Brak dźwi
IgiKoval
Brak dźwięku na Debianie Sid
Post autor: IgiKoval »
Jest to moja kolejna instalacja Debiana, która przebiegała na początku poprawnie. Niestety, mimo tego, że robiłem wszystko jak zawsze, mój system nie odtwarza dźwięku. Mam zainstalowane oczywiście alsa-base i alsa-utils, w alsamixer wszystko na maksimum.
Tutaj http://www.alsa-project.org/db/?f=84f6c ... b5357b608f informacje, które zapewne będą przydatne w diagnozowaniu mojego problemu.
!!ALSA Information Script v 0.4.60
!!Script ran on: Wed Jun 22 19:14:32 UTC 2011
!!Linux Distribution
Debian GNU/Linux wheezy/sid \n \l
!!DMI Information
Manufacturer:
Product Name:      K7VT4A
Product Version:   1.0x
!!Kernel Information
Kernel release:    2.6.39-2-486
Operating System:  GNU/Linux
Architecture:      i686
Processor:         unknown
SMP Enabled:       No
!!ALSA Version
Driver version:     1.0.24
Library version:    1.0.23
Utilities version:  1.0.23
!!Loaded ALSA modules
snd_emu10k1
snd_mpu401
!!Sound Servers on this system
No sound servers found.
!!Soundcards recognised by ALSA
 0 [Audigy         ]: Audigy - SB Audigy 1 [SB0092]
                      SB Audigy 1 [SB0092] (rev.3, serial:0x531102) at 0xe800, irq 19
 1 [UART           ]: MPU-401 UART - MPU-401 UART
                      MPU-401 UART at 0x300, irq 5
!!PCI Soundcards installed in the system
00:0b.0 Multimedia audio controller: Creative Labs SB Audigy (rev 03)
!!Advanced information - PCI Vendor/Device/Subsystem ID's
00:0b.0 0401: 1102:0004 (rev 03)
	Subsystem: 1102:0053
!!Modprobe options (Sound related)
snd-atiixp-modem: index=-2
snd-intel8x0m: index=-2
snd-via82xx-modem: index=-2
snd-pcsp: index=-2
snd-usb-audio: index=-2
!!Loaded sound module options
!!Module: snd_emu10k1
	delay_pcm_irq : 2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_ir : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
	extin : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	extout : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	high_res_gpr_volume : N
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	max_buffer_size : 128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128,128
	max_synth_voices : 64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64,64
	seq_ports : 4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4
	subsystem : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
!!Module: snd_mpu401
	enable : Y,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
	index : -2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2,-2
	irq : 5,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535,65535
	pnp : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	port : 768,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1
	uart_enter : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
!!AC97 Codec information
--startcollapse--
0-0/0: SigmaTel STAC9721,23
PCI Subsys Vendor: 0x0000
PCI Subsys Device: 0x0000
Flags: 0
Capabilities     :
DAC resolution   : 18-bit
ADC resolution   : 18-bit
3D enhancement   : SigmaTel 3D Enhancement
Current setup
Mic gain         :  0dB [ 0dB]
POP path         : pre 3D
Sim. stereo      : off
3D enhancement   : on
Loudness         : off
Mono output      : MIX
Mic select       : Mic1
ADC/DAC loopback : off
Extended ID      : codec=0 rev=0 AMAP DSA=0
Extended status  : PRJ
0:00 = 6940
0:02 = 0000
0:04 = 8000
0:06 = 801f
0:08 = 0000
0:0a = 801e
0:0c = 801f
0:0e = 801f
0:10 = 9f1f
0:12 = 0606
