Zainstalowałem sobie niedawno postfiksa z dovecotem. Uruchomiłem i działa... do czasu.
W pewnym momencie (kilka godzin zazwyczaj mija) zaczynają być zaśmiecone logi czymś takim:
Sep 17 11:50:45 krolnet dovecot: imap-login: Fatal: chroot(/var/run/dovecot/login) failed: Operation not permitted
Sep 17 11:50:45 krolnet dovecot: master: Error: service(imap-login): command startup failed, throttling
Sep 17 11:51:45 krolnet dovecot: imap-login: Fatal: chroot(/var/run/dovecot/login) failed: Operation not permitted
Sep 17 11:51:45 krolnet dovecot: master: Error: service(imap-login): command startup failed, throttling
Sep 17 11:52:45 krolnet dovecot: imap-login: Fatal: chroot(/var/run/dovecot/login) failed: Operation not permitted
Sep 17 11:52:45 krolnet dovecot: master: Error: service(imap-login): command startup failed, throttling
Sep 17 11:52:59 krolnet dovecot: master: Error: service(auth): kill(18092, SIGINT) failed: Operation not permitted
Sep 17 11:53:46 krolnet dovecot: imap-login: Fatal: chroot(/var/run/dovecot/login) failed: Operation not permitted
Sep 17 11:53:46 krolnet dovecot: master: Error: service(imap-login): command startup failed, throttling
Sep 17 11:54:00 krolnet dovecot: master: Error: service(auth): Process 18092 is ignoring idle SIGINT
Sep 17 11:54:46 krolnet dovecot: imap-login: Fatal: chroot(/var/run/dovecot/login) failed: Operation not permitted
Sep 17 11:54:46 krolnet dovecot: master: Error: service(imap-login): command startup failed, throttling
Sep 17 11:55:46 krolnet dovecot: imap-login: Fatal: chroot(/var/run/dovecot/login) failed: Operation not permitted
Sep 17 11:55:46 krolnet dovecot: master: Error: service(imap-login): command startup failed, throttling
