Cups i tryb textowy
Rady
Cups i tryb textowy
Post autor: Rady »
Witam czy istnieje jakiś program co konfiguracji i administracji Cupsem działający z pod konsoli w trybie textowym ??
Wiem że można administrować za pomocą lynx i tak sobie skonfigurowałem ale wolałby jakiś programek bo w przeglądarce jakoś źle mi się działa :mrgreen:
Gość
Post autor: Gość »
foomatic-configure
       foomatic-configure  is  a  program  to  set  up and configure print queues for every known
       spooler  (CUPS,  LPRng,  LPD,  GNUlpr,  PPR,  PDQ.  CPS,  no  spooler)  and  every   valid
       printer/driver  combo  in  the  Foomatic database or every PPD file coming with PostScript
       printers. As RIP filter (Raster Image Processor, translation from PostScript to the native
       language  of  the  printer)  always  foomatic-rip(1) will be used, except for PPD files of
       PostScript printers under CUPS or PPR, they will be used without RIP filter.
       It also comprises half of a programatic API for user tools:  you  can  learn  and  control
       everything  about  the  static  properties  of  print queues here. With the sister program
       foomatic-printjob(1), you can do everything related to the print  queue’s  dynamic  state:
       submit jobs, and query, cancel, reorder, and redirect them.
lpadmin
       lpadmin  configures  printer and class queues provided by CUPS. It can also be used to set
       the server default printer or class.
       When specified before the -d, -p, or -x options, the -E option forces encryption when
       connecting to the server.
       The first form of the command (-d) sets the default printer or class to destination.  Sub
       sequent print jobs submitted via the lp(1) or lpr(1) commands will  use  this  destination
       unless the user specifies otherwise with the lpoptions(1) command.
       The  second form of the command (-p) configures the named printer.  The additional options
       are described below.
       The third form of the command (-x) deletes the printer or class destination. Any jobs that
       are pending for the destination will be removed and any job that is currently printed will
       be aborted.
... jest tego więcej :)
Rady
Post autor: Rady »
Chodziło mi o coś co posiada już interface tylko że textowy i nie działa poprzez przeglądarkę. Do tych programów musiał bym napisać skrypty a na to czasu nie mam zabardzo, jesli jest taki program to prośł bym o podanie nazwy lub linka do strony gdzie będe mógł przejżeć programy.
