Mam problem z połączeniem się z domową siecią wifi. Według wiki karta to:
AR9285 Wireless Network Adapter (PCI-Express).
Błąd:
wpa_supplicant: /sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
Linux Nabuchodonozor 2.6.32-5-amd64 #1 SMP Wed May 18 23:13:22 UTC 2011 x86_64 GNU/Linux
Sieć jest wykrywana, ale nie mogę się z nią połączyć. Gdzie robię błąd?
root@Nabuchodonozor:~# iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 IEEE 802.11bgn ESSID :o ff/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry long limit:7 RTS thr :o ff Fragment thr :o ff
Encryption key :o ff
Power Management :o n
pan0 no wireless extensions.
root@Nabuchodonozor:~# iwlist wlan0 scanning | less
wlan0 Scan completed :
Cell 01 - Address: D8:5D:4C:FA:0A:E4
Channel:1
Frequency:2.412 GHz (Channel 1)
Quality=26/70 Signal level=-84 dBm
Encryption key :o n
ESSID:"Olivia's Private Network"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
24 Mb/s; 36 Mb/s; 54 Mb/s
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
Mode:Master
Extra:tsf=000000016b12e19c
Extra: Last beacon: 488ms ago
IE: Unknown: 00184F6C6976696127732050726976617465204E6574776F726B
IE: Unknown: 010882848B962430486C
IE: Unknown: 030101
IE: Unknown: 2A0100
IE: Unknown: 2F0100
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : PSK
root@Nabuchodonozor:~# cat /etc/network/interfaces
auto lo
iface lo inet loopback
allow-hotplug eth0
iface eth0 inet dhcp
# The primary wireless interface
auto wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
root@Nabuchodonozor:~# cat /etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=/var/run/wpa_supplicant
ap_scan=1
network {
ssid="Olivia's Private Network"
psk="XXXXX"
