Mam mały problem z wysyłaniem maili, z poziomu php funkcją mail(), poprzez postfixa zainstalowanego na serwerze. Czy mógłby mi ktoś pomóc z rozwiązaniem tego problemu?
Poniżej kilka danych technicznych:
System: Debian Lenny
PHP: 5.3.6-6~dotdeb.0
Postfix: 2.5.5
Wynik polecenia:
postconf -d | grep mail_versionKod: Zaznacz cały
2bounce_notice_recipient = postmaster
access_map_reject_code = 554
address_verify_default_transport = $default_transport
address_verify_local_transport = $local_transport
address_verify_map =
address_verify_negative_cache = yes
address_verify_negative_expire_time = 3d
address_verify_negative_refresh_time = 3h
address_verify_poll_count = 3
address_verify_poll_delay = 3s
address_verify_positive_expire_time = 31d
address_verify_positive_refresh_time = 7d
address_verify_relay_transport = $relay_transport
address_verify_relayhost = $relayhost
address_verify_sender = $double_bounce_sender
address_verify_sender_dependent_relayhost_maps = $sender_dependent_relayhost_maps
address_verify_service_name = verify
address_verify_transport_maps = $transport_maps
address_verify_virtual_transport = $virtual_transport
alias_maps = hash:/etc/aliases, nis:mail.aliases
allow_mail_to_commands = alias, forward
allow_mail_to_files = alias, forward
allow_min_user = no
allow_percent_hack = yes
allow_untrusted_routing = no
alternate_config_directories =
always_bcc =
anvil_rate_time_unit = 60s
anvil_status_update_time = 600s
append_at_myorigin = yes
append_dot_mydomain = yes
application_event_drain_time = 100s
authorized_flush_users = static:anyone
authorized_mailq_users = static:anyone
authorized_submit_users = static:anyone
backwards_bounce_logfile_compatibility = yes
berkeley_db_create_buffer_size = 16777216
berkeley_db_read_buffer_size = 131072
best_mx_transport =
biff = yes
body_checks =
body_checks_size_limit = 51200
bounce_queue_lifetime = 5d
bounce_service_name = bounce
bounce_size_limit = 50000
bounce_template_file =
broken_sasl_auth_clients = no
canonical_classes = envelope_sender, envelope_recipient, header_sender, header_recipient
canonical_maps =
cleanup_service_name = cleanup
command_directory = /usr/sbin
command_execution_directory =
command_expansion_filter = 1234567890!@%-_=+:,./abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ
command_time_limit = 1000s
config_directory = /etc/postfix
connection_cache_protocol_timeout = 5s
connection_cache_service_name = scache
connection_cache_status_update_time = 600s
connection_cache_ttl_limit = 2s
content_filter =
cyrus_sasl_config_path =
daemon_directory = /usr/lib/postfix
daemon_timeout = 18000s
data_directory = /var/lib/postfix
debug_peer_level = 2
debug_peer_list =
default_database_type = hash
default_delivery_slot_cost = 5
default_delivery_slot_discount = 50
default_delivery_slot_loan = 3
default_destination_concurrency_failed_cohort_limit = 1
default_destination_concurrency_limit = 20
default_destination_concurrency_negative_feedback = 1
default_destination_concurrency_positive_feedback = 1
default_destination_rate_delay = 0s
default_destination_recipient_limit = 50
default_extra_recipient_limit = 1000
default_minimum_delivery_slots = 3
default_privs = nobody
default_process_limit = 100
