Mam Debiana Wheezy 64-bit 2.6.39. Mam problem z połączeniem się z internetem za pomocą modemu GSM Option GI0225.
NetworkManager[1415]: <warn> GSM modem enable failed: (32) Failed to find a usable modem character set
Jul 15 07:48:30 s745 NetworkManager[1415]: <info> (hso0): device state change: 4 -> 9 (reason 28)
Jul 15 07:48:30 s745 NetworkManager[1415]: <info> Marking connection 'ERA Default' invalid.
Jul 15 07:48:30 s745 NetworkManager[1415]: <warn> Activation (hso0) failed.
Jul 15 07:48:30 s745 NetworkManager[1415]: <info> (hso0): device state change: 9 -> 3 (reason 0)
Jul 15 07:48:30 s745 NetworkManager[1415]: <info> (hso0): deactivating device (reason: 0).
Jul 15 07:49:16 s745 NetworkManager[1415]: <info> Activation (hso0) starting connection 'ERA Default'
Jul 15 07:49:16 s745 NetworkManager[1415]: <info> (hso0): device state change: 3 -> 4 (reason 0)
Jul 15 07:49:16 s745 NetworkManager[1415]: <info> Activation (hso0) Stage 1 of 5 (Device Prepare) scheduled...
Jul 15 07:49:16 s745 NetworkManager[1415]: <info> Activation (hso0) Stage 1 of 5 (Device Prepare) started...
Jul 15 07:49:16 s745 NetworkManager[1415]: <info> (hso0): device state change: 4 -> 6 (reason 0)
Jul 15 07:49:16 s745 NetworkManager[1415]: <info> Activation (hso0) Stage 1 of 5 (Device Prepare) complete.
Jul 15 07:49:16 s745 NetworkManager[1415]: <info> (hso0): device state change: 6 -> 4 (reason 0)
Jul 15 07:49:16 s745 modem-manager[1425]: <info> (ttyHS0) opening serial port...
Jul 15 07:49:16 s745 modem-manager[1425]: <info> Modem /org/freedesktop/ModemManager/Modems/0: state changed (disabled -> enabling)
Jul 15 07:49:20 s745 modem-manager[1425]: <info> Modem /org/freedesktop/ModemManager/Modems/0: state changed (enabling -> disabled)
Jul 15 07:49:20 s745 modem-manager[1425]: <info> (ttyHS0) closing serial port...
Jul 15 07:49:20 s745 modem-manager[1425]: <info> (ttyHS0) serial port closed
Jul 15 07:49:20 s745 NetworkManager[1415]: <warn> GSM modem enable failed: (32) Serial command timed outKod: Zaznacz cały
nmcli con up iface hso0 uuid b5895aff-0231-4a69-9ce7-28e052888dc2Kod: Zaznacz cały
Active connection state: activating
Active connection path: /org/freedesktop/NetworkManager/ActiveConnection/2
** (process:2686): WARNING **: _nm_object_get_property: Error getting 'State' for /org/freedesktop/NetworkManager/ActiveConnection/2: (19) Method "Get" with signature "ss" on interface "org.freedesktop.DBus.Properties" doesn't exist
state: unknown
Error: Connection activation failed.Macie jakieś pomysły?
