Posiadam laptopa MSI cx640 z procesorem i3 i dwoma kartami graficznymi. Jedna zintegrowana z procesorem (intel) i druga to nvidia gt520M. Mam problem z konfiguracją Xorga. Mianowicie, niby mam środowisko graficzne Gnome ale np. w menu monitory, mam tylko rozdzielczość 1024x768. A powinna być 1366x768. Znalazłem w internecie przeróżne informacje typu:
dpkg --reconfigureKod: Zaznacz cały
uname -a
Linux Creed 2.6.32-5-686 #1 SMP Thu Nov 3 04:23:54 UTC 2011 i686 GNU/Linux
lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
01:00.0 VGA compatible controller: nVidia Corporation Device 0ded (rev a1)
X.Org X Server 1.7.7
Release Date: 2010-05-04
Build Operating System: Linux 2.6.32.29-dsa-ia32 i686 Debian
Current Operating System: Linux Creed 2.6.32-5-686 #1 SMP Thu Nov 3 04:23:54 UTC 2011 i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-686 root=UUID=6374c787-45c3-4bac-96bd-e07798a216cb ro quiet
Build Date: 19 February 2011 02:37:36PM
xorg-server 2:1.7.7-13 (Cyril Brulebois <kibi@debian.org>)
Current version of pixman: 0.16.4
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Jan 8 22:27:44 2012
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(==) No Layout section. Using the first Screen section.
(==) No screen section available. Using defaults.
(**) |-->Screen "Default Screen Section" (0)
(**) | |-->Monitor "<default monitor>"
(==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
Entry deleted from font path.
(WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
(WW) `fonts.dir' not found (or not valid) in "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType".
(Run 'mkfontdir' on "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType").
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
(II) The server relies on udev to provide the list of input devices.
(II) Loader magic: 0x81ecca0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(++) using VT number 7
(--) PCI:*(0:0:2:0) 8086:0116:1462:109c Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller rev 9, Mem @ 0xf4400000/4194304, 0xc0000000/268435456, I/O @ 0x0000e000/64
(--) PCI: (0:1:0:0) 10de:0ded:1462:109c nVidia Corporation rev 161, Mem @ 0xf3000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/524288
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
compiled for 1.7.7, module version = 1.0.0
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(==) Matched intel as autoconfigured driver 0
(==) Matched vesa as autoconfigured driver 1
(==) Matched fbdev as autoconfigured driver 2
(==) Assigned the driver to the xf86ConfigLayout
(II) LoadModule: "intel"
(II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
(II) Module intel: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 2.13.0
ABI class: X.Org Video Driver, version 6.0
(II) LoadModule: "vesa"
(II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
(II) Module vesa: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 2.3.0
(II) LoadModule: "fbdev"
(II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) Module fbdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 0.4.2
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
Sandybridge, Sandybridge, Sandybridge, Sandybridge, Sandybridge,
(II) VESA: driver for VESA chipsets: vesa
(II) FBDEV: driver for framebuffer: fbdev
(II) Primary Device is: PCI 00@00:02:0
(WW) Falling back to old probe method for fbdev
(II) Loading sub module "fbdevhw"
(II) LoadModule: "fbdevhw"
(II) Loading /usr/lib/xorg/modules/linux/libfbdevhw.so
(II) Module fbdevhw: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 0.0.2
(EE) open /dev/fb0: No such file or directory
(II) Loading sub module "vbe"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) VESA(0): initializing int10
(II) VESA(0): Primary V_BIOS segment is: 0xc000
(II) VESA(0): VESA BIOS detected
(II) VESA(0): VESA VBE Version 3.0
(II) VESA(0): VESA VBE Total Mem: 65472 kB
(II) VESA(0): VESA VBE OEM: Intel(R)Sandybridge Mobile Graphics Chipset Accelerated VGA BIOS
(II) VESA(0): VESA VBE OEM Software Rev: 1.0
(II) VESA(0): VESA VBE OEM Vendor: Intel Corporation
(II) VESA(0): VESA VBE OEM Product: Intel(R)Sandybridge Mobile Graphics Controller
(II) VESA(0): VESA VBE OEM Product Rev: Hardware Version 0.0
(II) VESA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
(==) VESA(0): Depth 24, (--) framebuffer bpp 32
(==) VESA(0): RGB weight 888
(==) VESA(0): Default visual is TrueColor
(==) VESA(0): Using gamma correction (1.0, 1.0, 1.0)
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Module "ddc" already built-in
(II) VESA(0): VESA VBE DDC supported
(II) VESA(0): VESA VBE DDC Level 2
(II) VESA(0): VESA VBE DDC transfer in appr. 1 sec.
