[+] Instalacja tunera dvb-t
q2werty
Post autor: q2werty »
M
am taki problem przy kompilacji sterowników do tunera lv5tdlx z pliku
20110614_linux_install_package.zip otrzymuję takie błędy:
root@local:/home/local/media_build# make
make -C /home/local/media_build/v4l
make[1]: Wejście do katalogu `/home/local/media_build/v4l'
[B]No version yet, using 2.6.32-5-686[/B]
make[1]: Opuszczenie katalogu `/home/local/media_build/v4l'
scripts/make_makefile.pl
Updating/Creating .config
make[2]: Entering directory `/home/local/media_build/linux'
Applying patches for kernel v2.6.32
patch -s -f -N -p1 -i ../backports/v2.6.37_dont_use_alloc_ordered_workqueue.patch
patch -s -f -N -p1 -i ../backports/v2.6.36_input_getkeycode.patch
patch -s -f -N -p1 -i ../backports/v2.6.36_dvb_usb_input_getkeycode.patch
patch -s -f -N -p1 -i ../backports/v2.6.35_vm_prev.patch
patch -s -f -N -p1 -i ../backports/v2.6.35_firedtv_handle_fcp.patch
patch -s -f -N -p1 -i ../backports/v2.6.35_i2c_new_probed_device.patch
patch -s -f -N -p1 -i ../backports/v2.6.35_work_handler.patch
patch -s -f -N -p1 -i ../backports/v2.6.34_dvb_net.patch
patch -s -f -N -p1 -i ../backports/v2.6.34_fix_define_warnings.patch
patch -s -f -N -p1 -i ../backports/v2.6.33_input_handlers_are_int.patch
patch -s -f -N -p1 -i ../backports/v2.6.33_pvrusb2_sysfs.patch
patch -s -f -N -p1 -i ../backports/v2.6.32_kfifo.patch
Patched drivers/media/dvb/dvb-core/dvbdev.c
Patched drivers/media/video/v4l2-dev.c
Patched drivers/media/rc/rc-main.c
make[2]: Leaving directory `/home/local/media_build/linux'
Preparing to compile for kernel version 2.6.32
File not found: /lib/modules/2.6.32-5-686/build/.config at ./scripts/make_kconfig.pl line 33, <IN> line 4.
Patches for v2.6.32 already applied.
[B]Preparing to compile for kernel version 2.6.32[/B]
make[1]: *** Brak reguł do zrobienia obiektu `.myconfig', wymaganego przez `config-compat.h'. Stop.
make: *** [all] Błąd 2
Co mam z tym zrobić bo chodzi na pewno o jądro.
Proszę o pomoc.
ilin
Post autor: ilin »
Pokaż co to za karta.
Jeśli na usb to pokaż
lsusb
q2werty
Już sobie poradziłem i uważam temat za zamknięty
apt-get install linux-headers-$(uname -r)
apt-get install kernel-package
