Mam problem z uruchomieniem efektów pulpitu. Po próbie włączenia ich wyskakuje mi okienko z informacją o tym, że program kwin niespodziewanie zakończył działanie, a w szczegółach:
Plik wykonywalny: kwin PID: 2446 Sygnał: Segmentation fault (11)Kod: Zaznacz cały
glxinfo | grep render
direct rendering: Yes
OpenGL renderer string: Mesa DRI Intel(R) Sandybridge Mobile
GL_EXT_vertex_array_bgra, GL_NV_conditional_render
Plik .xsession-errors
Xsession: X session started for marcin at sob, 3 gru 2011, 14:43:27 CET
startkde: Starting up...
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
kbuildsycoca4 running...
Object::connect: No such signal QDBusAbstractInterface: :D eviceAdded(const QString&)
Object::connect: No such signal QDBusAbstractInterface: :D eviceRemoved(const QString&)
kded(2138): dbus error: "org.freedesktop.DBus.Error.ServiceUnknown" : "The name org.freedesktop.Hal was not provided by any .service files"
kded(2138)/kdecore (KConfigSkeleton) KCoreConfigSkeleton::writeConfig:
Agent registered
Object::connect: No such signal QDBusAbstractInterface::Changed()
Invalid D-BUS member name 'idle-hint' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection
Invalid D-BUS member name 'is-local' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection
Invalid D-BUS member name 'x11-display-device' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection
Invalid D-BUS member name 'x11-display' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection
Invalid D-BUS member name 'display-device' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection
Invalid D-BUS member name 'remote-host-name' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection
Invalid D-BUS member name 'session-type' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection
Invalid D-BUS member name 'unix-user' found in interface 'org.freedesktop.ConsoleKit.Session' while parsing introspection
QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.5'
QDBusObjectPath: invalid path ""
plasma-desktop(2262)/libplasma Plasma::FrameSvg::resizeFrame: Invalid size QSizeF(0, 0)
Object::connect: No such slot AbstractItemView::iconSettingsChanged()
plasma-desktop(2262)/libplasma Plasma::FrameSvg::resizeFrame: Invalid size QSizeF(-33, -18)
Object::connect: No such signal KWindowSystem::windowChanged(WId,unsigned long*)
plasma-desktop(2262)/kdecore (services) KServiceFactory::findServiceByDesktopPath: "" not found
link XMLID_34_ hasn't been detected!
link XMLID_36_ hasn't been detected!
plasma-desktop(2262)/libplasma Plasma::FrameSvg::resizeFrame: Invalid size QSizeF(127, 0)
QGridLayoutEngine::addItem: Cell (1, 1) already taken
QGraphicsLinearLayout::removeAt: invalid index 0
QGridLayoutEngine::addItem: Cell (0, 1) already taken
"/usr/bin/kactivitymanagerd(2252)" Soprano: "org.freedesktop.DBus.Error.ServiceUnknown - The name org.kde.nepomuk.services.nepomukstorage was not provided by any .service files"
"/usr/bin/kactivitymanagerd(2252)" Soprano: "QLocalSocket::connectToServer: Invalid name"
plasma-desktop(2262)/libakonadi Akonadi::AgentManagerPrivate::createDBusInterface: AgentManager failed to get a valid AgentManager DBus interface. Error is: 1 "org.freedesktop.DBus.Error.NameHasNoOwner" "Could not get owner of name 'org.freedesktop.Akonadi.Control': no such name"
plasma-desktop(2262)/libakonadi Akonadi::SessionPrivate::socketError: Socket error occurred: "QLocalSocket::connectToServer: Invalid name"