(II) VESA(0): VESA VBE DDC read successfully
(II) VESA(0): Manufacturer: INL Model: 5 Serial#: 0
(II) VESA(0): Year: 2009 Week: 0
(II) VESA(0): EDID Version: 1.3
(II) VESA(0): Digital Display Input
(II) VESA(0): Max Image Size [cm]: horiz.: 34 vert.: 19
(II) VESA(0): Gamma: 2.20
(II) VESA(0): No DPMS capabilities specified
(II) VESA(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
(II) VESA(0): First detailed timing is preferred mode
(II) VESA(0): redX: 0.620 redY: 0.340 greenX: 0.330 greenY: 0.605
(II) VESA(0): blueX: 0.150 blueY: 0.070 whiteX: 0.313 whiteY: 0.329
(II) VESA(0): Manufacturer's mask: 0
(II) VESA(0): Supported detailed timing:
(II) VESA(0): clock: 71.1 MHz Image Size: 344 x 194 mm
(II) VESA(0): h_active: 1366 h_sync: 1397 h_sync_end 1418 h_blank_end 1493 h_border: 0
(II) VESA(0): v_active: 768 v_sync: 771 v_sync_end 775 v_blanking: 793 v_border: 0
(II) VESA(0): INL
(II) VESA(0): Unknown vendor-specific block 0
(II) VESA(0): EDID (in hex):
(II) VESA(0): 00ffffffffffff0025cc050000000000
(II) VESA(0): 00130103802213780ac8859e57549b26
(II) VESA(0): 12505400000001010101010101010101
(II) VESA(0): 010101010101c61b567f500019301f15
(II) VESA(0): 340058c2100000180000000000000000
(II) VESA(0): 00000000000000000000000000fe0049
(II) VESA(0): 4e4c0a20202020202020202000000000
(II) VESA(0): 004254313536475730315632321000a6
(II) VESA(0): EDID vendor "INL", prod id 5
(II) VESA(0): Printing DDC gathered Modelines:
(II) VESA(0): Modeline "1366x768"x0.0 71.10 1366 1397 1418 1493 768 771 775 793 -hsync -vsync (47.6 kHz)
(II) VESA(0): Searching for matching VESA mode(s):
Mode: 160 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
GreenFieldPosition: 0
BlueMaskSize: 0
BlueFieldPosition: 0
RsvdMaskSize: 0
RsvdFieldPosition: 0
DirectColorModeInfo: 0
PhysBasePtr: 0x0
LinBytesPerScanLine: 0
BnkNumberOfImagePages: 0
LinNumberOfImagePages: 0
LinRedMaskSize: 0
LinRedFieldPosition: 0
LinGreenMaskSize: 0
LinGreenFieldPosition: 0
LinBlueMaskSize: 0
LinBlueFieldPosition: 0
LinRsvdMaskSize: 0
LinRsvdFieldPosition: 0
MaxPixelClock: 0
Mode: 161 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 162 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 163 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 164 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 165 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 166 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 167 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 168 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 169 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 16a (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 16b (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 16c (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 16d (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 16e (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 16f (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 170 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 171 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 13c (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 14d (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 15c (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 13a (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 14b (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 15a (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 107 (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 11a (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 11b (0x0)
ModeAttributes: 0x0
WinAAttributes: 0x0
WinBAttributes: 0x0
WinGranularity: 0
WinSize: 0