0:14 = 9f1f
0:16 = 9f1f
0:18 = 9f1f
0:1a = 0000
0:1c = 0000
0:1e = 0000
0:20 = 2000
0:22 = 000c
0:24 = 0000
0:26 = 000f
0:28 = 0200
0:2a = 1000
0:2c = 0000
0:2e = 0000
0:30 = 0000
0:32 = 0000
0:34 = 0000
0:36 = 0000
0:38 = 0000
0:3a = 0000
0:3c = 0000
0:3e = 0000
0:40 = 0000
0:42 = 0000
0:44 = 0000
0:46 = 0000
0:48 = 0000
0:4a = 0000
0:4c = 0000
0:4e = 0000
0:50 = 0000
0:52 = 0000
0:54 = 0000
0:56 = 0000
0:58 = 0000
0:5a = 0000
0:5c = 0000
0:5e = 0000
0:60 = 0000
0:62 = 0000
0:64 = 0000
0:66 = 0000
0:68 = 0000
0:6a = 0000
0:6c = 00c4
0:6e = 0008
0:70 = 0000
0:72 = 0000
0:74 = 0380
0:76 = 0000
0:78 = 8380
0:7a = 0000
0:7c = 8384
0:7e = 7609
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 13 Jun 22 18:35 /dev/snd/controlC0
crw-rw---- 1 root audio 116,  3 Jun 22 18:35 /dev/snd/controlC1
crw-rw---- 1 root audio 116,  4 Jun 22 18:35 /dev/snd/hwC0D0
crw-rw---- 1 root audio 116, 14 Jun 22 18:35 /dev/snd/hwC0D2
crw-rw---- 1 root audio 116,  6 Jun 22 18:35 /dev/snd/midiC0D0
crw-rw---- 1 root audio 116,  5 Jun 22 18:35 /dev/snd/midiC0D1
crw-rw---- 1 root audio 116, 15 Jun 22 18:35 /dev/snd/midiC0D2
crw-rw---- 1 root audio 116, 16 Jun 22 18:35 /dev/snd/midiC0D3
crw-rw---- 1 root audio 116,  2 Jun 22 18:35 /dev/snd/midiC1D0
crw-rw---- 1 root audio 116, 12 Jun 22 18:35 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 11 Jun 22 19:13 /dev/snd/pcmC0D0p
crw-rw---- 1 root audio 116, 10 Jun 22 18:35 /dev/snd/pcmC0D1c
crw-rw---- 1 root audio 116,  9 Jun 22 18:35 /dev/snd/pcmC0D2c
crw-rw---- 1 root audio 116,  8 Jun 22 18:35 /dev/snd/pcmC0D2p
crw-rw---- 1 root audio 116,  7 Jun 22 18:35 /dev/snd/pcmC0D3p
crw-rw---- 1 root audio 116,  1 Jun 22 18:35 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Jun 22 18:35 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  60 Jun 22 18:35 .
drwxr-xr-x 3 root root 400 Jun 22 18:35 ..
lrwxrwxrwx 1 root root  12 Jun 22 18:35 pci-0000:00:0b.0 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: Audigy [SB Audigy 1 [SB0092]], device 0: emu10k1 [ADC Capture/Standard PCM Playback]
  Subdevices: 32/32
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
  Subdevice #7: subdevice #7
  Subdevice #8: subdevice #8
  Subdevice #9: subdevice #9
  Subdevice #10: subdevice #10
  Subdevice #11: subdevice #11
  Subdevice #12: subdevice #12
  Subdevice #13: subdevice #13
  Subdevice #14: subdevice #14
  Subdevice #15: subdevice #15
  Subdevice #16: subdevice #16
  Subdevice #17: subdevice #17
  Subdevice #18: subdevice #18
  Subdevice #19: subdevice #19
  Subdevice #20: subdevice #20
  Subdevice #21: subdevice #21
  Subdevice #22: subdevice #22
  Subdevice #23: subdevice #23
  Subdevice #24: subdevice #24
  Subdevice #25: subdevice #25
  Subdevice #26: subdevice #26
  Subdevice #27: subdevice #27
  Subdevice #28: subdevice #28
  Subdevice #29: subdevice #29
  Subdevice #30: subdevice #30
  Subdevice #31: subdevice #31
card 0: Audigy [SB Audigy 1 [SB0092]], device 2: emu10k1 efx [Multichannel Capture/PT Playback]
  Subdevices: 8/8
card 0: Audigy [SB Audigy 1 [SB0092]], device 3: emu10k1 [Multichannel Playback]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
card 0: Audigy [SB Audigy 1 [SB0092]], device 1: emu10k1 mic [Mic Capture]
  Subdevices: 1/1
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card 0 [Audigy]
Card hw:0 'Audigy'/'SB Audigy 1 [SB0092] (rev.3, serial:0x531102) at 0xe800, irq 19'
  Mixer name	: 'SigmaTel STAC9721,23'
