deb http://ftp.debian.org/debian/ etch main non-free contribKod: Zaznacz cały
deb http://archive.debian.org/debian/ etch main non-free contribKod: Zaznacz cały
# security updates for etch
deb http://security.debian.org/ etch/updates main contrib non-free
deb-src http://security.debian.org/ etch/updates main contrib non-free
awa:/etc/apt# apt-get update
Ign http://security.debian.org etch/updates Release.gpg
Ign http://security.debian.org etch/updates/main Packages
Ign http://security.debian.org etch/updates/contrib Packages
Ign http://security.debian.org etch/updates/non-free Packages
Ign http://security.debian.org etch/updates/main Sources
Ign http://security.debian.org etch/updates/contrib Sources
Ign http://security.debian.org etch/updates/non-free Sources
Błąd http://security.debian.org etch/updates/main Packages
404 Not Found [IP: 195.20.242.89 80]
Błąd http://security.debian.org etch/updates/contrib Packages
Błąd http://security.debian.org etch/updates/non-free Packages
Błąd http://security.debian.org etch/updates/main Sources
Błąd http://security.debian.org etch/updates/contrib Sources
Błąd http://security.debian.org etch/updates/non-free Sources
Pob: 1 http://archive.debian.org etch Release.gpg [1033B]
Traf http://archive.debian.org etch Release
Ign http://archive.debian.org etch/main Packages/DiffIndex
Ign http://archive.debian.org etch/non-free Packages/DiffIndex
Ign http://archive.debian.org etch/contrib Packages/DiffIndex
Ign http://archive.debian.org etch/main Sources/DiffIndex
Ign http://archive.debian.org etch/contrib Sources/DiffIndex
Ign http://archive.debian.org etch/non-free Sources/DiffIndex
Traf http://archive.debian.org etch/main Packages
Traf http://archive.debian.org etch/non-free Packages
Traf http://archive.debian.org etch/contrib Packages
Traf http://archive.debian.org etch/main Sources
Traf http://archive.debian.org etch/contrib Sources
Traf http://archive.debian.org etch/non-free Sources
Pobrano 1B w 2s (0B/s)
Nie udało się pobrać http://security.debian.org/dists/etch/updates/main/binary-i386/Packages.gz 404 Not Found [IP: 195.20.242.89 80]
Nie udało się pobrać http://security.debian.org/dists/etch/updates/contrib/binary-i386/Packages.gz 404 Not Found [IP: 195.20.242.89 80]
Nie udało się pobrać http://security.debian.org/dists/etch/updates/non-free/binary-i386/Packages.gz 404 Not Found [IP: 195.20.242.89 80]
Nie udało się pobrać http://security.debian.org/dists/etch/updates/main/source/Sources.gz 404 Not Found [IP: 195.20.242.89 80]
Nie udało się pobrać http://security.debian.org/dists/etch/updates/contrib/source/Sources.gz 404 Not Found [IP: 195.20.242.89 80]
Nie udało się pobrać http://security.debian.org/dists/etch/updates/non-free/source/Sources.gz 404 Not Found [IP: 195.20.242.89 80]
W: Nie udało się wykonać operacji stat na liście pakietów źródłowych http://security.debian.org etch/updates/main Packages (/var/lib/apt/lists/security.debian.org_dists_etch_updates_main_binary-i386_Packages) - stat (2 Nie ma takiego pliku ani katalogu)
W: Nie udało się wykonać operacji stat na liście pakietów źródłowych http://security.debian.org etch/updates/contrib Packages (/var/lib/apt/lists/security.debian.org_dists_etch_updates_contrib_binary-i386_Packages) - stat (2 Nie ma takiego pliku ani katalogu)
W: Nie udało się wykonać operacji stat na liście pakietów źródłowych http://security.debian.org etch/updates/non-free Packages (/var/lib/apt/lists/security.debian.org_dists_etch_updates_non-free_binary-i386_Packages) - stat (2 Nie ma takiego pliku ani katalogu)
W: Należy uruchomić apt-get update aby naprawić te problemy.
E: Nie udało się pobrać niektórych plików indeksu, zostały one zignorowane lub została użyta ich starsza wersja.
