Mam problem z zainstalowaniem modułów dla vmware workstation 7.1.4.
Posiadam jądro 3.0.0-1-amd64, zainstalowałam także linux-headers (instalator je widzi). Jednak nie jest w stanie dokończyć kompilacji modułu vmmon.
Log:
1 Aug 01 18:51:39.404: app-139792517871360| Log for VMware Workstation pid=27862 version=7.1.4 build=build-385536 option=Release
2 Aug 01 18:51:39.404: app-139792517871360| The process is 64-bit.
3 Aug 01 18:51:39.404: app-139792517871360| Host codepage=UTF-8 encoding=UTF-8
4 Aug 01 18:51:39.404: app-139792517871360| Logging to /tmp/vmware-root/setup-27862.log
5 Aug 01 18:51:39.447: app-139792517871360| modconf query interface initialized
6 Aug 01 18:51:39.447: app-139792517871360| modconf library initialized
45 Aug 01 18:51:39.836: app-139792517871360| Trying to find a suitable PBM set for kernel 3.0.0-1-amd64.
46 Aug 01 18:51:39.842: app-139792517871360| Trying to find a suitable PBM set for kernel 3.0.0-1-amd64.
47 Aug 01 18:51:39.844: app-139792517871360| Trying to find a suitable PBM set for kernel 3.0.0-1-amd64.
48 Aug 01 18:51:39.846: app-139792517871360| Trying to find a suitable PBM set for kernel 3.0.0-1-amd64.
49 Aug 01 18:51:39.848: app-139792517871360| Trying to find a suitable PBM set for kernel 3.0.0-1-amd64.
50 Aug 01 18:51:39.856: app-139792517871360| Your GCC version: 4.4
51 Aug 01 18:51:39.856: app-139792517871360| Searching for GCC 4.5.
52 Aug 01 18:51:39.857: app-139792517871360| Kernel compiled with: GCC 4.5
53 Aug 01 18:51:39.857: app-139792517871360| Your GCC version: 4.5
54 Aug 01 18:51:39.865: app-139792517871360| Your GCC version: 4.4
55 Aug 01 18:51:39.865: app-139792517871360| Searching for GCC 4.5.
56 Aug 01 18:51:39.867: app-139792517871360| Kernel compiled with: GCC 4.5
57 Aug 01 18:51:39.867: app-139792517871360| Your GCC version: 4.5
58 Aug 01 18:51:39.942: app-139792517871360| Trying to find a suitable PBM set for kernel 3.0.0-1-amd64.
59 Aug 01 18:51:39.948: app-139792517871360| Trying to find a suitable PBM set for kernel 3.0.0-1-amd64.
60 Aug 01 18:51:39.952: app-139792517871360| Trying to find a suitable PBM set for kernel 3.0.0-1-amd64.
61 Aug 01 18:51:39.953: app-139792517871360| Trying to find a suitable PBM set for kernel 3.0.0-1-amd64.
62 Aug 01 18:51:39.955: app-139792517871360| Trying to find a suitable PBM set for kernel 3.0.0-1-amd64.
63 Aug 01 18:51:40.187: app-139792517871360| Trying to find a suitable PBM set for kernel 3.0.0-1-amd64.
64 Aug 01 18:51:40.188: app-139792517871360| Building module vmmon.
65 Aug 01 18:51:40.188: app-139792517871360| Extracting the sources of the vmmon module.
66 Aug 01 18:51:40.207: app-139792517871360| Building module with command: /usr/bin/make -C /tmp/vmware-root/modules/vmmon-only auto-build SUPPORT_S MP=1 HEADER_DIR=/lib/modules/3.0.0-1-amd64/build/include CC=/usr/bin/gcc-4.5 GREP=/usr/bin/make IS_GCC_3=no VMCCVER=4.5.3
67 Aug 01 18:51:41.355: app-139792517871360| Failed to compile module vmmon!