WinASegment: 0x0
WinBSegment: 0x0
WinFuncPtr: 0x0
BytesPerScanline: 0
XResolution: 0
YResolution: 0
XCharSize: 0
YCharSize: 0
NumberOfPlanes: 0
BitsPerPixel: 0
NumberOfBanks: 0
MemoryModel: 0
BankSize: 0
NumberOfImages: 0
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0x0
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 0
Mode: 105 (1024x768)
ModeAttributes: 0x9b
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
WinFuncPtr: 0xc00084d9
BytesPerScanline: 1024
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 84
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
PhysBasePtr: 0xc0000000
LinBytesPerScanLine: 1024
BnkNumberOfImagePages: 84
LinNumberOfImagePages: 84
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
MaxPixelClock: 230000000
Mode: 117 (1024x768)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 2048
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 41
RedMaskSize: 5
RedFieldPosition: 11
GreenMaskSize: 6
GreenFieldPosition: 5
BlueMaskSize: 5
RsvdMaskSize: 0
LinBytesPerScanLine: 2048
BnkNumberOfImagePages: 41
LinNumberOfImagePages: 41
LinRedMaskSize: 5
LinRedFieldPosition: 11
LinGreenMaskSize: 6
LinGreenFieldPosition: 5
LinBlueMaskSize: 5
LinRsvdMaskSize: 0
*Mode: 118 (1024x768)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 4096
XResolution: 1024
YResolution: 768
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 20
RedMaskSize: 8
RedFieldPosition: 16
GreenMaskSize: 8
GreenFieldPosition: 8
BlueMaskSize: 8
RsvdMaskSize: 8
RsvdFieldPosition: 24
LinBytesPerScanLine: 4096
BnkNumberOfImagePages: 20
LinNumberOfImagePages: 20
LinRedMaskSize: 8
LinRedFieldPosition: 16
LinGreenMaskSize: 8
LinGreenFieldPosition: 8
LinBlueMaskSize: 8
LinRsvdMaskSize: 8
LinRsvdFieldPosition: 24
*Mode: 112 (640x480)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 2560
XResolution: 640
YResolution: 480
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 52
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 8
LinBytesPerScanLine: 2560
BnkNumberOfImagePages: 52
LinNumberOfImagePages: 52
LinRedMaskSize: 8
LinGreenMaskSize: 8
LinBlueMaskSize: 8
LinRsvdMaskSize: 8
Mode: 114 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 1600
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 67
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
LinBytesPerScanLine: 1600
BnkNumberOfImagePages: 67
LinNumberOfImagePages: 67
LinRedMaskSize: 5
LinGreenMaskSize: 6
LinBlueMaskSize: 5
LinRsvdMaskSize: 0
*Mode: 115 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 3200
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 32
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 33
RedMaskSize: 8
GreenMaskSize: 8
BlueMaskSize: 8
RsvdMaskSize: 8
LinBytesPerScanLine: 3200
BnkNumberOfImagePages: 33
LinNumberOfImagePages: 33
LinRedMaskSize: 8
LinGreenMaskSize: 8
LinBlueMaskSize: 8
LinRsvdMaskSize: 8
Mode: 101 (640x480)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 640
XResolution: 640
YResolution: 480
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 203
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
LinBytesPerScanLine: 640
BnkNumberOfImagePages: 203
LinNumberOfImagePages: 203
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
Mode: 103 (800x600)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 832
XResolution: 800
YResolution: 600
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 8
NumberOfBanks: 1
MemoryModel: 4
BankSize: 0
NumberOfImages: 126
RedMaskSize: 0
RedFieldPosition: 0
GreenMaskSize: 0
BlueMaskSize: 0
RsvdMaskSize: 0
LinBytesPerScanLine: 832
BnkNumberOfImagePages: 126
LinNumberOfImagePages: 126
LinRedMaskSize: 0
LinGreenMaskSize: 0