default_rbl_reply = $rbl_code Service unavailable; $rbl_class [$rbl_what] blocked using $rbl_domain${rbl_reason?; $rbl_reason}
default_recipient_limit = 20000
default_recipient_refill_delay = 5s
default_recipient_refill_limit = 100
default_transport = smtp
default_verp_delimiters = +=
defer_code = 450
defer_service_name = defer
defer_transports =
delay_logging_resolution_limit = 2
delay_notice_recipient = postmaster
delay_warning_time = 0h
deliver_lock_attempts = 20
deliver_lock_delay = 1s
destination_concurrency_feedback_debug = no
detect_8bit_encoding_header = yes
disable_dns_lookups = no
disable_mime_input_processing = no
disable_mime_output_conversion = no
disable_verp_bounces = no
disable_vrfy_command = no
dont_remove = 0
double_bounce_sender = double-bounce
duplicate_filter_limit = 1000
empty_address_recipient = MAILER-DAEMON
empty_address_relayhost_maps_lookup_key = <>
enable_original_recipient = yes
error_notice_recipient = postmaster
error_service_name = error
execution_directory_expansion_filter = 1234567890!@%-_=+:,./abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ
expand_owner_alias = no
export_environment = TZ MAIL_CONFIG LANG
fallback_transport =
fallback_transport_maps =
fast_flush_domains = $relay_domains
fast_flush_purge_time = 7d
fast_flush_refresh_time = 12h
fault_injection_code = 0
flush_service_name = flush
fork_attempts = 5
fork_delay = 1s
forward_expansion_filter = 1234567890!@%-_=+:,./abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ
forward_path = $home/.forward${recipient_delimiter}${extension}, $home/.forward
frozen_delivered_to = yes
hash_queue_depth = 1
hash_queue_names = deferred, defer
header_address_token_limit = 10240
header_checks =
header_size_limit = 102400
helpful_warnings = yes
home_mailbox =
hopcount_limit = 50
html_directory = no
ignore_mx_lookup_error = no
import_environment = MAIL_CONFIG MAIL_DEBUG MAIL_LOGTAG TZ XAUTHORITY DISPLAY LANG=C
in_flow_delay = 1s
inet_interfaces = all
inet_protocols = ipv4
initial_destination_concurrency = 5
internal_mail_filter_classes =
invalid_hostname_reject_code = 501
ipc_idle = 5s
ipc_timeout = 3600s
ipc_ttl = 1000s
line_length_limit = 2048
lmtp_bind_address =
lmtp_bind_address6 =
lmtp_body_checks =
lmtp_cname_overrides_servername = no
lmtp_connect_timeout = 0s
lmtp_connection_cache_destinations =
lmtp_connection_cache_on_demand = yes
lmtp_connection_cache_time_limit = 2s
lmtp_connection_reuse_time_limit = 300s
lmtp_data_done_timeout = 600s
lmtp_data_init_timeout = 120s
lmtp_data_xfer_timeout = 180s
lmtp_defer_if_no_mx_address_found = no
lmtp_destination_concurrency_failed_cohort_limit = $default_destination_concurrency_failed_cohort_limit
lmtp_destination_concurrency_limit = $default_destination_concurrency_limit
lmtp_destination_concurrency_negative_feedback = $default_destination_concurrency_negative_feedback
lmtp_destination_concurrency_positive_feedback = $default_destination_concurrency_positive_feedback
lmtp_destination_rate_delay = $default_destination_rate_delay
lmtp_destination_recipient_limit = $default_destination_recipient_limit
lmtp_discard_lhlo_keyword_address_maps =
lmtp_discard_lhlo_keywords =
lmtp_enforce_tls = no
lmtp_generic_maps =
lmtp_header_checks =
lmtp_host_lookup = dns
