Mam na komputerze programowy RAID-1 (mdadm). Ostatnio postanowiłem sprawdzić stan dysków S.M.A.R.T-em i zaobserwowałem błędy. Będę wdzięczny za informacje w czym tkwi problem i czy konieczna jest wymiana dysków?
smartctl -a /dev/hda
smartctl version 5.38 [i686-pc-linux-gnu] Copyright (C) 2002-8 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Device Model: SAMSUNG SP0411N
Serial Number: S01JJ20WB76790
Firmware Version: TW100-08
User Capacity: 40,060,403,712 bytes
Device is: In smartctl database [for details use: -P show]
ATA Version is: 7
ATA Standard is: ATA/ATAPI-7 T13 1532D revision 0
Local Time is: Thu Oct 6 11:53:18 2011 CEST
==> WARNING: May need -F samsung or -F samsung2 enabled; see manual for details.
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 112) The previous self-test completed having
the read element of the test failed.
Total time to complete Offline
data collection: ( 900) seconds.
capabilities: (0x1b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
No General Purpose Logging support.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 15) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 051 Pre-fail Always - 11
3 Spin_Up_Time 0x0007 063 063 000 Pre-fail Always - 6336
4 Start_Stop_Count 0x0032 094 094 000 Old_age Always - 6535
5 Reallocated_Sector_Ct 0x0033 099 099 010 Pre-fail Always - 3
7 Seek_Error_Rate 0x000b 253 253 051 Pre-fail Always - 0
8 Seek_Time_Performance 0x0024 253 253 000 Old_age Offline - 0
9 Power_On_Hours 0x0032 097 097 000 Old_age Always - 1846290
10 Spin_Retry_Count 0x0013 253 253 049 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 098 098 000 Old_age Always - 2531
194 Temperature_Celsius 0x0022 133 118 000 Old_age Always - 35
195 Hardware_ECC_Recovered 0x000a 100 100 000 Old_age Always - 74417408
196 Reallocated_Event_Count 0x0012 099 099 000 Old_age Always - 4
197 Current_Pending_Sector 0x0033 253 253 010 Pre-fail Always - 0
198 Offline_Uncorrectable 0x0031 100 100 010 Pre-fail Offline - 1
199 UDMA_CRC_Error_Count 0x000b 100 100 051 Pre-fail Always - 0
200 Multi_Zone_Error_Rate 0x000b 100 100 051 Pre-fail Always - 0
201 Soft_Read_Error_Rate 0x000b 100 100 051 Pre-fail Always - 1
SMART Error Log Version: 1
Warning: ATA error count 4864 inconsistent with error log pointer 5
ATA Error Count: 4864 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 4864 occurred at disk power-on lifetime: 8947 hours (372 days + 19 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
04 51 00 01 c2 4f a0 Error: ABRT
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
b0 d9 00 01 c2 4f a0 00 03:16:46.938 SMART DISABLE OPERATIONS
ec 00 ff 01 00 00 a0 00 03:16:46.938 IDENTIFY DEVICE
10 00 ff 01 01 00 a0 00 03:16:46.875 RECALIBRATE [OBS-4]
91 00 ff 01 01 00 af 00 03:16:46.875 INITIALIZE DEVICE PARAMETERS [OBS-6]
ec 00 ff 01 00 00 a0 00 03:16:46.875 IDENTIFY DEVICE
Error 4863 occurred at disk power-on lifetime: 7915 hours (329 days + 19 hours)
b0 d9 00 01 c2 4f a0 00 01:11:17.438 SMART DISABLE OPERATIONS
ec 00 ff 01 00 00 a0 00 01:11:17.438 IDENTIFY DEVICE
10 00 ff 01 01 00 a0 00 01:11:17.375 RECALIBRATE [OBS-4]
91 00 ff 01 01 00 af 00 01:11:17.375 INITIALIZE DEVICE PARAMETERS [OBS-6]
ec 00 ff 01 00 00 a0 00 01:11:17.188 IDENTIFY DEVICE
Error 4862 occurred at disk power-on lifetime: 7915 hours (329 days + 19 hours)
b0 d9 00 01 c2 4f a0 00 00:52:32.625 SMART DISABLE OPERATIONS
ec 00 ff 01 00 00 a0 00 00:52:32.625 IDENTIFY DEVICE
10 00 ff 01 01 00 a0 00 00:52:32.625 RECALIBRATE [OBS-4]
91 00 ff 01 01 00 af 00 00:52:32.625 INITIALIZE DEVICE PARAMETERS [OBS-6]
ec 00 ff 01 00 00 a0 00 00:52:32.500 IDENTIFY DEVICE
Error 4861 occurred at disk power-on lifetime: 4604 hours (191 days + 20 hours)
b0 d9 00 01 c2 4f a0 00 00:00:06.625 SMART DISABLE OPERATIONS
ec 00 ff 01 00 00 a0 00 00:00:06.625 IDENTIFY DEVICE
10 00 ff 01 01 00 a0 00 00:00:06.625 RECALIBRATE [OBS-4]
91 00 ff 01 01 00 af 00 00:00:06.625 INITIALIZE DEVICE PARAMETERS [OBS-6]
ec 00 ff 01 00 00 a0 00 00:00:06.563 IDENTIFY DEVICE
Error 4860 occurred at disk power-on lifetime: 1210 hours (50 days + 10 hours)
b0 d9 00 01 c2 4f a0 00 00:00:05.688 SMART DISABLE OPERATIONS
ec 00 ff 01 00 00 a0 00 00:00:05.688 IDENTIFY DEVICE
10 00 ff 01 01 00 a0 00 00:00:05.625 RECALIBRATE [OBS-4]
91 00 ff 01 01 00 af 00 00:00:05.625 INITIALIZE DEVICE PARAMETERS [OBS-6]
ec 00 ff 01 00 00 a0 00 00:00:05.563 IDENTIFY DEVICE
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed: read failure 00% 15319 76596352
# 2 Short offline Completed without error 00% 15318 -
Device does not support Selective Self Tests/Logging
smartctl -a /dev/hdb
Device Model: SAMSUNG SV0411N
Serial Number: S01RJ20WB91051
Firmware Version: UA100-08
ATA Version is: 7
Local Time is: Thu Oct 6 12:05:59 2011 CEST
was never started.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
data collection: (1200) seconds.
