Transmission-daemon i prawa zapisu
Delleg
Post autor: Delleg »
Kłania się moja niewiedza na temat poleceń uniksowych, ale mimo wszystko proszę Was o pomoc. Chcę mieć zdalny dostęp do ,,transmision'' przez przeglądarkę, czyli IP_maszyny:9091, i rzeczywiście działa, ale mam problem z zapisem plików bo wciąż mam:
Permission danied
settings.json
    "alt-speed-down": 300,
    "alt-speed-enabled": true,
    "alt-speed-time-begin": 435,
    "alt-speed-time-day": 62,
    "alt-speed-time-enabled": true,
    "alt-speed-time-end": 915,
    "alt-speed-up": 1,
    "bind-address-ipv4": "0.0.0.0",
    "bind-address-ipv6": "::",
    "blocklist-date": 1254838899,
    "blocklist-enabled": false,
    "blocklist-updates-enabled": 1,
    "dht-enabled": true,
    "download-dir": "/var/lib/transmission-daemon/info/Downloads",
    "download-limit": 100,
    "download-limit-enabled": 0,
    "encryption": 2,
    "incomplete-dir": "/var/lib/transmission-daemon/info/Downloads",
    "incomplete-dir-enabled": false,
    "inhibit-desktop-hibernation": 0,
    "lazy-bitfield-enabled": true,
    "lpd-enabled": false,
    "main-window-height": 500,
    "main-window-layout-order": "menu,toolbar,filter,list,statusbar",
    "main-window-width": 447,
    "main-window-x": 221,
    "main-window-y": 138,
    "message-level": 2,
    "minimal-view": 0,
    "open-dialog-dir": "/home/torrent/seeding",
    "open-file-limit": 32,
    "peer-limit-global": 240,
    "peer-limit-per-torrent": 60,
    "peer-port": 51413,
    "peer-port-random-enabled": 0,
    "peer-port-random-high": 65535,
    "peer-port-random-low": 1024,
    "peer-port-random-on-start": false,
    "peer-socket-tos": 0,
    "pex-enabled": true,
    "port-forwarding-enabled": true,
    "preallocation": 1,
    "prompt-before-exit": 1,
    "proxy": "",
    "proxy-auth-enabled": false,
    "proxy-auth-password": "",
    "proxy-auth-username": "",
    "proxy-enabled": false,
    "proxy-port": 80,
    "proxy-type": 0,
    "ratio-limit": 2.0000,
    "ratio-limit-enabled": false,
    "recent-announce-url-0-announce": "http://9.rarbg.com:2710/announce",
    "recent-announce-url-0-tier": 0,
    "recent-announce-url-1-announce": "",
    "recent-announce-url-1-tier": 0,
    "recent-announce-url-2-announce": "",
    "recent-announce-url-2-tier": 0,
    "recent-announce-url-count": 1,
    "recent-download-dir-1": "/root/torrent",
    "rename-partial-files": true,
    "rpc-authentication-required": false,
    "rpc-bind-address": "0.0.0.0",
    "rpc-enabled": true,
    "rpc-password": "{3497e6f97be37b610e4ad7d4c6901e84a202a0edAxCpHJkd",
    "rpc-port": 9091,
    "rpc-username": "root",
    "rpc-whitelist": "127.0.0.*,192.168.16.5,192.168.16.12",
    "rpc-whitelist-enabled": false,
    "sched-begin": 1380,
    "sched-download-limit": 200,
    "sched-end": 420,
    "sched-limit-enabled": 0,
    "sched-upload-limit": 100,
    "script-torrent-done-enabled": false,
    "script-torrent-done-filename": "",
    "show-desktop-notification": 1,
    "show-filterbar": 1,
    "show-notification-area-icon": 0,
    "show-options-window": 1,
    "show-statusbar": 1,
    "show-toolbar": 1,
    "sort-mode": "sort-by-name",
    "sort-reversed": 0,
    "speed-limit-down": 100,
    "speed-limit-down-enabled": false,
    "speed-limit-up": 100,
    "speed-limit-up-enabled": false,
    "start-added-torrents": true,
    "statusbar-stats": "total-ratio",
    "trash-original-torrent-files": false,
    "umask": 0,
    "upload-limit": 100,
    "upload-limit-enabled": 0,
    "upload-slots-per-torrent": 14,
    "watch-dir": "/root/Desktop",
    "watch-dir-enabled": 0
Uprawnienia dla katalogu ustawiłem w następujący sposób:
usermod -a -G debian-transmission root
chown -R debian-transmission:debian-transmission /var/lib/transmission-daemon/info/Downloads/
chmod 770 -R /var/lib/transmission-daemon/info/Downloads/
ploosh
Post autor: ploosh »
Miałem ten sam problem.
Transmission-daemon miał pobierać do /home/użytkownik/download i cały czas wyświetlało:
permission danied
Pomogło jak wykonałem:
chmod -R 777 /home
Wcześniejsze prawa dostępu dla /home/użytkownik/download nie dawało żadnego rezultatu.
