Instalator nVidia nie może okre
dominbik
Instalator nVidia nie może określić wersji źródeł jądra
Post autor: dominbik »
Witam!
Mam problem z zainstalowaniem sterowników zamkniętych nvidii. http://damlab.pl/howto/nvidia_drivers/ Korzystam z tego poradnika, ściągam wersję legacy 96xx dla systemów 32bitowych (karta GeForce4 MX 440 - wersja się zgadza).
Wyskakuje:
ERROR: Unable to determine the version of the kernel sources located in
       '/lib/modules/2.6.39-2-686-pae/source'.  Please make sure you have
       installed the kernel source files for your kernel and that they are
       properly configured; on Red Hat Linux systems, for example, be sure you
       have the 'kernel-source' or 'kernel-devel' RPM installed.  If you know
       the correct kernel source files are installed, you may specify the
       kernel source path with the '--kernel-source-path' command line option.
Załączam wyniki poleceń:
dpkg -l |grep headers
ii  linux-headers-2.6.39-2-686-pae        2.6.39-3                          Header files for Linux 2.6.39-2-686-pae
ii  linux-headers-2.6.39-2-common         2.6.39-3                          Common header files for Linux 2.6.39-2
ii  linux-libc-dev                        2.6.39-3                          Linux support headers for userspace development
dpkg -l |grep linux-image
ii  linux-image-2.6-686-pae               2.6.39+35.1                       Linux 2.6 for modern PCs (meta-package)
ii  linux-image-2.6.39-2-686-pae          2.6.39-3                          Linux 2.6.39 for modern PCs
dpkg -l |grep nvidia
Nic ;)
uname -a
Linux stacjonarny 2.6.39-2-686-pae #1 SMP Tue Jul 5 03:48:49 UTC 2011 i686 GNU/Linux
ls /lib/modules/*
build   modules.alias      modules.dep      modules.devname  modules.softdep  modules.symbols.bin
kernel  modules.alias.bin  modules.dep.bin  modules.order    modules.symbols  source
ls -l /usr/src
razem 73728
drwxr-xr-x 3 root root     4096 07-25 09:42 gcc-4.6
drwxr-xr-x 4 root root     4096 07-24 22:38 linux-headers-2.6.39-2-686-pae
drwxr-xr-x 4 root root     4096 07-24 22:38 linux-headers-2.6.39-2-common
lrwxrwxrwx 1 root root       26 05-20 06:01 linux-kbuild-2.6.39 -> ../lib/linux-kbuild-2.6.39
-rw-r--r-- 1 root root 75480384 07-04 18:32 linux-source-2.6.39.tar.bz2
Podgląd całego pliku nvidia-installer.log :
http://pokazywarka.pl/idf8ef/
Mógłby ktoś mi pomóc lub chociaż wskazać gdzie szukać rozwiązania, bo podoba mi się ten Debian lecz brak tego sterownika stwarza dość odczuwalny dyskomfort (działanie środowiska, złe działania youtube itd.).
Mam taką kartę, w jednym komputerze, i wszystko na niej działa z otwartym sterownikiem. Ostatnio sprawdzałem nawet na tym komputerze instalator Debiana w wersji testowej. Wszystko zainstalowane domyślnie działa tak jak powinno. Nie ma problemu nawet z jądrem z serii 3.0.
dominbik
Dziękuję. Ostatecznie skorzystałem z tych sterowników: ftp://download.nvidia.com/XFree86/Linux-x86/96.43.20/, chodź za jakiś czas mają chyba pojawić się w repozytorium Debiana Wheezy.