  Components	: 'AC97a:83847609'
  Controls      : 198
  Simple ctrls  : 34
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined penum
  Playback channels: Mono
  Limits: Playback 0 - 100
  Mono: Playback 100 [100%] [0.00dB]
Simple mixer control 'Tone',0
  Capabilities: pswitch penum
  Playback channels: Front Left - Front Right
  Mono:
  Front Left: Playback [on]
  Front Right: Playback [on]
Simple mixer control 'Bass',0
  Capabilities: volume penum
  Capture channels: Front Left - Front Right
  Limits: 0 - 40
  Front Left: 20 [50%]
  Front Right: 20 [50%]
Simple mixer control 'Treble',0
  Limits: 0 - 40
Simple mixer control '3D Control - Switch',0
  Capabilities: pswitch pswitch-joined penum
  Mono: Playback [on]
Simple mixer control '3D Control Sigmatel - Depth',0
  Capabilities: volume volume-joined penum
  Capture channels: Mono
  Limits: 0 - 3
  Mono: 3 [100%]
Simple mixer control 'PCM',0
  Capabilities: pvolume cvolume penum
  Limits: Playback 0 - 100 Capture 0 - 100
  Front Left: Playback 100 [100%] [0.00dB] Capture 100 [100%] [0.00dB]
  Front Right: Playback 100 [100%] [0.00dB] Capture 100 [100%] [0.00dB]
Simple mixer control 'PCM Center',0
Simple mixer control 'PCM Front',0
  Capabilities: pvolume penum
  Mono:
Simple mixer control 'PCM LFE',0
Simple mixer control 'PCM Surround',0
  Mono:
Simple mixer control 'Front',0
  Mono:
Simple mixer control 'Surround',0
  Mono:
Simple mixer control 'Surround Phase Inversion',0
  Mono: Playback [on]
Simple mixer control 'Center',0
Simple mixer control 'LFE',0
Simple mixer control 'Synth',0
  Front Left: Playback 100 [100%] [0.00dB] Capture 80 [80%] [-8.00dB]
  Front Right: Playback 100 [100%] [0.00dB] Capture 80 [80%] [-8.00dB]
Simple mixer control 'Line',0
  Capabilities: pvolume pswitch pswitch-joined penum
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Line2',0
  Front Left: Playback 0 [0%] [-99999.99dB] Capture 0 [0%] [-99999.99dB]
  Front Right: Playback 0 [0%] [-99999.99dB] Capture 0 [0%] [-99999.99dB]
Simple mixer control 'CD',0
  Mono:
  Front Left: Playback 25 [81%] [3.00dB] [on]
  Front Right: Playback 25 [81%] [3.00dB] [on]
Simple mixer control 'Mic',0
Simple mixer control 'Mic Boost ( 20dB)',0
  Mono: Playback [off]
Simple mixer control 'Phone',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined penum
  Mono: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'IEC958 Optical',0
Simple mixer control 'IEC958 Optical Raw',0
  Mono:
  Front Left: Playback [off]
  Front Right: Playback [off]
Simple mixer control 'Beep',0
  Limits: Playback 0 - 15
  Mono: Playback 0 [0%] [-45.00dB] [off]
Simple mixer control 'Aux',0
  Mono:
Simple mixer control 'Aux2',0
Simple mixer control 'Analog Capture Boost',0
Simple mixer control 'Analog Mix',0
Simple mixer control 'Audigy Analog/Digital Output Jack',0
  Mono: Playback [on]
Simple mixer control 'Audigy CD',0
Simple mixer control 'External Amplifier',0
  Mono: Playback [on]
Simple mixer control 'Sigmatel 4-Speaker Stereo',0
!!-------Mixer controls for card 1 [UART]
Card hw:1 'UART'/'MPU-401 UART at 0x300, irq 5'
  Mixer name	: ''
  Components	: ''
  Controls      : 0
  Simple ctrls  : 0
!!Alsactl output
--startcollapse--
state.Audigy {
	control.1 {
		comment.access 'read write'
		comment.type INTEGER
		comment.count 2
		comment.range '0 - 100'
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'PCM Front Playback Volume'
		value.0 100
		value.1 100
