Po zainstalowaniu sterowników Nvidii system operacyjny pad
BryQ
Po zainstalowaniu sterowników Nvidii system operacyjny padł
Post autor: BryQ »
Zainstalowałem Debiana Sid 64-bity, wersja jądra 3.1.0-1-amd64, na laptopie Dell Inspiron n5110, który posiada dwie karty graficzne:
lspci -k
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
[U][B]00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)[/B][/U]
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
00:1c.1 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 (rev b5)
00:1c.3 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 (rev b5)
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b5)
00:1c.7 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 8 (rev b5)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation HM67 Express Chipset Family LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
[U][B]01:00.0 VGA compatible controller: nVidia Corporation Device 0df5 (rev a1)[/B][/U]
01:00.1 Audio device: nVidia Corporation GF108 High Definition Audio Controller (rev a1)
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 05)
09:00.0 Network controller: Atheros Communications Inc. AR9285 Wireless Network Adapter (PCI-Express) (rev 01)
0b:00.0 USB controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 04)
Po instalacji karta Intela działa i w systemie mam akcelerację 3D. Nvidię obsługuje sterownik nouveau, przy czym podczas startu systemu wyświetlał mi się błąd z nim związany. Postanowiłem więc zainstalować niewolne sterowniki producenta do tej karty. W tym celu skorzystałem z tego poradnika: http://damlab.pl/howto/nvidia_drivers/ Wykonałem wszystko dokładnie zgodnie z opisem lecz po restarcie systemu na ekranie wyświetlają mi się ładujące moduły, a później zamiast ekranu logowania mam czarny ekran z migającym podkreśleniem. Kombinacja klawiszy Ctrl+Alt+F1 działa na jakieś dwie sekundy i znowu widzę migający kursor, więc nie jestem w stanie sprawdzić logów w /var/log/Xorg.0.log.
[    20.377]
X.Org X Server 1.11.2.902 (1.11.3 RC 2)
Release Date: 2011-12-09
[    20.377] X Protocol Version 11, Revision 0
[    20.377] Build Operating System: Linux 3.1.0-1-amd64 x86_64 Debian
[    20.377] Current Operating System: Linux bryq 3.1.0-1-amd64 #1 SMP Sun Dec 11 20:36:41 UTC 2011 x86_64
[    20.377] Kernel command line: BOOT_IMAGE=/vmlinuz-3.1.0-1-amd64 root=UUID=c05a03d4-82f4-4919-b21a-bc30be0516cd ro quiet
[    20.377] Build Date: 10 December 2011  09:55:45PM
[    20.377] xorg-server 2:1.11.2.902-1 (Cyril Brulebois <kibi@debian.org>)
[    20.377] Current version of pixman: 0.24.0
[    20.377] 	Before reporting problems, check http://wiki.x.org
[    20.377] Markers: (--) probed, (**) from config file, (==) default setting,
[    20.377] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 28 01:20:28 2011
[    20.396] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    20.445] (==) No Layout section.  Using the first Screen section.
[    20.445] (==) No screen section available. Using defaults.
[    20.445] (**) |-->Screen "Default Screen Section" (0)
[    20.445] (**) |   |-->Monitor "<default monitor>"
[    20.446] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[    20.446] (==) Automatically adding devices
[    20.446] (==) Automatically enabling devices
[    20.489] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    20.489] 	Entry deleted from font path.
[    20.527] (WW) `fonts.dir' not found (or not valid) in "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType".
[    20.527] 	Entry deleted from font path.
[    20.527] 	(Run 'mkfontdir' on "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType").
[    20.527] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	built-ins
[    20.527] (==) ModulePath set to "/usr/lib/xorg/modules"
[    20.527] (II) The server relies on udev to provide the list of input devices.
[    20.527] (II) Loader magic: 0x7ffe45941ae0
[    20.527] (II) Module ABI versions:
[    20.527] 	X.Org ANSI C Emulation: 0.4
[    20.527] 	X.Org Video Driver: 11.0
[    20.527] 	X.Org XInput driver : 13.0
[    20.527] 	X.Org Server Extension : 6.0
[    20.528] (--) PCI:*(0:0:2:0) 8086:0116:1028:04ca rev 9, Mem @ 0xf6400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64
[    20.528] (--) PCI: (0:1:0:0) 10de:0df5:1028:04ca rev 161, Mem @ 0xf5000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[    20.528] (II) Open ACPI successful (/var/run/acpid.socket)
[    20.528] (II) LoadModule: "extmod"
[    20.559] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[    20.614] (II) Module extmod: vendor="X.Org Foundation"
[    20.614] 	compiled for 1.11.2.902, module version = 1.0.0
[    20.614] 	Module class: X.Org Server Extension
[    20.614] 	ABI class: X.Org Server Extension, version 6.0
[    20.614] (II) Loading extension SELinux
[    20.614] (II) Loading extension MIT-SCREEN-SAVER
[    20.614] (II) Loading extension XFree86-VidModeExtension
[    20.615] (II) Loading extension XFree86-DGA
[    20.615] (II) Loading extension DPMS
[    20.615] (II) Loading extension XVideo
[    20.615] (II) Loading extension XVideo-MotionCompensation
[    20.615] (II) Loading extension X-Resource
[    20.615] (II) LoadModule: "dbe"
[    20.615] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[    20.631] (II) Module dbe: vendor="X.Org Foundation"
[    20.631] 	compiled for 1.11.2.902, module version = 1.0.0
[    20.631] 	Module class: X.Org Server Extension
[    20.631] 	ABI class: X.Org Server Extension, version 6.0
[    20.631] (II) Loading extension DOUBLE-BUFFER
[    20.631] (II) LoadModule: "glx"
