA Generic [HDA Generic]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 3: INTEL HDMI [INTEL HDMI]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card 0 [Intel]
Card hw:0 'Intel'/'HDA Intel at 0xf0900000 irq 22'
Mixer name : 'Intel G45 DEVIBX'
Components : 'HDA:10ec0665,1028046c,00100003 HDA:80862804,80860101,00100000'
Controls : 9
Simple ctrls : 5
Simple mixer control 'Master',0
Capabilities: pvolume penum
Playback channels: Front Left - Front Right
Limits: Playback 0 - 64
Mono:
Front Left: Playback 55 [86%] [-9.00dB]
Front Right: Playback 55 [86%] [-9.00dB]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined penum
Playback channels: Mono
Mono: Playback [off]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch penum
Capture channels: Front Left - Front Right
Limits: Capture 0 - 31
Front Left: Capture 20 [65%] [13.50dB] [on]
Front Right: Capture 20 [65%] [13.50dB] [on]
Simple mixer control 'Digital',0
Capabilities: cvolume penum
Limits: Capture 0 - 120
Front Left: Capture 60 [50%] [0.00dB]
Front Right: Capture 60 [50%] [0.00dB]
!!Alsactl output
--startcollapse--
state.Intel {
control.1 {
comment.access 'read write'
comment.type BOOLEAN
comment.count 2
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
control.2 {
comment.type INTEGER
comment.count 2
comment.range '0 - 31'
comment.dbmin -1650
comment.dbmax 3000
iface MIXER
name 'Capture Volume'
value.0 20
value.1 20
control.3 {
comment.count 2
comment.range '0 - 64'
comment.dbmin -6400
comment.dbmax 0
iface MIXER
name 'Master Playback Volume'
value.0 55
value.1 55
control.4 {
comment.access read
comment.type IEC958
comment.count 1
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
control.5 {
comment.access read
comment.type IEC958
comment.count 1
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
control.6 {
comment.type IEC958
comment.count 1
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
control.7 {
comment.count 1
iface MIXER
name 'IEC958 Playback Switch'
value false
control.8 {
comment.access 'read write user'
comment.count 2
comment.range '0 - 255'
comment.tlv '0000000100000008ffffec1400000014'
comment.dbmin -5100
comment.dbmax 0
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
control.9 {
comment.count 2
comment.range '0 - 120'
comment.tlv '0000000100000008fffff44800000032'
comment.dbmin -3000
comment.dbmax 3000
iface MIXER
name 'Digital Capture Volume'
value.0 60
value.1 60
--endcollapse--
!!All Loaded Modules
Module
nls_utf8
nls_cp437
vfat
fat
usb_storage
parport_pc
ppdev
lp
parport
sco
bridge
stp
bnep
rfcomm
l2cap
acpi_cpufreq
cpufreq_powersave
cpufreq_userspace
cpufreq_conservative
cpufreq_stats
binfmt_misc
uinput
fuse
loop
snd_hda_codec_intelhdmi
snd_hda_codec_realtek
joydev
nouveau
snd_hda_intel
snd_hda_codec
ttm
i915
snd_hwdep
drm_kms_helper
arc4
snd_pcm
ecb
drm
iwlagn
uvcvideo
snd_seq
snd_timer
snd_seq_device
iwlcore
snd
mac80211
videodev
v4l1_compat
soundcore
i2c_i801
led_class
i2c_algo_bit
v4l2_compat_ioctl32
dell_laptop
btusb
video
bluetooth
cfg80211
snd_page_alloc
psmouse
wmi
processor
ac
battery
pcspkr
rfkill
evdev
dcdbas
i2c_core
output
button
serio_raw
ext4
mbcache
jbd2
crc16
sg
usbhid
sr_mod
hid
cdrom
sd_mod
crc_t10dif
xhci
ahci
libata
ehci_hcd
scsi_mod
fan
r8169
mii
usbcore
nls_base
thermal
thermal_sys
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x11 0x411111f0
0x12 0x99a30950
0x13 0x411111f0
0x14 0x411111f0
0x15 0x99130110
0x16 0x411111f0
0x17 0x411111f0
0x18 0x411111f0
0x19 0x03211020
0x1a 0x03a11840
0x1b 0x0321101f
0x1d 0x598301f0
0x1e 0x03451130
0x21 0x411111f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D3/init_pin_configs:
0x04 0x58560010
0x05 0x18560020
0x06 0x58560030
/sys/class/sound/hwC0D3/driver_pin_configs:
/sys/class/sound/hwC0D3/user_pin_configs:
/sys/class/sound/hwC0D3/init_verbs:
!!ALSA/HDA dmesg
[ 9.754444] alloc kstat_irqs on node -1
[ 9.754453] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 9.754506] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 11.919865] Adding 3919864k swap on /dev/sda5. Priority:-1 extents:1 across:3919864k
Witam ponownie.