search paths: ("/usr/local/bin", "/usr/bin", "/bin", "/usr/local/games", "/usr/games", "/usr/sbin", "/usr/local/sbin", "/usr/local/libexec", "/usr/libexec", "/opt/mysql/libexec", "/opt/local/lib/mysql5/bin", "/opt/mysql/sbin")
Found mysql_install_db: ""
Found mysqlcheck: ""
Database "akonadi" opened using driver "QMYSQL"
DbInitializer::run()
checking table "SchemaVersionTable"
checking table "ResourceTable"
checking table "CollectionTable"
checking table "MimeTypeTable"
checking table "PimItemTable"
checking table "FlagTable"
checking table "PartTable"
checking table "CollectionAttributeTable"
checking relation "PimItemFlagRelation"
checking relation "CollectionMimeTypeRelation"
checking relation "CollectionPimItemRelation"
DbInitializer::run() done
skipping update 2
skipping update 3
skipping update 4
skipping update 8
skipping update 10
skipping update 12
skipping update 13
skipping update 14
skipping update 15
skipping update 16
skipping update 17
skipping update 18
skipping update 19
Nepomuk Query Server not available
DataStore::unhideAllPimItems()
PLUGINS: "/usr/share/akonadi/agents"
PLUGINS: ("birthdaysresource.desktop", "contactsresource.desktop", "icalresource.desktop", "imapresource.desktop", "kabcresource.desktop", "kcalresource.desktop", "knutresource.desktop", "kolabproxyresource.desktop", "localbookmarksresource.desktop", "maildirresource.desktop", "maildispatcheragent.desktop", "mboxresource.desktop", "microblog.desktop", "mtdummyresource.desktop", "nepomukcalendarfeeder.desktop", "nepomukcontactfeeder.desktop", "nepomuktagresource.desktop", "nntpresource.desktop", "notesresource.desktop", "pop3resource.desktop", "vcarddirresource.desktop", "vcardresource.desktop")
search paths: ("/usr/local/bin", "/usr/bin", "/bin", "/usr/local/games", "/usr/games")
PLUGINS inserting: "akonadi_birthdays_resource" 0 ("Resource")
PLUGINS inserting: "akonadi_contacts_resource" 2 ("Resource")
PLUGINS inserting: "akonadi_ical_resource" 2 ("Resource")
PLUGINS inserting: "akonadi_imap_resource" 0 ("Resource")
PLUGINS inserting: "akonadi_kabc_resource" 0 ("Resource")
PLUGINS inserting: "akonadi_kcal_resource" 0 ("Resource")
PLUGINS inserting: "akonadi_knut_resource" 0 ("Resource")
PLUGINS inserting: "akonadi_kolabproxy_resource" 0 ("Resource", "Unique", "NoConfig")
PLUGINS inserting: "akonadi_localbookmarks_resource" 0 ("Resource")
PLUGINS inserting: "akonadi_maildir_resource" 1 ("Resource")
PLUGINS inserting: "akonadi_maildispatcher_agent" 0 ("Unique", "Autostart", "NoConfig")
PLUGINS inserting: "akonadi_mbox_resource" 0 ("Resource")
PLUGINS inserting: "akonadi_microblog_resource" 0 ("Resource")
PLUGINS inserting: "akonadi_mailtransport_dummy_resource" 0 ("Resource", "MailTransport")
PLUGINS inserting: "akonadi_nepomuk_calendar_feeder" 0 ("Unique", "NoConfig")
PLUGINS inserting: "akonadi_nepomuk_contact_feeder" 0 ("Unique", "Autostart", "NoConfig")
PLUGINS inserting: "akonadi_nepomuktag_resource" 0 ("Resource", "Virtual", "Unique", "NoConfig")
PLUGINS inserting: "akonadi_nntp_resource" 0 ("Resource")
PLUGINS inserting: "akonadi_notes_resource" 0 ("Resource")
PLUGINS inserting: "akonadi_pop3_resource" 0 ("Resource")
PLUGINS inserting: "akonadi_vcarddir_resource" 0 ("Resource")
PLUGINS inserting: "akonadi_vcard_resource" 0 ("Resource")
Akonadi server is now operational.
