Sieć przeskanowana przez:
airodump-ngKod: Zaznacz cały
ENC CIPHER AUTH
WEP WEP <pusto>
Przy próbie połączenia z konsoli po wpisaniu:
dhclient wlan0Kod: Zaznacz cały
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval x
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
Inne informacje:
ifconfigKod: Zaznacz cały
eth0 Link encap:Ethernet HWaddr 00:1e:ec:42:c4:af
collisions:0 txqueuelen:1000
Interrupt:17
lo Link encap:Local Loopback
RX packets:64 errors:0 dropped:0 overruns:0 frame:0
TX packets:64 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:9401 (9.4 KB) TX bytes:9401 (9.4 KB)
wlan0 Link encap:Ethernet HWaddr 00:1f:3b:48:60:b7
UP BROADCAST NOTRAILERS PROMISC ALLMULTI MTU:1500 Metric:1
RX packets:1428 errors:0 dropped:0 overruns:0 frame:0
RX bytes:126834 (126.8 KB) TX bytes:0 (0.0 B)
iwlist scanKod: Zaznacz cały
wlan0 Scan completed :
Cell 01 - Address: 00:10:C6:CA:C8:F8
Channel:10
Frequency:2.457 GHz (Channel 10)
Quality=26/70 Signal level=-84 dBm
Encryption key :o n
ESSID:"neostrada_6643"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
24 Mb/s; 36 Mb/s; 54 Mb/s
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
Mode:Master
Extra:tsf=00000475e0799d9f
Extra: Last beacon: 2060ms ago
IE: Unknown: 000E6E656F7374726164615F36363433
IE: Unknown: 010882848B962430486C
IE: Unknown: 03010A
IE: Unknown: 2A0104
IE: Unknown: 2F0104
IE: Unknown: 32040C121860
IE: Unknown: DD060010180200F0
IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
Cell 02 - Address: 00:14:C1:30:FE:ED
Channel:11
Frequency:2.462 GHz (Channel 11)
Quality=61/70 Signal level=-49 dBm
Encryption key :o n
ESSID:"Masters"
Mode:Master
Extra:tsf=000000001fe0fd25
Extra: Last beacon: 1910ms ago
IE: Unknown: 00074D617374657273
IE: Unknown: 03010B
IE: Unknown: 2A0104
IE: Unknown: 2F0104
IE: Unknown: DD06001018020015
iwconfigKod: Zaznacz cały
wlan0 IEEE 802.11abgn ESSID:"Masters"
Mode:Managed Access Point: Not-Associated Tx-Power=15 dBm
Retry long limit:7 RTS thr :o ff Fragment thr :o ff
Encryption key:6D61-7374-756E-696E-6732-3030-30
Power Management :o ff
Typ zabezpieczeń: Udostępnione
Typ szyfrowania: WEP
