Problemy z xorgiem
Problemy z xorgiem
zainstalowalem sterowniki do nVidii(legacy) wg FAQ z tego forum. na Etch ktorego mialem wczesniej zadzialalo wszystko bez problemu natomiast na Lennym(dzisiaj zrobilem upgrade z Etch do Lenny) X-y nie chca sie odpalic. uzywam podstawowego xorg.conf teraz mimo te ze pozwolilem instalatorowi nvidii samemu skonfigurowac xorga( i to wlasnie nie dziala). w czym problem?
xorg.conf
xorg.0.log
po instalalcji sterow nVidii gdy wpisalem [code:1:167
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder3) Wed Nov 1 19:47:17 PST 2006
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 30.0 - 110.0
VertRefresh 50.0 - 150.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "1600x1200" "1280x1024" "1024x768" "800x600" "640x480"
EndSubSection
EndSection
X Window System Version 1.3.0
Release Date: 19 April 2007
X Protocol Version 11, Revision 0, Release 1.3
Build Operating System: Linux Debian
Current Operating System: Linux debian 2.6.18-4-k7 #1 SMP Mon Mar 26 17:57:15 UTC 2007 i686
Build Date: 01 June 2007
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Jun 21 19:40:52 2007
(EE) Unable to locate/open config file
(II) Loader magic: 0x81e5f60
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.2
X.Org XInput driver : 0.7
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
compiled for 1.3.0, module version = 1.0.0
ABI class: X.Org Video Driver, version 1.2
(++) using VT number 7
(II) PCI: 00:00:0: chip 1106,0305 card 1019,0987 rev 03 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,8305 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:07:0: chip 1106,0686 card 1106,0000 rev 40 class 06,01,00 hdr 80
(II) PCI: 00:07:1: chip 1106,0571 card 1106,0571 rev 06 class 01,01,8a hdr 00
(II) PCI: 00:07:2: chip 1106,3038 card 0925,1234 rev 1a class 0c,03,00 hdr 00
(II) PCI: 00:07:3: chip 1106,3038 card 0925,1234 rev 1a class 0c,03,00 hdr 00
(II) PCI: 00:07:4: chip 1106,3057 card 1019,0987 rev 40 class 06,00,00 hdr 00
(II) PCI: 00:0a:0: chip 11c1,008c card 11c1,004c rev 02 class 03,80,00 hdr 00
(II) PCI: 00:0b:0: chip 13f6,0111 card 13f6,0111 rev 10 class 04,01,00 hdr 00
(II) PCI: 00:0c:0: chip 10ec,8139 card 10ec,8139 rev 20 class 02,00,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0171 card 0000,0000 rev a3 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xe8000000 - 0xea0fffff (0x2100000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:7:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI: (0:10:0) unknown vendor (0x11c1) unknown chipset (0x008c) rev 2, Mem @ 0xe0000000/8, I/O @ 0xe000/3, 0xe400/8
(--) PCI:*(1:0:0) nVidia Corporation NV17 [GeForce4 MX 440] rev 163, Mem @ 0xe8000000/24, 0xd0000000/27, 0xd8000000/19
New driver is "nv"
(==) Using default built-in configuration (55 lines)
(==) --- Start of built-in configuration ---
Section "Module"
Load "extmod"
Load "dbe"
Load "glx"
Load "freetype"
Load "type1"
Load "record"
Load "dri"
EndSection
Section "Monitor"
Identifier "Builtin Default Monitor"
EndSection
Section "Device"
Identifier "Builtin Default nv Device 0"
Driver "nv"
EndSection
Section "Screen"
Identifier "Builtin Default nv Screen 0"
Device "Builtin Default nv Device 0"
Monitor "Builtin Default Monitor"
EndSection
Section "Device"
Identifier "Builtin Default fbdev Device 0"
Driver "fbdev"
EndSection
Section "Screen"
Identifier "Builtin Default fbdev Screen 0"
Device "Builtin Default fbdev Device 0"
EndSection
Section "Device"
Identifier "Builtin Default vesa Device 0"
Driver "vesa"
EndSection
Section "Screen"
Identifier "Builtin Default vesa Screen 0"
Device "Builtin Default vesa Device 0"
EndSection
Section "Device"
Identifier "Builtin Default vga Device 0"
Driver "vga"
EndSection
Section "Screen"
Identifier "Builtin Default vga Screen 0"
Device "Builtin Default vga Device 0"
EndSection
Identifier "Builtin Default Layout"
Screen "Builtin Default nv Screen 0"
Screen "Builtin Default fbdev Screen 0"
Screen "Builtin Default vesa Screen 0"
Screen "Builtin Default vga Screen 0"
EndSection
(==) --- End of built-in configuration ---
(==) ServerLayout "Builtin Default Layout"
(**) |-->Screen "Builtin Default nv Screen 0" (0)
(**) | |-->Monitor "Builtin Default Monitor"
(**) | |-->Device "Builtin Default nv Device 0"
(**) |-->Screen "Builtin Default fbdev Screen 0" (1)
(**) | |-->Device "Builtin Default fbdev Device 0"
(**) |-->Screen "Builtin Default vesa Screen 0" (2)
(**) | |-->Device "Builtin Default vesa Device 0"
(**) |-->Screen "Builtin Default vga Screen 0" (3)
(**) | |-->Device "Builtin Default vga Device 0"
(==) |-->Input Device "<default pointer>"
(==) |-->Input Device "<default keyboard>"
(WW) The core pointer device wasn't specified explicitly in the layout.