[    20.631] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    20.654] (II) Module glx: vendor="X.Org Foundation"
[    20.654] 	compiled for 1.11.2.902, module version = 1.0.0
[    20.655] 	ABI class: X.Org Server Extension, version 6.0
[    20.655] (==) AIGLX enabled
[    20.655] (II) Loading extension GLX
[    20.655] (II) LoadModule: "record"
[    20.655] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[    20.668] (II) Module record: vendor="X.Org Foundation"
[    20.668] 	compiled for 1.11.2.902, module version = 1.13.0
[    20.668] 	Module class: X.Org Server Extension
[    20.668] 	ABI class: X.Org Server Extension, version 6.0
[    20.668] (II) Loading extension RECORD
[    20.668] (II) LoadModule: "dri"
[    20.668] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[    20.676] (II) Module dri: vendor="X.Org Foundation"
[    20.676] 	compiled for 1.11.2.902, module version = 1.0.0
[    20.676] 	ABI class: X.Org Server Extension, version 6.0
[    20.676] (II) Loading extension XFree86-DRI
[    20.676] (II) LoadModule: "dri2"
[    20.676] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[    20.677] (II) Module dri2: vendor="X.Org Foundation"
[    20.677] 	compiled for 1.11.2.902, module version = 1.2.0
[    20.677] 	ABI class: X.Org Server Extension, version 6.0
[    20.677] (II) Loading extension DRI2
[    20.677] (==) Matched intel as autoconfigured driver 0
[    20.677] (==) Matched vesa as autoconfigured driver 1
[    20.677] (==) Matched fbdev as autoconfigured driver 2
[    20.677] (==) Assigned the driver to the xf86ConfigLayout
[    20.677] (II) LoadModule: "intel"
[    20.677] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[    20.819] (II) Module intel: vendor="X.Org Foundation"
[    20.819] 	compiled for 1.11.1.902, module version = 2.17.0
[    20.819] 	Module class: X.Org Video Driver
[    20.819] 	ABI class: X.Org Video Driver, version 11.0
[    20.819] (II) LoadModule: "vesa"
[    20.819] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    20.833] (II) Module vesa: vendor="X.Org Foundation"
[    20.834] 	compiled for 1.11.0, module version = 2.3.0
[    20.834] 	Module class: X.Org Video Driver
[    20.834] 	ABI class: X.Org Video Driver, version 11.0
[    20.834] (II) LoadModule: "fbdev"
[    20.834] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    20.849] (II) Module fbdev: vendor="X.Org Foundation"
[    20.849] 	compiled for 1.11.0, module version = 0.4.2
[    20.849] 	ABI class: X.Org Video Driver, version 11.0
[    20.849] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
	i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
	E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
	965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
	4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
	Sandybridge Desktop (GT1), Sandybridge Desktop (GT2),
	Sandybridge Desktop (GT2+), Sandybridge Mobile (GT1),
	Sandybridge Mobile (GT2), Sandybridge Mobile (GT2+),
	Sandybridge Server, Ivybridge Mobile (GT1), Ivybridge Mobile (GT2),
	Ivybridge Desktop (GT1), Ivybridge Desktop (GT2), Ivybridge Server
[    20.849] (II) VESA: driver for VESA chipsets: vesa
[    20.849] (II) FBDEV: driver for framebuffer: fbdev
[    20.849] (++) using VT number 7
[    20.867] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[    20.867] (WW) Falling back to old probe method for vesa
[    20.867] (WW) Falling back to old probe method for fbdev
[    20.867] (II) Loading sub module "fbdevhw"
[    20.867] (II) LoadModule: "fbdevhw"
[    20.867] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    20.884] (II) Module fbdevhw: vendor="X.Org Foundation"
[    20.884] 	compiled for 1.11.2.902, module version = 0.0.2
[    20.884] 	ABI class: X.Org Video Driver, version 11.0
[    20.884] drmOpenDevice: node name is /dev/dri/card0
[    20.884] drmOpenDevice: open result is 9, (OK)
[    20.884] drmOpenByBusid: Searching for BusID pci:0000:00:02.0
[    20.884] drmOpenByBusid: drmOpenMinor returns 9
[    20.884] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[    20.884] (II) intel(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    20.884] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[    20.884] (==) intel(0): RGB weight 888
[    20.884] (==) intel(0): Default visual is TrueColor
[    20.884] (II) intel(0): Integrated Graphics Chipset: Intel(R) Sandybridge Mobile (GT2)
[    20.884] (--) intel(0): Chipset: "Sandybridge Mobile (GT2)"
[    20.884] (**) intel(0): Relaxed fencing enabled
[    20.884] (**) intel(0): Wait on SwapBuffers? enabled
[    20.884] (**) intel(0): Triple buffering? enabled
[    20.884] (**) intel(0): Framebuffer tiled
[    20.884] (**) intel(0): Pixmaps tiled
[    20.884] (**) intel(0): 3D buffers tiled
[    20.884] (**) intel(0): SwapBuffers wait enabled
[    20.884] (==) intel(0): video overlay key set to 0x101fe
[    20.885] (II) intel(0): Output LVDS1 has no monitor section
[    20.885] (II) intel(0): found backlight control interface /sys/class/backlight/acpi_video1
[    20.885] (II) intel(0): Output VGA1 has no monitor section
[    20.885] (II) intel(0): EDID for output LVDS1
[    20.885] (II) intel(0): Manufacturer: AUO  Model: 22ec  Serial#: 0
[    20.885] (II) intel(0): Year: 2009  Week: 1
[    20.885] (II) intel(0): EDID Version: 1.3
[    20.885] (II) intel(0): Digital Display Input
[    20.885] (II) intel(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[    20.885] (II) intel(0): Gamma: 2.20
[    20.885] (II) intel(0): No DPMS capabilities specified
[    20.885] (II) intel(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    20.885] (II) intel(0): First detailed timing is preferred mode