Ponieważ Debian odmówił mi posłuszeństwa i postanowił nie uruchomić się - wykasowałem go, i na jego miejsce zainstalowałem Ubuntu 11.04. W tym wypadku dźwięk działa, więc dla potomnych zostawiam wyniki alsy z Ubuntu. Może dla kogoś mądrego będzie to użyteczna informacja. Sam jestem ciekaw co było nie tak.
http://www.alsa-project.org/db/?f=45b79 ... 1ad3c4e42e
!!Script ran on: Thu Jan 12 20:01:25 UTC 2012
Ubuntu 11.04 \n \l DISTRIB_ID=Ubuntu DISTRIB_DESCRIPTION="Ubuntu 11.04"
!!DMI Information
Kernel release: 2.6.38-13-generic-pae
Architecture: i686
Processor: i686
SMP Enabled: Yes
!!ALSA Version
Driver version: 1.0.23
Library version: 1.0.24.1
Utilities version: 1.0.24.2
snd_hda_intel
snd_hda_intel
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
ESound Daemon:
Installed - Yes (/usr/bin/esd)
Running - No
HDA Intel at 0xf0900000 irq 50
1 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xabefc000 irq 17
02:00.1 Audio device: nVidia Corporation GF106 High Definition Audio Controller (rev a1)
snd-usb-caiaq: index=-2
snd-usb-ua101: index=-2
snd-usb-us122l: index=-2
snd-usb-usx2y: index=-2
snd-cmipci: mpu_port=0x330 fm_port=0x388
snd-pcsp: index=-2
bdl_pos_adj : 1,32,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
power_save : 0
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : N
enable_msi : -1
power_save : 0
single_cmd : N
--startcollapse--
Codec: Realtek ALC665
Address: 0
AFG Function Id: 0x1 (unsol 1)
Default PCM:
formats [0x1]: PCM
Control: name="PCM Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Device: name="ALC665 Analog", type="Audio", device=0
Amp-Out vals: [0x1a 0x1a]
Converter: stream=5, channel=0
PCM:
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Control: name="Speaker Playback Volume", index=0, device=0
Control: name="Headphone Playback Volume", index=0, device=0
PCM:
formats [0x1]: PCM
PCM:
formats [0x1]: PCM
Control: name="IEC958 Playback Con Mask", index=0, device=0
Control: name="IEC958 Playback Pro Mask", index=0, device=0
Control: name="IEC958 Playback Default", index=0, device=0
Control: name="IEC958 Playback Switch", index=0, device=0
Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
Device: name="ALC665 Digital", type="SPDIF", device=1
Digital: Enabled
PCM:
formats [0x1]: PCM
Control: name="Capture Switch", index=1, device=0
Control: name="Capture Volume", index=1, device=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Control: name="Capture Switch", index=0, device=0
Control: name="Capture Volume", index=0, device=0
Amp-In vals: [0x13 0x13]
Converter: stream=1, channel=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Control: name="Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name="Mic Playback Switch", index=0, device=0
Control: name="Beep Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=4, ofs=0
Control: name="Beep Playback Switch", index=0, device=0
Connection: 8
Control: name="PCM Playback Switch", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Amp-In vals: [0x00 0x00] [0x00 0x00]
Connection: 2
0x02 0x0b
Control: name="Speaker Playback Switch", index=0, device=0
Control: name="Headphone Playback Switch", index=0, device=0
Connection: 2
0x03 0x0b
Connection: 2
0x04 0x0b
Amp-In vals: [0x00] [0x00]
Connection: 2
0x02 0x0b
Digital:
PCM:
formats [0x1]: PCM
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x10
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Misc = NO_PRESENCE
Pin-ctls: 0x00:
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 2
0x0c* 0x0d
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 2
0x0c 0x0d*
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x0e
Amp-Out vals: [0x00]
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x0f
Misc = NO_PRESENCE
Connection: 1
0x0e
