Smart - interpretacja logu
cooleq
Post autor: cooleq »
Mam taką prośbę o pomoc w interpretacji logu.
smartctl version 5.38 [i686-pc-linux-gnu] Copyright (C) 2002-8 Bruce AllenHome page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Caviar Second Generation Serial ATA family
Device Model:     WDC WD5000AAKS-00UU3A0
Serial Number:    WD-WCAYU8978117
Firmware Version: 01.03B01
User Capacity:    500,107,862,016 bytes
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   8
ATA Standard is:  Exact ATA specification draft version not indicated
Local Time is:    Mon Nov 14 09:51:03 2011 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x84) Offline data collection activity
                                        was suspended by an interrupting command from host.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                 (8160) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        (  97) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x3037) SCT Status supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   138   137   021    Pre-fail  Always       -       4075
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       22
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   093   093   000    Old_age   Always       -       5290
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       20
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       12
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       9
194 Temperature_Celsius     0x0022   113   105   000    Old_age   Always       -       30
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       4
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       1
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       14
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
  1. Co to znaczy, że status jest ,,pre-fail''?
  2. Czy te wartości oznaczają, że dysk należy wymienić, czy są jeszcze w granicach normy?
Zamieszczę jeszcze kawałek syslog
Nov 14 07:49:30 Heimdall smartd[3868]: Device: /dev/sda, SMART Prefailure Attribute: 3 Spin_Up_Time changed from 192 to 201Nov 14 07:49:30 Heimdall smartd[3868]: Device: /dev/sda, SMART Usage Attribute: 194 Temperature_Celsius changed from 121 to 118
Nov 14 07:49:31 Heimdall smartd[3868]: Device: /dev/sdb, SMART Usage Attribute: 7 Seek_Error_Rate changed from 200 to 100
Nov 14 07:49:31 Heimdall smartd[3868]: Device: /dev/sdb, SMART Usage Attribute: 194 Temperature_Celsius changed from 116 to 114
Nov 14 07:49:31 Heimdall smartd[3868]: Device: /dev/sdc, 4 Currently unreadable (pending) sectors
Nov 14 07:49:31 Heimdall smartd[3868]: Device: /dev/sdc, 1 Offline uncorrectable sectors
Generalnie system, po zwiększeniu macierzy o właśnie sdc, strasznie zwolnił (otworzenie edytora nano to jakieś 3s) i nie wiem czym jest to spowodowane.
Interpretacja to bardzo obszerny temat:
http://www.elektroda.pl/rtvforum/viewto ... 9315c4f3bb
cooleq
Dziękuję, ten temat mi sporo pomógł. Wcześniej znalazłem tylko mało przydatny artykuł w Wikipedii.
Generalnie dysk jest lekko uszkodzony i należy go wymienić ponieważ zawiera ważne dane. Mam jeszcze jednak pytanie, czy może to powodować "zawieszanie" systemu? Chodzi o krótkie przerwy, widać to przy jakiejkolwiek pracy, czy to na udziałach sieciowych (otwieranie, przesyłanie danych,) czy też pracując na zdalnej konsoli, niektóre operacje takie proste jak np. otwarcie pliku tekstowego trwają kilka/kilkanaście sekund, po czym wszystko już działa. Przerwy są nawet kilka razy na minutę.
Logi przejrzałem, nie zauważyłem tam nieprawidłowości poza dyskiem.
Edycja2:
Zakładam temat w dziale sieci w związku z tym problemem.