[    20.885] (II) intel(0): redX: 0.620 redY: 0.340   greenX: 0.330 greenY: 0.570
[    20.885] (II) intel(0): blueX: 0.150 blueY: 0.060   whiteX: 0.313 whiteY: 0.329
[    20.885] (II) intel(0): Manufacturer's mask: 0
[    20.885] (II) intel(0): Supported detailed timing:
[    20.885] (II) intel(0): clock: 65.1 MHz   Image Size:  344 x 193 mm
[    20.885] (II) intel(0): h_active: 1366  h_sync: 1382  h_sync_end 1390 h_blank_end 1398 h_border: 0
[    20.885] (II) intel(0): v_active: 768  v_sync: 771  v_sync_end 775 v_blanking: 776 v_border: 0
[    20.885] (II) intel(0):  1JC2N€B156XW2
[    20.885] (II) intel(0): Unknown vendor-specific block 0
[    20.885] (II) intel(0): EDID (in hex):
[    20.885] (II) intel(0): 	00ffffffffffff0006afec2200000000
[    20.885] (II) intel(0): 	01130103902213780ac8959e57549226
[    20.885] (II) intel(0): 	0f505400000001010101010101010101
[    20.885] (II) intel(0): 	0101010101016e195620500008301008
[    20.885] (II) intel(0): 	340058c11000001a6e19562050000830
[    20.885] (II) intel(0): 	1008340058c11000001a000000fe0031
[    20.885] (II) intel(0): 	4a43324e804231353658573200000000
[    20.885] (II) intel(0): 	00000000000000000001010a202000d4
[    20.885] (II) intel(0): EDID vendor "AUO", prod id 8940
[    20.885] (II) intel(0): Printing DDC gathered Modelines:
[    20.885] (II) intel(0): Modeline "1366x768"x0.0   65.10  1366 1382 1390 1398  768 771 775 776 +hsync -vsync (46.6 kHz)
[    20.885] (II) intel(0): Not using default mode "320x240" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "512x384" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "640x480" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "640x512" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "896x672" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "928x696" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "960x720" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "576x432" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "680x384" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "700x525" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "720x450" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "800x512" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "840x525" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "960x540" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "960x600" (doublescan mode not supported)
[    20.885] (II) intel(0): Not using default mode "1024x768" (doublescan mode not supported)
[    20.885] (II) intel(0): Printing probed modes for output LVDS1
[    20.885] (II) intel(0): Modeline "1366x768"x60.0   65.10  1366 1382 1390 1398  768 771 775 776 +hsync -vsync (46.6 kHz)
[    20.885] (II) intel(0): Modeline "1360x768"x59.8   84.75  1360 1432 1568 1776  768 771 781 798 -hsync +vsync (47.7 kHz)
[    20.885] (II) intel(0): Modeline "1360x768"x60.0   72.00  1360 1408 1440 1520  768 771 781 790 +hsync -vsync (47.4 kHz)
[    20.885] (II) intel(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz)
[    20.886] (II) intel(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz)
[    20.886] (II) intel(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz)
[    20.886] (II) intel(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz)
[    20.886] (II) intel(0): EDID for output VGA1
[    20.886] (II) intel(0): Output LVDS1 connected
[    20.886] (II) intel(0): Output VGA1 disconnected
[    20.886] (II) intel(0): Using exact sizes for initial modes
[    20.886] (II) intel(0): Output LVDS1 using initial mode 1366x768
[    20.886] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[    20.886] (II) intel(0): Kernel page flipping support detected, enabling
[    20.886] (**) intel(0): Display dimensions: (340, 190) mm
[    20.886] (**) intel(0): DPI set to (102, 102)
[    20.886] (II) Loading sub module "fb"
[    20.886] (II) LoadModule: "fb"
[    20.906] (II) Loading /usr/lib/xorg/modules/libfb.so
[    20.950] (II) Module fb: vendor="X.Org Foundation"
[    20.950] 	compiled for 1.11.2.902, module version = 1.0.0
[    20.950] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    20.950] (II) Loading sub module "dri2"
[    20.950] (II) LoadModule: "dri2"
[    20.950] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[    20.950] (II) Module dri2: vendor="X.Org Foundation"
[    20.950] 	compiled for 1.11.2.902, module version = 1.2.0
[    20.950] 	ABI class: X.Org Server Extension, version 6.0
[    20.950] (II) UnloadModule: "vesa"
[    20.950] (II) Unloading vesa
[    20.950] (II) UnloadModule: "fbdev"
[    20.950] (II) Unloading fbdev
[    20.951] (II) UnloadModule: "fbdevhw"
[    20.951] (II) Unloading fbdevhw
[    20.951] (==) Depth 24 pixmap format is 32 bpp
[    20.951] (II) intel(0): [DRI2] Setup complete
[    20.951] (II) intel(0): [DRI2]   DRI driver: i965
[    20.951] (II) intel(0): Allocated new frame buffer 1408x768 stride 5632, tiled
[    20.995] (II) UXA(0): Driver registered support for the following operations:
[    20.995] (II)         solid
[    20.995] (II)         copy
[    20.995] (II)         composite (RENDER acceleration)
[    20.995] (II)         put_image
[    20.995] (II)         get_image
[    20.995] (==) intel(0): Backing store disabled
[    20.995] (==) intel(0): Silken mouse enabled
[    20.995] (II) intel(0): Initializing HW Cursor
[    21.056] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    21.056] (==) intel(0): DPMS enabled
[    21.056] (==) intel(0): Intel XvMC decoder enabled
[    21.056] (II) intel(0): Set up textured video
[    21.056] (II) intel(0): [XvMC] xvmc_vld driver initialized.
