AP541N-A-K9# config upload
Syntax: config upload/download [tftp|file]://[host]/filename
AP541N-A-K9# config upload tftp://192.168.100.241/config.xml
Initializing for uploading configuration...AP541N-A-K9#
Intializing TFTP...
Transfer not complete Kod: Zaznacz cały
listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
15:44:22.954486 ARP, Request who-has 192.168.100.2 tell 192.168.100.124, length 46
15:44:59.955097 ARP, Request who-has 192.168.100.241 tell 192.168.100.2, length 46
15:44:59.955115 ARP, Reply 192.168.100.241 is-at bc:ae:c5:b4:53:66 (oui Unknown), length 28
15:44:59.955492 IP 192.168.100.2.32778 > 192.168.100.241.tftp: 19 RRQ "config.xml" octet
15:44:59.957996 IP 192.168.100.241.39998 > 192.168.100.2.32778: UDP, length 19
15:45:04.957162 ARP, Request who-has 192.168.100.2 tell 192.168.100.241, length 28
15:45:04.957538 ARP, Reply 192.168.100.2 is-at 00:21:29:07:3a:30 (oui Unknown), length 46 Przy udanym transferze z innego urządzonka jest:
09:07:31.383310 ARP, Request who-has 192.168.100.1 tell 192.168.100.133, length 46
09:07:37.943878 IP 192.168.100.1.51160 > 192.168.100.241.tftp: 25 WRQ "skrypt_emaile" netascii
09:07:37.944194 IP 192.168.100.241.52141 > 192.168.100.1.51160: UDP, length 4
09:07:37.944528 IP 192.168.100.1.51160 > 192.168.100.241.52141: UDP, length 516
09:07:37.944699 IP 192.168.100.241.52141 > 192.168.100.1.51160: UDP, length 4
09:07:37.945019 IP 192.168.100.1.51160 > 192.168.100.241.52141: UDP, length 516
09:07:37.945201 IP 192.168.100.241.52141 > 192.168.100.1.51160: UDP, length 4
09:07:37.945545 IP 192.168.100.1.51160 > 192.168.100.241.52141: UDP, length 516
09:07:37.945700 IP 192.168.100.241.52141 > 192.168.100.1.51160: UDP, length 4
09:07:37.945848 IP 192.168.100.1.51160 > 192.168.100.241.52141: UDP, length 70
09:07:37.945926 IP 192.168.100.241.52141 > 192.168.100.1.51160: UDP, length 4 Niestety pomoce na Cisco do tego urządzenia ograniczają się do obsługi przez stronę www a nie przez szczątkowy cli/ios (jak zwał tak zwał).
Problem rozwiązany, wysłanie konfiguracji z urządzenia na tfpt to oczywiście pobieranie danych. Cóż za paranoja - albo pijany programista.
config download tftp://192.168.100.241/config.xml