command.
power-saving mode.
recommended polling time: ( 20) minutes.
1 Raw_Read_Error_Rate 0x000b 100 100 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0007 079 042 000 Pre-fail Always - 4032
4 Start_Stop_Count 0x0032 098 098 000 Old_age Always - 2952
5 Reallocated_Sector_Ct 0x0033 253 253 010 Pre-fail Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 1709141
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 1488
194 Temperature_Celsius 0x0022 133 124 000 Old_age Always - 35
195 Hardware_ECC_Recovered 0x000a 100 100 000 Old_age Always - 53090052
196 Reallocated_Event_Count 0x0012 253 253 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0031 253 253 010 Pre-fail Offline - 0
201 Soft_Read_Error_Rate 0x000b 100 100 051 Pre-fail Always - 0
Warning: ATA error count 9984 inconsistent with error log pointer 5
ATA Error Count: 9984 (device log contains only the most recent five errors)
Error 9984 occurred at disk power-on lifetime: 8671 hours (361 days + 7 hours)
b0 d9 00 01 c2 4f a0 00 07:02:29.938 SMART DISABLE OPERATIONS
ec 00 ff 01 00 00 a0 00 07:02:29.938 IDENTIFY DEVICE
10 00 ff 01 01 00 a0 00 07:02:29.875 RECALIBRATE [OBS-4]
91 00 ff 01 01 00 af 00 07:02:29.875 INITIALIZE DEVICE PARAMETERS [OBS-6]
ec 00 ff 01 00 00 a0 00 07:02:25.813 IDENTIFY DEVICE
Error 9983 occurred at disk power-on lifetime: 8671 hours (361 days + 7 hours)
b0 d9 00 01 c2 4f a0 00 06:45:01.750 SMART DISABLE OPERATIONS
ec 00 ff 01 00 00 a0 00 06:45:01.750 IDENTIFY DEVICE
10 00 ff 01 01 00 a0 00 06:45:01.750 RECALIBRATE [OBS-4]
91 00 ff 01 01 00 af 00 06:45:01.750 INITIALIZE DEVICE PARAMETERS [OBS-6]
ec 00 ff 01 00 00 a0 00 06:44:57.688 IDENTIFY DEVICE
Error 9982 occurred at disk power-on lifetime: 8671 hours (361 days + 7 hours)
b0 d9 00 01 c2 4f a0 00 06:29:51.563 SMART DISABLE OPERATIONS
ec 00 ff 01 00 00 a0 00 06:29:51.563 IDENTIFY DEVICE
10 00 ff 01 01 00 a0 00 06:29:51.563 RECALIBRATE [OBS-4]
91 00 ff 01 01 00 af 00 06:29:51.563 INITIALIZE DEVICE PARAMETERS [OBS-6]
ec 00 ff 01 00 00 a0 00 06:29:47.125 IDENTIFY DEVICE
Error 9981 occurred at disk power-on lifetime: 8665 hours (361 days + 1 hours)
b0 d9 00 01 c2 4f a0 00 00:00:33.563 SMART DISABLE OPERATIONS
ec 00 ff 01 00 00 a0 00 00:00:33.563 IDENTIFY DEVICE
10 00 ff 01 01 00 a0 00 00:00:33.500 RECALIBRATE [OBS-4]
91 00 ff 01 01 00 af 00 00:00:33.500 INITIALIZE DEVICE PARAMETERS [OBS-6]
ec 00 ff 01 00 00 a0 00 00:00:28.500 IDENTIFY DEVICE
Error 9980 occurred at disk power-on lifetime: 8665 hours (361 days + 1 hours)
b0 d9 00 01 c2 4f a0 00 00:00:17.563 SMART DISABLE OPERATIONS
ec 00 ff 01 00 00 a0 00 00:00:17.563 IDENTIFY DEVICE
10 00 ff 01 01 00 a0 00 00:00:12.813 RECALIBRATE [OBS-4]
91 00 ff 01 01 00 af 00 00:00:12.813 INITIALIZE DEVICE PARAMETERS [OBS-6]
ec 00 ff 01 00 00 a0 00 00:00:08.688 IDENTIFY DEVICE
Warning! SMART Self-Test Log Structure error: invalid SMART checksum.
No self-tests have been logged. [To run self-tests, use: smartctl -t]