LinBlueMaskSize: 0
LinRsvdMaskSize: 0
Mode: 111 (640x480)
WinAAttributes: 0x7
WinBAttributes: 0x0
WinGranularity: 64
WinSize: 64
WinASegment: 0xa000
WinBSegment: 0x0
BytesPerScanline: 1280
XResolution: 640
YResolution: 480
XCharSize: 8
YCharSize: 16
NumberOfPlanes: 1
BitsPerPixel: 16
NumberOfBanks: 1
MemoryModel: 6
BankSize: 0
NumberOfImages: 101
RedMaskSize: 5
GreenMaskSize: 6
BlueMaskSize: 5
RsvdMaskSize: 0
LinBytesPerScanLine: 1280
BnkNumberOfImagePages: 101
LinNumberOfImagePages: 101
LinRedMaskSize: 5
LinGreenMaskSize: 6
LinBlueMaskSize: 5
LinRsvdMaskSize: 0
(II) VESA(0): Total Memory: 1023 64KB banks (65472kB)
(II) VESA(0): <default monitor>: Using hsync value of 47.62 kHz
(II) VESA(0): <default monitor>: Using vrefresh value of 60.05 Hz
(WW) VESA(0): Unable to estimate virtual size
(II) VESA(0): Not using built-in mode "1024x768" (no mode of this name)
(II) VESA(0): Not using built-in mode "800x600" (no mode of this name)
(II) VESA(0): Not using built-in mode "640x480" (no mode of this name)
(WW) VESA(0): No valid modes left. Trying less strict filter...
(II) VESA(0): Not using built-in mode "800x600" (hsync out of range)
(II) VESA(0): Not using built-in mode "640x480" (hsync out of range)
(--) VESA(0): Virtual size is 1024x768 (pitch 1024)
(**) VESA(0): *Built-in mode "1024x768"
(**) VESA(0): Display dimensions: (340, 190) mm
(**) VESA(0): DPI set to (76, 102)
(**) VESA(0): Using "Shadow Framebuffer"
(II) Loading sub module "shadow"
(II) LoadModule: "shadow"
(II) Loading /usr/lib/xorg/modules/libshadow.so
(II) Module shadow: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) UnloadModule: "fbdev"
(II) Unloading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) UnloadModule: "fbdevhw"
(II) Unloading /usr/lib/xorg/modules/linux/libfbdevhw.so
(==) Depth 24 pixmap format is 32 bpp
(II) Reloading /usr/lib/xorg/modules/libint10.so
(II) VESA(0): virtual address = 0xb3244000,
physical address = 0xc0000000, size = 67043328
(II) VESA(0): Setting up VESA Mode 0x118 (1024x768)
(==) VESA(0): Backing store disabled
(==) VESA(0): DPMS enabled
(==) RandR enabled
(II) Found 2 VGA devices: arbiter wrapping enabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XC-MISC
SELinux: Disabled on system, not enabling in X server
(II) AIGLX: Screen 0 is not DRI2 capable
(II) AIGLX: Screen 0 is not DRI capable
(II) AIGLX: Loaded and initialized /usr/lib/dri/swrast_dri.so
(II) GLX: Initialized DRISWRAST GL provider for screen 0
(II) config/udev: Adding input device Power Button (/dev/input/event7)
(**) Power Button: Applying InputClass "evdev keyboard catchall"
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 2.3.2
ABI class: X.Org XInput driver, version 7.0
(**) Power Button: always reports core events
(**) Power Button: Device: "/dev/input/event7"
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) Option "xkb_model" "pc105"
(**) Option "xkb_layout" "pl"
(II) config/udev: Adding input device Lid Switch (/dev/input/event5)
(II) No input driver/identifier specified (ignoring)
(II) config/udev: Adding input device Sleep Button (/dev/input/event6)
(**) Sleep Button: Applying InputClass "evdev keyboard catchall"
(**) Sleep Button: always reports core events
(**) Sleep Button: Device: "/dev/input/event6"
(II) Sleep Button: Found keys
(II) Sleep Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD)
(II) config/udev: Adding input device USB2.0 UVC 1.3M Webcam (/dev/input/event9)
(**) USB2.0 UVC 1.3M Webcam: Applying InputClass "evdev keyboard catchall"
(**) USB2.0 UVC 1.3M Webcam: always reports core events
(**) USB2.0 UVC 1.3M Webcam: Device: "/dev/input/event9"