[    21.056] (II) intel(0): direct rendering: DRI2 Enabled
[    21.056] (==) intel(0): hotplug detection: "enabled"
[    21.056] (--) RandR disabled
[    21.056] (II) Initializing built-in extension Generic Event Extension
[    21.056] (II) Initializing built-in extension SHAPE
[    21.056] (II) Initializing built-in extension MIT-SHM
[    21.056] (II) Initializing built-in extension XInputExtension
[    21.056] (II) Initializing built-in extension XTEST
[    21.056] (II) Initializing built-in extension BIG-REQUESTS
[    21.056] (II) Initializing built-in extension SYNC
[    21.056] (II) Initializing built-in extension XKEYBOARD
[    21.056] (II) Initializing built-in extension XC-MISC
[    21.056] (II) Initializing built-in extension SECURITY
[    21.056] (II) Initializing built-in extension XINERAMA
[    21.056] (II) Initializing built-in extension XFIXES
[    21.056] (II) Initializing built-in extension RENDER
[    21.056] (II) Initializing built-in extension RANDR
[    21.056] (II) Initializing built-in extension COMPOSITE
[    21.056] (II) Initializing built-in extension DAMAGE
[    21.057] (II) SELinux: Disabled on system
[    21.603] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[    21.603] (II) AIGLX: enabled GLX_INTEL_swap_event
[    21.603] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[    21.603] (II) AIGLX: enabled GLX_SGI_make_current_read
[    21.603] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[    21.603] (II) AIGLX: Loaded and initialized i965
[    21.603] (II) GLX: Initialized DRI2 GL provider for screen 0
[    21.603] (II) intel(0): Setting screen physical size to 361 x 203
[    22.080] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[    22.080] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    22.080] (II) LoadModule: "evdev"
[    22.080] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    22.126] (II) Module evdev: vendor="X.Org Foundation"
[    22.126] 	compiled for 1.11.0, module version = 2.6.0
[    22.126] 	Module class: X.Org XInput Driver
[    22.126] 	ABI class: X.Org XInput driver, version 13.0
[    22.126] (II) Using input driver 'evdev' for 'Power Button'
[    22.126] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    22.126] (**) Power Button: always reports core events
[    22.126] (**) Power Button: Device: "/dev/input/event4"
[    22.126] (--) Power Button: Found keys
[    22.126] (II) Power Button: Configuring as keyboard
[    22.126] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input4/event4"
[    22.126] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    22.126] (**) Option "xkb_rules" "evdev"
[    22.126] (**) Option "xkb_model" "pc105"
[    22.126] (**) Option "xkb_layout" "pl"
[    22.172] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[    22.172] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    22.172] (II) Using input driver 'evdev' for 'Video Bus'
[    22.172] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    22.172] (**) Video Bus: always reports core events
[    22.172] (**) Video Bus: Device: "/dev/input/event10"
[    22.172] (--) Video Bus: Found keys
[    22.172] (II) Video Bus: Configuring as keyboard
[    22.172] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:01/input/input10/event10"
[    22.172] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    22.172] (**) Option "xkb_rules" "evdev"
[    22.172] (**) Option "xkb_model" "pc105"
[    22.172] (**) Option "xkb_layout" "pl"
[    22.173] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[    22.173] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    22.173] (II) Using input driver 'evdev' for 'Video Bus'
[    22.173] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    22.173] (**) Video Bus: always reports core events
[    22.173] (**) Video Bus: Device: "/dev/input/event9"
[    22.173] (--) Video Bus: Found keys
[    22.173] (II) Video Bus: Configuring as keyboard
[    22.173] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/device:1a/LNXVIDEO:00/input/input9/event9"
[    22.173] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    22.173] (**) Option "xkb_rules" "evdev"
[    22.173] (**) Option "xkb_model" "pc105"
[    22.173] (**) Option "xkb_layout" "pl"
[    22.173] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    22.173] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    22.173] (II) Using input driver 'evdev' for 'Power Button'
[    22.173] (**) Power Button: always reports core events
[    22.173] (**) Power Button: Device: "/dev/input/event2"
[    22.173] (--) Power Button: Found keys
[    22.173] (II) Power Button: Configuring as keyboard
[    22.173] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input2/event2"