Pin-ctls: 0x40: OUT VREF_HIZ
Connection: 3
0x0c* 0x0d 0x0e
Control: name="Mic Boost Volume", index=0, device=0
Connection: 1
0x0d
Unsolicited: tag=04, enabled=1
Connection: 3
0x0c 0x0d* 0x0e
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 3
0x0c* 0x0d 0x0e
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x00 0x00]
Connection: 10
Amp-In vals: [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
Codec: Intel IbexPeak HDMI
Address: 3
AFG Function Id: 0x1 (unsol 0)
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Control: name="IEC958 Playback Con Mask", index=1, device=0
Control: name="IEC958 Playback Pro Mask", index=1, device=0
Control: name="IEC958 Playback Default", index=1, device=0
Control: name="IEC958 Playback Switch", index=1, device=0
Device: name="HDMI 0", type="HDMI", device=3
Converter: stream=8, channel=0
Digital: Enabled
PCM:
Power states: D0 D3
Digital: Enabled
PCM:
Power states: D0 D3
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin-ctls: 0x40: OUT
Power states: D0 D3
Connection: 2
0x02* 0x03
Pin-ctls: 0x40: OUT
Unsolicited: tag=05, enabled=1
Power states: D0 D3
Connection: 2
0x02* 0x03
Pin-ctls: 0x40: OUT
Power states: D0 D3
Connection: 2
0x02* 0x03
Codec: Nvidia GPU 11 HDMI/DP
Address: 0
Vendor Id: 0x10de0011
Subsystem Id: 0x10de0101
Revision Id: 0x100100
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Node 0x04 [Audio Output] wcaps 0x72b1: 8-Channels Digital Stripe CP
Converter: stream=6, channel=0
Digital: Enabled
PCM:
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x40: OUT
Connection: 1
0x04
Address: 1
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Device: name="HDMI 0", type="HDMI", device=7
Digital: Enabled
PCM:
Pin-ctls: 0x40: OUT
Connection: 1
0x04
Address: 2
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Control: name="IEC958 Playback Con Mask", index=2, device=0
Control: name="IEC958 Playback Pro Mask", index=2, device=0
Control: name="IEC958 Playback Default", index=2, device=0
Control: name="IEC958 Playback Switch", index=2, device=0
Device: name="HDMI 0", type="HDMI", device=8
Digital: Enabled
PCM:
Pin-ctls: 0x40: OUT
Connection: 1
0x04
Address: 3
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Control: name="IEC958 Playback Con Mask", index=3, device=0
Control: name="IEC958 Playback Pro Mask", index=3, device=0
Control: name="IEC958 Playback Default", index=3, device=0
Control: name="IEC958 Playback Switch", index=3, device=0
Device: name="HDMI 0", type="HDMI", device=9
Digital: Enabled
PCM:
Pin-ctls: 0x40: OUT
Connection: 1
0x04
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 8 Jan 12 19:49 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 17 Jan 12 19:49 /dev/snd/controlC1
crw-rw---- 1 root audio 116, 7 Jan 12 19:49 /dev/snd/hwC0D0
crw-rw---- 1 root audio 116, 6 Jan 12 19:49 /dev/snd/hwC0D3
crw-rw---- 1 root audio 116, 16 Jan 12 19:49 /dev/snd/hwC1D0
crw-rw---- 1 root audio 116, 15 Jan 12 19:49 /dev/snd/hwC1D1
crw-rw---- 1 root audio 116, 14 Jan 12 19:49 /dev/snd/hwC1D2
crw-rw---- 1 root audio 116, 13 Jan 12 19:49 /dev/snd/hwC1D3
crw-rw---- 1 root audio 116, 5 Jan 12 19:49 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 4 Jan 12 20:33 /dev/snd/pcmC0D0p
crw-rw---- 1 root audio 116, 3 Jan 12 19:49 /dev/snd/pcmC0D1p
crw-rw---- 1 root audio 116, 2 Jan 12 19:49 /dev/snd/pcmC0D3p
crw-rw---- 1 root audio 116, 12 Jan 12 19:49 /dev/snd/pcmC1D3p
crw-rw---- 1 root audio 116, 11 Jan 12 19:49 /dev/snd/pcmC1D7p
crw-rw---- 1 root audio 116, 10 Jan 12 19:49 /dev/snd/pcmC1D8p
crw-rw---- 1 root audio 116, 9 Jan 12 19:49 /dev/snd/pcmC1D9p
crw-rw---- 1 root audio 116, 1 Jan 12 19:49 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Jan 12 19:49 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Jan 12 19:49 .
