Konfiguracja lm-sensors
hef
Post autor: hef »
Mój problem dotyczy programu lm-sensors, a dokładniej tego, że pomimo wykrycia czujników, wyświetla:
root@dhcppc1:~# sensors
No sensors found!
Make sure you loaded all the kernel drivers you need.
Try sensors-detect to find out which these are.
root@dhcppc1:~# sensors-detect
# sensors-detect revision 5818 (2010-01-18 17:22:07 +0100)
# System: MICRO-STAR INC. MS-6728
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no): y
Silicon Integrated Systems SIS5595...                       No
VIA VT82C686 Integrated Sensors...                          No
VIA VT8231 Integrated Sensors...                            No
AMD K8 thermal sensors...                                   No
AMD Family 10h thermal sensors...                           No
AMD Family 11h thermal sensors...                           No
Intel Core family thermal sensor...                         No
Intel Atom thermal sensor...                                No
Intel AMB FB-DIMM thermal sensor...                         No
VIA C7 thermal sensor...                                    No
VIA Nano thermal sensor...                                  No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no): y
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor'...                   No
Trying family `SMSC'...                                     No
Trying family `VIA/Winbond/Nuvoton/Fintek'...               Yes
Found `Winbond W83627THF/THG Super IO Sensors'              Success!
    (address 0x290, driver `w83627hf')
Probing for Super-I/O at 0x4e/0x4f
Trying family `National Semiconductor'...                   Yes
Found unknown chip with ID 0xf7f7
Some systems (mainly servers) implement IPMI, a set of common interfaces
through which system health data may be retrieved, amongst other things.
We first try to get the information from SMBIOS. If we don't find it
there, we have to read from arbitrary I/O ports to probe for such
interfaces. This is normally safe. Do you want to scan for IPMI
interfaces? (YES/no): y
Probing for `IPMI BMC KCS' at 0xca0...                      No
Probing for `IPMI BMC SMIC' at 0xca8...                     No
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (yes/NO): y
Probing for `National Semiconductor LM78' at 0x290...       No
Probing for `National Semiconductor LM79' at 0x290...       No
Probing for `Winbond W83781D' at 0x290...                   No
Probing for `Winbond W83782D' at 0x290...                   No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no): y
Using driver `i2c-i801' for device 0000:00:1f.3: Intel 82801EB ICH5
Module i2c-dev loaded successfully.
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `w83627hf':
  * ISA bus, address 0x290
    Chip `Winbond W83627THF/THG Super IO Sensors' (confidence: 9)
To load everything that is needed, add this to /etc/modules:
#----cut here----
# Chip drivers
w83627hf
#----cut here----
If you have some drivers built into your kernel, the list above will
contain too many modules. Skip the appropriate ones!
Do you want to add these lines automatically to /etc/modules? (yes/NO)y
Successful!
Monitoring programs won't work until the needed modules are
loaded. You may want to run '/etc/init.d/module-init-tools start'
to load them.
Unloading i2c-dev... OK
root@dhcppc1:~# /etc/init.d/module-init-tools start
Loading kernel modules...done.
Oczywiście sprawdziłem, czy w /etc/modules jest dodana odpowiednia linia - jest.
# Generated by sensors-detect on Thu Nov 17 18:48:24 2011
# Chip drivers
w83627hf
Program lm-sensors pobierałem przez:
apt-get install lm-sensors
Co instaluje wersję 3.1.2-6.
Próbowałem instalować także nowszą wersję z http://www.lm-sensors.org z takim samym efektem.
root@dhcppc1:~# modprobe  w83627hf
FATAL: Error inserting w83627hf (/lib/modules/2.6.32-5-686/kernel/drivers/hwmon/w83627hf.ko): Device or resource busy
root@dhcppc1:~#
dmesg
[ 3542.180260] w83627hf: Found W83627THF chip at 0x290
[ 3542.180307] ACPI: I/O resource w83627hf [0x295-0x296] conflicts with ACPI region HWMT [0x295-0x296]
[ 3542.180322] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
System to Debian z jądrem 2.6.32-5-686
Płyta główna: MSI 865PE NEO2P Platinum
Procesor: Pentium 4 2,8Ghz
Mogę dodać, że hddtemp działa bez zarzutu.
Z góry dziękuję.