Known subscriber "akonadi_maildispatcher_agent" subscribes again
"/usr/bin/akonadi_nepomuk_contact_feeder(2307)" Soprano: "org.freedesktop.DBus.Error.ServiceUnknown - The name org.kde.nepomuk.services.nepomukstorage was not provided by any .service files"
"/usr/bin/akonadi_nepomuk_contact_feeder(2307)" Soprano: "QLocalSocket::connectToServer: Invalid name"
krunner(2344)/kdecore (services) KServiceFactory::findServiceByDesktopPath: "searchproviders/wikit.desktop" not found
krunner(2344)/kio (KDirWatch) KDirWatchPrivate::removeEntry: doesn't know "/home/marcin/.kde/share/apps/kabc"
I/O warning : failed to load external entity "/home/marcin/.qalculate/eurofxref-daily.xml"
krunner(2344)/libplasma Plasma::Package::isValid: Could not find required file mainscript
kwin: nie można przejąć zarządzania oknami, być może działa już inny menedżer okien? (proszę spróbować użyć opcji --replace)
[34mWarning: QSslSocket: cannot resolve SSLv2_client_method[0m
backtrace: ('warning from Qt (above)')
======= BEGIN OF BACKTRACE =====
[0] /usr/bin/kadu(_Z14printBacktraceRK7QString+0x41) [0x662a11]
[1] /usr/bin/kadu() [0x4ede23]
[2] /usr/lib/libQtCore.so.4(_Z17qt_message_output9QtMsgTypePKc+0x2e) [0x7fd2d821b26e]
[3] /usr/lib/libQtCore.so.4(+0x826cf) [0x7fd2d821b6cf]
[4] /usr/lib/libQtCore.so.4(_Z8qWarningPKcz+0x94) [0x7fd2d821be34]
[5] /usr/lib/libQtNetwork.so.4(+0xe9908) [0x7fd2d8727908]
[6] /usr/lib/libQtNetwork.so.4(+0xdffcc) [0x7fd2d871dfcc]
[7] /usr/lib/libQtNetwork.so.4(+0x43ef5) [0x7fd2d8681ef5]
[8] /usr/lib/libQtNetwork.so.4(+0x49057) [0x7fd2d8687057]
[9] /usr/lib/libQtNetwork.so.4(+0x491be) [0x7fd2d86871be]
[10] /usr/lib/libQtNetwork.so.4(+0x4cdc7) [0x7fd2d868adc7]
[11] /usr/lib/libQtNetwork.so.4(_ZN5QHttp11qt_metacallEN11QMetaObject4CallEiPPv+0x201) [0x7fd2d868b3a1]
[12] /usr/lib/libQtCore.so.4(_ZN7QObject5eventEP6QEvent+0x36a) [0x7fd2d83216ca]
[13] /usr/lib/libQtGui.so.4(_ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent+0xb4) [0x7fd2d96959f4]
[14] /usr/lib/libQtGui.so.4(_ZN12QApplication6notifyEP7QObjectP6QEvent+0x121) [0x7fd2d969a881]
[15] /usr/lib/libQtCore.so.4(_ZN16QCoreApplication14notifyInternalEP7QObjectP6QEvent+0x8c) [0x7fd2d830afbc]
[16] /usr/lib/libQtCore.so.4(_ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData+0x338) [0x7fd2d830e378]
[17] /usr/lib/libQtCore.so.4(+0x19c663) [0x7fd2d8335663]
[18] /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x1df) [0x7fd2d55f20cf]
[19] /lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x478c8) [0x7fd2d55f28c8]
[20] /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x69) [0x7fd2d55f2a99]
[21] /usr/lib/libQtCore.so.4(_ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+0x6f) [0x7fd2d8335abf]
[22] /usr/lib/libQtGui.so.4(+0x2ae9ce) [0x7fd2d97399ce]
[23] /usr/lib/libQtCore.so.4(_ZN10QEventLoop13processEventsE6QFlagsINS_17ProcessEventsFlagEE+0x32) [0x7fd2d830a1c2]
[24] /usr/lib/libQtCore.so.4(_ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE+0x9f) [0x7fd2d830a3bf]
[25] /usr/lib/libQtCore.so.4(_ZN16QCoreApplication4execEv+0x87) [0x7fd2d830e567]
[26] /usr/bin/kadu(main+0x187a) [0x4ec9ba]
[27] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xfd) [0x7fd2d6c50ead]
[28] /usr/bin/kadu() [0x4edb9d]
======= END OF BACKTRACE ======
[34mWarning: QSslSocket: cannot resolve SSLv2_server_method[0m
[5] /usr/lib/libQtNetwork.so.4(+0xe9840) [0x7fd2d8727840]
New PolkitAgentListener 0x1802d00
Adding new listener PolkitQt1::Agent::Listener(0x18d19c0) for 0x1802d00
plasma-desktop(2262)/plasma StatusNotifierItemSource::refreshCallback: DBusMenu disabled for this application
plasma-desktop(2262)/kdecore (services) KServiceFactory::findServiceByDesktopPath: "nvidia-settings.desktop" not found
OpenGL vendor string: Tungsten Graphics, Inc
OpenGL version string: 1.4 (2.1 Mesa 7.11)
Driver: Intel
GPU class: i965
OpenGL version: 1.4
Mesa version: 7.11
X server version: 1.11.1
Linux kernel version: 2.6.39
Direct rendering: no
Requires strict binding: yes
GLSL shaders: no
Texture NPOT support: yes
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_sheet"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_glide"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_mousemark"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_slidingpopups"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_magiclamp"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_blur"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_wobblywindows"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_fade"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_fadedesktop"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_shadow"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_thumbnailaside"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_slide"