drwxr-xr-x 3 root root 420 Jan 12 19:49 ..
lrwxrwxrwx 1 root root 12 Jan 12 19:49 pci-0000:00:1b.0 -> ../controlC0
lrwxrwxrwx 1 root root 12 Jan 12 19:49 pci-0000:02:00.1 -> ../controlC1
APLAY
card 0: Intel [HDA Intel], device 0: ALC665 Analog [ALC665 Analog]
Subdevices: 1/1
card 0: Intel [HDA Intel], device 1: ALC665 Digital [ALC665 Digital]
Subdevices: 1/1
card 0: Intel [HDA Intel], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 0 [HDMI 0]
Subdevices: 1/1
ARECORD
Subdevices: 1/1
!!Amixer output
Card hw:0 'Intel'/'HDA Intel at 0xf0900000 irq 50'
Mixer name : 'Intel IbexPeak HDMI'
Controls : 26
Simple ctrls : 12
Capabilities: pvolume pvolume-joined pswitch pswitch-joined penum
Mono: Playback 26 [41%] [-38.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch penum
Mono:
Front Left: Playback 64 [100%] [0.00dB] [on]
Front Right: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
Mono:
Mono:
Simple mixer control 'Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 23 [74%] [0.00dB] [off]
Front Right: Playback 23 [74%] [0.00dB] [off]
Simple mixer control 'Mic Boost',0
Capabilities: volume penum
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Mono: Playback [on]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'Beep',0
Mono:
Front Left: Capture 19 [61%] [12.00dB] [on]
Front Right: Capture 19 [61%] [12.00dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 11 [35%] [0.00dB] [off]
Front Right: Capture 11 [35%] [0.00dB] [off]
!!-------Mixer controls for card 1 [NVidia]
Card hw:1 'NVidia'/'HDA NVidia at 0xabefc000 irq 17'
Mixer name : 'Nvidia GPU 11 HDMI/DP'
Components : 'HDA:10de0011,10de0101,00100100'
Controls : 16
Simple ctrls : 4
Mono: Playback [on]
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.Intel {
control.1 {
iface MIXER
value.0 64
value.1 64
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.2 {
iface MIXER
name 'PCM Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Speaker Playback Volume'
value.0 64
value.1 64
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Speaker Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Headphone Playback Volume'
value.0 64
value.1 64
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.6 {
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.7 {
iface MIXER
name 'Mic Playback Volume'
value.0 23
value.1 23
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 0
dbvalue.1 0
control.8 {
iface MIXER
name 'Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.9 {
iface MIXER
name 'Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.10 {
iface MIXER
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.11 {
iface MIXER
index 1
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.12 {
iface MIXER
value.0 19
value.1 19
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -1650
dbmax 3000
dbvalue.0 1200
dbvalue.1 1200
control.13 {
iface MIXER
index 1
value.0 11
value.1 11
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -1650
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.14 {
iface MIXER
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface MIXER
name 'IEC958 Default PCM Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.19 {
iface MIXER
name 'Beep Playback Volume'
value.0 23
value.1 23
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 0
dbvalue.1 0
control.20 {
iface MIXER
name 'Beep Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.21 {
iface MIXER
value 26
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 -3800
control.22 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.23 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.24 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.25 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.26 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