	control.2 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'PCM Surround Playback Volume'
		value.0 100
		value.1 100
	control.3 {
		comment.count 1
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'PCM Center Playback Volume'
		value 100
	control.4 {
		comment.count 1
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'PCM LFE Playback Volume'
		value 100
	control.5 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'PCM Playback Volume'
		value.0 100
		value.1 100
	control.6 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Synth Playback Volume'
		value.0 100
		value.1 100
	control.7 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'PCM Capture Volume'
		value.0 100
		value.1 100
	control.8 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Synth Capture Volume'
		value.0 80
		value.1 80
	control.9 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Mic Playback Volume'
		value.0 0
		value.1 0
	control.10 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Mic Capture Volume'
		value.0 0
		value.1 0
	control.11 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Audigy CD Playback Volume'
		value.0 0
		value.1 0
	control.12 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Audigy CD Capture Volume'
		value.0 0
		value.1 0
	control.13 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'IEC958 Optical Playback Volume'
		value.0 0
		value.1 0
	control.14 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'IEC958 Optical Capture Volume'
		value.0 0
		value.1 0
	control.15 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Line2 Playback Volume'
		value.0 0
		value.1 0
	control.16 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Line2 Capture Volume'
		value.0 0
		value.1 0
	control.17 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Analog Mix Playback Volume'
		value.0 0
		value.1 0
	control.18 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Analog Mix Capture Volume'
		value.0 0
		value.1 0
	control.19 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Aux2 Playback Volume'
		value.0 0
		value.1 0
	control.20 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Aux2 Capture Volume'
		value.0 0
		value.1 0
	control.21 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Front Playback Volume'
		value.0 100
		value.1 100
	control.22 {
		comment.count 2
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Surround Playback Volume'
		value.0 100
		value.1 100
	control.23 {
		comment.count 1
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Center Playback Volume'
		value 100
	control.24 {
		comment.count 1
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'LFE Playback Volume'
		value 100
	control.25 {
		comment.count 2
		comment.range '0 - 40'
		iface MIXER
		name 'Tone Control - Bass'
		value.0 20
		value.1 20
	control.26 {
		comment.count 2
		iface MIXER
		name 'Tone Control - Treble'
		value.0 20
		value.1 20
	control.27 {
		comment.type BOOLEAN
		comment.count 2
		iface MIXER
		name 'Tone Control - Switch'
		value.0 true
		value.1 true
	control.28 {
		comment.count 1
		comment.dbmin -4000
		comment.dbmax 0
		iface MIXER
		name 'Master Playback Volume'
		value 100
	control.29 {
		comment.count 2
		iface MIXER
		name 'IEC958 Optical Raw Playback Switch'
		value.0 false
		value.1 false
	control.30 {
		comment.count 64
		iface PCM
		device 2
		name 'Captured FX8010 Outputs'
		value.0 false
		value.1 false
		value.2 false
		value.3 false