[    22.173] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[    22.174] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[    22.174] (II) No input driver/identifier specified (ignoring)
[    22.174] (II) config/udev: Adding input device Sleep Button (/dev/input/event3)
[    22.174] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    22.174] (II) Using input driver 'evdev' for 'Sleep Button'
[    22.174] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    22.174] (**) Sleep Button: always reports core events
[    22.174] (**) Sleep Button: Device: "/dev/input/event3"
[    22.174] (--) Sleep Button: Found keys
[    22.174] (II) Sleep Button: Configuring as keyboard
[    22.174] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input3/event3"
[    22.174] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[    22.174] (**) Option "xkb_rules" "evdev"
[    22.174] (**) Option "xkb_model" "pc105"
[    22.174] (**) Option "xkb_layout" "pl"
[    22.175] (II) config/udev: Adding input device HDA NVidia HDMI/DP (/dev/input/event14)
[    22.175] (II) No input driver/identifier specified (ignoring)
[    22.175] (II) config/udev: Adding input device HDA NVidia HDMI/DP (/dev/input/event15)
[    22.175] (II) config/udev: Adding input device HDA NVidia HDMI/DP (/dev/input/event16)
[    22.175] (II) config/udev: Adding input device HDA NVidia HDMI/DP (/dev/input/event17)
[    22.176] (II) config/udev: Adding input device Laptop_Integrated_Webcam_HD (/dev/input/event8)
[    22.176] (**) Laptop_Integrated_Webcam_HD: Applying InputClass "evdev keyboard catchall"
[    22.176] (II) Using input driver 'evdev' for 'Laptop_Integrated_Webcam_HD'
[    22.176] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    22.176] (**) Laptop_Integrated_Webcam_HD: always reports core events
[    22.176] (**) Laptop_Integrated_Webcam_HD: Device: "/dev/input/event8"
[    22.176] (--) Laptop_Integrated_Webcam_HD: Found keys
[    22.176] (II) Laptop_Integrated_Webcam_HD: Configuring as keyboard
[    22.176] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5:1.0/input/input8/event8"
[    22.176] (II) XINPUT: Adding extended input device "Laptop_Integrated_Webcam_HD" (type: KEYBOARD, id 11)
[    22.176] (**) Option "xkb_rules" "evdev"
[    22.176] (**) Option "xkb_model" "pc105"
[    22.176] (**) Option "xkb_layout" "pl"
[    22.176] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event11)
[    22.176] (II) No input driver/identifier specified (ignoring)
[    22.176] (II) config/udev: Adding input device HDA Intel PCH Mic at Ext Right Jack (/dev/input/event12)
[    22.177] (II) config/udev: Adding input device HDA Intel PCH HP Out at Ext Right Jack (/dev/input/event13)
[    22.177] (II) No input driver/identifier specified (ignoring)
[    22.177] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[    22.177] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    22.177] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[    22.177] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    22.177] (**) AT Translated Set 2 keyboard: always reports core events
[    22.177] (**) AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[    22.177] (--) AT Translated Set 2 keyboard: Found keys
[    22.177] (II) AT Translated Set 2 keyboard: Configuring as keyboard
[    22.177] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[    22.177] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[    22.177] (**) Option "xkb_rules" "evdev"
[    22.177] (**) Option "xkb_model" "pc105"
[    22.177] (**) Option "xkb_layout" "pl"
[    22.177] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/event7)
[    22.177] (**) PS/2 Generic Mouse: Applying InputClass "evdev pointer catchall"
[    22.177] (II) Using input driver 'evdev' for 'PS/2 Generic Mouse'
[    22.178] (**) PS/2 Generic Mouse: always reports core events
[    22.178] (**) PS/2 Generic Mouse: Device: "/dev/input/event7"
[    22.178] (--) PS/2 Generic Mouse: Found 3 mouse buttons
[    22.178] (--) PS/2 Generic Mouse: Found relative axes
[    22.178] (--) PS/2 Generic Mouse: Found x and y relative axes
[    22.178] (II) PS/2 Generic Mouse: Configuring as mouse
[    22.178] (**) PS/2 Generic Mouse: YAxisMapping: buttons 4 and 5
[    22.178] (**) PS/2 Generic Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    22.178] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event7"
[    22.178] (II) XINPUT: Adding extended input device "PS/2 Generic Mouse" (type: MOUSE, id 13)
[    22.178] (II) PS/2 Generic Mouse: initialized for relative axes.
[    22.178] (**) PS/2 Generic Mouse: (accel) keeping acceleration scheme 1
[    22.178] (**) PS/2 Generic Mouse: (accel) acceleration profile 0
[    22.178] (**) PS/2 Generic Mouse: (accel) acceleration factor: 2.000
[    22.178] (**) PS/2 Generic Mouse: (accel) acceleration threshold: 4