Using the default mouse configuration.
(WW) The core keyboard device wasn't specified explicitly in the layout.
Using the default keyboard configuration.
(WW) No FontPath specified. Using compiled-in default.
Entry deleted from font path.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to "/etc/X11/rgb"
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe4000000 from 0xe7ffffff to 0xe3ffffff
(II) Active PCI resource ranges:
[0] -1 0 0xeb001000 - 0xeb0010ff (0x100) MX[B]
[1] -1 0 0xe4000000 - 0xe3ffffff (0x0) MX[B]O
[2] -1 0 0xd8000000 - 0xd807ffff (0x80000) MX[B](B)
[3] -1 0 0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
[4] -1 0 0xe8000000 - 0xe8ffffff (0x1000000) MX[B](B)
[5] -1 0 0xe0000000 - 0xe00000ff (0x100) MX[B](B)
[6] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
[7] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[8] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[9] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
[10] -1 0 0x0000d000 - 0x0000d00f (0x10) IX[B]
[11] -1 0 0x0000e400 - 0x0000e4ff (0x100) IX[B](B)
[12] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xeb001000 - 0xeb0010ff (0x100) MX[B]
[5] -1 0 0xe4000000 - 0xe3ffffff (0x0) MX[B]O
[6] -1 0 0xd8000000 - 0xd807ffff (0x80000) MX[B](B)
[7] -1 0 0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
[8] -1 0 0xe8000000 - 0xe8ffffff (0x1000000) MX[B](B)
[9] -1 0 0xe0000000 - 0xe00000ff (0x100) MX[B](B)
[10] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[11] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[12] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
[13] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[14] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[15] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
[16] -1 0 0x0000d000 - 0x0000d00f (0x10) IX[B]
[17] -1 0 0x0000e400 - 0x0000e4ff (0x100) IX[B](B)
[18] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B](B)
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "glx"
(WW) Warning, couldn't open module glx
(II) UnloadModule: "glx"
(EE) Failed to load module "glx" (module does not exist, 0)
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
compiled for 1.3.0, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "type1"
(II) Loading /usr/lib/xorg/modules//fonts/libtype1.so
(II) Module type1: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.0.2
(II) Loading font Type1
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
compiled for 1.3.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) LoadModule: "nv"
(II) Loading /usr/lib/xorg/modules/drivers//nv_drv.so
(II) Module nv: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 2.0.2
ABI class: X.Org Video Driver, version 1.0
(II) LoadModule: "fbdev"
(II) Loading /usr/lib/xorg/modules/drivers//fbdev_drv.so
(II) Module fbdev: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 0.3.1
(II) LoadModule: "vesa"
(II) Loading /usr/lib/xorg/modules/drivers//vesa_drv.so
(II) Module vesa: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.3.0
(II) LoadModule: "vga"
(II) Loading /usr/lib/xorg/modules/drivers//vga_drv.so
(II) Module vga: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 4.1.0
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
compiled for 7.1.1, module version = 1.1.1
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
compiled for 7.1.1, module version = 1.1.0
(II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2,
Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64,
Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400,
GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go,
GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra,
Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420,
GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go,
GeForce4 420 Go 32M, GeForce4 460 Go, Quadro4 550 XGL,
GeForce4 440 Go 64M, Quadro NVS, Quadro4 500 GoGL,
GeForce4 410 Go 16M, GeForce4 MX 440 with AGP8X,
GeForce4 MX 440SE with AGP8X, GeForce4 MX 420 with AGP8X,
GeForce4 MX 4000, GeForce4 448 Go, GeForce4 488 Go, Quadro4 580 XGL,
Quadro4 NVS 280 SD, Quadro4 380 XGL, Quadro NVS 50 PCI,
GeForce4 448 Go, GeForce4 MX Integrated GPU, GeForce3,
GeForce3 Ti 200, GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600,
GeForce4 Ti 4400, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL,
Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X,
GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL,
Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra,
GeForce FX 5800, Quadro FX 2000, Quadro FX 1000,
GeForce FX 5600 Ultra, GeForce FX 5600, GeForce FX 5600XT,
GeForce FX Go5600, GeForce FX Go5650, Quadro FX Go700,
GeForce FX 5200, GeForce FX 5200 Ultra, GeForce FX 5200,
GeForce FX 5200LE, GeForce FX Go5200, GeForce FX Go5250,
GeForce FX 5500, GeForce FX 5100, GeForce FX Go5200 32M/64M,
Quadro NVS 55/280 PCI, Quadro FX 500/600 PCI,
GeForce FX Go53xx Series, GeForce FX Go5100, GeForce FX 5900 Ultra,
GeForce FX 5900, GeForce FX 5900XT, GeForce FX 5950 Ultra,
GeForce FX 5900ZT, Quadro FX 3000, Quadro FX 700,
GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE,
GeForce FX 5700VE, GeForce FX Go5700, GeForce FX Go5700,
Quadro FX Go1000, Quadro FX 1100, GeForce 6800 Ultra, GeForce 6800,
GeForce 6800 LE, GeForce 6800 XE, GeForce 6800 XT, GeForce 6800 GT,
GeForce 6800 GT, GeForce 6800 GS, GeForce 6800 XT, Quadro FX 4000,
GeForce 6800 GS, GeForce 6800, GeForce 6800 LE, GeForce 6800 XT,
GeForce Go 6800, GeForce Go 6800 Ultra, Quadro FX Go1400,
Quadro FX 3450/4000 SDI, Quadro FX 1400, GeForce 6600 GT,
GeForce 6600, GeForce 6600 LE, GeForce 6600 VE, GeForce Go 6600,
GeForce 6610 XL, GeForce Go 6600 TE/6200 TE, GeForce 6700 XL,
GeForce Go 6600, GeForce Go 6600 GT, Quadro FX 550, Quadro FX 550,
Quadro FX 540, GeForce 6200, GeForce 6500,
GeForce 6200 TurboCache(TM), GeForce 6200SE TurboCache(TM),
GeForce 6200 LE, GeForce Go 6200, Quadro NVS 285, GeForce Go 6400,
GeForce Go 6200, GeForce Go 6400, GeForce 6250, GeForce 6800,
GeForce 6800 LE, GeForce 6800 GT, GeForce 6800 XT, GeForce 6200,
GeForce 6200 A-LE, GeForce 7800 GTX, GeForce 7800 GTX,
GeForce 7800 GT, GeForce 7800 GS, GeForce 7800 SLI, GeForce Go 7800,
GeForce Go 7800 GTX, Quadro FX 4500, GeForce 7300 LE,
GeForce 7300 SE, GeForce Go 7200, GeForce Go 7300, GeForce Go 7400,
GeForce Go 7400 GS, Quadro NVS 110M, Quadro NVS 120M, Quadro FX 350M,
GeForce 7500 LE, Quadro FX 350, GeForce 7300 GS, GeForce 7600 GT,
GeForce 7600 GS, GeForce 7300 GT, GeForce 7600 LE, GeForce 7300 GT,
GeForce Go 7700, GeForce Go 7600, GeForce Go 7600 GT,
Quadro NVS 300M, GeForce Go 7900 SE, Quadro FX 550M, Quadro FX 560,
GeForce 7900 GTX, GeForce 7900 GT, GeForce 7900 GS,
GeForce Go 7900 GS, GeForce Go 7900 GTX, Quadro FX 2500M,
Quadro FX 1500M, Quadro FX 5500, Quadro FX 3500, Quadro FX 1500,
Quadro FX 4500 X2, GeForce 6150, GeForce 6150 LE, GeForce 6100,
GeForce Go 6150, GeForce Go 6100, GeForce 8800 GTX, GeForce 8800 GTS,
Quadro FX 5600, Quadro FX 4600, GeForce 8600 GTS, GeForce 8600 GT,
GeForce 8500 GT
(II) FBDEV: driver for framebuffer: fbdev
(II) VESA: driver for VESA chipsets: vesa
(II) VGA: Generic VGA driver (version 4.1) for chipsets: generic
(II) Primary Device is: PCI 01:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset GeForce4 MX 440 found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) Loading sub module "fbdevhw"