lmtp_initial_destination_concurrency = $initial_destination_concurrency
lmtp_lhlo_name = $myhostname
lmtp_lhlo_timeout = 300s
lmtp_line_length_limit = 990
lmtp_mail_timeout = 300s
lmtp_mime_header_checks =
lmtp_mx_address_limit = 5
lmtp_mx_session_limit = 2
lmtp_nested_header_checks =
lmtp_pix_workaround_delay_time = 10s
lmtp_pix_workaround_maps =
lmtp_pix_workaround_threshold_time = 500s
lmtp_pix_workarounds = disable_esmtp,delay_dotcrlf
lmtp_quit_timeout = 300s
lmtp_quote_rfc821_envelope = yes
lmtp_randomize_addresses = yes
lmtp_rcpt_timeout = 300s
lmtp_rset_timeout = 20s
lmtp_sasl_auth_cache_name =
lmtp_sasl_auth_cache_time = 90d
lmtp_sasl_auth_enable = no
lmtp_sasl_auth_soft_bounce = yes
lmtp_sasl_mechanism_filter =
lmtp_sasl_password_maps =
lmtp_sasl_path =
lmtp_sasl_security_options = noplaintext, noanonymous
lmtp_sasl_tls_security_options = $lmtp_sasl_security_options
lmtp_sasl_tls_verified_security_options = $lmtp_sasl_tls_security_options
lmtp_sasl_type = cyrus
lmtp_send_xforward_command = no
lmtp_sender_dependent_authentication = no
lmtp_skip_5xx_greeting = yes
lmtp_starttls_timeout = 300s
lmtp_tcp_port = 24
lmtp_tls_CAfile =
lmtp_tls_CApath =
lmtp_tls_cert_file =
lmtp_tls_dcert_file =
lmtp_tls_dkey_file = $lmtp_tls_dcert_file
lmtp_tls_enforce_peername = yes
lmtp_tls_exclude_ciphers =
lmtp_tls_fingerprint_cert_match =
lmtp_tls_fingerprint_digest = md5
lmtp_tls_key_file = $lmtp_tls_cert_file
lmtp_tls_loglevel = 0
lmtp_tls_mandatory_ciphers = medium
lmtp_tls_mandatory_exclude_ciphers =
lmtp_tls_mandatory_protocols = SSLv3, TLSv1
lmtp_tls_note_starttls_offer = no
lmtp_tls_per_site =
lmtp_tls_policy_maps =
lmtp_tls_scert_verifydepth = 9
lmtp_tls_secure_cert_match = nexthop
lmtp_tls_security_level =
lmtp_tls_session_cache_database =
lmtp_tls_session_cache_timeout = 3600s
lmtp_tls_verify_cert_match = hostname
lmtp_use_tls = no
lmtp_xforward_timeout = 300s
local_command_shell =
local_destination_concurrency_failed_cohort_limit = $default_destination_concurrency_failed_cohort_limit
local_destination_concurrency_limit = 2
local_destination_concurrency_negative_feedback = $default_destination_concurrency_negative_feedback
local_destination_concurrency_positive_feedback = $default_destination_concurrency_positive_feedback
local_destination_rate_delay = $default_destination_rate_delay
local_destination_recipient_limit = 1
local_header_rewrite_clients = permit_inet_interfaces
local_initial_destination_concurrency = $initial_destination_concurrency
local_recipient_maps = proxy:unix :p asswd.byname $alias_maps
local_transport = local:$myhostname
luser_relay =
mail_name = Postfix
mail_owner = postfix
mail_release_date = 20080902
mail_spool_directory = /var/mail
mail_version = 2.5.5
mailbox_command =
mailbox_command_maps =
mailbox_delivery_lock = fcntl, dotlock
mailbox_size_limit = 51200000
mailbox_transport =
mailbox_transport_maps =
mailq_path = /usr/bin/mailq
manpage_directory = /usr/share/man
maps_rbl_domains =
maps_rbl_reject_code = 554
masquerade_classes = envelope_sender, header_sender, header_recipient
masquerade_domains =
masquerade_exceptions =
max_idle = 100s
max_use = 100
maximal_backoff_time = 4000s
maximal_queue_lifetime = 5d
message_reject_characters =
message_size_limit = 10240000
