instalacja serwera mysql
dan-j2
Post autor: dan-j2 »
Próbowałem zainstalować z pomocą apt-get mysql ale nie startuje po instalacji. Potem próbowałem instalować mysql ze źródeł ale wyskakuje mi taki błąd:
debian:/usr/local/src/mysql# ./configure --prefix=/usr/local/mysqld
NOTE: This is a MySQL binary distribution. It's ready to run, you don't
need to configure it!
To help you a bit, I am now going to create the needed MySQL databases
and start the MySQL server for you.  If you run into any trouble, please
consult the MySQL manual, that you can find in the Docs directory.
Installing MySQL system tables...
ERROR: 1582  Duplicate entry '%-test-' for key 'PRIMARY'
070621 22:35:41 [ERROR] Aborting
070621 22:35:41 [Note] ./bin/mysqld: Shutdown complete
Installation of system tables failed!
Examine the logs in ./data for more information.
You can try to start the mysqld daemon with:
./bin/mysqld --skip-grant &
and use the command line tool
./bin/mysql to connect to the mysql
database and look at the grant tables:
shell> ./bin/mysql -u root mysql
mysql> show tables
Try 'mysqld --help' if you have problems with paths. Using --log
gives you a log in ./data that may be helpful.
The latest information about MySQL is available on the web at
[url]http://www.mysql.com[/url]
Please consult the MySQL manual section: 'Problems running mysql_install_db',
and the manual section that describes problems on your OS.
Another information source is the MySQL email archive.
Please check all of the above before mailing us!
And if you do mail us, you MUST use the ./bin/mysqlbug script!
debian:/usr/local/src/mysql# ./configure --prefix=/usr/local/mysql --with-charset=latin2
070621 22:37:09 [ERROR] Aborting
070621 22:37:09 [Note] ./bin/mysqld: Shutdown complete
mysql> show tables
O co w tym może chodzić? Próbuję zainstalować mysql ale nie daję rady.
chyl-o
Post autor: chyl-o »
A powiedz co wywalal mysql z paczek że nie chciał wstać ?
dan-j2
wywala cos takiego przy probie odpalenia
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
chyl-o
pokaz
/etc/mysql/my.cnf | grep -v '#'
netstat -lnp | grep mysql
i sprawdz prawa zapisu w /var/run w katalogu mysqld
pozdr.
wojtekz_
Re: problem z instalacja serwera mysql
Post autor: wojtekz_ »
dan-j2 pisze:(...)
o co z tym moze chodzic proboje zrobic tego mysql ale niedaje rade :/
Ten błąd wskazuje, że to nie problem instalacji jako takiej, tylko bazy danych. Polecenie, które wywołujesz próbuje utworzyć bazę danych i ją odpalić. Ponieważ baza już jest, więc się to nie udaje ze względu na duplikacje unikalnych indeksów. Prawdopodobnie trzeba usunąć już istniejącą bazę danych.
dan-j2
Wczoraj robilem aktualizacje systemu oczywiscie jak zwykle zawsze cos sie narypalo po aktualizacji tym razem wywalilo mi procesy z pliku rc ktore ma podnosic przy starcie to mysql niby w procesach widnieje
root      2447  0.0  0.1   2428  1276 ?        S    11:38   0:00 /bin/sh /usr/bin/mysqld_safe
mysql    18001  0.0  1.6  77948 17108 ?        S    11:38   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/run/my
root     27052  0.0  0.0   1384   480 ?        S    11:38   0:00 logger -p daemon.err -t mysqld_safe -i -t mysqld
mysql    13636  0.0  1.6  77948 17108 ?        S    11:38   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/run/my
mysql     4476  0.0  1.6  77948 17108 ?        S    11:38   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/run/my
mysql     4880  0.0  1.6  77948 17108 ?        S    11:38   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/run/my
mysql     7218  0.0  1.6  77948 17108 ?        S    11:38   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/run/my
mysql    22585  0.0  1.6  77948 17108 ?        S    11:38   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/run/my
mysql     4861  0.0  1.6  77948 17108 ?        S    11:38   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/run/my
mysql    31869  0.0  1.6  77948 17108 ?        S    11:38   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/run/my
mysql    23371  0.0  1.6  77948 17108 ?        S    11:38   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/run/my
mysql     9645  0.0  1.6  77948 17108 ?        S    11:38   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/run/my
mysql    28993  0.0  1.6  77948 17108 ?        S    11:38   0:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/run/my
ale przez phpmyadmin laczyc mi sie nie chce i lms z tamtych komend co mi podales wywala takie cos
debian:~# /etc/mysql/my.cnf | grep -v '#'
-bash: /etc/mysql/my.cnf: Brak dostępu
debian:~# netstat -lnp | grep mysql
tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN     1        8001/mysqld
unix  2      [ ACC ]     STREAM     LISTENING     3127     18001/mysqld        /
chyl-o
nie tak tylko
cat /etc/mysql/my.cnf | grep -v '#'
A jak z zapisem do katalogu z socketem?
dan-j2
podaje wynik:
debian:~# cat /etc/mysql/my.cnf | grep -v '#'
[client]
port            = 3306
socket          = /var/run/mysqld/mysqld.sock
[mysqld_safe]
nice            = 0
[mysqld]
user            = mysql
pid-file        = /var/run/mysqld/mysqld.pid
port            = 3306
basedir         = /usr
datadir         = /var/lib/mysql
tmpdir          = /tmp
language        = /usr/share/mysql/english
skip-external-locking
bind-address            = 127.0.0.1
key_buffer              = 16M
max_allowed_packet      = 16M
thread_stack            = 128K
thread_cache_size       = 8
query_cache_limit       = 1M
query_cache_size        = 16M
log_bin                 = /var/log/mysql/mysql-bin.log
expire_logs_days        = 10
max_binlog_size         = 100M
skip-bdb
[mysqldump]
quick
quote-names
[mysql]
[isamchk]
key_buffer              = 16M
!includedir /etc/mysql/conf.d/
chyl-o
jak z zapisem w katalogu z socketem?
na firewallu nie masz zablokowanego portu 3306 na lo?
dan-j2
na firewallu napewno nie ma blokady tego portu jedynie jest 135-139 i 445 a jezeli chodzi o plik mysql.sock w katalogu '/var/lib/mysql/' to nie wiem dlaczego ale nie ma wogle tego pliku