[    22.178] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/mouse0)
[    22.178] (II) No input driver/identifier specified (ignoring)
[    22.178] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[    22.179] (II) config/udev: Adding input device ACPI Virtual Keyboard Device (/dev/input/event18)
[    22.179] (**) ACPI Virtual Keyboard Device: Applying InputClass "evdev keyboard catchall"
[    22.179] (II) Using input driver 'evdev' for 'ACPI Virtual Keyboard Device'
[    22.179] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    22.179] (**) ACPI Virtual Keyboard Device: always reports core events
[    22.179] (**) ACPI Virtual Keyboard Device: Device: "/dev/input/event18"
[    22.179] (--) ACPI Virtual Keyboard Device: Found keys
[    22.179] (II) ACPI Virtual Keyboard Device: Configuring as keyboard
[    22.179] (**) Option "config_info" "udev:/sys/devices/virtual/input/input18/event18"
[    22.179] (II) XINPUT: Adding extended input device "ACPI Virtual Keyboard Device" (type: KEYBOARD, id 14)
[    22.179] (**) Option "xkb_rules" "evdev"
[    22.179] (**) Option "xkb_model" "pc105"
[    22.179] (**) Option "xkb_layout" "pl"
[    22.179] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event6)
[    22.179] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    22.179] (II) Using input driver 'evdev' for 'Dell WMI hotkeys'
[    22.179] (**) Dell WMI hotkeys: always reports core events
[    22.179] (**) Dell WMI hotkeys: Device: "/dev/input/event6"
[    22.179] (--) Dell WMI hotkeys: Found keys
[    22.179] (II) Dell WMI hotkeys: Configuring as keyboard
[    22.179] (**) Option "config_info" "udev:/sys/devices/virtual/input/input6/event6"
[    22.179] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 15)
[    22.207] (II) intel(0): EDID vendor "AUO", prod id 8940
[    22.207] (II) intel(0): Printing DDC gathered Modelines:
[    22.207] (II) intel(0): Modeline "1366x768"x0.0   65.10  1366 1382 1390 1398  768 771 775 776 +hsync -vsync (46.6 kHz)
[    26.505] (II) intel(0): EDID vendor "AUO", prod id 8940
[    26.505] (II) intel(0): Printing DDC gathered Modelines:
[    26.505] (II) intel(0): Modeline "1366x768"x0.0   65.10  1366 1382 1390 1398  768 771 775 776 +hsync -vsync (46.6 kHz)
[    26.513] (II) intel(0): EDID vendor "AUO", prod id 8940
[    26.513] (II) intel(0): Printing DDC gathered Modelines:
[    26.513] (II) intel(0): Modeline "1366x768"x0.0   65.10  1366 1382 1390 1398  768 771 775 776 +hsync -vsync (46.6 kHz)
[    26.514] (II) intel(0): EDID vendor "AUO", prod id 8940
[    26.514] (II) intel(0): Printing DDC gathered Modelines:
[    26.514] (II) intel(0): Modeline "1366x768"x0.0   65.10  1366 1382 1390 1398  768 771 775 776 +hsync -vsync (46.6 kHz)
[    41.489] (II) intel(0): EDID vendor "AUO", prod id 8940
[    41.489] (II) intel(0): Printing DDC gathered Modelines:
[    41.489] (II) intel(0): Modeline "1366x768"x0.0   65.10  1366 1382 1390 1398  768 771 775 776 +hsync -vsync (46.6 kHz)
[    41.492] (II) intel(0): EDID vendor "AUO", prod id 8940
[    41.492] (II) intel(0): Printing DDC gathered Modelines:
[    41.492] (II) intel(0): Modeline "1366x768"x0.0   65.10  1366 1382 1390 1398  768 771 775 776 +hsync -vsync (46.6 kHz)
[    41.493] (II) intel(0): EDID vendor "AUO", prod id 8940
[    41.493] (II) intel(0): Printing DDC gathered Modelines:
[    41.493] (II) intel(0): Modeline "1366x768"x0.0   65.10  1366 1382 1390 1398  768 771 775 776 +hsync -vsync (46.6 kHz)
[    43.891] (II) intel(0): EDID vendor "AUO", prod id 8940
[    43.891] (II) intel(0): Printing DDC gathered Modelines:
[    43.891] (II) intel(0): Modeline "1366x768"x0.0   65.10  1366 1382 1390 1398  768 771 775 776 +hsync -vsync (46.6 kHz)
Plik, który dołączyłem to /var/log/Xorg.0.log przed zmianą sterowników. Próbowałem również instalacji sterowników z repozytorium lecz kończy się to tym samym efektem co instalacja skryptem Nvidii według poradnika.
W Ubuntu dzieje się dokładnie to samo tylko, że tam mam zupełnie czarny ekran i nie działają żadne kombinacje klawiszy. Nie wiem dlaczego, ale przed przekierowaniem polecenia lspci -k do pliku, wiersz z kartą graficzną Nvidii wyglądał inaczej. Było tam podane, że mam kartę GeForce GT 540M. Ze strony producenta pobrałem więc sterownik 290.10.
Czy spotkał się ktoś z Was z czymś takim? Proszę o pomoc bo zupełnie nie mam pomysłów jak rozwiązać ten problem. Z góry dziękuję za pomoc.
Który jest w tej sytuacji mało przydatny. Potrzebny jest aktualny log, kiedy nie działa.
Przejrzałeś dokładnie?
http://debian.linux.pl/threads/12771-Za ... #post81406
13. W przypadku braku możliwości uruchomienia systemu, skorzystaj z pomocy jednej z dystrybucji narzędziowych Linuksa:
http://debian.linux.pl/threads/9479-Dys ... #post61503
Knoppix będzie odpowiedni (przy okazji sprawdzisz sprzęt).