		value.4 false
		value.5 false
		value.6 false
		value.7 false
		value.8 false
		value.9 false
		value.10 false
		value.11 false
		value.12 false
		value.13 false
		value.14 false
		value.15 false
		value.16 false
		value.17 false
		value.18 false
		value.19 false
		value.20 false
		value.21 false
		value.22 false
		value.23 false
		value.24 false
		value.25 false
		value.26 false
		value.27 false
		value.28 false
		value.29 false
		value.30 false
		value.31 false
		value.32 true
		value.33 true
		value.34 true
		value.35 true
		value.36 true
		value.37 true
		value.38 true
		value.39 true
		value.40 true
		value.41 true
		value.42 true
		value.43 true
		value.44 true
		value.45 true
		value.46 true
		value.47 true
		value.48 false
		value.49 false
		value.50 false
		value.51 false
		value.52 false
		value.53 false
		value.54 false
		value.55 false
		value.56 false
		value.57 false
		value.58 false
		value.59 false
		value.60 false
		value.61 false
		value.62 false
		value.63 false
	control.35 {
		comment.count 1
		iface MIXER
		name 'Beep Playback Switch'
		value false
	control.36 {
		comment.count 1
		comment.range '0 - 15'
		comment.dbmin -4500
		comment.dbmax 0
		iface MIXER
		name 'Beep Playback Volume'
		value 0
	control.37 {
		comment.count 1
		iface MIXER
		name 'Phone Playback Switch'
		value false
	control.38 {
		comment.count 1
		comment.range '0 - 31'
		comment.dbmin -3450
		comment.dbmax 1200
		iface MIXER
		name 'Phone Playback Volume'
		value 0
	control.41 {
		comment.count 1
		iface MIXER
		name 'Mic Boost ( 20dB)'
		value false
	control.42 {
		comment.count 1
		iface MIXER
		name 'Line Playback Switch'
		value false
	control.43 {
		comment.count 2
		comment.dbmin -3450
		comment.dbmax 1200
		iface MIXER
		name 'Line Playback Volume'
		value.0 0
		value.1 0
	control.44 {
		comment.count 1
		iface MIXER
		name 'CD Playback Switch'
		value true
	control.45 {
		comment.count 2
		comment.dbmin -3450
		comment.dbmax 1200
		iface MIXER
		name 'CD Playback Volume'
		value.0 25
		value.1 25
	control.48 {
		comment.count 1
		iface MIXER
		name 'Aux Playback Switch'
		value false
	control.49 {
		comment.count 2
		comment.dbmin -3450
		comment.dbmax 1200
		iface MIXER
		name 'Aux Playback Volume'
		value.0 0
		value.1 0
	control.55 {
		comment.count 1
		iface MIXER
		name '3D Control - Switch'
		value true
	control.58 {
		comment.count 1
		comment.range '0 - 3'
		iface MIXER
		name '3D Control Sigmatel - Depth'
		value 3
	control.59 {
		comment.count 1
		iface MIXER
		name 'Sigmatel 4-Speaker Stereo Playback Switch'
		value false
	control.60 {
		comment.count 1
		iface MIXER
		name 'Surround Phase Inversion Playback Switch'
		value true
	control.61 {
		comment.count 1
		iface MIXER
		name 'External Amplifier'
		value true
	control.206 {
		comment.access read
		comment.type IEC958
		comment.count 1
		iface PCM
		name 'IEC958 Playback Mask'
		value ffffffff00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
	control.207 {
		comment.access read
		comment.type IEC958
		comment.count 1
		iface PCM
		index 1
	control.208 {
		comment.access read
		comment.type IEC958
		comment.count 1
		iface PCM
		index 2
	control.209 {
		comment.type IEC958
		comment.count 1
		iface PCM
		name 'IEC958 Playback Default'
		value '0492100200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
	control.210 {
		comment.type IEC958
		comment.count 1
		iface PCM
		index 1