(II) LoadModule: "fbdevhw"
(II) Loading /usr/lib/xorg/modules/linux//libfbdevhw.so
(II) Module fbdevhw: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 0.0.2
(EE) open /dev/fb0: No such file or directory
(--) Chipset vesa found
(--) Chipset generic found
(II) resource ranges after probing:
[10] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[11] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[12] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[13] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[14] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[15] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
[16] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[17] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[18] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
[19] -1 0 0x0000d000 - 0x0000d00f (0x10) IX[B]
[20] -1 0 0x0000e400 - 0x0000e4ff (0x100) IX[B](B)
[21] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B](B)
[22] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[23] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) NV(0): Initializing int10
(II) NV(0): Primary V_BIOS segment is: 0xc000
(--) NV(0): Chipset: "GeForce4 MX 440"
(II) NV(0): Creating default Display subsection in Screen section
"Builtin Default nv Screen 0" for depth/fbbpp 24/32
(==) NV(0): Depth 24, (==) framebuffer bpp 32
(==) NV(0): RGB weight 888
(==) NV(0): Default visual is TrueColor
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 0.1.0
(==) NV(0): Using HW cursor
(--) NV(0): Linear framebuffer at 0xD0000000
(--) NV(0): MMIO registers at 0xE8000000
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"(II) Module already built-in
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"(II) Module already built-in
(II) NV(0): I2C bus "DDC" initialized.
(II) NV(0): Probing for analog device on output A...
(--) NV(0): ...found one
(II) NV(0): Probing for analog device on output B...
(--) NV(0): ...can't find one
(II) NV(0): Probing for EDID on I2C bus A...
(II) NV(0): I2C device "DDC:ddc2" registered at address 0xA0.
(II) NV(0): I2C device "DDC:ddc2" removed.
(--) NV(0): DDC detected a CRT:
(II) NV(0): Manufacturer: ADI Model: 550 Serial#: 1259
(II) NV(0): Year: 1995 Week: 48
(II) NV(0): EDID Version: 1.0
(II) NV(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
(II) NV(0): Sync: Separate
(II) NV(0): Max H-Image Size [cm]: horiz.: 30 vert.: 23
(II) NV(0): Gamma: 2.25
(II) NV(0): DPMS capabilities: Suspend Off; RGB/Color Display
(II) NV(0): redX: 0.625 redY: 0.340 greenX: 0.310 greenY: 0.592
(II) NV(0): blueX: 0.150 blueY: 0.063 whiteX: 0.281 whiteY: 0.311
(II) NV(0): Supported VESA Video Modes:
(II) NV(0): 720x400@70Hz
(II) NV(0): 720x400@88Hz
(II) NV(0): 640x480@60Hz
(II) NV(0): 640x480@67Hz
(II) NV(0): 640x480@72Hz
(II) NV(0): 640x480@75Hz
(II) NV(0): 800x600@56Hz
(II) NV(0): 800x600@60Hz
(II) NV(0): 800x600@72Hz
(II) NV(0): 800x600@75Hz
(II) NV(0): 832x624@75Hz
(II) NV(0): 1024x768@87Hz (interlaced)
(II) NV(0): 1024x768@60Hz
(II) NV(0): 1024x768@70Hz
(II) NV(0): 1024x768@75Hz
(II) NV(0): Manufacturer's mask: 0
(II) NV(0): Supported Future Video Modes:
(II) NV(0): #0: hsize: 640 vsize 512 refresh: 70 vid: 35377
(II) NV(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) NV(0): EDID (in hex):
(II) NV(0): 00ffffffffffff0004895005eb040000
(II) NV(0): 30050100081e177d680692a0574f9726
(II) NV(0): 10484ffffe00318a8180010101010101
(II) NV(0): 01010101010101010101010101010101
(II) NV(0): 0101010101010101010101010101008e
(II) NV(0): Probing for EDID on I2C bus B...
