Mam problem z Sambą.
root@WWW-INTRA:~# smbclient -L //10.100.100.15/SGRUPA -U user
Enter user's password:
Connection to 10.100.100.15 failed (Error NT_STATUS_CONNECTION_REFUSED)Kod: Zaznacz cały
debian:~/etc_BKP/pam.d# nmblookup -d 2 '*' -R SGRUPA -S
added interface ip=10.100.100.15 bcast=10.100.13.255 nmask=255.255.255.0
querying * on 10.100.100.255
Got a positive name query response from 10.100.100.15 ( 10.100.100.15 )
10.100.100.15 *<00>
Looking up status of 10.100.100.15
DEBIAN <00> - B <ACTIVE>
DEBIAN <03> - B <ACTIVE>
DEBIAN <20> - B <ACTIVE>
..__MSBROWSE__. <01> - <GROUP> B <ACTIVE>
SGRUPA <1d> - B <ACTIVE>
SGRUPA <1e> - <GROUP> B <ACTIVE>
SGRUPA <00> - <GROUP> B <ACTIVE>
MAC Address = 00-00-00-00-00-00
querying SGRUPA on 10.100.100.255
10.100.100.15 SGRUPA<00>
debian:~/etc_BKP/pam.d# ps aux | grep smbd
root 20651 0.0 0.0 10096 1036 ? S Jun21 0:00 /usr/sbin/smbd -D
root 20865 0.0 0.1 10424 3316 ? S Jun21 0:00 /usr/sbin/smbd -D
root 12269 0.0 0.0 3856 788 pts/0 S+ 10:47 0:00 grep smbd
debian:~/etc_BKP/pam.d# ps aux | grep nmbd
root 12223 0.0 0.0 8368 1288 ? Ss 10:40 0:00 /usr/sbin/nmbd -D
root 12271 0.0 0.0 3856 788 pts/0 S+ 10:48 0:00 grep nmbdKod: Zaznacz cały
debian:~/etc_BKP/pam.d# smbd -V
Version 3.0.24
# Sample configuration file for the Samba suite for Debian GNU/Linux.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Any line which starts with a ; (semi-colon) or a # (hash)
# is a comment and is ignored. In this example we will use a #
# for commentary and a ; for parts of the config file that you
# may wish to enable
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not made any basic syntactic
# errors.
#======================= Global Settings =======================
[global]
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
workgroup = SGRUPA
# server string is the equivalent of the NT Description field
server string = %h server
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable its WINS Server
; wins support = no
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
; wins server = w.x.y.z
# This will prevent nmbd to search for NetBIOS names through DNS.
dns proxy = no
# What naming service and in what order should we use to resolve host names
# to IP addresses
; name resolve order = lmhosts host wins bcast
#### Networking ####
# The specific set of interfaces / networks to bind to
# This can be either the interface name or an IP address/netmask;
# interface names are normally preferred
; interfaces = 127.0.0.0/8 eth0
# Only bind to the named interfaces and/or networks; you must use the
# 'interfaces' option above to use this.
# It is recommended that you enable this feature if your Samba machine is
# not protected by a firewall or is a firewall itself. However, this
# option cannot handle dynamic or non-broadcast interfaces correctly.
; bind interfaces only = true
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
# that connects
# Put a capping on the size of the log files (in Kb).
max log size = 1000
# If you want Samba to only log through syslog then set the following
# parameter to 'yes'.
; syslog only = no
# We want Samba to log a minimum amount of information to syslog. Everything
# should go to /var/log/samba/log.{smbd,nmbd} instead. If you want to log
# through syslog you should set the following parameter to something higher.
syslog = 0
# Do something sensible when Samba crashes: mail the admin a backtrace
####### Authentication #######
# "security = user" is always a good idea. This will require a Unix account
# in this server for every user accessing the server. See
# /usr/share/doc/samba-doc/htmldocs/Samba3-HOWTO/ServerType.html
# in the samba-doc package for details.
; security = user
# You may wish to use password encryption. See the section on
# 'encrypt passwords' in the smb.conf(5) manpage before enabling.
encrypt passwords = true
# If you are using encrypted passwords, Samba will need to know what
# password database type you are using.
passdb backend = tdbsam
obey pam restrictions = yes
; guest account = nobody
invalid users = root
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
; unix password sync = no
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Ian Kahan <<kahan@informatik.tu-muenchen.de> for
# sending the correct chat script for the passwd program in Debian Sarge).
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\sUNIX\spassword:* %n\n *Retype\snew\sUNIX\spassword:* %n\n *password\supdated\ssuccessfully* .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
; pam password change = no
########## Domains ###########
# Is this machine able to authenticate users. Both PDC and BDC
# must have this setting enabled. If you are the BDC you must
# change the 'domain master' setting to no
; domain logons = yes
# The following setting only takes effect if 'domain logons' is set
# It specifies the location of the user's profile directory
# from the client point of view)
# The following required a [profiles] share to be setup on the
# samba server (see below)
; logon path = \\%N\profiles\%U
# Another common choice is storing the profile in the user's home directory
; logon path = \\%N\%U\profile
# It specifies the location of a user's home directory (from the client
# point of view)
; logon drive = H:
; logon home = \\%N\%U
# It specifies the script to run during logon. The script must be stored
# in the [netlogon] share
# NOTE: Must be store in 'DOS' file format convention
; logon script = logon.cmd
# This allows Unix users to be created on the domain controller via the SAMR
# RPC pipe. The example command creates a user account with a disabled Unix
# password; please adapt to your needs
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
########## Printing ##########
# If you want to automatically load your printer list rather
# than setting them up individually then you'll need this
; load printers = yes
# lpr(ng) printing. You may wish to override the location of the
# printcap file
; printing = bsd
; printcap name = /etc/printcap
# CUPS printing. See also the cupsaddsmb(8) manpage in the
# cupsys-client package.
; printing = cups
; printcap name = cups
# When using [print$], root is implicitly a 'printer admin', but you can
# also give this right to other users to add drivers and set printer
# properties
; printer admin = @ntadmin
############ Misc ############
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
; include = /home/samba/etc/smb.conf.%m
# Most people will find that this option gives better performance.
# See smb.conf(5) and /usr/share/doc/samba-doc/htmldocs/Samba3-HOWTO/speed.html
# for details
# You may want to add the following on a Linux system:
# SO_RCVBUF=8192 SO_SNDBUF=8192
socket options = TCP_NODELAY
# The following parameter is useful only if you have the linpopup package
# installed. The samba maintainer and the linpopup maintainer are
# working to ease installation and configuration of linpopup and samba.
; message command = /bin/sh -c '/usr/bin/linpopup "%f" "%m" %s; rm %s' &
# Domain Master specifies Samba to be the Domain Master Browser. If this
# machine will be configured as a BDC (a secondary logon server), you
# must set this to 'no'; otherwise, the default behavior is recommended.
; domain master = auto
# Some defaults for winbind (make sure you're not using the ranges
# for something else.)
; idmap uid = 10000-20000
; idmap gid = 10000-20000
; template shell = /bin/bash
; The following was the default behaviour in sarge
; but samba upstream reverted the default because it might induce
; performance issues in large organizations
; See #368251 for some of the consequences of *not* having
; this setting and smb.conf(5) for all details
; winbind enum groups = yes
; winbind enum users = yes
#======================= Share Definitions =======================
[homes]
comment = Home Directories
browseable = no
#[SGRUPA]
# comment = SGRUPA System
# path = /home/SGRUPA/
# writable = yes
# browseable = yes
# create mode = 0775
# By default, the home directories are exported read-only. Change next
# parameter to 'yes' if you want to be able to write to them.
writable = no
# File creation mask is set to 0700 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0775.
create mask = 0700
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
directory mask = 0700
# Restrict access to home directories
# to the one of the authenticated user
# This might need tweaking when using external authentication schemes
valid users = %S
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
; comment = Network Logon Service
; path = /home/samba/netlogon
; guest ok = yes
; writable = no
; share modes = no
# Un-comment the following and create the profiles directory to store
# users profiles (see the "logon path" option above)
# The path below should be writable by all users so that their
# profile directory may be created the first time they log on
;[profiles]
; comment = Users profiles
; path = /home/samba/profiles
; guest ok = no
; browseable = no
; create mask = 0600
; directory mask = 0700
[printers]
comment = All Printers
browseable = no
path = /var/spool/samba
printable = yes
public = no
writable = no
create mode = 0700
# Windows clients look for this share name as a source of downloadable
# printer drivers
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
browseable = yes
read only = yes
guest ok = no
# Uncomment to allow remote administration of Windows print drivers.
# Replace 'ntadmin' with the name of the group your admin users are
# members of.
; write list = root, @ntadmin
# A sample share for sharing your CD-ROM with others.
;[cdrom]
; comment = Samba server's CD-ROM
; writable = no
; locking = no
; path = /cdrom
; public = yes
# The next two parameters show how to auto-mount a CD-ROM when the
# cdrom share is accesed. For this to work /etc/fstab must contain
# an entry like this:
# /dev/scd0 /cdrom iso9660 defaults,noauto,ro,user 0 0
# The CD-ROM gets unmounted automatically after the connection to the
# If you don't want to use auto-mounting/unmounting make sure the CD
# is mounted on /cdrom
; preexec = /bin/mount /cdrom
; postexec = /bin/umount /cdrom
[SGRUPA]
writable = yes
browseable = yes
create mode = 0775Kod: Zaznacz cały
[2011/06/22 08:07:57, 0] printing/pcap.c :p cap_cache_reload(159)
Unable to open printcap file /etc/printcap for read!
[2011/06/22 08:23:29, 0] lib/fault.c:fault_report(41)
[2011/06/22 08:23:29, 0] lib/fault.c:fault_report(42)
INTERNAL ERROR: Signal 11 in pid 20623 (3.0.24)
Please read the Trouble-Shooting section of the Samba3-HOWTO
[2011/06/22 08:23:29, 0] lib/fault.c:fault_report(44)
From: http://www.samba.org/samba/docs/Samba3-HOWTO.pdf
[2011/06/22 08:23:29, 0] lib/fault.c:fault_report(45)
[2011/06/22 08:23:29, 0] lib/util.c:smb_panic(1599)
PANIC (pid 20623): internal error
[2011/06/22 10:40:44, 0] nmbd/nmbd.c:terminate(58)
Got SIGTERM: going down...
[2011/06/22 10:40:47, 0] nmbd/nmbd.c:main(699)
Netbios nameserver version 3.0.24 started.
Copyright Andrew Tridgell and the Samba Team 1992-2006
[2011/06/22 10:46:33, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(396)
Samba name server DEBIAN is now a local master browser for workgroup SENTE on subnet 10.100.13.21
Eh, stary konfig był trzymany w pamięci podręcznej.
/etc/init.d/samba force-reload