message_strip_characters =
milter_command_timeout = 30s
milter_connect_macros = j {daemon_name} v
milter_connect_timeout = 30s
milter_content_timeout = 300s
milter_data_macros = i
milter_default_action = tempfail
milter_end_of_data_macros = i
milter_end_of_header_macros = i
milter_helo_macros = {tls_version} {cipher} {cipher_bits} {cert_subject} {cert_issuer}
milter_macro_daemon_name = $myhostname
milter_macro_v = $mail_name $mail_version
milter_mail_macros = i {auth_type} {auth_authen} {auth_author} {mail_addr}
milter_protocol = 2
milter_rcpt_macros = i {rcpt_addr}
milter_unknown_command_macros =
mime_boundary_length_limit = 2048
mime_header_checks = $header_checks
mime_nesting_limit = 100
minimal_backoff_time = 300s
multi_recipient_bounce_reject_code = 550
mydestination = $myhostname, localhost.$mydomain, localhost
mydomain = localdomain
myhostname = {nazwa}.localdomain
mynetworks = 127.0.0.0/8 127.0.0.1/32 {IP_serwera}/32
mynetworks_style = subnet
myorigin = $myhostname
nested_header_checks = $header_checks
newaliases_path = /usr/bin/newaliases
non_fqdn_reject_code = 504
non_smtpd_milters =
notify_classes = resource, software
owner_request_special = yes
parent_domain_matches_subdomains = debug_peer_list,fast_flush_domains,mynetworks,permit_mx_backup_networks,qmqpd_authorized_clients,smtpd_access_maps
permit_mx_backup_networks =
pickup_service_name = pickup
plaintext_reject_code = 450
prepend_delivered_header = command, file, forward
process_id_directory = pid
propagate_unmatched_extensions = canonical, virtual
proxy_interfaces =
proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $virtual_alias_domains $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonical_maps $sender_canonical_maps $recipient_canonical_maps $relocated_maps $transport_maps $mynetworks $sender_bcc_maps $recipient_bcc_maps $smtp_generic_maps $lmtp_generic_maps
proxy_write_maps = $smtp_sasl_auth_cache_name $lmtp_sasl_auth_cache_name
qmgr_clog_warn_time = 300s
qmgr_fudge_factor = 100
qmgr_message_active_limit = 20000
qmgr_message_recipient_limit = 20000
qmgr_message_recipient_minimum = 10
qmqpd_authorized_clients =
qmqpd_client_port_logging = no
qmqpd_error_delay = 1s
qmqpd_timeout = 300s
queue_directory = /var/spool/postfix
queue_file_attribute_count_limit = 100
queue_minfree = 0
queue_run_delay = 300s
queue_service_name = qmgr
rbl_reply_maps =
readme_directory = /usr/share/doc/postfix
receive_override_options =
recipient_bcc_maps =
recipient_canonical_classes = envelope_recipient, header_recipient
recipient_canonical_maps =
recipient_delimiter =
reject_code = 554
relay_clientcerts =
relay_destination_concurrency_failed_cohort_limit = $default_destination_concurrency_failed_cohort_limit
relay_destination_concurrency_limit = $default_destination_concurrency_limit
relay_destination_concurrency_negative_feedback = $default_destination_concurrency_negative_feedback
relay_destination_concurrency_positive_feedback = $default_destination_concurrency_positive_feedback
relay_destination_rate_delay = $default_destination_rate_delay
relay_destination_recipient_limit = $default_destination_recipient_limit
relay_domains = $mydestination
relay_domains_reject_code = 554
relay_initial_destination_concurrency = $initial_destination_concurrency