(II) NV(0): ... none found
(--) NV(0): CRTC 0 appears to have a CRT attached
(II) NV(0): Using CRT on CRTC 0
(II) NV(0): DDCModeFromDetailedTiming: 1x1 Warning: We only handle seperate sync.
(II) NV(0): Printing DDC gathered Modelines:
(II) NV(0): Modeline "800x600" 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync
(II) NV(0): Modeline "800x600" 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync
(II) NV(0): Modeline "640x480" 31.50 640 656 720 840 480 481 484 500 -hsync -vsync
(II) NV(0): Modeline "640x480" 31.50 640 664 704 832 480 489 491 520 -hsync -vsync
(II) NV(0): Modeline "640x480" 30.24 640 704 768 864 480 483 486 525 -hsync -vsync
(II) NV(0): Modeline "640x480" 25.20 640 656 752 800 480 490 492 525 -hsync -vsync
(II) NV(0): Modeline "720x400" 35.50 720 738 846 900 400 421 423 449 -hsync -vsync
(II) NV(0): Modeline "720x400" 28.32 720 738 846 900 400 412 414 449 -hsync +vsync
(II) NV(0): Modeline "1024x768" 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
(II) NV(0): Modeline "1024x768" 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync
(II) NV(0): Modeline "1024x768" 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync
(II) NV(0): Modeline "1024x768" 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync
(II) NV(0): Modeline "832x624" 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync
(II) NV(0): Modeline "800x600" 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync
(II) NV(0): Modeline "800x600" 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync
(II) NV(0): Modeline "640x512" 30.50 640 664 728 816 512 515 522 536 -hsync +vsync
(II) NV(0): Modeline "1280x1024" 109.00 1280 1368 1496 1712 1024 1027 1034 1063 -hsync +vsync
(II) NV(0): Modeline "1x1" 2.57 1 2 3 258 1 1 18 258 -hsync -vsync
(--) NV(0): VideoRAM: 65536 kBytes
(==) NV(0): Using gamma correction (1.0, 1.0, 1.0)
(II) NV(0): Builtin Default Monitor: Using hsync range of 9.96-63.67 kHz
(II) NV(0): Builtin Default Monitor: Using vrefresh range of 38.61-87.85 Hz
(II) NV(0): Estimated virtual size for aspect ratio 1.3043 is 1280x1024
(II) NV(0): Clock range: 12.00 to 350.00 MHz
(II) NV(0): Not using default mode "1024x768" (bad mode clock/interlace/doublescan)
(II) NV(0): Not using default mode "512x384" (bad mode clock/interlace/doublescan)
(II) NV(0): Not using default mode "1024x768" (hsync out of range)
(II) NV(0): Not using default mode "512x384" (hsync out of range)
(II) NV(0): Not using default mode "1152x864" (hsync out of range)
(II) NV(0): Not using default mode "576x432" (hsync out of range)
(II) NV(0): Not using default mode "1280x960" (hsync out of range)
(II) NV(0): Not using default mode "640x480" (hsync out of range)
(II) NV(0): Not using default mode "1280x1024" (hsync out of range)
(II) NV(0): Not using default mode "640x512" (hsync out of range)
(II) NV(0): Not using default mode "1600x1200" (width too large for virtual size)
(II) NV(0): Not using default mode "800x600" (hsync out of range)
(II) NV(0): Not using default mode "1792x1344" (width too large for virtual size)
(II) NV(0): Not using default mode "896x672" (hsync out of range)
(II) NV(0): Not using default mode "1856x1392" (width too large for virtual size)
(II) NV(0): Not using default mode "928x696" (hsync out of range)
(II) NV(0): Not using default mode "1920x1440" (width too large for virtual size)
(II) NV(0): Not using default mode "960x720" (hsync out of range)
(II) NV(0): Not using default mode "1400x1050" (width too large for virtual size)
(II) NV(0): Not using default mode "700x525" (hsync out of range)
(II) NV(0): Not using default mode "1440x900" (width too large for virtual size)
(II) NV(0): Not using default mode "1600x1024" (width too large for virtual size)
(II) NV(0): Not using default mode "1680x1050" (width too large for virtual size)
(II) NV(0): Not using default mode "840x525" (hsync out of range)
(II) NV(0): Not using default mode "1920x1200" (width too large for virtual size)
(II) NV(0): Not using default mode "960x600" (hsync out of range)
(II) NV(0): Not using default mode "2048x1536" (width too large for virtual size)