state.NVidia {
control.1 {
iface MIXER
comment {
access read
type IEC958
count 1
control.2 {
iface MIXER
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.4 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.5 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.6 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.7 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.8 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.9 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.11 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.12 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.13 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.14 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.16 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
--endcollapse--
Module
ipt_REJECT
ipt_LOG
xt_limit
xt_tcpudp
ipt_addrtype
xt_state
ip6table_filter
ip6_tables
nf_nat_irc
nf_conntrack_irc
nf_nat_ftp
nf_nat
nf_conntrack_ipv4
nf_defrag_ipv4
nf_conntrack_ftp
nf_conntrack
iptable_filter
ip_tables
x_tables
vboxnetadp
vboxnetflt
vboxdrv
nls_iso8859_1
nls_cp437
vfat
fat
usb_storage
uas
cryptd
aes_i586
aes_generic
binfmt_misc
rfcomm
sco
bnep
l2cap
parport_pc
ppdev
snd_hda_codec_hdmi
snd_hda_intel
snd_hda_codec
snd_hwdep
snd_pcm
snd_seq_midi
snd_rawmidi
nvidia
i915
snd_seq_midi_event
arc4
drm_kms_helper
snd_seq
joydev
snd_timer
snd_seq_device
drm
iwlagn
iwlcore
lp
snd
dell_laptop
i2c_algo_bit
psmouse
soundcore
uvcvideo
videodev
dcdbas
btusb
snd_page_alloc
dell_wmi
parport
intel_ips
mac80211
video
serio_raw
sparse_keymap
cfg80211
bluetooth
usbhid
hid
ahci
xhci_hcd
libahci
r8169
!!Sysfs Files
0x11 0x411111f0
0x12 0x99a30950
0x13 0x411111f0
0x14 0x411111f0
0x15 0x99130110
0x16 0x411111f0
0x17 0x411111f0
0x18 0x411111f0
0x19 0x03211020
0x1a 0x03a11840
0x1b 0x0321101f
0x1d 0x598301f0
0x1e 0x03451130
0x21 0x411111f0
0x04 0x58560010
0x05 0x18560020
0x06 0x58560030
/sys/class/sound/hwC1D0/init_pin_configs:
0x05 0x18560010
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D1/init_pin_configs:
0x05 0x18560010
/sys/class/sound/hwC1D1/driver_pin_configs:
/sys/class/sound/hwC1D1/user_pin_configs:
/sys/class/sound/hwC1D1/init_verbs:
/sys/class/sound/hwC1D2/init_pin_configs:
0x05 0x18560010
/sys/class/sound/hwC1D2/driver_pin_configs:
/sys/class/sound/hwC1D2/user_pin_configs:
/sys/class/sound/hwC1D2/init_verbs:
/sys/class/sound/hwC1D3/init_pin_configs:
0x05 0x18560010
/sys/class/sound/hwC1D3/driver_pin_configs:
/sys/class/sound/hwC1D3/user_pin_configs:
/sys/class/sound/hwC1D3/init_verbs:
!!ALSA/HDA dmesg
[ 9.484365] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 10.589880] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 10.589944] HDA Intel 0000:00:1b.0: irq 50 for MSI/MSI-X
[ 10.589974] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 10.914485] hda_codec: ALC665: SKU not ready 0x598301f0
[ 10.914659] hda_codec: ALC665: BIOS auto-probing.
[ 11.181928] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 11.182004] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 11.182221] HDA Intel 0000:02:00.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 11.182225] hda_intel: Disable MSI for Nvidia chipset
[ 11.182285] HDA Intel 0000:02:00.1: setting latency timer to 64
[ 12.346038] intel ips 0000:00:1f.6: i915 driver attached, reenabling gpu turbo
[ 26.791925] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro,commit=0
[ 31.710856] hda-intel: IRQ timing workaround is activated for card #1. Suggest a bigger bdl_pos_adj.
[ 46.668804] wlan0: authenticate with d0:15:4a:fa:2e:d3 (try 1)