BryQ
Post autor: BryQ »
Zrobiłem tak jak napisałeś i oto informacje jakie udało mi się uzyskać:
# lspci -k
      Subsystem: Dell Device 04b0
      Kernel driver in use: agpgart-intel
      Subsystem: Dell Device 04ca
      Kernel driver in use: i915
      Kernel driver in use: HDA Intel
      Kernel driver in use: ahci
      Kernel driver in use: i801_smbus
  01:00.0 VGA compatible controller: nVidia Corporation GF108 [GeForce GT 540M] (rev a1)
      Kernel driver in use: nouveau
      Kernel driver in use: r8169
      Subsystem: Dell Wireless 1702 802.11bgn Half-size Mini PCIe Card [AR9002WB-1NGCD]
      Kernel driver in use: ath9k
      Kernel driver in use: xhci_hcd
# lspci -n
  00:00.0 0600: 8086:0104 (rev 09)
  00:01.0 0604: 8086:0101 (rev 09)
  00:02.0 0300: 8086:0116 (rev 09)
  00:16.0 0780: 8086:1c3a (rev 04)
  00:1a.0 0c03: 8086:1c2d (rev 05)
  00:1b.0 0403: 8086:1c20 (rev 05)
  00:1c.0 0604: 8086:1c10 (rev b5)
  00:1c.1 0604: 8086:1c12 (rev b5)
  00:1c.3 0604: 8086:1c16 (rev b5)
  00:1c.4 0604: 8086:1c18 (rev b5)
  00:1c.7 0604: 8086:1c1e (rev b5)
  00:1d.0 0c03: 8086:1c26 (rev 05)
  00:1f.0 0601: 8086:1c4b (rev 05)
  00:1f.2 0106: 8086:1c03 (rev 05)
  00:1f.3 0c05: 8086:1c22 (rev 05)
  01:00.0 0300: 10de:0df5 (rev a1)
  01:00.1 0403: 10de:0bea (rev a1)
  05:00.0 0200: 10ec:8136 (rev 05)
  09:00.0 0280: 168c:002b (rev 01)
  0b:00.0 0c03: 1033:0194 (rev 04)
# cat Xorg.0.log
  [   112.649]
  [   112.649] X Protocol Version 11, Revision 0
  [   112.649] Build Operating System: Linux 3.1.0-1-amd64 x86_64 Debian
  [   112.649] Current Operating System: Linux bryq 3.1.0-1-amd64 #1 SMP Sun Dec 11 20:36:41 UTC 2011 x86_64
  [   112.650] Kernel command line: BOOT_IMAGE=/vmlinuz-3.1.0-1-amd64 root=UUID=c05a03d4-82f4-4919-b21a-bc30be0516cd ro quiet
  [   112.650] Build Date: 10 December 2011  09:55:45PM
  [   112.650] xorg-server 2:1.11.2.902-1 (Cyril Brulebois <kibi@debian.org>)
  [   112.650] Current version of pixman: 0.24.0
  [   112.650]     Before reporting problems, check http://wiki.x.org
  [   112.650] Markers: (--) probed, (**) from config file, (==) default setting,
  [   112.650] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 28 11:01:51 2011
  [   112.650] (==) Using config file: "/etc/X11/xorg.conf"
  [   112.650] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
  [   112.651] (==) ServerLayout "Layout0"
  [   112.651] (**) |-->Screen "Screen0" (0)
  [   112.651] (**) |   |-->Monitor "Monitor0"
  [   112.651] (**) |   |-->Device "Device0"
  [   112.651] (**) |-->Input Device "Keyboard0"
  [   112.651] (**) |-->Input Device "Mouse0"
  [   112.651] (==) Automatically adding devices
  [   112.651] (==) Automatically enabling devices
  [   112.651] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
  [   112.651]     Entry deleted from font path.
  [   112.651] (WW) `fonts.dir' not found (or not valid) in "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType".
  [   112.651]     (Run 'mkfontdir' on "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType").
  [   112.651] (==) FontPath set to:
      built-ins
  [   112.651] (==) ModulePath set to "/usr/lib/xorg/modules"
  [   112.651] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
  [   112.651] (WW) Disabling Keyboard0
  [   112.651] (WW) Disabling Mouse0
  [   112.651] (II) Loader magic: 0x7f1c91d52ae0
  [   112.651] (II) Module ABI versions:
  [   112.651]     X.Org ANSI C Emulation: 0.4
  [   112.652]     X.Org Video Driver: 11.0
  [   112.652]     X.Org XInput driver : 13.0
  [   112.652]     X.Org Server Extension : 6.0
  [   112.653] (--) PCI:*(0:0:2:0) 8086:0116:1028:04ca rev 9, Mem @ 0xf6400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64
  [   112.653] (--) PCI: (0:1:0:0) 10de:0df5:1028:04ca rev 161, Mem @ 0xf5000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
  [   112.653] (II) Open ACPI successful (/var/run/acpid.socket)
  [   112.653] (II) LoadModule: "extmod"
  [   112.654] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
  [   112.655] (II) Module extmod: vendor="X.Org Foundation"
  [   112.655]     compiled for 1.11.2.902, module version = 1.0.0
  [   112.655]     Module class: X.Org Server Extension
  [   112.655]     ABI class: X.Org Server Extension, version 6.0
  [   112.655] (II) Loading extension SELinux
  [   112.655] (II) Loading extension MIT-SCREEN-SAVER
  [   112.655] (II) Loading extension XFree86-VidModeExtension
  [   112.655] (II) Loading extension XFree86-DGA
  [   112.655] (II) Loading extension DPMS
  [   112.655] (II) Loading extension XVideo
  [   112.655] (II) Loading extension XVideo-MotionCompensation
  [   112.655] (II) Loading extension X-Resource
  [   112.655] (II) LoadModule: "dbe"
  [   112.655] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
  [   112.655] (II) Module dbe: vendor="X.Org Foundation"
  [   112.655] (II) Loading extension DOUBLE-BUFFER
  [   112.655] (II) LoadModule: "glx"
  [   112.656] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
  [   112.668] (II) Module glx: vendor="NVIDIA Corporation"
  [   112.668]     compiled for 4.0.2, module version = 1.0.0
  [   112.668]     Module class: X.Org Server Extension
  [   112.668] (II) NVIDIA GLX Module  290.10  Wed Nov 16 18:01:24 PST 2011
  [   112.668] (II) Loading extension GLX
  [   112.668] (II) LoadModule: "record"
  [   112.668] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
  [   112.668] (II) Module record: vendor="X.Org Foundation"
  [   112.668]     compiled for 1.11.2.902, module version = 1.13.0
  [   112.668]     ABI class: X.Org Server Extension, version 6.0
  [   112.668] (II) Loading extension RECORD
  [   112.668] (II) LoadModule: "dri"
  [   112.668] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
  [   112.668] (II) Module dri: vendor="X.Org Foundation"
  [   112.668]     compiled for 1.11.2.902, module version = 1.0.0
  [   112.668] (II) Loading extension XFree86-DRI
  [   112.668] (II) LoadModule: "dri2"
  [   112.668] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
  [   112.668] (II) Module dri2: vendor="X.Org Foundation"
  [   112.668]     compiled for 1.11.2.902, module version = 1.2.0
  [   112.668] (II) Loading extension DRI2
  [   112.668] (II) LoadModule: "nvidia"
  [   112.668] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
  [   112.669] (II) Module nvidia: vendor="NVIDIA Corporation"
  [   112.669]     compiled for 4.0.2, module version = 1.0.0
  [   112.669]     Module class: X.Org Video Driver
  [   112.669] (II) NVIDIA dlloader X Driver  290.10  Wed Nov 16 17:41:10 PST 2011
  [   112.669] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
  [   112.669]
  Fatal server error:
  [   112.669] xf86OpenConsole: Cannot find a free VT
  [   112.669]
  [   112.669]
  Please consult the The X.Org Foundation support
       at http://wiki.x.org
   for help.