(II) NV(0): Not using driver mode "1024x768" (bad mode clock/interlace/doublescan)
(II) NV(0): Not using driver mode "1x1" (bad mode clock/interlace/doublescan)
(--) NV(0): Virtual size is 1280x1024 (pitch 1280)
(**) NV(0): *Driver mode "1280x1024": 109.0 MHz, 63.7 kHz, 59.9 Hz
(**) NV(0): *Default mode "1280x1024": 108.0 MHz, 64.0 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x1024" 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
(**) NV(0): *Default mode "1280x960": 108.0 MHz, 60.0 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x960" 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync
(**) NV(0): *Default mode "1280x800": 83.5 MHz, 49.7 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x800" 83.46 1280 1344 1480 1680 800 801 804 828
(**) NV(0): *Default mode "1280x768": 80.1 MHz, 47.7 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x768" 80.14 1280 1344 1480 1680 768 769 772 795
(**) NV(0): *Default mode "1152x768": 65.0 MHz, 44.2 kHz, 54.8 Hz
(II) NV(0): Modeline "1152x768" 65.00 1152 1178 1314 1472 768 771 777 806 +hsync +vsync
(**) NV(0): *Driver mode "1024x768": 78.8 MHz, 60.1 kHz, 75.1 Hz
(**) NV(0): *Driver mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(**) NV(0): *Driver mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(**) NV(0): *Default mode "1024x768": 78.8 MHz, 60.0 kHz, 75.0 Hz
(II) NV(0): Modeline "1024x768" 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
(**) NV(0): *Default mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(**) NV(0): *Default mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(**) NV(0): *Driver mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
(**) NV(0): *Default mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
(**) NV(0): *Driver mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(**) NV(0): *Driver mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(**) NV(0): *Driver mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(**) NV(0): *Driver mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(**) NV(0): *Default mode "800x600": 56.3 MHz, 53.7 kHz, 85.1 Hz
(II) NV(0): Modeline "800x600" 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync
(**) NV(0): *Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(**) NV(0): *Default mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(**) NV(0): *Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(**) NV(0): *Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(**) NV(0): *Driver mode "640x512": 30.5 MHz, 37.4 kHz, 69.7 Hz
(**) NV(0): *Default mode "640x512": 54.0 MHz, 64.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x512" 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync
(**) NV(0): *Default mode "720x450": 54.4 MHz, 56.9 kHz, 60.2 Hz (D)
(II) NV(0): Modeline "720x450" 54.42 720 736 940 956 450 459 463 473 doublescan +hsync +vsync
(**) NV(0): *Driver mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(**) NV(0): *Driver mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
(**) NV(0): *Driver mode "640x480": 30.2 MHz, 35.0 kHz, 66.7 Hz
(**) NV(0): *Driver mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
(**) NV(0): *Default mode "640x480": 36.0 MHz, 43.3 kHz, 85.0 Hz
(II) NV(0): Modeline "640x480" 36.00 640 696 752 832 480 481 484 509 -hsync -vsync
(**) NV(0): *Default mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(**) NV(0): *Default mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
(II) NV(0): Modeline "640x480" 31.50 640 664 704 832 480 489 492 520 -hsync -vsync
(**) NV(0): *Default mode "640x480": 54.0 MHz, 60.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x480" 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync
(**) NV(0): *Default mode "640x480": 25.2 MHz, 31.5 kHz, 59.9 Hz
(II) NV(0): Modeline "640x480" 25.18 640 656 752 800 480 490 492 525 -hsync -vsync
(**) NV(0): *Driver mode "720x400": 35.5 MHz, 39.4 kHz, 87.8 Hz
(**) NV(0): *Driver mode "720x400": 28.3 MHz, 31.5 kHz, 70.1 Hz
(**) NV(0): *Default mode "720x400": 35.5 MHz, 37.9 kHz, 85.0 Hz