relay_recipient_maps =
relay_transport = relay
relayhost =
relocated_maps =
remote_header_rewrite_domain =
require_home_directory = no
resolve_dequoted_address = yes
resolve_null_domain = no
resolve_numeric_domain = no
rewrite_service_name = rewrite
sample_directory = /usr/share/doc/postfix/examples
send_cyrus_sasl_authzid = no
sender_bcc_maps =
sender_canonical_classes = envelope_sender, header_sender
sender_canonical_maps =
sendmail_path = /usr/sbin/sendmail
service_throttle_time = 60s
setgid_group = postdrop
show_user_unknown_table_name = yes
showq_service_name = showq
smtp_always_send_ehlo = yes
smtp_bind_address =
smtp_bind_address6 =
smtp_body_checks =
smtp_cname_overrides_servername = no
smtp_connect_timeout = 30s
smtp_connection_cache_destinations =
smtp_connection_cache_on_demand = yes
smtp_connection_cache_time_limit = 2s
smtp_connection_reuse_time_limit = 300s
smtp_data_done_timeout = 600s
smtp_data_init_timeout = 120s
smtp_data_xfer_timeout = 180s
smtp_defer_if_no_mx_address_found = no
smtp_destination_concurrency_failed_cohort_limit = $default_destination_concurrency_failed_cohort_limit
smtp_destination_concurrency_limit = $default_destination_concurrency_limit
smtp_destination_concurrency_negative_feedback = $default_destination_concurrency_negative_feedback
smtp_destination_concurrency_positive_feedback = $default_destination_concurrency_positive_feedback
smtp_destination_rate_delay = $default_destination_rate_delay
smtp_destination_recipient_limit = $default_destination_recipient_limit
smtp_discard_ehlo_keyword_address_maps =
smtp_discard_ehlo_keywords =
smtp_enforce_tls = no
smtp_fallback_relay = $fallback_relay
smtp_generic_maps =
smtp_header_checks =
smtp_helo_name = $myhostname
smtp_helo_timeout = 300s
smtp_host_lookup = dns
smtp_initial_destination_concurrency = $initial_destination_concurrency
smtp_line_length_limit = 990
smtp_mail_timeout = 300s
smtp_mime_header_checks =
smtp_mx_address_limit = 5
smtp_mx_session_limit = 2
smtp_nested_header_checks =
smtp_never_send_ehlo = no
smtp_pix_workaround_delay_time = 10s
smtp_pix_workaround_maps =
smtp_pix_workaround_threshold_time = 500s
smtp_pix_workarounds = disable_esmtp,delay_dotcrlf
smtp_quit_timeout = 300s
smtp_quote_rfc821_envelope = yes
smtp_randomize_addresses = yes
smtp_rcpt_timeout = 300s
smtp_rset_timeout = 20s
smtp_sasl_auth_cache_name =
smtp_sasl_auth_cache_time = 90d
smtp_sasl_auth_enable = no
smtp_sasl_auth_soft_bounce = yes
smtp_sasl_mechanism_filter =
smtp_sasl_password_maps =
smtp_sasl_path =
smtp_sasl_security_options = noplaintext, noanonymous
smtp_sasl_tls_security_options = $smtp_sasl_security_options
smtp_sasl_tls_verified_security_options = $smtp_sasl_tls_security_options
smtp_sasl_type = cyrus
smtp_send_xforward_command = no
smtp_sender_dependent_authentication = no
smtp_skip_5xx_greeting = yes
smtp_skip_quit_response = yes
smtp_starttls_timeout = 300s
smtp_tls_CAfile =
smtp_tls_CApath =
smtp_tls_cert_file =
smtp_tls_dcert_file =
smtp_tls_dkey_file = $smtp_tls_dcert_file
smtp_tls_enforce_peername = yes
smtp_tls_exclude_ciphers =
smtp_tls_fingerprint_cert_match =
smtp_tls_fingerprint_digest = md5
smtp_tls_key_file = $smtp_tls_cert_file
smtp_tls_loglevel = 0
