[+] Po
Sz4k4l
[+] Połączenie z Internetem działa, ale nie ma go w kadu i conky
Post autor: Sz4k4l »
Połączenie z Internetem na ogół działa w przeglądarce, przy pobieraniu plików itp. Jednak nie działa w kadu i conky, tak jakby go nie było w systemie. Nie wiem o co chodzi. Mam nadzieję, że mi pomożecie.
uname -a
Linux debian 3.1.0-1-amd64 #1 SMP Mon Nov 14 08:02:25 UTC 2011 x86_64 GNU/Linux
dpkg --print-architecture
amd64
lspci -k
00:00.0 Host bridge: ATI Technologies Inc RD780 Northbridge only dual slot PCI-e_GFX and HT1 K8 part
    Subsystem: ATI Technologies Inc RD780 Northbridge only dual slot PCI-e_GFX and HT1 K8 part
00:02.0 PCI bridge: ATI Technologies Inc RD790 PCI to PCI bridge (external gfx0 port A)
00:0a.0 PCI bridge: ATI Technologies Inc RD790 PCI to PCI bridge (PCI express gpp port F)
00:12.0 SATA controller: ATI Technologies Inc SB600 Non-Raid-5 SATA
    Subsystem: Giga-byte Technology Device b002
    Kernel driver in use: ahci
00:13.0 USB Controller: ATI Technologies Inc SB600 USB (OHCI0)
    Subsystem: Giga-byte Technology Device 5004
    Kernel driver in use: ohci_hcd
00:13.1 USB Controller: ATI Technologies Inc SB600 USB (OHCI1)
00:13.2 USB Controller: ATI Technologies Inc SB600 USB (OHCI2)
00:13.3 USB Controller: ATI Technologies Inc SB600 USB (OHCI3)
00:13.4 USB Controller: ATI Technologies Inc SB600 USB (OHCI4)
00:13.5 USB Controller: ATI Technologies Inc SB600 USB Controller (EHCI)
00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 14)
    Subsystem: Giga-byte Technology GA-MA770-DS3rev2.0 Motherboard
    Kernel driver in use: piix4_smbus
00:14.1 IDE interface: ATI Technologies Inc SB600 IDE
    Subsystem: Giga-byte Technology Gigabyte GA-MA69G-S3H Motherboard
    Kernel driver in use: pata_atiixp
00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA)
    Subsystem: Giga-byte Technology Device a002
00:14.3 ISA bridge: ATI Technologies Inc SB600 PCI to LPC Bridge
    Subsystem: Giga-byte Technology Device 5001
00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge
00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor HyperTransport Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Miscellaneous Control
00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Link Control
01:00.0 VGA compatible controller: nVidia Corporation G92 [GeForce 8800 GT] (rev a2)
    Kernel driver in use: nvidia
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 01)
    Subsystem: Giga-byte Technology GA-EP45-DS5 Motherboard
    Kernel driver in use: r8169
03:0e.0 FireWire (IEEE 1394): Texas Instruments TSB43AB23 IEEE-1394a-2000 Controller (PHY/Link)
    Kernel driver in use: firewire_ohci
ifconfig -a
eth0      Link encap:Ethernet  HWaddr 00:1f:d0:ac:de:8c
          inet addr:192.168.1.104  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::21f:d0ff:feac:de8c/64 Scope:Link
          RX packets:6060 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5725 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:4603425 (4.3 MiB)  TX bytes:946095 (923.9 KiB)
          Interrupt:42
          LOOPBACK  MTU:16436  Metric:1
          collisions:0 txqueuelen:0
cat /etc/resolv.conf
nameserver 91.192.88.80
nameserver 91.192.88.90
cat /etc/network/interfaces
auto lo
iface lo inet loopback
auto lo
auto eth0
iface eth0 inet dhcp
monolith
Post autor: monolith »
A próbowałeś podać dodatkowe serwery DNS w /etc/resolv.conf
np.: --> http://pl.wikipedia.org/wiki/OpenDNS
Sz4k4l
Dodałem 4 nowe DNS-y. I jak chciałem wykonać restart sieci poprzez
/etc/init.d/networking restart
dostałem:
[/B]Running /etc/init.d/networking restart is deprecated because it may not enable again some interfaces ... (warning).
Reconfiguring network interfaces.../etc/network/interfaces:9: interface lo declared allow-auto twice
ifdown: couldn't read interfaces file "/etc/network/interfaces"
ifup: couldn't read interfaces file "/etc/network/interfaces"
failed.
monolith
Po pierwsze w /etc/network/interfaces masz podwójnie zadeklarowany interfejs zwrotny "lo". Weź usuń którąś z linijek "auto lo" i "iface lo inet loopback" co by pojawiły się tylko raz.
Po drugie użycie "restart" jest jak w komunikacie:
deprecated
czyli już nie używane. Użyj po prostu:
/etc/init.d/network stop
a później:
/etc/init.d/network start
Najłatwiej po prostu uruchomić jeszcze raz system.
Napisz, czy nowe DNS-y pomogły.
&quot pisze:Dodałem 4 nowe DNS-y
Nie masz dodawać tylko zmienić. Dodanie nic nie da bo pierwszy i drugi serwer DNS (te które przedstawiłeś) musiałby fizycznie nie działać, a tak nie jest.
Sz4k4l
Dodałem te 4 DNS'y zrobiłem restart systemu i działa Kadu lecz w Conky dalej nie ma internetu.
Wpisz i pokaż wynik polecenia:
ping onet.pl
traceroute onet.pl
Czy poprawnie jest skonfigurowane kadu, numer i hasło?
W jaki sposób w conky ma być sieć?
czy dhcp przydziela też adres bramy?
Dhcp-client nie nadpisuje adresów serwerów dhcp?
Sz4k4l
PING onet.pl (213.180.146.27) 56(84) bytes of data.
64 bytes from s4.m1r2.onet.pl (213.180.146.27): icmp_req=1 ttl=57 time=13.9 ms
64 bytes from s4.m1r2.onet.pl (213.180.146.27): icmp_req=2 ttl=57 time=14.7 ms
64 bytes from s4.m1r2.onet.pl (213.180.146.27): icmp_req=3 ttl=57 time=13.8 ms
64 bytes from s4.m1r2.onet.pl (213.180.146.27): icmp_req=4 ttl=57 time=13.6 ms
^C
--- onet.pl ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3005ms
rtt min/avg/max/mdev = 13.664/14.052/14.714/0.422 ms
traceroute to onet.pl (213.180.146.27), 30 hops max, 60 byte packets
Kadu działa normalnie.
W conky internet potrzebny do pogody :)
Zajmij się teraz konfiguracją samego programu conky. Plikiem konfiguracyjnym i skryptami. Połączenie z internetem już działa, nic więcej z nim nie kombinuj.
Sz4k4l
Dziękuję bardzo za pomoc. Temat do zamknięcia.