(II) USB2.0 UVC 1.3M Webcam: Found keys
(II) USB2.0 UVC 1.3M Webcam: Configuring as keyboard
(II) XINPUT: Adding extended input device "USB2.0 UVC 1.3M Webcam" (type: KEYBOARD)
(II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/event1)
(**) Chicony USB Wireless HID Receiver: Applying InputClass "evdev keyboard catchall"
(**) Chicony USB Wireless HID Receiver: always reports core events
(**) Chicony USB Wireless HID Receiver: Device: "/dev/input/event1"
(II) Chicony USB Wireless HID Receiver: Found keys
(II) Chicony USB Wireless HID Receiver: Configuring as keyboard
(II) XINPUT: Adding extended input device "Chicony USB Wireless HID Receiver" (type: KEYBOARD)
(II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/event2)
(**) Chicony USB Wireless HID Receiver: Device: "/dev/input/event2"
(II) Chicony USB Wireless HID Receiver: Found 1 mouse buttons
(II) Chicony USB Wireless HID Receiver: Found scroll wheel(s)
(II) Chicony USB Wireless HID Receiver: Found relative axes
(II) Chicony USB Wireless HID Receiver: Found absolute axes
(II) Chicony USB Wireless HID Receiver: Found x and y absolute axes
(II) Chicony USB Wireless HID Receiver: Configuring as mouse
(**) Chicony USB Wireless HID Receiver: YAxisMapping: buttons 4 and 5
(**) Chicony USB Wireless HID Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(EE) Chicony USB Wireless HID Receiver: failed to initialize for relative axes.
(WW) Device 'Chicony USB Wireless HID Receiver' has 37 axes, only using first 36.
(II) Chicony USB Wireless HID Receiver: initialized for absolute axes.
(II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/js0)
(II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/event3)
(**) Chicony USB Wireless HID Receiver: Applying InputClass "evdev pointer catchall"
(**) Chicony USB Wireless HID Receiver: Device: "/dev/input/event3"
(II) Chicony USB Wireless HID Receiver: Found 3 mouse buttons
(II) Chicony USB Wireless HID Receiver: Found x and y relative axes
(II) XINPUT: Adding extended input device "Chicony USB Wireless HID Receiver" (type: MOUSE)
(II) Chicony USB Wireless HID Receiver: initialized for relative axes.
(II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/mouse0)
(II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
(**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
(**) AT Translated Set 2 keyboard: always reports core events
(**) AT Translated Set 2 keyboard: Device: "/dev/input/event0"
(II) AT Translated Set 2 keyboard: Found keys
(II) AT Translated Set 2 keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
(II) config/udev: Adding input device FSPPS/2 Sentelic FingerSensingPad (/dev/input/event8)
(**) FSPPS/2 Sentelic FingerSensingPad: Applying InputClass "evdev pointer catchall"
(**) FSPPS/2 Sentelic FingerSensingPad: always reports core events
(**) FSPPS/2 Sentelic FingerSensingPad: Device: "/dev/input/event8"
(II) FSPPS/2 Sentelic FingerSensingPad: Found 11 mouse buttons
(II) FSPPS/2 Sentelic FingerSensingPad: Found scroll wheel(s)
(II) FSPPS/2 Sentelic FingerSensingPad: Found relative axes
(II) FSPPS/2 Sentelic FingerSensingPad: Found x and y relative axes
(II) FSPPS/2 Sentelic FingerSensingPad: Configuring as mouse
(**) FSPPS/2 Sentelic FingerSensingPad: YAxisMapping: buttons 4 and 5
(**) FSPPS/2 Sentelic FingerSensingPad: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "FSPPS/2 Sentelic FingerSensingPad" (type: MOUSE)
(II) FSPPS/2 Sentelic FingerSensingPad: initialized for relative axes.
(II) config/udev: Adding input device FSPPS/2 Sentelic FingerSensingPad (/dev/input/mouse1)
(II) config/udev: Adding input device PC Speaker (/dev/input/event4)