smtp_tls_mandatory_ciphers = medium
smtp_tls_mandatory_exclude_ciphers =
smtp_tls_mandatory_protocols = SSLv3, TLSv1
smtp_tls_note_starttls_offer = no
smtp_tls_per_site =
smtp_tls_policy_maps =
smtp_tls_scert_verifydepth = 9
smtp_tls_secure_cert_match = nexthop, dot-nexthop
smtp_tls_security_level =
smtp_tls_session_cache_database =
smtp_tls_session_cache_timeout = 3600s
smtp_tls_verify_cert_match = hostname
smtp_use_tls = no
smtp_xforward_timeout = 300s
smtpd_authorized_verp_clients = $authorized_verp_clients
smtpd_authorized_xclient_hosts =
smtpd_authorized_xforward_hosts =
smtpd_banner = $myhostname ESMTP $mail_name
smtpd_client_connection_count_limit = 50
smtpd_client_connection_rate_limit = 0
smtpd_client_event_limit_exceptions = ${smtpd_client_connection_limit_exceptions:$mynetworks}
smtpd_client_message_rate_limit = 0
smtpd_client_new_tls_session_rate_limit = 0
smtpd_client_port_logging = no
smtpd_client_recipient_rate_limit = 0
smtpd_client_restrictions =
smtpd_data_restrictions =
smtpd_delay_open_until_valid_rcpt = yes
smtpd_delay_reject = yes
smtpd_discard_ehlo_keyword_address_maps =
smtpd_discard_ehlo_keywords =
smtpd_end_of_data_restrictions =
smtpd_enforce_tls = no
smtpd_error_sleep_time = 1s
smtpd_etrn_restrictions =
smtpd_expansion_filter = \t\40!"#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\\]^_`abcdefghijklmnopqrstuvwxyz{|}~
smtpd_forbidden_commands = CONNECT GET POST
smtpd_hard_error_limit = 20
smtpd_helo_required = no
smtpd_helo_restrictions =
smtpd_history_flush_threshold = 100
smtpd_junk_command_limit = 100
smtpd_milters =
smtpd_noop_commands =
smtpd_null_access_lookup_key = <>
smtpd_peername_lookup = yes
smtpd_policy_service_max_idle = 300s
smtpd_policy_service_max_ttl = 1000s
smtpd_policy_service_timeout = 100s
smtpd_proxy_ehlo = $myhostname
smtpd_proxy_filter =
smtpd_proxy_timeout = 100s
smtpd_recipient_limit = 1000
smtpd_recipient_overshoot_limit = 1000
smtpd_recipient_restrictions = permit_mynetworks, reject_unauth_destination
smtpd_reject_unlisted_recipient = yes
smtpd_reject_unlisted_sender = no
smtpd_restriction_classes =
smtpd_sasl_auth_enable = no
smtpd_sasl_authenticated_header = no
smtpd_sasl_exceptions_networks =
smtpd_sasl_local_domain =
smtpd_sasl_path = smtpd
smtpd_sasl_security_options = noanonymous
smtpd_sasl_tls_security_options = $smtpd_sasl_security_options
smtpd_sasl_type = cyrus
smtpd_sender_login_maps =
smtpd_sender_restrictions =
smtpd_soft_error_limit = 10
smtpd_starttls_timeout = 300s
smtpd_timeout = 300s
smtpd_tls_CAfile =
smtpd_tls_CApath =
smtpd_tls_always_issue_session_ids = yes
smtpd_tls_ask_ccert = no
smtpd_tls_auth_only = no
smtpd_tls_ccert_verifydepth = 9
smtpd_tls_cert_file =
smtpd_tls_dcert_file =
smtpd_tls_dh1024_param_file =
smtpd_tls_dh512_param_file =
smtpd_tls_dkey_file = $smtpd_tls_dcert_file
smtpd_tls_exclude_ciphers =
smtpd_tls_fingerprint_digest = md5
smtpd_tls_key_file = $smtpd_tls_cert_file
smtpd_tls_loglevel = 0
smtpd_tls_mandatory_ciphers = medium
smtpd_tls_mandatory_exclude_ciphers =
smtpd_tls_mandatory_protocols = SSLv3, TLSv1
smtpd_tls_received_header = no
smtpd_tls_req_ccert = no
smtpd_tls_security_level =
smtpd_tls_session_cache_database =
smtpd_tls_session_cache_timeout = 3600s
smtpd_tls_wrappermode = no