  [   112.669] Please also check the log file at "/var/log/Xorg.0.log" for additional information.
  [   112.669]
Udało mi się ustalić, że problem polega na niemożliwości znalezienia wolnego wirtualnego terminala. Na polskich forach praktycznie nic o tym nie ma, więc jak znajdę chwilę to przeglądnę angielskie, chyba, że ktoś z Was ma pomysł jak to naprawić to będę wdzięczny.
DaVidoSS
Post autor: DaVidoSS »
Twój system wciąż używa nouveau.
Wykonaj:
root
echo 'blacklist nouveau' >> /etc/modprobe.d/blacklist.conf
echo 'blacklist i915' >> /etc/modprobe.d/blacklist.conf
sed  -i '/^i915$/d'  /etc/modules
sed  -i '/^nouveau$/d'  /etc/modules
Instalacja sterownika z pliku binarnego nie powiodła się zatem spróbuj użyć paczek z repozytorium Debiana.
W tym celu najpierw odinstaluj to co zainstalował instalator Nvidia.
Przejdź do katalogu gdzie znajduje się binarny plik instalatora.
Wykonaj polecenia :
./NVIDIA-Linux-x86_64-173.14.09-pkg2.run --uninstall
apt-get remove nvidia* --purge
apt-get autoremove --purge
rm /etc/X11/xorg.conf
apt-get  install nvidia-kernel-source  nvidia-kernel-dkms nvidia-kernel-common module-assistant binutils build-essential linux-headers-`uname -r` dkms
apt-get  install nvidia-glx-ia32 nvidia-vdpau-driver-ia32
apt-get install nvidia-glx nvidia-vdpau-driver nvidia-xconfig libvdpau1
nvidia-xconfig
reboot
BryQ
Post autor: BryQ »
Postępowałem zgodnie z Twoimi wskazówkami z poziomu Knoppiksa. Wszystkie polecenia zakończyły się powodzeniem, lecz po restarcie systemu znowu zobaczyłem czarny ekran z migającym podkreśleniem. Plik Xorg.0.org był dokładnie takim sam jak podałem w poprzednim poście. Zatem postanowiłem od nowa zainstalować Debiana i spróbować Twojej metody na czystym systemie. Nie miałem pliku /etc/modprobe.d/blacklist.conf więc wpisy dodałem do pliku fbdev-blacklist.conf.
ls -ma /etc/modprobe.d
., .., aliases.conf, alsa-base-blacklist.conf, alsa-base.conf, blacklist-cups-usblp.conf,
[B]fbdev-blacklist.conf[/B], i915-kms.conf, linux-sound-base_noOSS.conf, radeon-kms.conf
Pliku /etc/X11/xorg.conf też nie miałem, więc nie było co usuwać. Instalacja pakietów przebiegła bez problemów. Na koniec restart i po uruchomieniu systemu ukazał mi się dobrze znany czarny ekran. Zawartość pliku /var/log/Xorg.0.log była dokładnie taka sama jak poprzednio.
Wyciąg z pliku:
 Fatal server error:
Niestety błąd dalej pozostaje taki sam.
Na polskim forum Ubuntu znalazłem wątek dotyczący sterowników kart graficznych mojego laptopa. Według tego, co ktoś tam napisał, Nvidia po prostu nie wspiera kart hybrydowych w Linuksie. Po ich zainstalowaniu pojawia się czarny ekran również u innych osób. Tak, więc pozostaje mi czekać aż programiści Nvidii coś z tym zrobią. Z racji tego, postanowiłem zainstalować sterowniki do karty Intela, która nieźle się sprawdza i posiada akcelerację 3D, a Nvidię obsługiwać nouveau (chyba, że będzie sprawiać problemy to zablokuje).
Dziękuję wszystkim za pomoc.
DaVidoSS
Nie ma co od razu rezygnować. Pobaw się jeszcze bo się możesz mile zaskoczyć.
Nvidia oferuje sterownik binarny dla twojej karty i systemu.
Czy aby próbowałeś zainstalować właściwy?
http://www.nvidia.pl/object/linux-displ ... er-pl.html
Jeśli nie to spróbuj. Usuń wcześniej wszystkie pakiety nVidia.
BryQ
Post autor: BryQ »
Dokładnie taki sam sterownik próbowałem zainstalować w Debianie, a także w Ubuntu. Działałby on wtedy, gdy karta nVidii byłaby jedyną w komputerze. Niestety ja mam hybrydową kartę graficzną (nazywa się to bodajże Optimus). Nvidia nie wspiera Optimusa w Linuksie, a także nie daje opcji aby z tej karty nie korzystać. Wniosek z tego taki, że karta jest włączona i pobiera prąd z baterii, ale używać się jej po prostu nie da.