(II) NV(0): Modeline "720x400" 35.50 720 756 828 936 400 401 404 446 -hsync +vsync
(**) NV(0): *Default mode "640x400": 31.5 MHz, 37.9 kHz, 85.1 Hz
(II) NV(0): Modeline "640x400" 31.50 640 672 736 832 400 401 404 445 -hsync +vsync
(**) NV(0): *Default mode "640x400": 41.7 MHz, 49.7 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x400" 41.73 640 672 740 840 400 400 402 414 doublescan
(**) NV(0): *Default mode "640x384": 40.1 MHz, 47.7 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "640x384" 40.07 640 672 740 840 384 384 386 397 doublescan
(**) NV(0): *Default mode "640x350": 31.5 MHz, 37.9 kHz, 85.1 Hz
(II) NV(0): Modeline "640x350" 31.50 640 672 736 832 350 382 385 445 +hsync -vsync
(**) NV(0): *Default mode "576x384": 32.5 MHz, 44.2 kHz, 54.8 Hz (D)
(II) NV(0): Modeline "576x384" 32.50 576 589 657 736 384 385 388 403 doublescan +hsync +vsync
(**) NV(0): *Default mode "512x384": 39.4 MHz, 60.0 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "512x384" 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync
(**) NV(0): *Default mode "512x384": 37.5 MHz, 56.5 kHz, 70.1 Hz (D)
(II) NV(0): Modeline "512x384" 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync
(**) NV(0): *Default mode "512x384": 32.5 MHz, 48.4 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "512x384" 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync
(**) NV(0): *Default mode "416x312": 28.6 MHz, 49.7 kHz, 74.7 Hz (D)
(II) NV(0): Modeline "416x312" 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync
(**) NV(0): *Default mode "400x300": 28.1 MHz, 53.7 kHz, 85.3 Hz (D)
(II) NV(0): Modeline "400x300" 28.15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync
(**) NV(0): *Default mode "400x300": 24.8 MHz, 46.9 kHz, 75.1 Hz (D)
(II) NV(0): Modeline "400x300" 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync
(**) NV(0): *Default mode "400x300": 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
(II) NV(0): Modeline "400x300" 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync
(**) NV(0): *Default mode "400x300": 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
(II) NV(0): Modeline "400x300" 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync
(**) NV(0): *Default mode "400x300": 18.0 MHz, 35.2 kHz, 56.3 Hz (D)
(II) NV(0): Modeline "400x300" 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync
(**) NV(0): *Default mode "320x240": 18.0 MHz, 43.3 kHz, 85.2 Hz (D)
(II) NV(0): Modeline "320x240" 18.00 320 348 376 416 240 240 242 254 doublescan -hsync -vsync
(**) NV(0): *Default mode "320x240": 15.8 MHz, 37.5 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "320x240" 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync
(**) NV(0): *Default mode "320x240": 15.8 MHz, 37.9 kHz, 72.8 Hz (D)
(II) NV(0): Modeline "320x240" 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync
(**) NV(0): *Default mode "320x240": 12.6 MHz, 31.5 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "320x240" 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync
(**) NV(0): *Default mode "360x200": 17.8 MHz, 37.9 kHz, 85.0 Hz (D)
(II) NV(0): Modeline "360x200" 17.75 360 378 414 468 200 200 202 223 doublescan -hsync +vsync
(**) NV(0): *Default mode "320x200": 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
(II) NV(0): Modeline "320x200" 15.75 320 336 368 416 200 200 202 222 doublescan -hsync +vsync
(**) NV(0): *Default mode "320x175": 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
(II) NV(0): Modeline "320x175" 15.75 320 336 368 416 175 191 192 222 doublescan +hsync -vsync
(**) NV(0): Display dimensions: (300, 230) mm
(**) NV(0): DPI set to (108, 113)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
compiled for 1.3.0, module version = 1.2.0
(II) LoadModule: "ramdac"(II) Module already built-in
(II) UnloadModule: "fbdev"
(II) Unloading /usr/lib/xorg/modules/drivers//fbdev_drv.so
(II) UnloadModule: "fbdevhw"
(II) Unloading /usr/lib/xorg/modules/linux//libfbdevhw.so
(II) UnloadModule: "vesa"
(II) Unloading /usr/lib/xorg/modules/drivers//vesa_drv.so
(II) UnloadModule: "vga"