smtpd_use_tls = no
soft_bounce = no
stale_lock_time = 500s
stress =
strict_7bit_headers = no
strict_8bitmime = no
strict_8bitmime_body = no
strict_mailbox_ownership = yes
strict_mime_encoding_domain = no
strict_rfc821_envelopes = no
sun_mailtool_compatibility = no
swap_bangpath = yes
syslog_facility = mail
syslog_name = postfix
tls_daemon_random_bytes = 32
tls_export_cipherlist = ALL:+RC4:@STRENGTH
tls_high_cipherlist = ALL:!EXPORT:!LOW:!MEDIUM:+RC4:@STRENGTH
tls_low_cipherlist = ALL:!EXPORT:+RC4:@STRENGTH
tls_medium_cipherlist = ALL:!EXPORT:!LOW:+RC4:@STRENGTH
tls_null_cipherlist = eNULL:!aNULL
tls_random_bytes = 32
tls_random_exchange_name = ${data_directory}/prng_exch
tls_random_prng_update_period = 3600s
tls_random_reseed_period = 3600s
tls_random_source = dev:/dev/urandom
trace_service_name = trace
transport_maps =
transport_retry_time = 60s
trigger_timeout = 10s
undisclosed_recipients_header = To: undisclosed-recipients:;
unknown_address_reject_code = 450
unknown_client_reject_code = 450
unknown_hostname_reject_code = 450
unknown_local_recipient_reject_code = 550
unknown_relay_recipient_reject_code = 550
unknown_virtual_alias_reject_code = 550
unknown_virtual_mailbox_reject_code = 550
unverified_recipient_reject_code = 450
unverified_sender_reject_code = 450
verp_delimiter_filter = -=+
virtual_alias_domains = $virtual_alias_maps
virtual_alias_expansion_limit = 1000
virtual_alias_maps = $virtual_maps
virtual_alias_recursion_limit = 1000
virtual_destination_concurrency_failed_cohort_limit = $default_destination_concurrency_failed_cohort_limit
virtual_destination_concurrency_limit = $default_destination_concurrency_limit
virtual_destination_concurrency_negative_feedback = $default_destination_concurrency_negative_feedback
virtual_destination_concurrency_positive_feedback = $default_destination_concurrency_positive_feedback
virtual_destination_rate_delay = $default_destination_rate_delay
virtual_destination_recipient_limit = $default_destination_recipient_limit
virtual_gid_maps =
virtual_initial_destination_concurrency = $initial_destination_concurrency
virtual_mailbox_base =
virtual_mailbox_domains = $virtual_mailbox_maps
virtual_mailbox_limit = 51200000
virtual_mailbox_lock = fcntl, dotlock
virtual_mailbox_maps =
virtual_minimum_uid = 100
virtual_transport = virtual
virtual_uid_maps =
[mail function]
; For Win32 only.
; http://php.net/smtp
SMTP = localhost
; http://php.net/smtp-port
smtp_port = 25
; For Win32 only.
; http://php.net/sendmail-from
sendmail_from = automat@{domena}
; For Unix only. You may supply arguments as well (default: "sendmail -t -i").
; http://php.net/sendmail-path
sendmail_path = sendmail -t -i -f automat@{domena}
; Force the addition of the specified parameters to be passed as extra parameters
; to the sendmail binary. These parameters will always replace the value of
; the 5th parameter to mail(), even in safe mode.
;mail.force_extra_parameters =
; Add X-PHP-Originating-Script: that will include uid of the script followed by the filename
mail.add_x_header = On
; The path to a log file that will log all mail() calls. Log entries include
; the full path of the script, line number, To address and headers.
mail.log = /var/log/mail_postfix.log