	control.211 {
		comment.type IEC958
		comment.count 1
		iface PCM
		index 2
	control.212 {
		comment.count 1
		iface MIXER
		name 'Audigy Analog/Digital Output Jack'
		value true
	control.213 {
		comment.count 1
		iface MIXER
		name 'Analog Capture Boost'
		value false
state.UART {
	control {
--endcollapse--
!!All Loaded Modules
Module
btrfs
zlib_deflate
crc32c
libcrc32c
ufs
qnx4
hfsplus
hfs
minix
ntfs
vfat
msdos
fat
jfs
xfs
reiserfs
ext4
jbd2
crc16
dm_mod
fuse
ext2
snd_emu10k1_synth
snd_emux_synth
snd_seq_virmidi
snd_seq_midi_emul
snd_emu10k1
nvidia
snd_wavefront
snd_cs4236
snd_ac97_codec
snd_wss_lib
snd_opl3_lib
ac97_bus
arc4
snd_pcm
snd_page_alloc
snd_util_mem
snd_mpu401
snd_mpu401_uart
snd_hwdep
snd_seq_midi
ecb
snd_seq_midi_event
snd_rawmidi
snd_seq
rt61pci
rt2x00pci
rt2x00lib
mac80211
i2c_viapro
cfg80211
via_ircc
snd_timer
snd_seq_device
snd
irda
soundcore
i2c_core
rfkill
eeprom_93cx6
crc_ccitt
emu10k1_gp
shpchp
pci_hotplug
parport_pc
parport
button
evdev
joydev
ns558
gameport
pcspkr
processor
thermal_sys
psmouse
serio_raw
ext3
jbd
mbcache
usbhid
hid
sg
sd_mod
sr_mod
crc_t10dif
cdrom
ata_generic
pata_via
libata
uhci_hcd
ehci_hcd
scsi_mod
usbcore
firewire_ohci
floppy
firewire_core
crc_itu_t
!!ALSA/HDA dmesg
Z góry dziękuję za pomoc i pozdrawiam.
Użytkownik jest dodany do grupy audio?
IgiKoval
Zapomniałem o tym wspomnieć. Oczywiście jest dodany do grupy audio.
alsaconf
W konsoli jako root.
Głos nie jest gdzieś ściszony?
IgiKoval
bash: alsaconf: nie znaleziono polecenia
Tak miałem za każdym razem i działało bez tego.
W alsamikserze wszystko sprawdzałem, w pewnym momencie wszystko dałem na maksimum i włączyłem, dźwięku dalej brak.
ilin
Post autor: ilin »
&quot pisze:Tak miałem za każdym razem i działało bez tego.
Mam rozumieć, że ta karta na Debianie działała?
Uruchom w jednym terminalu polecenie:
speaker-test
W drugim:
alsamixer
Próbuj kombinować w alsamixerze być może usłyszysz szum, który generuje speaker-test.
W alsamixerze są jeszcze przełączniki OO, MM przełącza się klawiszem M, je też próbuj przełączać.
IgiKoval
Tak, to wszystko wiem. Karta za każdym razem działała pod Debianem. W alsamikserze już próbowałem wszystko włączać i zwiększać głośność do maksimum, mimo tego nic nie usłyszałem. Od razu mówię, że głośniki jak i karta są sprawne - na Windowsie działają bez zarzutu. Aktualnie sprawdzałem, pogłośniłem wszystko, bez wyjątku, mimo tego głośniki nie odezwały się.
ilin
Post autor: ilin »
Czasami trzeba przełączniki wyłączać aby karta działała.
Spróbuj zainstalować jakąś inną wersje sterowników.
Może w tej wersji jest jakiś błąd dotyczący tej karty.
Ewentualnie możesz też spróbować zainstalować OSS4
Może na nim będzie działać.
Jak odtworzysz jakiś plik np. mp3 konsolowym mplayerem.
mplayer /sciezka/plik.mp3 -ao alsa
Nie sypie żadnymi błędami?
IgiKoval
Mplayer wyrzuca tylko jakieś niezwiązane z dźwiękiem błędy.
Can't open joystick device /dev/input/js0: No such file or directory
Can't init input joystick
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Po czym normalnie odtwarza dźwięk. Oczywiście ja nic nie słyszę.
O jakie sterowniki i przełączniki Ci chodzi?
Właśnie instaluje OSS4, zobaczę jak zadziała?
ilin
Post autor: ilin »
Czyli mplayer żadnych błędów nie wykazuje.
Mnie to wygląda, że tu jest coś wyciszone, wyłączone.
Chodzi mi o przełączniki w alsamikserze, które mają postać MM lub OO
Sterowniki alsy oczywiście.
ftp://ftp.alsa-project.org/pub/driver/