(II) Unloading /usr/lib/xorg/modules/drivers//vga_drv.so
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xd8000000 - 0xd807ffff (0x80000) MX[B]
[1] 0 0 0xd0000000 - 0xd7ffffff (0x8000000) MX[B]
[2] 0 0 0xe8000000 - 0xe8ffffff (0x1000000) MX[B]
[3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[7] -1 0 0xeb001000 - 0xeb0010ff (0x100) MX[B]
[8] -1 0 0xe4000000 - 0xe3ffffff (0x0) MX[B]O
[9] -1 0 0xd8000000 - 0xd807ffff (0x80000) MX[B](B)
[10] -1 0 0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
[11] -1 0 0xe8000000 - 0xe8ffffff (0x1000000) MX[B](B)
[12] -1 0 0xe0000000 - 0xe00000ff (0x100) MX[B](B)
[13] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
[14] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
[15] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
[16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[18] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX[B]
[19] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[20] -1 0 0x0000d800 - 0x0000d81f (0x20) IX[B]
[21] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
[22] -1 0 0x0000d000 - 0x0000d00f (0x10) IX[B]
[23] -1 0 0x0000e400 - 0x0000e4ff (0x100) IX[B](B)
[24] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B](B)
[25] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[26] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(==) NV(0): Write-combining range (0xd0000000,0x4000000)
(II) NV(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
Indirect CPU to Screen color expansion
Solid Lines
Scanline Image Writes
Offscreen Pixmaps
Setting up tile and stipple cache:
32 128x128 slots
32 256x256 slots
16 512x512 slots
(==) NV(0): Backing store disabled
(==) NV(0): Silken mouse enabled
(==) RandR enabled
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension XEVIE
(WW) <default pointer>: No Device specified, looking for one...
(II) <default pointer>: Setting Device option to "/dev/input/mice"
(--) <default pointer>: Device: "/dev/input/mice"
(==) <default pointer>: Protocol: "Auto"
(**) Option "CorePointer"
(**) <default pointer>: Core Pointer
(==) <default pointer>: Emulate3Buttons, Emulate3Timeout: 50
(**) <default pointer>: ZAxisMapping: buttons 4 and 5
(**) <default pointer>: Buttons: 9
(**) Option "CoreKeyboard"
(**) <default keyboard>: Core Keyboard
(**) Option "Protocol" "standard"
(**) <default keyboard>: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) <default keyboard>: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) <default keyboard>: XkbModel: "pc105"
(**) Option "XkbLayout" "us"
(**) <default keyboard>: XkbLayout: "us"
(**) Option "CustomKeycodes" "off"
(**) <default keyboard>: CustomKeycodes disabled
(II) XINPUT: Adding extended input device "<default keyboard>" (type: KEYBOARD)
(II) XINPUT: Adding extended input device "<default pointer>" (type: MOUSE)
(--) <default pointer>: PnP-detected protocol: "ExplorerPS/2"
(II) <default pointer>: ps2EnableDataReporting: succeeded
AUDIT: Thu Jun 21 19:42:47 2007: 4650 X: client 19 rejected from local host (uid 0)
Auth name: MIT-MAGIC-COOKIE-1 ID: -1
AUDIT: Thu Jun 21 19:42:58 2007: 4650 X: client 19 rejected from local host (uid 0)
czy xorg.conf leży w /etc/X11/ ?rzepaczyk pisze: xorg.0.logKod: Zaznacz cały
a jakie tam sa prawa dla tego pliku? Moze nie moze otworzyc.
Nie masz tez glx i /dev/fb0. Z tym glx to prosta sprawa ale z /dev/fb0 to juz (z tego co ja wiem) jest wiekszy problem bo to juz trzeba sunac do jadra.
Moja propozycja to
parawa dla pliku]
dla glx (tu moge sie mylic ale jak cos to odinstalujesz)
i dla fb0 rekompilacja jajka (to tak bym zrobil)
Moja propozycja to
parawa dla pliku
-rw-r--r-- 1 root root 3125 2007-05-21 12:03 /etc/X11/xorg.conf
apt-get install libgl1-mesa-dev
czyli dla xorg.conf mam ustawic chmod ten co podal stepek. potem doinstalowac libgl1-mesa-dev.
ale z rekompilacja jajka bedzie problem albowiem nie wiem jak mam to zrobic
[ Dodano: 2007-07-06, 20:51 ] mam zainstalowane juz to
nie wiem tylko jak ten chmod ustawic ale wyglada na to ze tylko root ma pelne prawa do tego pliku. ja jako zwykly user moge go tylko obejrzec