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_dashboard"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_fallapart"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_login"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_windowgeometry"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_explosion"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_taskbarthumbnail"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_logout"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_screenshot"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_scalein"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_translucency"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_highlightwindow"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_minimizeanimation"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_lookingglass"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_invert"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_snaphelper"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_magnifier"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_zoom"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_sharpen"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_trackmouse"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_slideback"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_diminactive"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_dimscreen"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_dialogparent"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_cubeslide"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_presentwindows"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_boxswitch"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_coverswitch"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_flipswitch"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_desktopgrid"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_cube"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_resize"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_startupfeedback"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_snow"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 1 offers for "kwin4_effect_showfps"
systemsettings(2428)/kdecore (KPluginInfo) KPluginInfo::kcmServices: found 0 offers for "kwin4_effect_showpaint"
Driver: Intel
GPU class: i965
OpenGL version: 1.4
Mesa version: 7.11
GLSL shaders: no
kwin(2239): glCheckFramebufferStatus failed: "GL_NO_ERROR"
Application::crashHandler() called with signal 11; recent crashes: 1
KCrash: Application 'kwin' crashing...
KCrash: Attempting to start /usr/lib/kde4/libexec/drkonqi from kdeinit
Driver: Intel
GPU class: i965
OpenGL version: 1.4
Mesa version: 7.11
GLSL shaders: no
kwin(2446): glCheckFramebufferStatus failed: "GL_NO_ERROR"
Application::crashHandler() called with signal 11; recent crashes: 2
drkonqi(2447): Unable to find an internal debugger that can work with the KCrash backend
drkonqi(2462): Unable to find an internal debugger that can work with the KCrash backend
QGraphicsLinearLayout::removeAt: invalid index 1
QPainter::begin: Paint device returned engine == 0, type: 2
QPainter::setCompositionMode: Painter not active
QPainter::end: Painter not active, aborted
Couldn't find node horizontal-slider-shadow. Skipping rendering.
kdesu(2485)/kdesu (kdelibs) KDESu::PtyProcess::exec: [ ../../kdesu/process.cpp : 293 ] Running "/bin/su"
kdesu(2485)/kdesu (kdelibs) KDESu::SuProcess::ConverseSU: [ ../../kdesu/su.cpp : 259 ] Read line "Password: "
kdesu(2485)/kdesu (kdelibs) KDESu::PtyProcess::WaitSlave: [ ../../kdesu/process.cpp : 379 ] Child pid 2492
kdesu(2485)/kdesu (kdelibs) KDESu::SuProcess::ConverseSU: [ ../../kdesu/su.cpp : 259 ] Read line ""
kdesu(2485)/kdesu (kdelibs) KDESu::SuProcess::ConverseSU: [ ../../kdesu/su.cpp : 259 ] Read line "kdesu_stub"
kdesu(2485)/kdesu (kdelibs) KDESu::PtyProcess::WaitSlave: [ ../../kdesu/process.cpp : 379 ] Child pid 2508
plasma-desktop(2262)/kdecore (KConfigSkeleton) KCoreConfigSkeleton::writeConfig:
Driver: Intel
GPU class: i965
OpenGL version: 1.4
Mesa version: 7.11
GLSL shaders: no
kwin(2461): glCheckFramebufferStatus failed: "GL_NO_ERROR"
Driver: Intel
GPU class: i965
OpenGL version: 1.4
Mesa version: 7.11
GLSL shaders: no
kwin(2626): glCheckFramebufferStatus failed: "GL_NO_ERROR"
drkonqi(2627): Unable to find an internal debugger that can work with the KCrash backend
drkonqi(2642): Unable to find an internal debugger that can work with the KCrash backend
QMetaObject::invokeMethod: No such method MenuLauncherApplet::toolTipAboutToShow()
QMetaObject::invokeMethod: No such method MenuLauncherApplet::toolTipHidden()
Dziękuję za pomoc.
Edit:
zainstalowałem kde 4.7.4 z gałęzi experimental i wszystko pięknie śmiga
